POV-Ray : Newsgroups : povray.general : Hexagon pattern with 4 or 7 colors? Server Time
4 Nov 2026 22:23:46 EST (-0500)
  Hexagon pattern with 4 or 7 colors? (Message 1 to 33 of 33)
Subject: Hexagon pattern with 4 or 7 colors?
Date: 26 Apr 2018 03:15:40
Message: <5ae17c9c@news.povray.org>
Hi there,
why does the hexagon pattern in Povray only supports 3 colors?
I'd like to have a hexagonal pattern with 4 or 7 colors, see attached
images.
How can I do that with current povray versions?
Is it planned for a future release to make it easier?
Greetings,
	Lars R.
Download 'hexagon-4colors.jpg' (26 KB) Download 'hexagon-7colors.jpg' (29 KB)
Preview of image 'hexagon-4colors.jpg'
Preview of image 'hexagon-7colors.jpg'
Subject: Re: Hexagon pattern with 4 or 7 colors?
Date: 26 Apr 2018 12:41:23
Message: <5ae20133$1@news.povray.org>
Am 26.04.2018 um 09:15 schrieb Lars R.:
> Hi there,
> images.
And other users might want their hexagonal pattern with 11 colours, or
17, or 32. Or maybe 723.
We can't provide dedicated support for /all/ use cases our users might
come up with; we have to draw a line somewhere.
With a hexagonal pattern, 3 colours is the minimum you need to tile the
plane without having adjacent tiles of same colour, so that's the
"natural" number of colours for that tiling.
If you need a special variant of the hexagonal pattern, you can
implement it using a function pattern based on a user-defined function.
It's not easy, but it can be done. You'll need a lot of `switch()`, a
bit of trignonometry I guess, and maybe some `mod()` to achieve the
repetition.
Date: 26 Apr 2018 13:15:01
Message: <web.5ae207e797bd1601c437ac910@news.povray.org>
> It's not easy,
True.  I took a brief stab at this back in the Quantum Dot thread.
> but it can be done.
Yes.  And such a function would be great fun to experiment with.
> repetition.
Perhaps if the existing POV-Ray internal function code were posted here, that
would provide a good jumping-off point?
Date: 27 Apr 2018 03:05:01
Message: <web.5ae2218297bd1601c437ac910@news.povray.org>
Good idea Bill, get on that, will you?
Right.
Here ya go.
From fnintern.cpp
DBL f_hex_x(FPUContext *ctx, DBL *ptr, unsigned int fn); // 27
DBL f_hex_y(FPUContext *ctx, DBL *ptr, unsigned int fn); // 28
const Trap POVFPU_TrapTable[] =
    { f_hex_x,                   1 + 3 }, // 27
    { f_hex_y,                   1 + 3 }, // 28
DBL f_hex_x(FPUContext *ctx, DBL *ptr, unsigned int) // 27
    DBL x1,y1,x2,y2, th;
    x1=fabs(fmod(fabs(PARAM_X), sqrt(3.0))-sqrt(3.0)/2);
    y1=fabs(fmod(fabs(PARAM_Y), 3)-1.5);
    x2=sqrt(3.0)/2-x1;
    y2=1.5-y1;
    if ((x1*x1+y1*y1)>(x2*x2+y2*y2))
        x1=x2;
        y1=y2;
    if ((x1==0)&&(y1==0))
        PARAM_X=0.000001;
    th=atan2(y1,x1);
    if (th<M_PI/6)
        return(x1);
    else
        x1=cos(M_PI/3)*x1+sin(M_PI/3)*y1;
        return(x1);
DBL f_hex_y(FPUContext *ctx, DBL *ptr, unsigned int) // 28
    x2=sqrt(3.0)/2-x1;
    y2=1.5-y1;
        x1=x2;
        y1=y2;
        PARAM_X=0.000001;
    th=atan2(y1,x1);
    if (th<M_PI/6)
        return(y1);
    else
        y1=-sin(M_PI/3)*x1+cos(M_PI/3)*y1;
        return(fabs(y1));
Date: 27 Apr 2018 03:05:05
Message: <web.5ae22bdb97bd1601c437ac910@news.povray.org>
[Experiencing some problems with the website:  Trying this again]
Right.
Here ya go.
From fnintern.cpp
    x2=sqrt(3.0)/2-x1;
    y2=1.5-y1;
        x1=x2;
        y1=y2;
        PARAM_X=0.000001;
    th=atan2(y1,x1);
    if (th<M_PI/6)
        return(x1);
    else
        return(x1);
    x2=sqrt(3.0)/2-x1;
    y2=1.5-y1;
        x1=x2;
        y1=y2;
        PARAM_X=0.000001;
    th=atan2(y1,x1);
    if (th<M_PI/6)
        return(y1);
    else
        return(fabs(y1));
Date: 27 Apr 2018 08:05:00
Message: <web.5ae3114397bd1601c437ac910@news.povray.org>
Apparently there was a hiccup.
I tried to play with this a bit last night, and wanted to do it using functions,
so I could wind up with a pigment {function{}}
Is there a syntax by which I can do a function of a function?
I'm looking to something along the lines of:
#declare A = function (b, d) {b+d}
#declare Q = function (A(b,d), k) {A*k}
but POV-Ray doesn't calculate the result of A to be used as a parameter of Q.
It complains that it's expecting a parameter, but found a function instead.
I'm thinking there ought to be a way to G(F(x)).
Anyone?
Date: 27 Apr 2018 09:56:20
Message: <5ae32c04$1@news.povray.org>
Am 27.04.2018 um 14:02 schrieb Bald Eagle:
That depends on what you are trying to achieve.
For G(F(x)), how about
    #declare F = function(x) { x+1 }
    #declare G = function(y) { y*y }
    #declare Foo = G(F(4711)); // ((4711)+1)^2
Or, if you want to "hide" F(x) inside G(x), how about
    #declare G = function(x) { F(x)*F(x) }
    #declare Foo = G(4711); // ((4711)+1)^2
As a side note to the latter case, note that F(x) will be invoked twice
per invocation of G(x); to avoid this, in such cases I tend to use a mix
of the above:
    #declare F = function(x) { x^2 }
    #declare G_ = function(y) { y*y }
    #declare G = function(x) { G_(F(x)) }
Date: 27 Apr 2018 10:16:51
Message: <5ae330d3$1@news.povray.org>
Am 26.04.2018 um 21:44 schrieb Bald Eagle:
> Right.
> Here ya go.
> From fnintern.cpp
"These are not the functions you are looking for."
To the best of my knowledge, those functions actually correspond to the
`tiling 2` pattern, not the `hexagon` pattern.
The `hexagon` pattern is implemented by `HexagonPattern::Evaluate()` in
`source/core/material/pattern.cpp` (approx. line 6510).
Note however that the function is implemented using imperative
programming, and needs to be re-formulated as a pure function in order
to implement it as an SDL function.
Also, the function returns values 0, 1 or 2 to select the texture,
whereas a function to be used in a function-based pigment needs to
return values in the rang 0..1 (e.g. 0/N, 1/N, 2/N, ..., N/N) to select
the texture from a texture map.
Date: 27 Apr 2018 12:50:00
Message: <web.5ae3544c97bd1601c437ac910@news.povray.org>
Your Jedi mind tricks don't work on me, clipka.
I think there may be other closely related patterns in that same file, however
the functions.inc references the f_hex_x pattern, and I came across this early
thread, which I think might be before the pavement tilings were available.
http://news.povray.org/povray.general/thread/%3Cjerry-2B7BB9.10480402012003@netplex.aussie.org%3E/?ttop=285799&toff=320
0
Well, I'll certainly give it all a look over as time is available.
Yes, I had gotten that far, and believe I _might_ be able to do it with a few
functions and select()  [The code is at home, otherwise I'd post it for
early-stage critical review]
Yep, I think that's the idea.   Hopefully I'll be able to figure that part out
once I get the basics worked out and can better see the overall picture of how
to construct the pattern.
However, I'm also wondering if I can't somehow come up with a pattern that would
allow the tricks over in the bricks pattern thread to be used.  Or if somehow
that trick can be applied to the existing hexagon pattern[s] to eliminate the
need for writing a special function.
Date: 27 Apr 2018 20:05:01
Message: <web.5ae3b9b397bd16015cafe28e0@news.povray.org>
So, IRL is busy and chaotic, but here's what I have so far in case anyone can
point out some obvious mistakes.
Obviously I will try out other variations and source code functions...
#version 3.7;
global_settings {assumed_gamma 1.0}
sky_sphere {pigment {rgb <1, 1, 1>*0.2}}
   location <0, 0, -150>    // position & direction of view
  look_at  <0, 0, 0>
  right x*image_width/image_height           // horizontal size of view
  up y // vertical size of view
light_source {<25, 25, -150> color White}
//From fnintern.cpp
    x2=sqrt(3.0)/2-x1;
    y2=1.5-y1;
        x1=x2;
        y1=y2;
        PARAM_X=0.000001;
    th=atan2(y1,x1);
    if (th<M_PI/6)
        return(x1);
    else
        return(x1);
#declare S3 = sqrt(3.0);
#declare S32 = sqrt(3.0)/2;
#declare x1 = function (x) {abs(mod(abs(x), S3)-S32)}
#declare y1 = function (y) {abs(mod(abs(y), 3)-1.5)}
#declare x2 = function (x) {S32-x1(x)}
#declare y2 = function (y) {1.5-y1(y)}
#declare X0 = 0.000001;
#declare X1 = function (x, y) {select
((x1(x)*x1(x)+y1(y)*y1(y))-(x2(x)*x2(x)+y2(y)*y2(y)), x2(x), x1(x), x1(x))}
#declare Y1 = function (x, y) {select
((x1(x)*x1(x)+y1(y)*y1(y))-(x2(x)*x2(x)+y2(y)*y2(y)), y2(y), y1(y), y1(y))}
#declare Th = function (x, y) {select (X1(x1(x), y1(y))*Y1(x1(x), y1(y)),
atan2(Y1(x1(x), y1(y)), X0), atan2(Y1(x1(x), y1(y)), X1(x1(x), y1(y))),
atan2(Y1(x1(x), y1(y)), X0))}
#declare Hexagonal = function (x, y) {select(Th(X1(x1(x), y1(y)), Y1(x1(x),
y1(y)))-(pi/6), X1(x1(x), y1(y)), cos(pi/3)*Y1(x1(x), y1(y))+sin(pi/3)*Y1(x1(x),
y1(y)))}
#declare Hex = pigment {
 function {Hexagonal (x, y)}
 color_map {
  [0.00 rgb 0]
  [1.00 rgb 1]
 scale 10
box {<1,1,0.0001>*-50, <1,1,0.0001>*50 pigment {Hex} }
    x2=sqrt(3.0)/2-x1;
    y2=1.5-y1;
        x1=x2;
        y1=y2;
        PARAM_X=0.000001;
    th=atan2(y1,x1);
    if (th<M_PI/6)
        return(y1);
    else
        return(fabs(y1));
Date: 30 Apr 2018 15:05:01
Message: <web.5ae7679597bd1601a47873e10@news.povray.org>
> that would allow the tricks over in the bricks pattern thread to be used.
> Or if somehow that trick can be applied to the existing hexagon pattern[s]
> to eliminate the need for writing a special function.
You've inspired me; I'm experimenting with that idea...not with the 'brick'
pattern, but just using the cells pattern for the three hexagon 'triad'
pigments. The *fundamental* idea proves true: that the random cells colors can
create random-colored hexagons. But to get the colors to be scaled and placed
correctly in each hexagon shape requires *some* kind of warp{repeat.. offset
<...>} configuration that I haven't yet figured out. (The hexagon pattern itself
obviously has its own inner repeating/offset behavior, which might be messing
with things. And the cells pattern's default grid-position doesn't match the
layout of the hexagon pattern-- another complication.)
Although hexagon require 3 colors or pigments, it's easier for me at this stage
to use just ONE. (The other two hexagons of the 'triad' turn out black, which is
OK.)
This code is the general idea (horizontal on the x/z plane) -- but where to put
the warp{...} and the scales, and what they should be, is still a 'work in
progress'... ;-) The hexagon shape has 'inner angles' of 120-degrees at it's
points, so some of this code uses sin of 60-degrees to try and get the
cells-pattern scales to properly match the hexagon scales (I had to brush-up on
my trigonometry, ha):
pigment{
    hexagon
    pigment{ // #1
                 cells
                 color_map{
                         [0 rgb <1,0,0>]
                         [.5 rgb <0,1,0>]
                         [1.0 rgb <0,0,1>]
                 scale 1
                // warp{repeat x offset <0,0,2>} // ???
                 //translate <-.5,0,-.5> // ???
                 scale <2 + 1,1,2*.8660254> // .8660254 is sin of 60-degrees
                 translate <1.5,0,2*.8660254> // ???
   // pigment #2...
   // pigment #3...
Date: 30 Apr 2018 15:20:00
Message: <web.5ae76c3197bd1601c437ac910@news.povray.org>
No time to think about this very much at the moment, but the hexagon pattern is
alternating offset rows --- _almost_ similar to brick.
https://forum.processing.org/two/discussion/6735/hexagon-grid-with-almost-random-colour-fills-same-colour-adjacencies-m
inimized
Date: 30 Apr 2018 15:55:00
Message: <web.5ae7737197bd1601a47873e10@news.povray.org>
> random-colour-fills-same-colour-adjacencies-minimized
That looks interesting; I'm 'absorbing' some of the pertinent details and
letting them cook in the ol' brain.
I think you're right about the brick pattern; it seems to be tailor-made for
this problem (with a mortar thickness of zero.) I'll try that approach instead.
(I was hoping to work something out from 'first principles''-- those being the
cells pattern and warp{..}, ha-- which are not exactly 'fundamental', I admit!)
Date: 30 Apr 2018 16:50:01
Message: <web.5ae7809797bd1601c437ac910@news.povray.org>
This should have been bloody obvious --- but I'm slow.  :|
Use the TRIANGLE pattern.
Date: 30 Apr 2018 20:25:00
Message: <web.5ae7b3b797bd16015cafe28e0@news.povray.org>
(triangular)
But even more intriguing is the possibility to select the color based off a set
of two rectangular grids.
If rand can be used in a function, then along with mod and select, there might
be the chance this can somehow be applied to the problem.
I haven't had an uninterrupted minute to think about it clearly...
#version 3.7;
sky_sphere {pigment {rgb <1, 1, 1>}}
   location <0, 20, 0>    // position & direction of view
  look_at  <0, 0, 0.01>
light_source {<0, 25, -1> color White}
box {<-1, 0, -1>*10, <1, 0.01, 1>*10
 pigment {hexagon
  color Black,
  color Gray50,
  color White
  //rotate x*90
#declare A = sqrt(3);
#declare B = A/2;
#for (Z, -5, 5)
 #for (X, -3, 3)
  sphere {<X*3, 0, Z*A> 0.25 pigment {Red}}
#for (Z, -5, 5)
 #for (X, -3, 2)
  sphere {<(X*3)+1.5, 0, (Z*A)+B> 0.25 pigment {Green}}
Date: 1 May 2018 03:14:52
Message: <5ae813ec$1@news.povray.org>
Am 01.05.2018 um 02:24 schrieb Bald Eagle:
it cannot.
Date: 1 May 2018 08:20:01
Message: <web.5ae85b6c97bd1601c437ac910@news.povray.org>
I'll probably be posting some links here as a repository for working this out
further.
I found this, which seems to delve into some off the ideas I've been mulling
over.  The adaptation of a cubic pattern is something I was trying to work out,
having noticed this while doing my rgb color mapping project.
https://www.redblobgames.com/grids/hexagons/
I think the best way to further pursue this would be to define specific
hierarchical goals and expand that into pseudocode.
Then perhaps we can see if that can be adapted into a function-only pattern with
a 0-1 result that can be properly color/pigment/texture/material mapped.
It would be especially lovely if this could be expanded into a diamond-lattice
space-filling pattern as well.  And I might not be surprised if using a
backwards-approach from 3D to 2D or 4D to 3D by projection, or a geometric
inversion would somehow yield a solution.   There's a lot of stuff out there,
and sometimes I only have a whiff of what might be useful.
Date: 1 May 2018 08:25:00
Message: <web.5ae85c6297bd1601c437ac910@news.povray.org>
Some good explanations and algorithms here as well:
http://catlikecoding.com/unity/tutorials/hex-map/part-1/
Date: 2 May 2018 05:05:01
Message: <web.5ae97ed097bd1601a47873e10@news.povray.org>
Success! Random-colored hexagons. I didn't have to use the 'brick' pattern, just
cells.
-- For a horizontal surface, which is the default orientation of the hexagon
pattern.--
The three color-triad pigment blocks in the code are *almost* identical, but the
success lies in their translations, and in the offsets in warp{repeat...}. The
y-offsets are interesting-- they're actually arbitrary values, just to choose
some new 'color cubes' of the cells pattern. The cell colors are random from
cube to cube anyway, but the offsets kind of guarantee that the warp{repeats..}
are far separated from each other. Perhaps they're not really necessary; but
reduce the y-values to zero to see.
By default, each straight edge of POV-Ray's hexagon shape is 1-unit in length.
So the distance between opposite POINTS or vertices is 2.0 units, and the
distance between opposite EDGES is 2*sin(60), or 2*.8660254 units. The cells
patterns are scaled and translated so that they fully overlap each full hexagon
(but the overlaps aren't seen.)
The links that Bald Eagle provided were quite helpful with the hexagon math
details. (Thanks!)
Instead of fully random colors, the pigment_maps could have 4 or 7 or however
many 'segregated' colors, which was the original idea.
texture{
      pigment{
           hexagon
           pigment{ // #1
                 cells
                 color_map{
                         [0 rgb <1,0,0>]
                         [.5 rgb <.3,1,0>]
                         [1.0 rgb <0,0,1>]
                 scale <3,1,3*.8660254>
                 warp{repeat 3*.8660254*z offset <1.5,357.4,0>}
                 // the x-offset has to be 1.5, or can increase by
                 // adding multiples of 3.0 -- 1.5, 4.5, 7.5 etc.
                 translate <0,0,1.5*.8660254>
           pigment{ // #2
                 cells
                 color_map{
                         [0 rgb .5*<1,0,0>]
                         [.5 rgb .5*<.3,1,0>]
                         [1.0 rgb .5*<0,0,1>]
                 warp{repeat 3*.8660254*z offset <1.5,194.7,0>} // ditto
                 translate <1.5,0,0>
           pigment{ // #3
                 cells
                 color_map{
                         [0 rgb .25*<1,0,0>]
                         [.5 rgb .25*<.3,1,0>]
                         [1.0 rgb .25*<0,0,1>]
                 warp{repeat 3*.8660254*z offset <1.5,73.3,0>} //ditto
                 translate <0,0,0>
      finish{ambient .05 diffuse .95}
      scale .2
Date: 2 May 2018 09:30:01
Message: <web.5ae9bd3797bd16015cafe28e0@news.povray.org>
> cells.
Pretty damned impressive, my friend.   :)
"Whenever possible, let POV-Ray do the heavy lifting."
Very nice work applying the [warped] cells pattern.
Excellent.  I wouldn't have guessed that the squares would work well with the
hexagons, but --- lookitthat!
> details. (Thanks!)
Any time.   You've managed to get a good grasp on intertwining pigment patterns,
and I'd like to make a few suggestions for improvement so that it's usable for
experienced and new users alike.
1. Declare this as a standalone texture for use in an include file.
That way perhaps we can start a NewPatterns_v1.inc or something.
#declare FullHexagon = texture {....}
and obviously remove the finish {} block so that it can be applied by the
end-user.
2. Just a little nitpicky kinda thing: .8660254 is a "magic number" - it has no
meaning to someone looking at the code itself [and it has no leading zero
 :( ].  #declare Edge2Edge = 2 * sin (60); and then use that in your code.
Better still, since that still leaves out the implies "unit length of a side",
make it
#declare SideLength = 1;
#declare Edge2Edge = 2 * SideLength * sin (60);
and then scale <3, 1, (3 * Edge2Edge)>
Maybe include a way to specify dimensions based on different metrics:  edge to
edge, point to point, etc.
3. I, and likely anyone else who'd like to use this (OP), would probably enjoy a
simple mechanism by which to specify between 1 and N colors for the hexagons.  I
haven't dabbled with the code yet, but having a few easily understood #declares
that parameterize the pattern would make it a lot easier.
I'm trying to get my car repaired - AGAIN - and so I'm gonna be AFK for a while.
If there's a way to tie in the numeric pattern that I applied to crackle{} and
wood{}, that would help the use choose/modify the color pattern without a lot of
guessing.
.... and I see an obvious tie-in with the recently posted solution to the digital
camo!  :D
4.  Having just the outlines of the hexagons - a hexagonal grid (perhaps with
boxed{} or another pattern with a gradient or something? would be an obvious
extension of this.  Obviously some pattern would give hexagons with "holes"
rather than clean lines, but it's grid-like nonetheless.
Once again - super work, and super FAST!  :O
Date: 2 May 2018 10:35:01
Message: <web.5ae9cc3397bd1601a47873e10@news.povray.org>
> Success! Random-colored hexagons....
> texture{
>       pigment{
>            hexagon
>            pigment{ // #1
>                  cells
>                  color_map{
>                          [0 rgb <1,0,0>]
>                          [.5 rgb <.3,1,0>]
>                          [1.0 rgb <0,0,1>]
Here's a much better-looking color_map to use (for all THREE pigments.) The
original ones showed too much overall green. At first, I thought the problem was
due somehow to the simple index list I used-- 0.0 to 0.5 to 1.0 -- but the
solution was to dampen down the primary-green *intensity*. This new map has a
much more 'neutral' color appearance. To test it, I scaled the hexagon pattern
*really* small-- almost like noise-- then rendered it with AA (very important),
then took that image into Photoshop and blurred it. The resulting 'aggregate'
color was very close to neutral gray, as measured there... which is what the
three primary colors *should* look like, when combined correctly.
The new one:
    color_map{
        [0.0 rgb <1,0,0>]
        [0.5 rgb 0.47*<0,1,0>]
        [1.0 rgb 0.99*<0,0,1>]
OR, the srgb version...
    color_map{
        [0.0 srgb <1,0,0>]
        [0.5 srgb .715*<0,1,0>]
        [1.0 srgb .99*<0,0,1>]
Date: 2 May 2018 10:45:00
Message: <web.5ae9ce5297bd1601a47873e10@news.povray.org>
 Lots of good suggestions to ponder-- but I've been up all night working on this
stuff(!), and my brian is fizzing out. Will come back later...
zzzzzz
Date: 3 May 2018 12:45:01
Message: <web.5aeb3b9b97bd1601a47873e10@news.povray.org>
Well, it's only a 'basic' improvement-- the color choices are still only between
the three different hues of red, green and blue-- but it doesn't take into
account ALL the qualities of a color-space: hue, saturation (or tint), and
brightness. That's a much more difficult problem to solve, within a cells
pattern.
Date: 3 May 2018 13:35:01
Message: <web.5aeb474797bd1601a47873e10@news.povray.org>
>...I'd like to make a few suggestions for improvement so that it's usable for
Yes, either that or maybe as a macro (?)
> end-user.
Yes again. Although, *what if* the user wanted different finishes for the
different hexagons? (Imagine a hexagonal wood floor!) I guess that would require
 a "NewPatterns_v2" ;-)  A more complex version, in other words.
> has no meaning to someone looking at the code itself [and it has no leading
> zero :( ].
Agreed. My own code was more of an explanation (and not very detailed!) of why
the sin(60) was necessary. And cos(60) was also needed ;-)
> a side", make it
Hmm, I think that might be redundant-- only because the shape of a hexagon is
'fixed'. Adding those #declares would only add more bulk to the code (or perhaps
only 'explanatory' code.) And, if someone wanted to 'stretch' the hexagons, that
would be done more easily by a final scaling of the whole pattern, as with the
current implementation.
> enjoy a simple mechanism by which to specify between 1 and N colors for
> the hexagons.  I haven't dabbled with the code yet, but having a few
> easily understood #declares that parameterize the pattern would make it
> a lot easier.
Agreed.
And I'm currently mulling over thought-experiments of how to get the random
colors to include not only the hue, but the saturation and brightness as well.
Maybe that should be "NewPatterns_v3", ha-- if I can get it to work.
An interesting idea.
My own (different) attempts at using the 'boxed' pattern with the cells pattern
failed, though-- the boxed pattern appears to be a *single* entity that doesn't
repeat within the cells: The 'outer' pigment of boxed{} wipes out all the other
instances of that pattern. In other words, only ONE complete boxed pattern is
seen, in one cell; the rest of the cells pattern shows just the boxed outer
color. I haven't investigated this further; perhaps there's a way around it-- or
maybe it was due to my own early and uninformed use of the warp{repeat..}
offsets. (?) I should probably go back and try again.
But back to your idea of hexagon outlines: I think it would require a more
sophisticated version of something like the 'brick' pattern, with its mortar
lines. A hexagon-shaped version!
Date: 3 May 2018 15:15:06
Message: <web.5aeb5f7d97bd1601c437ac910@news.povray.org>
Well, elaborating on my initial brief post, the whole idea was that it could
probably be implemented as a macro, so that the user could pass parameters to
it.
But also that the include file would/could be a growing repository of new
patterns and variations on themes.  Once 10, 20, 30 patterns got added, it might
make into the next version distribution.
Implement it so that you can use a texture_map rather than just a pigment_map.
That way you can pass a full texture or just a pigment.  Or even go so far as to
make it a material_map.
Or have 3 macros, each a little different.
Author's choice as always.  ;)
> > a side", make it
True, but I think that a lot of posted code and code that can spur people on to
develop new patterns and textures ought to have as much info so that the next
guy can hit the ground running without having to unravel the meaning of his
archaeological find.
Well, don't use rgb - use the HSV2RGB macro in colors.inc.
That takes an "rgbft" vector as input (HSVft) and returns rgbft.
#declare it as a color rgbft and THEN use it in your pigment / texture or else
you'll get a "suspicious expression after rgb" warning for every instance.
Right.  I'm thinking the key has to be in a cylindrical or spherical pattern, or
maybe triangular with a gradient running from center to edge.
That quantum dot thread had something like that going on - I'll have to go back
and look through that.  There was a LOT of development going on at a very rapid
pace.  Too rapid for me to absorb it.
Date: 3 May 2018 20:35:00
Message: <web.5aeba9a597bd16015cafe28e0@news.povray.org>
I took a stab at it, but somehow with my numbered textures, it goes horribly
awry.
Having worked the initial pattern out, you likely stand a better chance of
seeing where it's going wrong and why.
I'll leave this here for you to fiddle with.
#version 3.7;
#declare Num = array [10];
#for (N, 0, 9)
 #declare Num[N] = text {ttf "arialbd.ttf" chr(48+N) 100, 0 translate <0, 0,
-50>}
#declare T = array [10];
#for (N, 0, 9)
 #declare Current = CHSV2RGB(<N*36, 1, 1>);
 #declare T[N] =
   pigment_pattern {
    object {Num[N]} // 1, 0}
    warp {repeat x}
    warp {repeat y}
   pigment_map {
    [0.0 rgbft Current]
    //[0.9 rgbft Current]
    [1.0 rgb 0]
  scale 0.25
  rotate x*90
// This seems to work fine
box {<-1, 0.1, -1>*10, <1, 0.02, 1>*10
 texture { // #1
                  cells
                  texture_map {
     #for (N, 0, 0.9, 0.1)
      [N     T[N*10] ]
      [N+0.1 T[N*10] ]
      //#debug concat ( " N = ", str (N, 3, 1),  " N+0.1 = ", str (N+0.1, 3, 1),
 " N*10 = ", str (N*10, 3, 1), "\n")
#declare SIN60 = sin (radians(60));
  //pigment{
  hexagon
  texture { // #1
   cells
   texture_map {
     [N     T[N*10] ]
     [N+0.1 T[N*10] ]
   scale <3, 1, 3*SIN60>
   // warp {repeat 3*.8660254*z offset <1.5,357.4,0>}
   translate <0, 0, (1.5*SIN60)>
  } // end texture #1
  texture { // #2
   cells
   texture_map {
     [N     T[N*10] ]
     [N+0.1 T[N*10] ]
   scale <3, 1, (3*SIN60)>
   // warp {repeat 3*.8660254*z offset <1.5,194.7,0>} // ditto
   translate <1.5, 0, 0>
  } // end texture #2
  texture { // #3
   cells
   texture_map {
     [N     T[N*10] ]
     [N+0.1 T[N*10] ]
   // warp {repeat 3*.8660254*z offset <1.5,73.3,0>} //ditto
   translate <0, 0, 0>
  } // end texture #3
  //finish {ambient .05 diffuse .95}
  //scale .2
 } // end hexagon texture
} // end box
Date: 3 May 2018 22:20:01
Message: <web.5aebc2a897bd16015cafe28e0@news.povray.org>
But I'm catching up  :D
the scale and the warp need to be immediately after cells, and before the
texture map.
This is still half-baked, but I think you can see how I worked it out.
(when warp gave me an error, I had commented it out, and forgot / read past it)
I still need to properly implement the infinite-thickness text-object function
pigment pattern....   (Say that 5 times fast)
#version 3.7;
#for (N, 0, 9)
 #declare Num[N] = text {ttf "arialbd.ttf" chr(48+N) 1, 0 translate <0, 0, -0.5>
scale <1, 1, 1e6>}
#declare f_Text = array [10];
#for (N, 0, 9)
 #declare f_Text[N] = function {
   pigment_pattern {
    warp {repeat x}
    warp {repeat y}
 #declare T[N] =
   pigment_pattern {
    warp {repeat x}
    warp {repeat y}
   pigment_map {
    [0.0 rgbft Current]
    [1.0 rgb 0]
  scale 0.15
  rotate x*90
 texture { // #1
            cells
            warp {repeat z*3*SIN60 offset <1.5, 357.4, 0>}
            texture_map {
    [N     T[N*10] ]
    [N+0.1 T[N*10] ]
#declare T_Clear = texture {pigment {rgbt 1}}
#declare Texture1 = texture { // #1
   cells
   warp {repeat 3*SIN60*z offset <1.5, 357.4, 0>}
   #declare ONE = on;
   #if (ONE)
    texture_map {
      [N     T[N*10] ]
      [N+0.1 T[N*10] ]
   #else
    texture_map {
      [N     T_Clear ]
      [N+0.1 T_Clear ]
  } // end texture #1
#declare Texture2 = texture { // #2
   cells
   warp {repeat 3*SIN60*z offset <1.5, 194.7, 0>} // ditto
   #declare TWO = on;
   #if (TWO)
    texture_map {
      [N     T[N*10] ]
      [N+0.1 T[N*10] ]
   #else
    texture_map {
      [N     T_Clear ]
      [N+0.1 T_Clear ]
  } // end texture #2
#declare Texture3 = texture { // #3
   cells
   warp {repeat z*3*SIN60 offset <1.5, 73.5, 0>} //ditto
   #declare THREE = on;
   #if (THREE)
    texture_map {
      [N     T[N*10] ]
      [N+0.1 T[N*10] ]
   #else
    texture_map {
      [N     T_Clear ]
      [N+0.1 T_Clear ]
  } // end texture #3
  //pigment{
  hexagon
  texture {Texture1}
  texture {Texture2}
  texture {Texture3}
  //scale .2
} // end box
box {<-1, -0.02, -1>*10, <1, -0.01, 1>*10 texture {Texture3}}
 pigment {hexagon
  color Black,
  color Gray50,
  color White
  //rotate x*90
#declare B = A/2;
//mod(A,B)
//Value of A modulo B. Returns the remainder after the integer division of A/B.
Formula is  mod=((A/B)-int(A/B))*B.
#for (Z, -10, 10)
 #for (X, -10, 10)
  #debug concat ( " mod(", str (X, 1, 0), "*3, 3) = ", str (mod(X*3, 3), 3, 3),
" mod(", str (Z, 1, 0), "*A, A) = ", str (mod(Z*A, A), 3, 3),  "\n")
#for (Z, -5, 5)
 #for (X, -3, 2)
Date: 10 May 2018 05:40:00
Message: <web.5af412fa97bd1601a47873e10@news.povray.org>
> Here's a much better-looking color_map to use (for all THREE pigments.)...
> The new one:
>     color_map{
>         [0.0 rgb <1,0,0>]
>     color_map{
>         [0.0 srgb <1,0,0>]
Well, that's wrong :-/
The *idea* is to get a continuous spectrum of colors, from red to green to
blue-- and those index-list values certainly don't do that. The index should be
divided into THREE equal segments. The following is much better...
           blend_mode ...  // optional
           blend_gamma ... // optional
           [0.0     rgb <1,0,0>]
           [0.333   rgb <0,1,0>]
           [0.666   rgb <0,0,1>]
           [1.0     rgb <1,0,0>]
BTW, it makes no difference if you use srgb colors instead, because the three
colors are all at FULL intensity. The srgb 'gamma curve' only applies to values
*between* 0.0 and 1.0.
Date: 10 May 2018 11:10:01
Message: <web.5af45fed97bd1601c437ac910@news.povray.org>
Well, I'd suggest using the HSV color conversion macro in colors.inc, and
calculate the rgb values that way.  Not sure if that will give you exactly what
you want, but plugging in 0, 120, and 240 for hue angle values might just do it.
I think this ought to get you real close to what you want:
(untested - writing this in as close to the proper syntax as I can)
#declare Color1 = HSV2RGB (  0, 1, 1, 0, 0)
#declare Color2 = HSV2RGB (120, 1, 1, 0, 0)
#declare Color3 = HSV2RGB (240, 1, 1, 0, 0)
[(0/3) rgb Color1]
[(1/3) rgb Color2]
[(2/3) rgb Color3]
[(3/3) rgb Color1]
Date: 15 May 2018 04:00:01
Message: <web.5afa92f697bd1601a47873e10@news.povray.org>
> > should be divided into THREE equal segments...
> >      [0.0     rgb <1,0,0>]
> >      [0.333   rgb <0,1,0>]
> >      [0.666   rgb <0,0,1>]
> >      [1.0     rgb <1,0,0>]
> exactly what you want, but plugging in 0, 120, and 240 for hue angle
[snip]
I *finally got some free time to look into this. (The HSV and HSL color models
are new to me-- as well as CIELAB and etc etc-- so I looked those up as well.
There are certainly a lot of facts to digest when it comes to colors, and how
they can be represented!!)
I tried the CHSV2RGB macro experiment with your HSV values, and the
color-spectrum results are visually identical to using the rgb color_map above;
so, either one works well. (The macro's equations certainly do what they're
supposed to do, and very accurately!)
Date: 15 May 2018 10:15:01
Message: <web.5afaeb1f97bd1601c437ac910@news.povray.org>
Excellent - I figured you were busy.  I haven't had much time to focus on any of
the various projects going on either.
Mike Horvath and clipka seem to be pretty active in modeling the various color
spaces, as evidence on Wikipedia.
Colors are indeed a lot more complicated than what people might naively assume
at first glance.  Like anything else, it's a combination of the wavelength(s)
involved, the eye receptors, the neurological interpretation of the sensed color
data, and in the case of the thing you're looking at, if it's printed - what
pigments, dues, waxes, inks are being used, and what range of colors they can
represent when mixed.
Which reminds me, I have to probably go back and fix an sRGB thing I was working
on and botched a while back.  :|
It's good to see that the simple color map gives a good [faux] HSV result - that
ought to be useful when I need to accomplish the same result yet keep the code
simple.
I looked a bit further into the method by which you accomplished the random
coloring of the hexagons, but haven't yet worked out how to specify a specific
number of colors to use.   Since you're color_mapping a 3-part pattern, I'm
assuming there may have to be a way to overlap the color maps for the various
parts, and there may be a few different ways to do that.
I haven't looked into the text / object pattering of the hexagon pattern - but
it's becoming clearer.
I'll bet it heating up down in VA - summer has arrived in NH   :O
Date: 15 May 2018 12:21:55
Message: <5afb0923$1@news.povray.org>
> data,
Like what else? ;)
dik
Rendered 328976 of 330000 (99%)
Date: 15 May 2018 17:15:00
Message: <web.5afb4c7097bd1601a47873e10@news.povray.org>
The built-in randomness of the 'cells' pattern underlies the random-colored
hexagons in my code, so for the THREE required cells patterns (all three, within
the hexagon outer pattern)), it's a simple matter of 'segregating' the distinct
colors. An example would be for five colors:
cells{
     color_map{
          [0.0 rgb <1,.3,.6>]
          [0.2 rgb <1,.3,.6>]
          [0.2 rgb <.5,.2,.7>]
          [0.4 rgb <.5,.2,.7>]
          [0.4 rgb <0,.5,.8>]
          [0.6 rgb <0,.5,.8>]
          [0.6 rgb <1,.5,.2>]
          [0.8 rgb <1,.5,.2>]
          [0.8 rgb <.3,1,.2>]
          [1.0 rgb <.3,1,.2>]
BTW, blend_mode/blend_gamma have no effect on this kind of color_map-- there are
no 'continuous color blends' for blend_gamma to work on. (I suspected this, but
never tried it 'til now.)
If you really want to shake up the 'randomness', translate each color_map
(immediately after its closing curly bracket) with some integer, like
translate 37. A different integer for each of the three. The underlying cells
patterns have 1-unit cubes by default, so this moves those patterns off into
space before the hexagon pattern has a chance to 'see' them. (As I continue to
experiment with my code, I'm finding several different ways of 'improving' the
randomness.)
