Subject: HELP - Rotating Railing Posts around Scaled Cylinder Edge
Date: 28 Mar 2018 00:23:11
Message: <5abb18af$1@news.povray.org>
if I want to distribute railing posts around the edge of a regular
CYLINDER (scale 1.0) it is easy: I would use something like
object
RailingPost
translate < MyCylinderRadius, 0.0, 0.0 >
rotate < 0.0, MyAngle, 0.0 >
But what would be the formula for distribution, if the cylinder has been
scaled unevenly, like this:
cylinder { < 0.0, 0.0, 0.0 > < 0.0, 1.0, 0.0 > scale < 0.5, 1.0, 1.0 > }
I need two algorithms:
- one for placing each post by myself
- one to place all posts with a WHILE loop
Thanks a lot.
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
A scaled circle is an actual ellipse.
If you're able to plot out an ellipse a la Kepler, then that will solve your
problem.
Subject: Re: HELP - Rotating Railing Posts around Scaled Cylinder Edge
Date: 28 Mar 2018 07:56:32
Message: <5abb82f0@news.povray.org>
Very unfortunately, I am not Kepler or anywhere close to this blessed
mathematician and astronomer.
I think, I still need a formula...
http://www.avg.com
Date: 28 Mar 2018 10:33:22
Message: <5abba7b2$1@news.povray.org>
Am 28.03.2018 um 06:22 schrieb Sven Littkowski:
Google "equidistant points on ellipse" for a point to start.
Or go here, which is where google took me:
https://math.stackexchange.com/questions/172766/calculating-equidistant-points-around-an-ellipse-arc
https://en.wikipedia.org/wiki/Ellipse#Polar_form_relative_to_center
#declare r = ab / sqrt(b*pow(cos(theta),2) + a*pow(sin(theta),2)) / theta;
then translate by r, and rotate by degrees(theta)
#version 3.7;
// Bill Walker "Bald Eagle" March 2018
global_settings {assumed_gamma 1.0}
location <0, 10, -0.01>
look_at <0, 0, 0>}
light_source { <0, 150, 0> color rgb <1, 1, 1>}
plane {y, 0 pigment {Gray10}}
#declare a = 1;
#declare b = 4;
#declare r = 0;
#declare o = <0, 0, 0>;
#for (theta, 0, tau, 0.1)
#declare r = (a*b / sqrt(b*pow(cos(theta),2) + a*pow(sin(theta),2)));
#debug concat ( " r = ", str (r, 3, 1), "\n")
sphere {o, 0.1 pigment {Green} translate <r, 0, 0> rotate -y*degrees(theta)}
#end // end for theta
Date: 29 Mar 2018 19:55:36
Message: <5abd7cf8$1@news.povray.org>
GREAT WORK!
Thanks, well-appreciated. This formula will help me a lot to develop my
ship!
http://www.avg.com
Date: 29 Mar 2018 19:59:24
Message: <5abd7ddc$1@news.povray.org>
Thanks a lot! I admit, I did not even know, how to search for this topic
(what search phrase to use). This helps me a lot.
http://www.avg.com
Sven Littkowski <I### [at] SvenLittkowski name> wrote:
> Hi,
> object
> RailingPost
At the Wikipedia page that Christoph linked to there is a method for a somewhat
even distribution of points around an ellipse:
https://en.wikipedia.org/wiki/Ellipse#Steiner_generation_of_an_ellipse
Try my code below to experiment with this method.
Tor Olav
http://subcube.com
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.7;
global_settings { assumed_gamma 1.0 }
#declare A = 2; // Semi-major axis
#declare B = 1; // semi-minor axis
#declare R = 0.05;
#declare T = 0.20;
#declare D = 0.21;
cylinder {
-T*y, +T*y, 1
scale <A, 1, B>
pigment { color Blue }
#declare Nil = 1e-9;
#declare Spline1 =
spline {
linear_spline
0 , <+A, 0, 0>
10 , <+A, 0, +2*B>
20 - Nil, <-A, 0, +2*B>
20 , <-A, 0, +B> // or <-A, 0, -B>
20 + Nil, <-A, 0, -2*B>
30 , <+A, 0, -2*B>
40 , <+A, 0, 0>
#declare Spline2 =
spline {
linear_spline
0, <+A, 0, +2*B>
10, <-A, 0, +2*B>
20, <-A, 0, 0>
30, <-A, 0, -2*B>
40, <+A, 0, -2*B>
#declare Step = 1; // Also try 0.5 and 2
#declare I = 0;
#while (I < 40)
#declare p1 = Spline1(I);
#declare p2 = Spline2(I);
#declare E = (p1.x + A)*p2.z;
#declare F = (p2.x - A)*p1.z;
#declare pS = A/(E - F)*<E + F, 0, 2*p1.z*p2.z>;
cylinder {
-D*y, +D*y, R
translate pS
pigment { color White }
#declare I = I + Step;
#end // while
location 4*y
look_at 0*y
sky z
light_source {
100*y
color White
Date: 30 Mar 2018 02:44:48
Message: <5abddce0$1@news.povray.org>
It took me a while to find what I was looking for. I think this would
help: vaxis_rotate. See test file.
Download 'vaxis_rotate_test.pov.txt' (2 KB)
That's a very nice construction, TOK! :)
It took me a minute look it all over and see what was going on - the diagram and
animation on that page really help.
It's so nice to have many different ways to construct the same shape, but with
different results in the point-by-point details.
I'll need to look at TdG's code, but it seems to be very similar to a way I was
thinking of that would show how the ellipse is the uneven scaling of a circle.
With radius and angle, use transforms to "move" a vector to a place on the
circle, then using scaling transforms, adjust it to be elliptical.
Then an "overall scaling" transform could be applied after that as well.
Thank you Bill :)
Yes, that animation helped me much too.
I Agree. And as you have probably noticed, I'm find it interesting when problems
like these can be solved without trigonometry.
Yes, that is a possible way of doing it. But if Sven wants to place the fence
posts evenly along his elliptic shape, then that way is more problematic,
because the distances between the posts will then wary quite much.
I see now that it was you that linked to the Wikipedia page. Christoph linked to
a StackExchange page. Sorry about that.
And on that StackExchange page Dr. Martin von Gagern mentions that a way to
calculate the coordinates of such evenly distributed points is to calculate
complete and incomplete elliptic integrals of the second kind and then do some
numerical solving (and more). I started to make code for that, but before I
finished it I found that an it could be done with much less effort in POV-Ray
with some more linear splines. (My way may not be not as good as MvG's solution,
but I suspect that it is good enough for Sven's purpose.) See the code below for
this.
Tor Olav
http://subcube.com
// Distributing points evenly around an ellipse
// By Tor Olav Kristensen
#version 3.7;
#declare T = 0.010; // Height of elliptic cylinder
#declare D = 0.011; // Height of the small sylinders
#declare R = 0.04; // Radius of the small cylinders
#declare B = 1; // Semi-minor axis
cylinder {
-T*y, +T*y, 1
scale <A, 1, B>
#declare Spline1 =
spline {
linear_spline
0.00 , <+A, 0, 0>
0.25 , <+A, 0, +2*B>
0.50 - Nil, <-A, 0, +2*B>
0.50 , <-A, 0, +B> // or <-A, 0, -B>
0.50 + Nil, <-A, 0, -2*B>
0.75 , <+A, 0, -2*B>
1.00 , <+A, 0, 0>
#declare Spline2 =
spline {
linear_spline
0.00, <+A, 0, +2*B>
0.25, <-A, 0, +2*B>
0.50, <-A, 0, 0>
0.75, <-A, 0, -2*B>
1.00, <+A, 0, -2*B>
#declare NrOfSteps = 1000;
#declare dS = 1/NrOfSteps;
#declare EllipseSpline =
spline {
linear_spline
#for (I, 0, NrOfSteps)
#declare S = I*dS;
#declare p1 = Spline1(S);
#declare p2 = Spline2(S);
S, A/(E - F)*<E + F, 0, 2*p1.z*p2.z>
#end // while
#declare LengthSpline =
spline {
linear_spline
#declare LengthSum = 0;
#declare pP = EllipseSpline(0);
#declare S = I*dS;
#declare pN = EllipseSpline(S);
#declare Length = vlength(pN - pP);
#declare LengthSum = LengthSum + Length;
S, LengthSum*<1, 1>
#declare pP = pN;
#end // for
#declare TotalLength = LengthSpline(1).u;
#declare InverseLengthSpline =
spline {
linear_spline
#declare S = I*dS;
#declare Length = LengthSpline(S).u;
#declare NL = Length/TotalLength;
NL, S*<1, 1>
#end // for
#declare dNL = 1/NrOfSteps;
#declare UniformIntervalsSpline =
spline {
linear_spline
#declare NL = I*dNL;
#declare S = InverseLengthSpline(NL).u;
NL, EllipseSpline(S)
#end // for
#declare NrOfCylinders = 40;
#declare Cylinders =
union {
#for (I, 1, NrOfCylinders)
#declare pS = UniformIntervalsSpline(I/NrOfCylinders);
cylinder {
-D*y, +D*y, R
translate pS
#end // for
object {
Cylinders
pigment { color Yellow }
location 4*y
look_at 0*y
sky z
light_source {
100*y
color White
Date: 30 Mar 2018 19:07:13
Message: <5abec321$1@news.povray.org>
Yes, it is. Big thanks!!!
> #declare R = 0.05;
> #declare T = 0.20;
> #declare D = 0.21;
> cylinder {
> -T*y, +T*y, 1
> scale <A, 1, B>
> #declare Spline1 =
> spline {
> linear_spline
> 0 , <+A, 0, 0>
> 10 , <+A, 0, +2*B>
> 30 , <+A, 0, -2*B>
> 40 , <+A, 0, 0>
> #declare Spline2 =
> spline {
> linear_spline
> 0, <+A, 0, +2*B>
> 10, <-A, 0, +2*B>
> 20, <-A, 0, 0>
> 30, <-A, 0, -2*B>
> 40, <+A, 0, -2*B>
> #declare I = 0;
> #while (I < 40)
> cylinder {
> -D*y, +D*y, R
> translate pS
> #end // while
http://www.avg.com
Date: 30 Mar 2018 19:10:08
Message: <5abec3d0@news.povray.org>
And yet another method! thanks a lot, Thomas!
http://www.avg.com
Date: 31 Mar 2018 02:49:14
Message: <5abf2f6a$1@news.povray.org>
Beware though, that my solution is problematic for equidistant posts,
like Tor Olaf rightly mentioned above.
Date: 31 Mar 2018 03:24:14
Message: <5abf379e@news.povray.org>
Yes, noted. But I copied all versions into one memory file. Soon, when
reaching the need to elliptically place posts, I will make my
experiences. :-)
If it is not so well for equally spaced posts, it is still good to place
single items.
http://www.avg.com
