POV-Ray : Newsgroups : povray.general : How to? light_source shining through a wall Server Time
5 Nov 2026 01:17:08 EST (-0500)
  How to? light_source shining through a wall (Message 1 to 30 of 30)
Subject: How to? light_source shining through a wall
Date: 8 Nov 2017 07:36:11
Message: <5a02fa3b$1@news.povray.org>
Consider the following setup:
- a camera
- an object in front of the camera
- a solid/non-transparant wall behind the object
- a light_source behind the wall
Now, for some arcane reason, I want the light_source to shine on the
object while the wall remains visible to the camera.
I first thought of a light_group {} with object and light_source in it,
but the wall still blocks the light.
Any smart idea? I am sure it should be possible and I have the nagging
feeling that it has been done before.
Subject: Re: How to? light_source shining through a wall
Date: 8 Nov 2017 08:21:13
Message: <5a0304c9$1@news.povray.org>
Am 08.11.2017 um 13:36 schrieb Thomas de Groot:
> - a camera
Did you try no_<https://youtu.be/_euDhMDDRq4>?
Date: 8 Nov 2017 08:27:39
Message: <5a03064b$1@news.povray.org>
> - a camera
Have you tried the no_shadow object qualifier on your wall object?
If no_shadow cannot be used for some reason, perhaps the light_source's
'projected_through' object feature might do the trick? There the object
could be a say thin box of sized how ever you want relative to the wall
and toward the object(1) from the wall. To this object you'd add the
usual no_image, no_shadow, no_reflection qualifiers as needed.
Bill P.
(1) - An idea I've had on my to to-try list for a long while, is to
variously light all the rooms in a large building - or a bunch of street
lights say - with a single light source using the projected_through
feature with a multi-shape object providing for 'magic light wormholes'
into each room/location. Think it would work to the first order. Unsure
it would result in a faster render - and perhaps the look of the lights
would be too limited...
Date: 8 Nov 2017 08:28:20
Message: <5a030674$1@news.povray.org>
Date: 8 Nov 2017 15:28:24
Message: <5a0368e8$1@news.povray.org>
>> - a camera
>> it, but the wall still blocks the light.
> Bill P.
The object in a projected_through is NEVER visible. It never cast
shadow, is never seen in reflections nor refractions, and don't affect
radiosity. Ity's just a kind or portail through the light comes.
Date: 9 Nov 2017 00:55:00
Message: <web.5a03ecdbfad04db289df8d30@news.povray.org>
You almost had it: Light_group of object and light_source, ALONG WITH no_shadow
for the wall.
Here's a small test scene, with two cameras to test that it works, and an extra
front-light to show that the sphere object still casts its own shadow on the
wall.
#version 3.71;
global_settings{assumed_gamma 1.0 max_trace_level 5}
  perspective
  location  <.5, .5, -5>
  look_at   <.5, .5,  0>
  angle 67
  perspective
  location  <30, 30, -5>
  look_at   <.5, .5,  0>
  angle 80
// wall behind object
box{0,1
no_shadow
translate <-.5,-.5,0>
scale 30*<1,1,.1>
pigment{rgb .7}
translate 1.5*z
light_group{
light_source {
  0*x
  color rgb <1,1,1>
  looks_like{sphere{0,1 pigment{srgb <1,.5,0>}finish{emission 1}}}
  translate <-15, 15, 20>
// object
sphere{0,1
pigment{rgb <0,1,0>}finish{ambient .05 emission 0 diffuse .8}
// extra DIRECTION POINTER between light and object
cylinder{<-15, 15, 20>,<0,0,0> .1
no_shadow
pigment{rgb <0,.5,1>}finish{emission 1}
// extra front-light for object and wall
light_source {
  0*x
  color rgb .4
  translate <20, 5, -20>
Date: 9 Nov 2017 01:10:00
Message: <web.5a03f0defad04db289df8d30@news.povray.org>
That video is blocked in the U.S. :-(  It probably contains confidential State
Secrets...
Date: 9 Nov 2017 01:45:00
Message: <web.5a03f877fad04db289df8d30@news.povray.org>
> no_shadow for the wall.
Hmm, for your real scene, I think there is still a problem: How to get your wall
to cast its own shadows from other lights in the scene. With my test set-up, it
doesn't do that, as the wall is necessarily made no_shadow in order to work
correctly :-/
I tried adding an identical NO_IMAGE wall into the light_group (without the
no_shadow tag), but that doesn't work-- this extra wall again blocks the light
to the sphere object.
My past use of this set-up never needed the 'wall object' to cast its own shadow
(I was shining a light up through a no_shadow height_field.) I wish I could
suggest a workable solution...
Date: 9 Nov 2017 03:01:17
Message: <5a040b4d$1@news.povray.org>
I did. Got a bit bruised... :-)
Good music by the way, but I had expected more from the POV-Ray scene
render and the use of Poser figures. I missed the chequered plane...
Date: 9 Nov 2017 03:20:16
Message: <5a040fc0$1@news.povray.org>
Incredible! Just adding no_shadow does the trick indeed and exactly as I
need it, without the light_group even. I had not thought of this at all
as the name implies that the object does not cast shadows, not that it
also becomes transparent to the light. This is not implied in the docs.
Thanks a lot!
> Bill P.
That would be a very interesting thing to do indeed.
Date: 9 Nov 2017 03:23:17
Message: <5a041075$1@news.povray.org>
> correctly :-/
It doesn't matter. I am still going to study your little test scene as
it provides some interesting possibilities. Thanks indeed for your
effort though.
Date: 9 Nov 2017 07:37:50
Message: <5a044c1e$1@news.povray.org>
Am 09.11.2017 um 07:08 schrieb Kenneth:
> Secrets...
British State secrets, if anything.
Nothing spectacular to see though. Just substitute any audio copy of
Mike Oldfield's "shadow on the wall" ;)
Date: 9 Nov 2017 07:46:45
Message: <5a044e35$1@news.povray.org>
Am 09.11.2017 um 09:20 schrieb Thomas de Groot:
Uh... and what exactly would "not cast shadows" do, if not make the
object "transparent to the light [directly from light sources]"?
Date: 9 Nov 2017 07:51:38
Message: <5a044f5a@news.povray.org>
To tell the truth, it took me some while to get the pun... ;-)
(I am slow)
>> Secrets...
Maybe those ladies in black leather are considered shocking for US
viewers? ;-)
Date: 9 Nov 2017 07:53:48
Message: <5a044fdc$1@news.povray.org>
Well, my thoughts did not go into that direction to tell the truth. Just
no shadows, without implications.
Date: 9 Nov 2017 09:45:01
Message: <web.5a0468dafad04db2c437ac910@news.povray.org>
I wasn't gonna say it....   :|
Date: 9 Nov 2017 11:45:01
Message: <web.5a0484dafad04db289df8d30@news.povray.org>
> viewers? ;-)
Ladies in black leather, eh? Well, maybe *that* explains the actual YouTube
message I'm seeing, "This video is blocked in your area"  My area is the city of
Virginia Beach, in the U.S. state of Virginia-- which just happens to be the
home of televangelist Pat Robertson's sprawling religious/conservative empire.
(BTW, it's HUGE and influential here, like an octopus with 100 tentacles.)
Hmm, time to protest!! "I demand ladies in black leather!".
Date: 9 Nov 2017 13:02:30
Message: <5a049836$1@news.povray.org>
You and me too. ;-)
Regards
Date: 9 Nov 2017 18:48:12
Message: <5a04e93c@news.povray.org>
> correctly :-/
Any object in a light_group will always cast shadows for any light in
the scene. The light in the light_group can also get shadowed by any
object outside the light_group.
The light(s) in a light_group can only illuminate objects that are part
of the same light_group.
The objects of the group don't receive illumination from lights outside
of the group unless you add "global_lights on" to the group.
Date: 10 Nov 2017 02:05:50
Message: <5a054fce$1@news.povray.org>
> viewers? ;-)
If they were being shot, or hacked up, that'd be ok.  But just standing
there looking good? My sensitive eyes!
dik
Date: 10 Nov 2017 02:37:16
Message: <5a05572c@news.povray.org>
> You and me too. ;-)
I agree. This is pure gender discrimination!  ;-)
Date: 10 Nov 2017 02:39:34
Message: <5a0557b6$1@news.povray.org>
Making my brain cells work a little harder than they normally do, I came
to the same conclusion ;-)
Date: 10 Nov 2017 07:45:01
Message: <web.5a059ef5fad04db2c437ac910@news.povray.org>
Maybe it's just me, but I can read that in several ways.
"Maybe if that were a B-rated hack and slash video, I'd be into it - but just
plain old hot chicks in leather?"
:D
Date: 10 Nov 2017 08:25:00
Message: <web.5a05a774fad04db289df8d30@news.povray.org>
I'm actually with Thomas on this one-- and not just to be argumentative ;-)
In its strictest sense, no_shadow implies only what it says (IMO), because the
object (the wall) is still *visually* OPAGUE. The fact that no_shadow also
allows light to pass *through* the wall-- as if it's invisible to the light--
seems to me to be a 'secondary effect', not necessarily implied by the meaning
of no_shadow-- and might well be an unexpected effect for new users.
When I started my make my test code example, *I* actually didn't realize (or
remember) the 'dual nature' of that keyword, and didn't even try adding it to
the wall as the first step(!). Instead, I went off on a tangent, coming up with
the (unnecessary!) light_group idea first, to figure out a way to get the light
to strike my sphere object through the 'opague' wall! :-0
The documentation says "You may specify the no_shadow keyword in an object to
make that object cast no shadow. This is useful for special effects and for
creating the illusion that a light source actually is visible"-- then it refers
to the looks_light object in a light. The latter part of that sentence might
actually makes little sense to a new user, unless he/she is already familiar
with what a looks_like object is. (But no_shadow is no longer required there
anyway, as a looks_like object already has an implied no_shadow keyword.)
Since both Thomas and I both failed to initially grasp no_shadow's full meaning,
I imagine there may be others as well...
My two cents :-)
Date: 10 Nov 2017 09:30:01
Message: <web.5a05b6ccfad04db289df8d30@news.povray.org>
As it turns out, my light_group wasn't needed anyway!
But I was also 'over-thinking' Thomas's original example-- guessing that his
wall was actually part of a much bigger scene, requiring the wall to *cast*
shadows onto other objects (but not onto his single specific object.)
Years ago, I made a REALLY complex scene like that, requiring no_shadow for some
of the objects, and had to figure out a way to get shadows to fall onto the rest
of the scene. If I recall, I had to use multiple (or even nested) light_groups.
In any case, my test code here probably confused things. :-(
Date: 10 Nov 2017 16:35:33
Message: <5a061ba5$1@news.povray.org>
Good point. Where a projected_through object is not otherwise used in
the scene, it's only a light portal.
Bill P.
Date: 22 Nov 2017 18:40:00
Message: <web.5a1608a0fad04db289df8d30@news.povray.org>
> In its strictest sense, no_shadow implies only what it says (IMO), [blah,blah]
Well, a lightbulb finally went off in my brain, so please forget my silly
argument.
If the wall object (with no_shadow) casts no shadow from a light, then what is
supposed to fill that no-longer-existing 'shadow area'? The light, of course.
Otherwise, there would be an illogical 'void' in that area, filled with...
what??  ;-)
Duh. It took me 'only' ten days to realize this... :-[
Date: 23 Nov 2017 02:53:46
Message: <5a167e8a$1@news.povray.org>
> argument.
> what??  ;-)
LOL
I am still pondering the issue; higher dimension bypasses. :-)
Date: 23 Nov 2017 03:57:29
Message: <5a168d79$1@news.povray.org>
That's the way it is looking to me. ;-)
Regards
Date: 23 Nov 2017 08:40:00
Message: <web.5a16cebffad04db25cafe28e0@news.povray.org>
Well of course.
It's a bypass!  Gotta build bypasses...
https://www.youtube.com/watch?v=HNmIQX_ImgM
