POV-Ray : Newsgroups : povray.general : Illegal escape sequence in string? Server Time
5 Nov 2026 01:17:31 EST (-0500)
  Illegal escape sequence in string? (Message 1 to 20 of 20)
Subject: Illegal escape sequence in string?
Date: 3 Dec 2017 20:57:10
Message: <5a24ab76$1@news.povray.org>
What in this code causes the parse error
"Illegal escape sequence in string"?
#declare MyGrassTexture = texture
 pigment { color rgb < 0.35, 0.65, 0.0 >*0.9 }
 normal { bumps 0.75 scale 0.015 }
 finish { phong 0.1 }
#declare MySandTexture = texture
 pigment { color rgb < 0.5098039,  0.3137255,  0.2156863 > }
 normal { granite 0.1 scale 10.0 }
height_field
 png "C:\Users\Sven Littkowski\Downloads\Images\POV-Ray Textures\SL -
Cloud Cities - Habitat - Heightfield.png" // the string is in one line
 smooth
 pigment { White }
 translate < -0.5, -0.5, -0.5 >
 scale < 38.0, 1.75, 38.0 >
 texture
  gradient y
  texture_map
   [ 0.000 MyGrassTexture ]
   [ 0.200 MySandTexture  ]
   [ 0.300 MyGrassTexture ]
   [ 0.400 MySandTexture  ]
   [ 0.500 MyGrassTexture ]
   [ 1.000 MySandTexture  ]
 translate < 0.0, -1.1999999999, 0.0 >
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: Illegal escape sequence in string?
Date: 3 Dec 2017 21:25:01
Message: <web.5a24b1ead18938585cafe28e0@news.povray.org>
use forward slashes for filenames.
png "C:/Users/Sven Littkowski/Downloads/Images/POV-Ray Textures/SL - Cloud
I'd also strongly advise using more parser-friendly filenames - the dashes and
spaces seem a bit iffy to me.
#usingContiguousCamelCaseFilenamesIsPreferable
Date: 4 Dec 2017 00:18:09
Message: <5a24da91$1@news.povray.org>
s and
Yes, your suggestion that slashes must be forward did actually solve my
little problem. Isn't it strange - I use POV-Ray since around 1989 or
1992, but nevertimes really much, and so I have still today all these
little problems and misunderstandings. After 28 years...
FILE NAMES
They all actually follow certain rules that I use all over my computers.
I make a difference between "connected-word" and "different - items".
But that wasn't the problem, fortunately. :-)
Big thanks!
PS: I am posting another problem in a new thread: how to create a
cylinder where one of the two round sides has the shape of a height_field.
http://www.avg.com
Date: 4 Dec 2017 01:34:05
Message: <5a24ec5d$1@news.povray.org>
Am 04.12.2017 um 06:17 schrieb Sven Littkowski:
As a matter of fact, POV-Ray for Windows can deal with both notations --
backslashes or forward slashes -- but the backslash happens to have a
special meaning in POV-Ray string literals, in that it changes the
meaning of the next character(s); for example:
    \n    new line
    \t    tab character
    \"    double quote character
    \\    backslash character
This is referred to as "escape sequences". There are more, but these are
the ones I recall off the top of my head.
The reason you never encountered this before might be because in version
v3.6 and earlier there were /some/ (poorly documented) cases where the
backslash character wasn't given any special treatment (except for
constituting a path separator character in Windows), and yours would
have been one of them.
Date: 4 Dec 2017 03:30:01
Message: <web.5a250736d189385889df8d30@news.povray.org>
But it's interesing that Windows itself uses back slashes for file locations.
Point taken, though.
I'm guilty of still using back slashes in my pov.ini file, and in quickres.ini.
I guess I should change that. But if I change the following to forward
slashes...
Output_File_Name="C:\Users\Computer\Documents\Kens POV-Ray rendered IMAGES\"
.... will Windows itself still recognize that as a valid location? I've never
tried it (due to the 'fear factor', ha.)
Date: 4 Dec 2017 03:30:31
Message: <5a2507a7$1@news.povray.org>
Spaces in file names are evil.
A filename is a single word.
I would think especially a native German speaker would gravitate more
towards Bezirksschornsteinfegermeister than "district chimney sweep
master". ;)
Date: 4 Dec 2017 05:05:01
Message: <web.5a251d42d189385889df8d30@news.povray.org>
Hmm, wasn't it Albert Einstein in 1905 who thought up the idea of using 'bottom
slashes' instead of spaces?? ;-P  (Sorry, I don't know what they are called)...
using_Contiguous_Camel_Case_Filenames_Is_Preferable
I still do that-- uh, from time to time...
Now, if I only knew what 'Camel Case filename' means... :-?
> master". ;)
Yes, German does seem to be more compact (???)
Date: 4 Dec 2017 06:14:49
Message: <5a252e29$1@news.povray.org>
FYI Underscore.
Regards
Date: 4 Dec 2017 06:25:00
Message: <web.5a253075d18938585cafe28e0@news.povray.org>
Underscores.
https://en.wikipedia.org/wiki/Camel_case
It is, however the screen display of ASCII(32) (IIRC) has no special meaning
unless we attribute it one.   So from a purely technical perspective, when the
filename is _inside quotes_ then it's kind of easy to see what's going on.
However, the obvious problem, and why I try to avoid spaces and underscores, is
that it's hard to deal with leading, trailing, and multiples characters like
that.
> > master". ;)
lol.
Date: 4 Dec 2017 10:10:28
Message: <5a256564$1@news.povray.org>
Am 04.12.2017 um 09:28 schrieb Kenneth:
Actually, Windows itself is fine with both forward and back slashes.
(There are a few minor issues with certain command shell (cmd.exe)
commands, but IIRC most of those go away if the file name is placed in
quotes.)
Date: 4 Dec 2017 10:12:35
Message: <5a2565e3$1@news.povray.org>
Am 04.12.2017 um 09:30 schrieb dick balaska:
>> dashes and
No, not at all.
What's evil is Unix shell script writers who forget that spaces are
perfectly legal characters in file names.
Date: 4 Dec 2017 12:08:43
Message: <5a25811b@news.povray.org>
> quotes.)
There will be isues if the / is preceded by a space. In that case, it's
assumed to be a switch/option indicator.
Date: 4 Dec 2017 15:05:00
Message: <web.5a25aa48d189385889df8d30@news.povray.org>
> > ...the idea of using 'bottom slashes' instead of spaces?? ;-P  (Sorry, I
> FYI Underscore.
 UNDERSCORE. Duh. I did hear that word once...or twice...
Bald Eagle wrote...
So that kind of compound-word construct actually has a name(!) And apparently
first used circa 1990-1995. By computer programmers (?)
Alas, the continual destruction of the English language proceeds swiftly :-O
SoonWeWillAllBeSpeakingAndWritingThatWay.
Date: 4 Dec 2017 15:41:04
Message: <5a25b2e0$1@news.povray.org>
My oh my. Guess how we in the UK feel about the Americanisation of
British English? At least the older ones of us.
Thou canst nay stop thy weans ganging thair ain way. ;-)
Regards
Date: 4 Dec 2017 15:55:01
Message: <web.5a25b5efd1893858c437ac910@news.povray.org>
#redefiningEverything
Date: 4 Dec 2017 16:00:00
Message: <web.5a25b623d1893858c437ac910@news.povray.org>
To gaol with ye, scalliwag.
Date: 4 Dec 2017 16:03:34
Message: <5a25b826$1@news.povray.org>
#Pause (10) ;
#loop ;
Regards
Date: 4 Dec 2017 16:08:00
Message: <5a25b930$1@news.povray.org>
Other than the spelling of jail. That is how a lot of people in the UK
speak. Mostly Northerners, I admit.
Regards
Date: 4 Dec 2017 16:35:01
Message: <web.5a25bf41d1893858c437ac910@news.povray.org>
Well, I d'know what n'good ye all are up to in Northern UK, but if I were ye,
I'd stop before someun hails a copper to collar yer unruly ass.
D'sturbin' the peace and smokin' the Devil's own weed, I'll bet ye.
No good end'll come to ye, Stephen, that I'll tell ye.
#lemmeBastardizeTheQueensTongueAndGaelnglishSummoor    :P
Date: 5 Dec 2017 05:10:08
Message: <5a267080$1@news.povray.org>
Ah! English learned at the knee of Dick Van Dyke. :-P
Regards
