POV-Ray : Newsgroups : povray.general : Macro Problem Server Time
28 Oct 2026 20:03:01 EDT (-0400)
  Macro Problem (Message 1 to 19 of 19)
Subject: Macro Problem
Date: 22 Apr 2018 01:47:02
Message: <5adc21d6$1@news.povray.org>
If you have a little bit time and experience at your hand, you can help
me to find my error.
When calling the texture macro directly from another file, it works. But
when calling it from within the parameter liner of another macro, I get
the error message you cans see as comment behind one of the lines. Why?
Why? Why?
#declare MyShipTex = on;
#declare MyRandom  = seed(now*24*60*60);
include "Rand.inc"
include "SL - Woods.inc"
 #macro MyBrownSimpleQuoVadis(MyOrientation)
  #declare MySeeder    = seed(now*24*60*60);
  #declare MyDirection = MyOrientation*<1,2,3>;
  #declare MyAlignment = MyDirection.x+MyDirection.y+MyDirection.z;
  #switch(MyAlignment)
   #case(1)
    texture { MyBrownDarkwood rotate < 00.0, 90.0, 00.0 > rotate < 00.0,
00.0, 00.0 > scale 0.5+rand(MySeeder)*1.5 translate < rand(MySeeder),
rand(MySeeder), rand(MySeeder) > } //  X
    texture { MyBrownSimple } // Parse Error: Expected ")", # found instead
   #break
   #case(2)
    texture { MyBrownDarkwood rotate < 90.0, 00.0, 00.0 > rotate < 00.0,
rand(MySeeder), rand(MySeeder) > } // Y
   #break
   #case(3)
    texture { MyBrownDarkwood rotate < 00.0, 00.0, 90.0 > rotate < 00.0,
rand(MySeeder), rand(MySeeder) > } // Z
   #break
#macro
PostsSideRailing(MyLength,MyPlankHeight,MyMinimum,MyMaximum,MyIncrease,MyR,
MyT,MyRY,MyX,MyMacroTexture)
// 1.99,0.15,0.55,1.45,0.30,2.5,0.02,0.0,9.90,MyYellowSimple
 union
  #declare MyLevel   = MyMinimum;
  #declare AllLevels = MyMaximum;
  #while(MyLevel<=AllLevels)
   box { <  -MyLength, 0.00, -0.025 > <   MyLength,  MyPlankHeight, 0.00
> MyMacroTexture rotate < 0.0, 0.0, RRand(-MyR,MyR,MyRandom) > rotate <
0.0, MyRY, 0.0 > translate <  0.0, MyLevel+RRand(-MyT,MyT,MyRandom),
-MyX > scale < 1.0, 1.0,  1.0 > }
-MyX > scale < 1.0, 1.0, -1.0 > }
   #declare MyLevel=MyLevel+MyIncrease;
object {
PostsSideRailing(0.725,0.30,0.60,4.50,0.65,1.5,0.02,-90.0,6.675,MyBrownSimp
leQuoVadis(x))
translate < -20.9, 0.0, 0.0 > }
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: Macro Problem
Date: 22 Apr 2018 02:29:43
Message: <5adc2bd7$1@news.povray.org>
> Why? Why?
> include "Rand.inc"
I guess the missing # before include are not part of the issue, right ?
Date: 22 Apr 2018 02:44:48
Message: <5adc2f60$1@news.povray.org>
No, that's not the problem - I just forgot them inside this demo scene.
The source of the error must be somewhere else.
http://www.avg.com
Date: 22 Apr 2018 02:47:37
Message: <5adc3009$1@news.povray.org>
> Why? Why?
Macro call inside macro call...
I'm not sure the parser is expecting such thing, at least in its design
& specification.
Foo( Bar() )
The above line, I would avoid, and use instead
#local BarValue = Bar():
Foo( BarValue )
I'm not a big fan of meta-programming in SDL, so even if there could be
legitimate use cases of a macro invocation from within another macro, I
do not know which path should be followed to handle Foo( Bar() )
1. Bar() is evaluated and its value is used as the parameter (or rather,
the text of the parameter is replaced with the value of Bar() and parsed
every time the parameter is used inside the macro Foo.
2. Bar() is copied as the parameter, and parsed every time the parameter
when Bar() has side effect, it results in something different.
Such as
#declare BarCounter = 0;
#macro Bar()
#declare BarCounter = BarCounter+1;
BarCounter
Should the parser become painful and more complex by forbidding such
macro in macro ? I'm not sure.
Date: 22 Apr 2018 06:36:13
Message: <5adc659d@news.povray.org>
Am 22.04.2018 um 08:47 schrieb Le_Forgeron:
> & specification.
"What design & specification?"
Whenever the tokenizer encounters an existing macro name `Bar` (except
in special contexts such as `#undef Bar`, `#define Bar` or `#macro
Bar`), it immediately invokes the macro, and effectively inserts the
"results" of the macro in-place. So for instance the following SDL code
is perfectly legitimate, as the apparent single parameter `Bar()`
actually happens to resolve to two parameters:
    #macro Bar()
      "4711", "42"
    #macro Foo(A,B)
      #debug concat(A,"\n")
      #debug concat(B,"\n")
    Foo(Bar())
Date: 22 Apr 2018 07:10:54
Message: <5adc6dbe$1@news.povray.org>
Am 22.04.2018 um 07:47 schrieb Sven Littkowski:
> Why? Why?
The parser is a bit old and creaky in the joints, and some of its
features may interfere in unexpected ways.
For instance, while parsing the parameter list of a macro invocation,
the parser doesn't like directives (`#if`, `#else`, `#break`, ...) after
a `texture{}` statement -- presumably as an unintended side effect of
the layered textures feature (`texture{} texture{}`).
A simple workaround is to first assign the result of the texture macro
to a temp variable, and then use that temp variable in the object macro
invocation.
Date: 22 Apr 2018 10:04:27
Message: <5adc966b$1@news.povray.org>
You mean, calling the texture macro at first before calling the object
macro, and saving the texture macro's result in a DECLARE, and using
that Declare inside the object macro?
http://www.avg.com
Date: 22 Apr 2018 14:20:07
Message: <web.5adcd12bff561b5af773ca290@news.povray.org>
> invocation.
I would argue that the layered texture feature is defective by design. It is
pretty much the only case where two blocks of the same kind without any wrapper
have a special meaning. For other cases, namely with the addition of "material"
this has been fixed a long time ago. Maybe it is time to force something similar
for layered textures... at least outside scene objects.
Date: 22 Apr 2018 17:36:02
Message: <5add0042$1@news.povray.org>
Am 22.04.2018 um 16:04 schrieb Sven Littkowski:
I /think/ what you're trying to say is what I was trying to say, yes ;)
Date: 22 Apr 2018 18:09:24
Message: <5add0814@news.povray.org>
Am 22.04.2018 um 20:15 schrieb Thorsten Froehlich:
I do agree that the current syntax was a bad idea. I would even argue
that its use in a geometric object is also broken, because it assigns
different semantics to the `texture{}` statement in different
situations; for example, in the following code,
    #declare O0 = sphere { ... }
    #declare O1 = object { O0 texture { T1 } }
    #declare O2 = object { O1 texture { T2 } }
the statement `texture{T2}` has the semantics "replace the object's
texture with T2", while in
    #declare O1 = object { O0 texture { T1 } texture { T2 } }
the statement `texture{T2}` has the semantics "layer T2 on top of the
object's current texture".
I guess a more reasonable syntax for creating layered textures would be:
      layered
      texture { ... }
      texture { ... }
One problem however -- besides the need to maintain backward
compatibility for legacy scenes -- is that with all the additions and
changes that have been made since the introduction of the layered
texture feature, it's probably difficult to identify (a) which portions
of the parser code actually constitute the implementation of this
feature in its current form, and (b) which of these portions have by now
been co-opted by other features.
And then there is the limitation of being unable to layer patterned
textures on top of one another, which I find pretty... well, limiting.
But that has (almost) nothing to do with parsing, and instead is a
limitation of the current rendering engine implementation.
Date: 22 Apr 2018 18:10:00
Message: <web.5add0796ff561b5a5cafe28e0@news.povray.org>
I would agree.
Also, Sven, whenever you see something expected, another thing found instead,
then what you need to do is think about why POV-Ray is looking for, in this case
")".   This is a very valuable general debugging skill that will serve you well
in the future.
I think _one_ simple fix could be for Sven to wrap the layered texture in a
material {} definition, and then call the macro before trying to invoke the
texture{} ---> material{}.
Then he can do something like
MyBrownSimpleQuoVadis(x)   // "returns" a #declared CurrentMaterial
object {
PostsSideRailing
(0.725,0.30,0.60,4.50,0.65,1.5,0.02,-90.0,6.675,CurrentMaterial)
I'm sure there are many more solution permutations.
Date: 22 Apr 2018 20:26:04
Message: <5add281c$1@news.povray.org>
The problem with layered textures and another texture on top of that, is
easy to bypass:
- creating a layered texture
- putting this layered texture on a declared (named) shape
- calling this object and applying now another texture to it
I believe, I did that a few times. Or something similar to this. Not the
perfect solution for all needs, but it works.
But what can be done about my real problem, the macro-macro situation?
Can any fix be done?
The suggestion to call first the texture macro and only afterwards the
object macro, would cause many, many, many more new code lines. If I can
avoid that, I would. Sounds like an urgent patch reason to me...
http://www.avg.com
Date: 23 Apr 2018 11:27:08
Message: <5addfb4c$1@news.povray.org>
Am 23.04.2018 um 02:26 schrieb Sven Littkowski:
Yes, actually there's a way: You can move the assignment to a variable
into the macro itself, essentially using the following construct:
    #macro MyBrownSimpleQuoVadis(...)
      #local Result =
      #switch(...)
        #case(1)
          texture { ... }
          texture { ... }
        #break
      Result
    object {
    PostsSideRailing(..., MyBrownSimpleQuoVadis(x))
This way, the `texture{...} texture{...}` followed by `#break` doesn't
technically occur in the context of the `PostsSideRailing` macro
invocation, but rather in the context of a `#local` assignment, where it
doesn't lead to a problem. In the context of the `PostsSideRailing`
macro invocation, all that's visible is the `Return` variable
identifier, which also is unproblematic.
I guess I can't repeat this too often: When writing a macro to construct
an individual texture, object, pigment or what-have-you, it is very good
practice to first assign the thing to a local variable (which I tend to
call `Result`), and then have the macro "emit" just that variable itself.
Date: 23 Apr 2018 12:55:00
Message: <web.5ade0ee7ff561b5ac437ac910@news.povray.org>
So, essentially what you're saying is, when writing a macro to construct
call `Result`), and then have the macro "emit" just that variable itself?
Date: 23 Apr 2018 13:21:48
Message: <5ade162c$1@news.povray.org>
Sounds good! I will give a try. It is kinda new to me, I might need some
more practical help. But I am going ahead now and add the RESULT
variable, and will then find out how to use the RESULT variable inside
the object macro.
Thanks for this great advise.
http://www.avg.com
Date: 23 Apr 2018 15:15:43
Message: <5ade30df$1@news.povray.org>
Am 23.04.2018 um 18:50 schrieb Bald Eagle:
Yes, when writing a macro to construct an individual texture, object,
pigment or what-have-you, it is very good practice to first assign the
thing to a local variable, and then have the macro "emit" just that
variable itself.
Date: 24 Apr 2018 23:54:31
Message: <5adffbf7$1@news.povray.org>
Yes, that new construct really works. Interesting.
Thanks, Clipka.
http://www.avg.com
Date: 27 Apr 2018 17:05:01
Message: <web.5ae38fb5ff561b5aa47873e10@news.povray.org>
Yes!! ;-)
Date: 28 Apr 2018 21:19:08
Message: <5ae51d8c@news.povray.org>
Yes!
http://www.avg.com
