This is from November 2016, where there was some experimentation with scanning
objects with trace() and building triangles. Obviously still needs some work.
Also, Jerome Grimbert has some excellent additions that do exactly this in
HgPOV-Ray.
http://wiki.povray.org/content/User:Le_Forgeron/tesselation
#version 3.7;
global_settings {
assumed_gamma 1.0
ambient_light color rgb <1, 1, 1>
#include "math.inc"
#include "transforms.inc"
#declare Camera_Origin = camera {
location <0, 0, 0>
look_at <0, 0, 0.01>}
#declare Camera_Angle = camera {
location <0.0 , 0.0, 0.0>
look_at <100, 30, 0>}
#declare Camera_Front = camera {
location <2, 5, -30.0>
//location <0.0, 12, -10.0>
sky y
look_at <2, 5, 0>}
#declare Camera_Rear = camera {
location <0.0, -100.0, -300.0>
look_at <0, 0, 0>}
#declare Camera_Top = camera {
location <0, 25.0, 0>
look_at <0, 0, 0>}
#declare Camera_Iso = camera {
location <-50, 0, 0>
look_at <0, 0, 0>}
//camera {Camera_Front}
light_source{ <50, 50, -100> color rgb <1, 1, 1>} // White top
// Create an infinite sphere around scene and allow any pigment on it
sky_sphere{ pigment { gradient <0,1,0>
color_map { [0.00 rgb <0.6, 0.7, 1.0>]
[0.35 rgb <0.0, 0.1, 0.8>]
[0.65 rgb <0.0, 0.1, 0.8>]
[1.00 rgb <0.6, 0.7, 1.0>]
scale 2
} // end of pigment
} //end of skysphere -------------------------------------
#declare Cylinder = cylinder {<0, 0, 0>, <0, 10, 0> 2 pigment {Red} }
#declare Sphere = sphere {<0, 0, 0>, 2 pigment {Red} }
#declare Box = box {-1, 1 pigment {Red} }
#declare Cross = union {
cylinder {<0, 0, 0>, <0, 10, 0> 1 pigment {Red} }
cylinder {<-5, 5, 0>, <5, 5, 0> 1 pigment {Red} }
#declare Cross2 = union {
cylinder {<0, 5, -5>, <0, 5, 5> 1 pigment {Red} }
#declare Torus = torus {3, 0.5 pigment {Red} rotate x*0}
#declare Blob =
//union {
blob {
threshold .65
sphere { <.5,0,0>, .8, 1 pigment {Blue} }
sphere { <-.5,0,0>,.8, 1 pigment {Red} }
finish { phong 1 }
//sphere { <.5,0,0>, .8 pigment { Blue transmit .9 }}
//sphere { <-.5,0,0>, .8 pigment { Red transmit .9 }}
//cylinder {<-1, 0, 0>, <1, 0, 0>, 0.65/2 pigment {color White transmit 0.9}
no_shadow}
#declare Object = object {Cylinder}
object {Cylinder}
// Scan object with a loop of traces
#declare Min = min_extent (Object);
#declare Max = max_extent (Object);
#declare MidHeight = (Min.y + Max.y)/2;
#declare Move = (Max.x*2)+4;
#declare Center = (Min.x + Move)/2;
location <Center, MidHeight, (Min.z*10)>
sky y
look_at <Center, MidHeight, 0>}
#declare TraceRadius = max (Min.x, Max.x, Min.z, Max.z) * 2;
#declare Step = 0.5;
#declare Arcs = 36;
#declare TraceNormal = <0, 0, 0>;
#declare Degrees = 360/Arcs;
#declare OddShift = Degrees/2;
#declare Levels = (Max.y-Min.y)/Step;
#debug concat( " Levels = ", str(Levels, 3, 1), "\n")
#declare TraceMeshArray = array [Levels+1][Arcs+1];
#declare ArrayY = 0;
#declare ArrayX = 0;
#for (Y, Min.y, Max.y, Step)
#if (odd(ArrayY))
#declare Shift = OddShift;
#else
#declare Shift = 0;
#for (Theta, 0, 360, Degrees)
#declare MyTransform = transform { rotate y*(Theta+Shift) };
#declare TracePoint = vtransform (<TraceRadius, Y, 0>, MyTransform);
#declare TraceMeshArray[ArrayY][ArrayX] = trace(Object, <0, Y, 0>, TracePoint,
TraceNormal);
//#debug concat( " Y = ", str(ArrayY, 3, 1), " X = ", str(ArrayX, 3, 1),
" TraceNormal = ", vstr(3, TraceNormal, ", ", 3, 0), "\n")
cylinder {TracePoint, <0, Y, 0> 0.005 pigment {Blue} }
#declare ArrayX = ArrayX+1;
#declare ArrayX = 0; // reset X
#declare ArrayY = ArrayY+1;
// plot mesh vertices
#declare SphereRadius = 0.03;
sphere {TraceMeshArray[ArrayY][ArrayX], SphereRadius pigment {Black} translate
x*Move}
// draw mesh edges
#declare SphereRadius = 0.025;
#declare SphereRadius = 0.0125;
//horizontal edges
#if (ArrayX >= 1)
//#debug concat( "TraceMeshArray[ArrayY][ArrayX] = ", vstr(3,
TraceMeshArray[ArrayY][ArrayX], ", ", 3, 3), "
TraceMeshArray[ArrayY][ArrayX-1] = ", vstr(3, TraceMeshArray[ArrayY][ArrayX-1],
", ", 3, 3),"\n")
cylinder {TraceMeshArray[ArrayY][ArrayX],
TraceMeshArray[ArrayY][ArrayX-1]+0.001, SphereRadius pigment {Green} translate
x*Move}
// diagonal edges
#if (Y > Min.y)
TraceMeshArray[ArrayY-1][ArrayX]+0.001, SphereRadius pigment {Green} translate
x*Move}
#if (odd(ArrayY))
#if (ArrayX < Arcs)
TraceMeshArray[ArrayY-1][ArrayX+1]+0.001, SphereRadius pigment {Green} translate
x*Move}
#else
TraceMeshArray[ArrayY-1][0]+0.001, SphereRadius pigment {Green} translate
x*Move}
#else
#if (ArrayX > 0)
TraceMeshArray[ArrayY-1][ArrayX-1]+0.001, SphereRadius pigment {Green} translate
x*Move}
#else
x*Move}
