POV-Ray : Newsgroups : povray.general : Disable radiosity render stages? Server Time
10 Jan 2025 18:07:36 EST (-0500)
  Disable radiosity render stages? (Message 1 to 9 of 9)
Subject: Disable radiosity render stages?
Date: 11 Jun 2019 22:36:43
Message: <5d00653b$1@news.povray.org>
When radiosity is enabled, there are multiple passes in a render, with
each pass rendering smaller and smaller boxes until it reaches 1x1 pixels.
Can this be disabled so that I can go straight to the final pass?
Thanks
Michael
Subject: Re: Disable radiosity render stages?
Date: 12 Jun 2019 08:50:00
Message: <web.5d00f4c6d8e71a88be7517870@news.povray.org>
> Thanks
> Michael
I think not. The implementation of radiosity is iterative, the coarse passes
providing surface colours in the scene to allow the next approximation to give a
better stab at self illumination.
However, there are those who know far more about about radiosity than I.
Thanks,
JimT.
Date: 12 Jun 2019 13:46:11
Message: <5d013a63$1@news.povray.org>
> Thanks
> Michael
You don't want to do that unless you are loading radiosity data saved
from an earlier render. In that case, use pretrace_start 1 pretrace_end
1 in the radiosity block of the global_settings.
If using UberPOV, you can use no_cache in the radiosity block. The image
WILL look somewhat grainy and the render will take more time.
The other option is to fiddle with pretrace_start and pretrace_end.
If you set both to 1, you'll only get a full frame block before the
final render pass. This will result in an image of uneven quality and
probably splotchy.
Normally, it don't reaches 1x1 pixel during the pretrace steps.
The pretrace is used to collect radiosity samples over the whole scene.
Otherwise, the rendering of the first pixels will only benefit from a
very restricted set of radiosity data, while pixels rendered later will
benefit from the data collected by the early parts. The result is an
image with a mixture of low quality sampling and high quality sampling.
The defaults are :
pretrace_start 0.08
pretrace_end 0.04
For good quality/final renders, you should reduce pretrace_end. Good
values are in the 0.01 down to 0.0025 range. You can also reduce
pretrace_start down to 0.02 in those cases.
Date: 13 Jun 2019 01:50:00
Message: <web.5d01e320d8e71a88fd6b6fe10@news.povray.org>
> > Thanks
> > Michael
> probably splotchy.
> The defaults are :
> pretrace_start 0.08
> pretrace_end 0.04
What you can do, is disable what is called the "Vain Pretrace".  Then the
radiosity passes will only do a luminosity map (I think that's what it's called)
and skip the expensive color passes which have no effect on the final result.
To do this, you can add -RVP to your command line.
A.D.B.
Date: 13 Jun 2019 02:54:25
Message: <5d01f321$1@news.povray.org>
Sorry, where is this described in the docs? RVP is not mentioned anywhere...
Date: 13 Jun 2019 05:47:46
Message: <5d021bc2$1@news.povray.org>
> anywhere...
http://wiki.povray.org/content/Reference:Tracing_Options#Radiosity_Vain_Pretrace
Date: 13 Jun 2019 06:53:02
Message: <5d022b0e$1@news.povray.org>
>> anywhere...
My heartfelt thanks! I had been looking for +RVP but forgot to look at
the web docs in the process.
Date: 13 Jun 2019 11:27:49
Message: <5d026b75$1@news.povray.org>
> Regards,
> A.D.B.
This don't disable the pretrace step, but it make it somewhat faster.
Date: 13 Jun 2019 15:35:00
Message: <web.5d02a4c0d8e71a88fd6b6fe10@news.povray.org>
> > Regards,
> > A.D.B.
The odd thing was that it wasn't disabled by default when using -D (No display)
I don't know if this has changed or not, but I brought it up a while ago.
A.D.B.
