POV-Ray : Newsgroups : povray.general : Animation INI flags Server Time
10 Jan 2025 18:07:22 EST (-0500)
  Animation INI flags (Message 1 to 3 of 3)
Subject: Animation INI flags
Date: 23 Feb 2019 19:05:36
Message: <5c71dfd0$1@news.povray.org>
If I have the following:
Initial_Clock=0.0
Final_Clock=1.0
Initial_Frame=0
Final_Frame=59
What happens to the clock if I change Initial_Frame to 10 and
Final_Frame to 30? Will the clock be automatically adjusted to fit
within those bounds?
Thanks.
Mike
Subject: Re: Animation INI flags
Date: 24 Feb 2019 00:58:52
Message: <5c72329c$1@news.povray.org>
Am 24.02.2019 um 01:05 schrieb Mike Horvath:
> Initial_Clock=0.0
> Final_Clock=1.0
> Initial_Frame=0
> Final_Frame=59
Yep: Frame 10 (the initial one) will then have a clock value of 0.0, and
frame 30 (the final one) will have a clock value of 1.0.
Date: 24 Feb 2019 01:30:01
Message: <web.5c723954100332499c5d6c810@news.povray.org>
> > Initial_Clock=0.0
> > Final_Clock=1.0
> > Initial_Frame=0
> > Final_Frame=59
I'm going to make a wild guess here and try to mind read, so if I get this wrong
clipka has it right already.
If the idea is to keep the start and end clock at zero and one for the frames 0
and 59 while changing only the midway portion, you can use Subset_Start_Frame
and Subset_End_Frame as 10 to 30 and those will adjust to the correct clock
value for that particular segment within the whole 60 frames.
Also abbreviated to +sf10 and +ef30 on the command line.
