POV-Ray : Newsgroups : povray.general : #version directive Server Time
10 Oct 2026 02:21:26 EDT (-0400)
  #version directive (Message 1 to 17 of 17)
Subject: #version directive
Date: 6 Feb 2018 21:23:20
Message: <5a7a6318$1@news.povray.org>
Does `#version 3.7` have to appear at the very top of a scene file? Or
can I store it as a variable or use it in a condition first? E.g.
   #declare MyVersion = version;
   #if (something = true)
     #version 3.7
   #else
     #version 3.6
Thanks.
Mike
Subject: Re: #version directive
Date: 7 Feb 2018 05:35:01
Message: <web.5a7ad640c5234a595cafe28e0@news.povray.org>
>      #version 3.7
>    #else
>      #version 3.6
>    #end
Both.
POV-Ray expects to fins a #version directive (and a global settings block with
gamma) at the beginning of every file, and will issue a warning is those are not
present.
You can, however, then go on to change the version the parser uses to interpret
your code by issuing another #version directive.
IIRC, this is done with some include files or macros, where the current version
is stored like you do above, and then after that block of code is run, the
version is restored by
#version MyVersion
Hope that makes sense.
Date: 7 Feb 2018 07:13:12
Message: <5a7aed58$1@news.povray.org>
>>       #version 3.7
>>     #else
>>       #version 3.6
>>     #end
> Both.
> present.
> #version MyVersion
Parse Warning: This scene had other declarations preceding the first
#version directive. Please be aware that as of Pov-Ray 3.7, un1ess
a1ready specified via an INI option, a #version is expected as the first
declaration in a scene file. If this is not done, POV—Ray may apply
compatibility settings to some features that are intended to make pre -
3.7 scenes render as designed. You are strongly encouraged to add a
#version statement to the scene to make your intent c1ear. Future
versions of Pov-Ray may make the presence of a #ver51on mandatory.
Which means it might not work in the future.
Regards
Date: 7 Feb 2018 15:03:22
Message: <5a7b5b8a$1@news.povray.org>
Yes, that's what I was worried about.
Mike
Date: 7 Feb 2018 15:42:51
Message: <5a7b64cb$1@news.povray.org>
>> first declaration in a scene file. If this is not done, POV—Ray may
>> apply compatibility settings to some features that are intended to
>> make pre - 3.7 scenes render as designed. You are strongly encouraged
>> to add a #version statement to the scene to make your intent c1ear.
>> Future versions of Pov-Ray may make the presence of a #ver51on mandatory.
> Mike
You could open with
#version 3.7
and then ignore it and do your calculated version when you're ready (I
mean, like 5 lines below the initial #version).  That should satisfy the
parser and work like you expect.
dik
Rendered 920576 of 921600 pixels (99%)
Date: 7 Feb 2018 15:48:51
Message: <5a7b6633$1@news.povray.org>
Me too as I use a modeller and the version correction is done after the
global settings.
Regards
Date: 7 Feb 2018 15:52:28
Message: <5a7b670c$1@news.povray.org>
Am 07.02.2018 um 03:23 schrieb Mike Horvath:
>     #version 3.7
>   #else
>     #version 3.6
>   #end
> Thanks.
If you want your scene to automatically adapt to whatever version is
used, it is recommended to use
    #version version;
as the first line and continue from there.
Date: 7 Feb 2018 15:55:50
Message: <5a7b67d6$1@news.povray.org>
Am 07.02.2018 um 21:48 schrieb Stephen:
>>> mandatory.
> global settings.
As long as the `#version` statement specifies a value of 3.7 or lower,
this will continue to work even in future versions.
Date: 8 Feb 2018 05:55:00
Message: <web.5a7c2b99c5234a59a47873e10@news.povray.org>
>     #version version;
I didn't realize this, even after re-reading the docs; the combination of the
#version directive and  version keyword has always been a little mysterious to
me. So, no matter what version of POV-Ray I'm using (or what version my scene
was originally written with), if I use
#version version
then the scene file will automatically be processed *as if* it was written in
the currently-running POV-Ray version? (I hope I'm being clear.) Disregarding
any compatibility problems that might arise, of course, if the scene file is an
old one. In other words, if I'm currently using a specific v3.7.1 beta, then
#version version
is basically a 'shorthand' way of specifying
#version 3.71;
The thing is, the docs say this:
"As of version 3.7, there has been a requirement implemented. In order to obtain
full version 3.7 functionality, you MUST specify the #version 3.7".  Or 3.71,
etc. But there, it doesn't mention the   #version version   trick (or rather,
the short explanation is not totally clear that it can be used instead.)
Also, this:
"...and a CHANGE as of POV-Ray 3.7.1 or later it is now considered an outright
error to use #version 3.71 or higher in a main scene file that does not start
with a #version directive."
Maybe it's just me, but that sounds confusing. "#version 3.71" is in GREEN there
(like the other keywords used in those paragraphs), but is it meant to be? I'm
wondering if the sentence is actually trying to say something like this:
error to run a scene file in v3.7.1 or higher that does not start with a
#version directive."  ??
And continuing... (the forward slashes are mine):
"If you do need to do some processing /before you decide/ on a version
compatibility option, start your scene with the following construct:
  #version version;
That could possibly be interpreted as meaning a 'real' #version number needs to
be added later in the scene.
If I'm wrong about any of this, I apologize for possibly confusing the issue
further ;-)
Date: 8 Feb 2018 10:20:01
Message: <web.5a7c6a73c5234a59c437ac910@news.povray.org>
> >     #version version;
> #version version
Essentially, yes.
I think that the term keyword blurs certain things, and would like to see a
change to something more descriptive _like_ "POV-Ray reserved constant."
>Disregarding
> #version version
> #version 3.71;
Again, yes.
The thing to do would be to write a short SDL script that sends the value of
version to the debug stream.
Then do #version 3.5, do #version version again, and see what version equals.
In that case, if version winds up being 3.5, then version is a "POV-Ray
predefined variable", rather than a constant that reflects the version of the
build.
Perhaps there ought to be a secondary "software_version" or "current_version"
constant that immutably reflects the software version.
Right, well, there's kind of a lot of that in the docs.
> Also, this:
I do believe you are correct, and that should be changed.
>   #version version;
Well, version is a "real" version number, it may just not be the desired one, or
one appropriate for correctly parsing a section of the SDL.
> further ;-)
The real trick here would be to somehow summarize WHY you'd want to specify an
earlier version, and list all of the directives that are "parsed / interpreted /
executed differently" depending on the version specified.
Ugh.
Date: 8 Feb 2018 12:08:15
Message: <5a7c83ff$1@news.povray.org>
Am 08.02.2018 um 11:52 schrieb Kenneth:
> #version version
> #version 3.71;
Exactly.
No. It literally means what it says.
You can also put it this way:
As of POV-Ray 3.7.1 or later, starting a scene file with anything other
than a `#version` statement is considered an outright error.
For backward compatibility, exceptions are made for scenes that do not
contain any `#version` directive in the main scene file at all, or where
all `#version` directives in the main scene file specify values lower
than 3.71.
For technical reasons, the error is raised at the first occurrence of a
`#version` directive with a value of 3.71 or higher in the main scene file.
>   #version version;
That would be a misinterpretation.
Date: 8 Feb 2018 12:32:35
Message: <5a7c89b3@news.povray.org>
Am 08.02.2018 um 16:19 schrieb Bald Eagle:
> build.
As a matter of fact, `version` /is/ a keyword, not a constant nor a
predefined variable.
In general, when using the keyword in an expression, it evaluates to the
most recent `#version` statement, `+MV` command-line setting or
`Version` INI file setting.
As an exception, if used in a `#version` statement right at the start of
the scene, it evaluates to the actual software version.
That's problematic, because older versions wouldn't recognize that keyword.
Even if it was implemented in such a way that `#ifdef` could test
whether the value is supported, you'd have to end up using something like:
#ifdef(software_version)
  #version software_version;
#else
  #version 3.7;
Note that such a construct would violate the "version statement first"
constraint, as the first statement would be an `#ifdef` instead.
With the special behaviour of `version` when used in the initial
`#version` statement, you can instead safely use:
    #version version;
    #declare software_version = version;
and go on from there.
Date: 8 Feb 2018 14:30:00
Message: <web.5a7ca42dc5234a59c437ac910@news.povray.org>
#version version;
// THEN:
#else
  #version 3.7;
The idea being that you can always access the actual software version, even if
you haven't "stored" the value in another variable.
It sounds to me like #version MyVersion "overwrites" this value, and it is then
lost.
I'm also writing this from the perspective that there will big changes when 4.0
gets written from the ground up, and I gathered that the whole
backwards-compatibility thing might be scrapped at that point.
Date: 9 Feb 2018 23:55:00
Message: <web.5a7e7a7dc5234a59a47873e10@news.povray.org>
> Also, this:
Not to nitpick, but I'm still having trouble 'parsing' that sentence ;-)
The way I see it is like this (and using a bit of Clipka's clarifications):
1) The #version directive is now a requirement (actually since v3.7.0, I think.)
That's clear.
2) Starting with v3.7.1 (alpha, beta, whatever), it's now considered an outright
error to leave out a #version directive in a scene. That's clear too-- I
think(?)
3) but: "... to use #version 3.71 [which is in green in the docs, meaning the
#version directive in a scene] in a a main scene file that does not start with a
#version directive", is the troublesome part. It kind of sounds 'circular' or
not quite logical. But I think there are two ways of reading it:
       A) An OLD scene file (one that didn't use a #version directive to begin
with) would produce "an outright error" if #version 3.7.1 were added to it AND
the scene were to be run in v3.7.1  (I'm actually still not sure if this
intepretation is correct.)
       B) Assuming that v3.7.1 (or later) *is* the currently running version,
and the scene itself does have #version 3.7.1 in it, then the scene already HAS
a #version directive-- definitely not a situation where the scene "does not
start with a #version directive"(!)  In this intepretation of the sentence, it
doesn't make much too much sense (and this is the way I generally read it,
unfortunately... without some effort to second-guess its meaning).
Date: 10 Feb 2018 03:23:16
Message: <5a7eabf4$1@news.povray.org>
I did a little test in version 3.7.1 as well as in UberPOV, with a scene
from 2000. With or without #version 3.71; (or #version unofficial patch
3.71;) as a first line, the scene renders with the following warning:
Parse warning: The scene finished parsing with a language version set to
3.1 or earlier. Full backward compatibility with scenes requiring
support for bugs in POV-Ray version 3.1 or earlier is not guaranteed.
Please use POV-Ray 3.5 or earlier if your scene depends on rendering
defects caused by these bugs.
Obviously, the resulting image has all kinds of defects but I wanted to
know if the scene would render at all. No fatal error, only a parse warning.
Date: 10 Feb 2018 05:52:57
Message: <5a7ecf09$1@news.povray.org>
Am 10.02.2018 um 05:52 schrieb Kenneth:
>> Also, this:
> That's clear.
In v3.7.0, this "requirement" is not actually enforced. In v3.7.0, you
always get a warning if the scene does not begin with a `#version`
statement, but that's it.
Inserting `#version 3.71` would mark the "old" scene file as no longer
"old", but rather overhauled to work with v3.7.1.
That totally depends on where the `#version 3.71` directive is placed.
Consider the following scene:
    // Just a comment
    global_settings { assumed_gamma 1.0 }
    #version 3.71;
That scene file would raise an error, because it claims to be a scene
designed for v3.7.1 but doesn't comply with the requirement that the
scene must start with a `#version` directive. The scene should be
changed as follows:
    // Just a comment
    #version 3.71;
The easiest way to enforce this would be to raise an error (rather than
warn, as was the case in v3.7.0) whenever the first statement is not a
`#version` directive. However, consider the following scene:
    // Just a comment
    #version 3.5;
This is apparently a scene designed for v3.5, where there was no
requirement for an initial `#version` statement, so for the sake of
backward compatibility we want just a warning, not an error.
Date: 10 Feb 2018 15:50:01
Message: <web.5a7f59cec5234a59a47873e10@news.povray.org>
> > already HAS a #version directive-- definitely not a situation where
> > the scene "does not start with a #version directive"(!)
{snip]
Ah, that would be 'interpretation C)'-- which I didn't think of. :-(  OK, it's
starting to make sense now. Thanks for the clarification. I can see that the
#version situation -- it's 'permutations' so to speak--is not easy or trifling
to explain in the docs.
