POV-Ray : Newsgroups : povray.general : Dumb clock animation question Server Time
4 Nov 2026 19:36:36 EST (-0500)
  Dumb clock animation question (Message 1 to 15 of 15)
Subject: Dumb clock animation question
Date: 17 Feb 2019 05:36:39
Message: <5c693937$1@news.povray.org>
This involves probably some very easy algebra.
I want a cylinder to spin 360 degrees when the clock is between 0 and
0.6667. I want another object to spin when the clock is between 0.3333
and 0.6667. Finally I want the camera to rotate 90 degrees when the
clock is between 0.6667 and 1.
How do I set this up? Thanks.
Michael
Subject: Re: Dumb clock animation question
Date: 17 Feb 2019 06:09:29
Message: <5c6940e9$1@news.povray.org>
> Michael
PS - I was thinking of maybe a macro that takes a start time and an end
time, and outputs a value between 0 and 1?
Michael
Date: 17 Feb 2019 07:30:00
Message: <web.5c69532030cdf98241e3d39f0@news.povray.org>
> > Michael
#macro MacroName(StartTime, EndTime)
    #local R = (clock - StartTime)/(EndTime - StartTime);
    #local S = min(max(0, R), 1);
    S
#end // macro MacroName
object {
    YourCylinder
    rotate MacroName(0/3, 2/3)*360*y
object {
    YourOtherObject
    rotate MacroName(1/3, 2/3)*SomeAngle*y
    YourCamera
    rotate MacroName(2/3, 3/3)*90*y
Tor Olav
http://subcube.com
https://github.com/t-o-k/
Date: 17 Feb 2019 12:36:11
Message: <5c699b8b@news.povray.org>
> Michael
Assuming that the clock goes from 0 to 1 :
To be added to the object of interest.
First case :
#if(clock <= 2/3) rotate x*360*3/2 #end
// *360 for a full rotation
// *3/2 adjust to the desired clock interval
Second case :
#if(clock > 1/3 & clock < 2/3) rotate y*(clock - 1/3)*720*3/2 #end
// *720 two full rotation, just because...
Third case :
#if(clock > 2/3) rotate z*(clock - 2/3)*90*3 #end
That should do it.
Date: 18 Feb 2019 07:47:31
Message: <5c6aa963$1@news.povray.org>
>      S
Thank you! That's perfect.
Mike
Date: 18 Feb 2019 12:40:05
Message: <web.5c6aed9530cdf982c97227110@news.povray.org>
> >      S
> Mike
I hesitate to try to improve on a TOK solution, but in my animations, a very
early line will be
#declare MyTime = clock;
then I use MyTime wherever I would use clock. This lets me #declare MyTime =
0.6667, for example to go to a position in the animation to test a particular
stage without running the whole animations. You would pass MyTime to the #macro.
This may be obvious, but it is an improvement.
Date: 19 Feb 2019 00:15:33
Message: <5c6b90f5@news.povray.org>
>>>       S
>> Mike
> early line will be
I'll keep that in mind, thanks! What I usually do is set the clock value
using the +K switch if I need to. I get confused by all the INI settings
sometimes too.
Mike
Date: 19 Feb 2019 00:18:05
Message: <5c6b918d$1@news.povray.org>
>      S
What do you think would be a good way to gradually speed up and then
slow down the motions using this macro? I'm thinking it would require a
sine wave (or some other bell curve), but am not sure how to apply it.
Mike
Date: 19 Feb 2019 04:28:04
Message: <5c6bcc24$1@news.povray.org>
Am 19.02.2019 um 06:18 schrieb Mike Horvath:
>>      S
A spline might help with this.
Date: 19 Feb 2019 07:15:00
Message: <web.5c6bf27730cdf982765e06870@news.povray.org>
> >      S
insert
#declare S = sin(S*Tau);
or
#declare S = abs(sin(S*Tau));
before the line
S
However you're running it.
Date: 19 Feb 2019 09:25:01
Message: <web.5c6c109030cdf982be7517870@news.povray.org>
> >>      S
Using a spline would de-linearise the time variable, which isn't the idea. The
simplest way is to just use a cubic:
#macro Spline_Param(StartTime,EndTime)
#local LinParam    = (clock - StartTime)/(EndTime - StartTime);
#local LinParam    = min(max(0,LinParam),1);
#local SplineParam =   2*LinParam*LinParam*(3/2 - LinParam);
SplineParam
#end // Spline_Param
but this doesn't have any adjustment. If you are interested in a constant
acceleration, followed by constant speed, followed by constant deceleration,
respond and I'll do it.
Date: 19 Feb 2019 09:45:00
Message: <web.5c6c15c330cdf982a48ba9b60@news.povray.org>
> >      S
If you want to use a simple trigonometric function then I recommend using a
cosine wave, like this:
    #local S = min(max(0, R), 1)*pi;
    #local T = (1 - cos(S))/2;
    T
Now S will vary between 0 and +pi. cos(S) will vary between +1 and -1. And T
will vary between 0 and +1.
https://upload.wikimedia.org/wikipedia/commons/d/d2/Sine_and_Cosine.svg
Tor Olav
http://subcube.com
Date: 19 Feb 2019 13:13:01
Message: <5c6c472d$1@news.povray.org>
Thank you again. That is what I needed.
Mike
Date: 20 Feb 2019 06:05:01
Message: <web.5c6d343930cdf982c97227110@news.povray.org>
> Mike
TOK's cosine formulation is actually extremely close to constant acceleration
for half the period followed by constant deceleration.
The following (tested in Matlab, not POVRay, but I think I've transliterated it)
allows for linear interpolation for AccFrac = 0, something very close to the
cosine for AccFrac = 0.5 (constant acceleration for half the period followed by
constant deceleration for the other half) or an acceleration followed by a
coast, followed by a deceleration for 0 < AccFrac < 0.5
#macro AccDec(StartTime,EndTime,AccFrac)
// AccFrac should be between 0 and 0.5. It will be clipped.
#local KFrac    = min(max(0,AccFrac),0.5);
#local RelTime  = (clock - StartTime)/(EndTime - StartTime);
#local RelTime  = min(max(0,RelTime),1);
#if(KFrac = 0)
  #local SP = RelTime;
#elseif(RelTime < KFrac)
  #local SP = RelTime*RelTime/(2*KFrac*(1-KFrac));
#elseif(RelTime < 1 - KFrac)
  #local SP = RelTime/(1-KFrac) - KFrac/(2*(1-KFrac));
#else
  #local SP = 1 - (1 - RelTime)*(1 - RelTime)/(2*KFrac*(1-KFrac));
  SP
Date: 21 Feb 2019 02:37:45
Message: <5c6e5549$1@news.povray.org>
I will keep this in mind. Constant acceleration was what I was trying to
achieve.
Mike
> #if(KFrac = 0)
> #else
> #end
>    SP
> #end
