POV-Ray : Newsgroups : povray.general : Offset surface Server Time
10 Oct 2026 01:08:26 EDT (-0400)
  Offset surface (Message 1 to 33 of 33)
Subject: Offset surface
Date: 19 Jul 2018 18:57:53
Message: <5b511771$1@news.povray.org>
Analogous to "parallel curve", but in three dimensions.
https://en.wikipedia.org/wiki/Parallel_curve
What formula could I use to generate an "offset surface" for an
ellipsoid/spheroid? (An ellipse rotated around a vertical axis.)
Would a parametric function or implicit function be better or faster or
simpler?
Thanks.
Mike
Download 'cone_of_latitude_oblate_thickness.png' (48 KB)
Preview of image 'cone_of_latitude_oblate_thickness.png'
Subject: Re: Offset surface
Date: 19 Jul 2018 20:25:01
Message: <web.5b512b1aa78a3750458c7afe0@news.povray.org>
> simpler?
> Thanks.
> Mike
Since it's symmetric around the origin, just scale it.
If you need a "2D" part of it, just take a slice out of it.
I'm sure you could use a parametric, an isosurface, or possibly even a
polynomial if those are 3D.
As a related aside:
In Shapes2 there's a spheroid, and in Shapes3 there's facetted sphere and ring
sphere, since those might be fun to play with in conjunction with a globe.
http://www.f-lohmueller.de/pov_tut/all_shapes/shapes3_45e.htm
Date: 19 Jul 2018 20:30:00
Message: <web.5b512be3a78a3750458c7afe0@news.povray.org>
Also of interest:
http://xahlee.info/SpecialPlaneCurves_dir/Parallel_dir/parallel.html
It's involved with curves, and I just cheated and used trace()   ;)
http://news.povray.org/povray.advanced-users/thread/%3Cweb.592816879146df1fc437ac910%40news.povray.org%3E/
Date: 19 Jul 2018 21:01:00
Message: <5b51344c$1@news.povray.org>
Not sure what you mean. The offset surface of an ellipsoid is definitely
not another ellipsoid, so simply scaling it won't work.
> Also of interest:
Interesting. I can't read the formula however. It's been too long since
took calculus.
Do you have any renders of your efforts that you might share?
Mike
Date: 19 Jul 2018 21:34:43
Message: <5b513c33$1@news.povray.org>
> Also of interest:
Xah Lee says the parametric formula for an offset curve is
{ xf[t] + d yf'[t]/Sqrt[xf'[t]^2 + yf'[t]^2],
   yf[t] - d xf'[t]/Sqrt[xf'[t]^2 + yf'[t]^2] }
Not sure how to extend that into three dimensions. (I might be able to
make an SOR using that formula, but I'd rather not.)
Wikipedia says the parametric formula for an ellipsoid is
<math>\begin{align}
x&=a\cos(\theta)\cos(\varphi),\\
y&=b\cos(\theta)\sin(\varphi),\\
z&=c\sin(\theta),\end{align}\,\!</math>
where
<math>
-\frac \pi 2 \le \theta\le \frac \pi 2,
\qquad
-\pi\le \varphi\le \pi.
</math>
Not sure what the derivative of this is. (Calculus was years ago...)
Mike
Date: 19 Jul 2018 21:50:10
Message: <5b513fd2$1@news.povray.org>
See here:
https://math.stackexchange.com/questions/2857219/formula-for-the-offset-curve-of-an-ellipsoid
Mike
>> Also of interest:
> <math>\begin{align}
> where
> <math>
> \qquad
> </math>
> Mike
Date: 20 Jul 2018 07:40:00
Message: <web.5b51c9daa78a3750458c7afe0@news.povray.org>
So, I think I started this around 10 last night and [mostly] solved it by
midnight.
I did it in parametric form, but then I couldn't get the stupid parametric to
render, so I somehow was able to see my way to doing it in implicit form for an
isosurface.
We already know the equation for the ellipsoid
https://en.wikipedia.org/wiki/Ellipsoid
In order to derive a normal vector for each point on its surface, we need to
know the equation of the plane tangent to the ellipsoid at those points.
http://www.math.ucla.edu/~ronmiech/Calculus_Problems/32A/chap12/section6/811d45/811_45.html
and that says that the coefficients for the polynomial are the scalars of the
normal vector.
Then ya just plug that into vnormalize to get a unit normal vector and tack that
onto the ellipsoid formula.
Hit the documentation to see what the formulae for vnormalize, vlength, and vdot
are, and you have:
#declare R = 1;
#declare a = 1;
#declare b = 0.7;
#declare c = 1;
#declare F_ellipsoid = function {(pow(x,2)/pow(a,2)) + (pow(y,2)/pow(b,2))
+(pow(z,2)/pow(c,2)) - R}
#declare F_Normal = function {
((pow(x,2)/pow(a,2)) / pow(a,2)) +
((pow(y,2)/pow(b,2)) / pow(b,2)) +
((pow(z,2)/pow(c,2)) / pow(c,2)) }
#declare FVdot = function {pow(((pow(x,2)/pow(a,2)) / pow(a,2)), 2) +
pow(((pow(y,2)/pow(b,2)) / pow(b,2)), 2) + pow(((pow(z,2)/pow(c,2)) / pow(c,2)),
2)}
#declare Normalized = function {F_Normal (x, y, z) / sqrt (FVdot (x, y, z))}
My full scene is here.
Perhaps someone better versed in the parametric object can determine why I can't
get it to render the full surface, since the exact same equations are used in
the nested loop of spheres to correctly approximate the surface.
I think the only additional thing I'd do is find some way to verify the
correctness of this solution by verifying that the distance between the offset
curve and the ellipsoid is constant over the entire surface.
For that, I'd likely use a trace() method for the offset and the ellipsoid, and
then calculate the shortest Euclidean distance.
Might be able to do that and rewrite my trace() based curve making script to
plot out an approximation, and then either use a triangular grid or a series of
rectangles to make a smooth triangle approximation of the surface like Nylander,
Loney, TOK, and Jaap Frank.
#version 3.8;
global_settings {assumed_gamma 1.0}
// Offset / Parallel surface of an ellipsoid.
// Bill Walker "Bald Eagle" 7/20/2018
// for Mike Horvath "posfan12" at
http://news.povray.org/povray.general/thread/%3C5b513fd2%241%40news.povray.org%3E/
// parametric only renders a small section - not functional yet, and SLOW
//#include "shapes.inc"
//#include "shapes2.inc"
#include "shapes3.inc"
#declare Zoom = 128;
  orthographic
   location <0, 0, -20>    // position & direction of view
  look_at  <0, 0, 0>
  right x*image_width/Zoom           // horizontal size of view
  up y*image_height/Zoom // vertical size of view
   location <0, 0, -4>    // position & direction of view
  look_at  <0, 0, 0>
  right x*image_width/image_height         // horizontal size of view
  up y // vertical size of view
sky_sphere {pigment {rgb <0.5, 0.5, 1>}}
plane {y, -3 pigment {checker}}
light_source {<5, 5, -30> color White}
#declare Ellipse = torus {1, 0.01 rotate x*90 pigment {Red} scale <0.5, 1, 1> }
#declare n=2;
//object {Ellipse}
//object {Ellipse scale <n, n, 1>}
#declare R = 1;
#declare a = 1;
#declare b = 0.7;
#declare c = 1;
2)}
// for dynamic adapting of the max_gradient value
#declare Min_factor = 0.6; // between 0 and 1
#declare MaxGradient = 4;
#declare P0 = MaxGradient*Min_factor;
#declare P1 = sqrt(MaxGradient/(MaxGradient*Min_factor));
#declare P2 = 0.7;  // between  0 and 1
#declare Ellipsoid =
isosurface {
 function {F_ellipsoid (x, y, z)}
 accuracy 0.001
 max_gradient 3
 //evaluate P0, P1, min (P2, 1)
 contained_by {sphere {0, R}}
 //contained_by {box {<-R, -R, -R>, <R, R, R>}}
 pigment {rgb <0, 0, 1>}
#declare MaxGradient = 3;
#declare PEllipsoid =
isosurface {
 function {F_ellipsoid (x, y, z) - Normalized (x, y, z)/5 }
 accuracy 0.001
 max_gradient 5
     contained_by {sphere {0, R*2}}
 //contained_by {box {<-R, -R, -R>*2, <R, R, R>*2}}
 pigment {rgbt <1, 1, 0, 0.8>}
object {Ellipsoid}
object {PEllipsoid} // translate x*R*2}
#declare EllipseX = function (u, v) {a*cos(u)*sin(v)}
#declare EllipseY = function (u, v) {b*sin(u)*sin(v)}
#declare EllipseZ = function (v) {c*cos(v)}
#declare FNormalX = function (u, v) {EllipseX (u, v) / pow(a,2)}
#declare FNormalY = function (u, v) {EllipseY (u, v) / pow(b,2)}
#declare FNormalZ = function (v) {EllipseZ (v) / pow(c,2)}
#declare FVDot = function (u, v)
{pow(FNormalX(u,v),2)+pow(FNormalY(u,v),2)+pow(FNormalZ(v),2)}
#declare FVnormalizeX = function (u, v) {FNormalX (u, v) / sqrt (FVDot (u, v))}
#declare FVnormalizeY = function (u, v) {FNormalY (u, v) / sqrt (FVDot (u, v))}
#declare FVnormalizeZ = function (u, v) {FNormalZ (v) / sqrt (FVDot (u, v))}
#declare Step1 = pi/18;
#declare Step2 = pi/36;
#for (V, 0, tau, Step2)
 #for (U, 0, pi, Step1)
  //#declare X = a*cos(U)*sin(V);
  #declare X = EllipseX (U, V);
  //#declare Y = b*sin(U)*sin(V);
  #declare Y = EllipseY (U, V);
  //#declare Z = c*cos(V);
  #declare Z = EllipseZ (V);
  sphere {<X, Y, Z> 0.01 pigment {Blue}}  //point at <x, y, z> on the ellipsoid
  #declare Normal = <X/pow(a,2), Y/pow(b,2), Z/pow(c, 2)>;
  sphere {<EllipseX (U, V) + FVnormalizeX (U, V)/10, EllipseY (U, V) +
FVnormalizeY (U, V)/10, EllipseZ (V) + FVnormalizeZ (U, V)/10> 0.01 pigment
{Red}} // surface normal at <X, Y, Z>
// --------------------------------------- parametric surface --------------
#declare Parallel = parametric {
 function {EllipseX (u, v)}
 function {EllipseY (u, v)}
 function {EllipseZ (v)}
 <0, pi>, <0, 2*pi>  // start, end (u,v)
 max_gradient 50
 accuracy 0.005
 precompute 5 x,y,z
 texture {pigment{ color rgb <0, 1, 0>}}
//object {Parallel}
Date: 20 Jul 2018 10:05:00
Message: <web.5b51eb7aa78a37504dbcf4f0@news.povray.org>
> See here:
> Mike
> >> Also of interest:
> > <math>\begin{align}
> > where
> > <math>
> > \qquad
> > </math>
> > Mike
Many years ago I ever do something for the same goal.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5264d1b954cff585cc1fd1150%40news.povray.org%3E/?ttop=423056
&toff=750
But not the same, I used the math formula, not parametric formula. And just suit
for a small offset(a thin shell)
Because it is just an approximation.
Date: 20 Jul 2018 10:42:06
Message: <5b51f4be$1@news.povray.org>
Am 20.07.2018 um 00:59 schrieb Mike Horvath:
> simpler?
You /could/ just pretend that the parallel curve to an ellipsis is also
an ellipsis. AFAIK that's not true, but it could be sufficiently close
for your purposes.
In that case, all you'd have to do would be to scale the ellipsoid.
Date: 20 Jul 2018 12:10:00
Message: <web.5b520925a78a3750c437ac910@news.povray.org>
> for your purposes.
I was initially under the impression that he could do this, but they're similar
shapes, and therefore proportional - not constant distance.
I just took a scaled torus and then made a scaled copy - it's definitely not
good.
I'm assuming Mike wants to make an atmosphere for the globe or something
similar.
I already suggested this, and was properly shot down.
Date: 20 Jul 2018 12:35:00
Message: <web.5b520eeda78a3750c437ac910@news.povray.org>
56&toff=750
Outstanding!  :)
This is exactly something I was trying to do and was having trouble with.
Hopefully I'll have time to look this over in detail tonight or over the
weekend.
Thanks so much for posting the link to that thread.  :)
Great work!
Date: 20 Jul 2018 22:44:41
Message: <5b529e19$1@news.povray.org>
Wow, thanks!!
I haven't tested it yet, but I saw your note about performance. Do you
think the parametric object is slower than an isosurface? I prefer the
parametric, since all the "sketches" I've been doing in GeoGebra so far
have been with parametric formulas, and in general I find them easier to
understand. Isosurfaces always make my brain freeze.
Mike
> midnight.
> isosurface.
> normal vector.
> are, and you have:
> #declare R = 1;
> #declare a = 1;
> #declare b = 0.7;
> #declare c = 1;
> 2)}
> #version 3.8;
> camera {
>    orthographic
>    look_at  <0, 0, 0>
> camera {
>    look_at  <0, 0, 0>
> #declare n=2;
> //object {Ellipse}
> #declare R = 1;
> #declare a = 1;
> #declare b = 0.7;
> #declare c = 1;
> 2)}
> isosurface {
>   accuracy 0.001
>   max_gradient 3
> isosurface {
>   accuracy 0.001
>   max_gradient 5
> object {Ellipsoid}
>   #end
> #end
>   max_gradient 50
>   accuracy 0.005
>   precompute 5 x,y,z
> //object {Parallel}
Date: 20 Jul 2018 23:10:12
Message: <5b52a414$1@news.povray.org>
Okay I have been testing your scene. I've attached an orthographic
render of an ellipsoid with equal axes (so, a sphere). You can tell in
the render that there are thicker regions at the top-left, top-right,
bottom-left, and bottom-right. So I don't think the code is working as
it should.
Mike
> midnight.
> isosurface.
> normal vector.
> are, and you have:
> #declare R = 1;
> #declare a = 1;
> #declare b = 0.7;
> #declare c = 1;
> 2)}
> #version 3.8;
> camera {
>    orthographic
>    look_at  <0, 0, 0>
> camera {
>    look_at  <0, 0, 0>
> #declare n=2;
> //object {Ellipse}
> #declare R = 1;
> #declare a = 1;
> #declare b = 0.7;
> #declare c = 1;
> 2)}
> isosurface {
>   accuracy 0.001
>   max_gradient 3
> isosurface {
>   accuracy 0.001
>   max_gradient 5
> object {Ellipsoid}
>   #end
> #end
>   max_gradient 50
>   accuracy 0.005
>   precompute 5 x,y,z
> //object {Parallel}
Download 'bald_eagle_text.png' (27 KB)
Preview of image 'bald_eagle_text.png'
Date: 20 Jul 2018 23:32:56
Message: <5b52a968$1@news.povray.org>
Just to be clear, the offset surface of a perfect sphere should be
another perfect sphere.
Mike
Date: 21 Jul 2018 02:22:15
Message: <5b52d117$1@news.povray.org>
> &toff=750
Very nice, thanks!
I did a test, but there are graphical artifacts related to max_gradient
I think. The docs say a warning should appear if max_gradient is too far
off, but I don't see such a warning.
#version 3.8;
camera
	orthographic
	location	-z * 128		// position & direction of view
	direction	+z
	rotate x * 15
	rotate y * 45
camera
	look_at  <0, 0, 0>
	rotate x * 15
	rotate y * 15
light_source {<30, 30, -30> color rgb 1 parallel point_at 0}
#declare surf_thick = 0.1;
#declare f_spheroid = function(var1,var2,var3, a,b)
{var1*var1/a/a+var2*var2/a/a+var3*var3/b/b-1}
#declare f_spheroid_normalized = function(var1,var2,var3, a,b)
{f_spheroid(var1,var2,var3,
a,b)/sqrt(4*(var1*var1+var2*var2)/pow(a,4)+4*var3*var3/pow(b,4))}
//than difference these two isosurfaces
difference
	isosurface
		function {f_spheroid_normalized(x,y,z,1,2)-surf_thick}
//		accuracy		0.001
		max_gradient	4
		contained_by {sphere {0, 4}}
	isosurface
		function {f_spheroid(x,y,z,1,2)}
//		accuracy		0.001
		max_gradient	4
	plane {-y, 0}
	pigment {color rgbt <1,1,1,1/4>}
Date: 21 Jul 2018 03:15:28
Message: <5b52dd90@news.povray.org>
It's all working now, thanks to you all!
I've attached the latest test code and render.
Mike
Download 'and_test.pov.txt' (2 KB) Download 'and_test.png' (40 KB)
Preview of image 'and_test.png'
Date: 21 Jul 2018 04:57:53
Message: <5b52f591$1@news.povray.org>
Am 21.07.2018 um 04:46 schrieb Mike Horvath:
> Wow, thanks!!
My gut feeling is that for any given task there's nothing slower than
isosurfaces. After all, isosurfaces are pretty much the pinnacle of
flexibility, so they also provide the least potential for optimization.
Date: 24 Jul 2018 18:20:00
Message: <web.5b57a510a78a3750a47873e10@news.povray.org>
That's some really nice math work and problem-solving. I played around with the
bowl thickness and object scaling in your code, just to test the 'uniform wall
thickness' idea-- which works well!
You might try scaling the final bounded_by object to more closely fit the
resulting isosurface (for the sole purpose of making the scene render a bit
faster.) Even though the initial two isosurfaces' contained_by spheres can't be
scaled (that is, *non-uniformly* scaled), the final bounded_by sphere can. For
my render, I used <2.0,0.8,0.7> in the two initial functions...
         function {f_spheroid(x,y,z,2.0,0.8,0.7)}
             and
         function {f_spheroid_normalized(x,y,z,2.0,0.8,0.7)+surf_thick}
.... with surf_thick = 0.4, and bounded_by{sphere{0,1 scale <2.0, 0.8, 0.7>}}
This works well; I even tested the resulting (hidden) 'bounding box' shape with
min_extent/max_extent, to make sure of the close fit.
Of course. maybe a scaled BOX for the bounded_by shape could be an even closer
fit (to coincide with the differenced PLANE object in your code.)
I did notice some artifacts, in the self-shadowing area of the bowl. From
testing various things, it seems to be solely due to the isosurface 'accuracy'
value. I changed that from 0.001 to 0.000001, which appears to eliminate the
Moire patterns there. (I actually don't know how *small* a value that accuracy
can be, before it has no further effect.)
I was going to attach an image here of my tests, but I can't (using the web
interface, anyway.) I'll post it to the images section instead.
Date: 24 Jul 2018 18:36:48
Message: <5b57aa00$1@news.povray.org>
Thanks!
>               and
I'm not too worried about the artifacts, since 99% of the shape is
hidden behind another texture. Only the edges are important to me. (See
globe render in p.b.i.)
Mike
Date: 24 Jul 2018 18:38:30
Message: <5b57aa66$1@news.povray.org>
> Mike
p.b.a rather
Date: 26 Jul 2018 14:26:29
Message: <5b5a1255$1@news.povray.org>
>> for your purposes.
> good.
> similar.
If you want the atmosphere for an oblate, rotating, planet, then, it
will be thicker over the equator and thinner at the poles.
So, a scalled up version of the original ellipsoid should be a prety
good approximation.
Date: 28 Jul 2018 23:35:01
Message: <web.5b5d34ada78a37509cbeb2fe0@news.povray.org>
>  max_gradient 50
>  accuracy 0.005
>  precompute 5 x,y,z
> //object {Parallel}
Try this:
parametric {
    function { a*cos(u)*cos(v) }
    function { b*cos(u)*sin(v) }
    function { c*sin(u) }
    <0, 0>, <2*pi, pi>
    contained_by {
        sphere { <0, 0, 0>, max(a, b, c) }
    max_gradient max(a, b, c)
    accuracy 1e-6
    precompute 10 x, y, z
    pigment { color Green }
The main problem was your boundaries for u and v.
Tor Olav
http://subcube.com
Date: 29 Jul 2018 14:30:01
Message: <web.5b5e0776a78a3750458c7afe0@news.povray.org>
Ah yes. that.   And my failure to see the obvious mistake.   :|
Some days.....
There's something that's a candidate for a parser warning.
Thanks - that's one less thing on my "I really need to go back and look at...."
list.
Date: 2 Aug 2018 18:26:42
Message: <5b638522$1@news.povray.org>
Are there isosurface functions for the hyperboloid? Both the saddle and
hourglass versions. Thanks!
Mike
Date: 2 Aug 2018 18:37:01
Message: <5b63878d$1@news.povray.org>
> Mike
I need to create confocal ellipsoids and hyperboloids, with a cross
section like in this image
https://commons.wikimedia.org/wiki/File:Elliptical_coordinates_grid.svg
Is this possible with isosurfaces? The parametric formulas are easier to
deal with, but I don't think you can do offset curves with the
parametrics. Am I wrong?
Mike
Date: 2 Aug 2018 20:20:01
Message: <web.5b639e8ea78a3750458c7afe0@news.povray.org>
> > hourglass versions.
I would probably have to say - of course there are.
Looks pretty straightforward:
https://en.wikipedia.org/wiki/Confocal_conic_sections
Isosurfaces and (conventionally portrayed) parametrics are infinitely thin
shells of a surface.
to make lines , you'd need sphere-sweeps or similar.
But if you're looking to make nested shells (which I think is actually where
you're going with this, then you're going to want are the 3D shapes.
Presumably you want the ones that come standard with POV-Ray:
shapes.old
Insert menu:
Shapes2
Special shapes
http://www.f-lohmueller.de/pov_tut/addon/00_Basic_Templates/22_Shapes2/__index.htm
 f_ellipsoid(x,y,z, P0, P1, P2). f_ellipsoid generates spheres and ellipsoids.
Needs "threshold 1".
Setting these scaling parameters to 1/n gives exactly the same effect as
performing a scale operation to increase the scaling by n in the corresponding
direction.
    P0 : X scale (inverse)
    P1 : Y scale (inverse)
    P2 : Z scale (inverse)
Date: 2 Aug 2018 20:40:01
Message: <web.5b63a3cba78a3750458c7afe0@news.povray.org>
I haven't had to dig into this, but it's possible to make the hyperboloid while
specifying the foci, so I can't imagine the ellipsoid is any more difficult:
http://news.povray.org/povray.binaries.images/message/%3Cweb.591d8c269364765ac437ac910%40news.povray.org%3E/#%3Cweb.591
Looks like a Two-fer:
https://theinnerframe.wordpress.com/2016/08/01/quadrics/
Date: 3 Aug 2018 21:16:08
Message: <5b64fe58$1@news.povray.org>
Since I'm trying to model ellipsoidal coordinate system, the formulas
need to be parametric, so that I can make proper grid lines at the
correct intervals and angles and so forth. You and Tor Olav did a great
job of figuring out the method of creating offset surfaces of implicit
functions. Would you mind trying the same for parametrics? Thanks.
Mike
Date: 4 Aug 2018 08:00:01
Message: <web.5b6594b7a78a3750458c7afe0@news.povray.org>
Surely I'm missing something.
(It's likely - as it's Saturday morning, and I'm only 1 cup into it)
You, Mike Horvath, are mikh2161, posfan12 as well as (but not limited to)
SharkD.
The elliptic and hyperbolic curves in the Geogebra file were made by you.
(10 years ago)
When you click on the Geogebra file link, you get the drawing on the right, and
the formulas on the left.
So all you need to do is make the same thing in 3D - a series of nested shells
(with thickness)
Those shells are proportional, not constant-thickness, correct?
So they're just scaled versions of each other.
And ellipsoids are just scaled spheres.
Do you want the GRID, or do you want to be able to place "points" on the grid?
Are you using standard elliptic math, or some specialized geodectic system with
an equation that only you have worked out and know the form of?
Because you can mix isosurface shells and parametrically placed points.
The solution of the implicit and parametric equations are exactly the same.
They give you exactly the same set of points in space.
I have a hard time (efficiently) programming using a ouijaboard instead of a
keyboard, and the only chicken I have is in the freezer.
If I'm lucky, I likely have another 15 minutes free before RL starts pulling me
away.
Ready... set.... GO!
Fully stating the exact goal in no uncertain terms helps define what needs to be
done, so that the solution is the one desired, not one that's close, but still
completely useless.  You probably can't use a 2015 Toyota starter in a 1958
Ford, but it would take the same amount of effort to deliver you either part.
Perhaps you could freely share some completed SDL that's implementing the
solutions already given to you to shed some light on the mystery.
"I need to get from HERE to THERE, in order to do exactly THIS (and NOT _that_)"
Please, and Thank You.
Date: 4 Aug 2018 10:31:46
Message: <5b65b8d2$1@news.povray.org>
> SharkD.
Correct.
> (10 years ago)
> (with thickness)
I just want the grid. So, thin lines/curves of constant thickness, like
the curves in this collection.
http://lib.povray.org/searchcollection/index2.php?objectName=ShapeGrid&version=1.12&contributorTag=SharkD
I may expand the collection to include more shapes, and simplify some of
the existing ones; and the parametric object formulas are a natural
(albeit slow) fit for this purpose.
Yes, placing points parametrically is not hard.
Thanks.
Mike
Date: 4 Aug 2018 12:53:59
Message: <5b65da27$1@news.povray.org>
Never mind America's opioid problem. Someone seems to have a caffeine
problem. ;)
Regards
Date: 4 Aug 2018 18:43:44
Message: <5b662c20$1@news.povray.org>
Stop!
I just remembered parametric objects are not solid. So they are of no
use to me. Sorry.
Mike
Date: 4 Aug 2018 20:46:08
Message: <5b6648d0$1@news.povray.org>
Everything is hunky-dory. Thanks, all, for the help!
Mike
