POV-Ray : Newsgroups : povray.general : trace question Server Time
10 Oct 2026 08:01:38 EDT (-0400)
  trace question (Message 1 to 15 of 15)
Subject: trace question
Date: 10 Sep 2017 09:13:19
Message: <59b53a6f$1@news.povray.org>
If I trace an object. How can I get the colour of the intersection of
the ray and object. As far as I can see trace() only returns the normal.
Regards
Subject: Re: trace question
Date: 10 Sep 2017 09:27:07
Message: <59b53dab$1@news.povray.org>
Am 10.09.2017 um 15:13 schrieb Stephen:
You'll need to know the pigment of the object, and invoke `eval_pigment`
on the intersection point you get...
... and hope that the pigment isn't UV-mapped, nor uses a special
pattern like slope or aoi.
Date: 10 Sep 2017 10:01:16
Message: <59b545ac$1@news.povray.org>
Thanks, I had a blank in my memory.
Hope is not involved because there is a good chance I would want to do
that. Is it at all possible?
Regards
Date: 10 Sep 2017 11:03:50
Message: <59b55456$1@news.povray.org>
Am 10.09.2017 um 16:01 schrieb Stephen:
No; not with the current versions of POV-Ray. The `trace` function would
have to be extended to report the UV coordinate of the intersection, so
that you could then feed it into `eval_pigment` instead of the 3D
coordinate.
Date: 10 Sep 2017 11:26:00
Message: <59b55988$1@news.povray.org>
> coordinate.
Again, thanks.
In that case for UV mapped models I'll continue to use the slicing
method for creating df3s for meshes.
Regards
Date: 10 Sep 2017 15:22:09
Message: <59b590e1$1@news.povray.org>
hi,
> coordinate.
do I understand this correctly?  if I trace some object with a regular
pigment it will work, but the trace will fail if the object's
pigment/colour is "not simple"?  seems .. strange.
regards, jr.
Date: 10 Sep 2017 15:57:35
Message: <59b5992f$1@news.povray.org>
Am 10.09.2017 um 21:22 schrieb jr:
> hi,
>> coordinate.
No, the `trace` function works perfectly fine for what it was designed
for: It gives you the point in 3D space where a given ray intersects a
given geometric object. In and of itself, it has nothing to do with
pigments whatsoever.
Likewise, the `eval_pigment` function works perfectly fine for what it
was designed for: It gives you the colour of a given pigment for a given
point in 3D space. In and of itself, it has nothing to do with geometry
whatsoever.
And that's where the problem with UV-mapped textures arises: Since
`trace` knows nothing about textures, and `eval_pigment` knows nothing
about geometry, the two can only be combined for good effect if there is
a direct mapping between geometry and pigment via 3D XYZ space. But with
UV-mapping that's not the case, and hence the /combo/ of the two
functions breaks down there.
Date: 10 Sep 2017 17:28:29
Message: <59b5ae7d$1@news.povray.org>
hi,
> whatsoever.
thanks.
regards, jr.
Date: 10 Sep 2017 17:55:01
Message: <web.59b5b3b6c9840c1a5cafe28e0@news.povray.org>
So, the color of a surface on a uv-mapped object is not directly measurable by
the eval_pigment() function? [ ! :O ]
I would never have guessed that.
It must then use a completely different algorithm than the ray-object
intersection used to generate the final scene.
Can you:
1. use trace() to get the point and the normal
2. define a pigment constructed in the plane intersecting that point with the
same normal
( I likely have no idea what I'm talking about here: I'm just confabulating the
possibility that some slice of a function-object-pattern thing might be a
workaround... )
3. then do an eval_pigment() on the plane?
Date: 11 Sep 2017 03:11:38
Message: <59b6372a$1@news.povray.org>
Follow up question.
How would you use eval_pigment if you were tracing a CSG?
Is it possible?
Regards
Date: 11 Sep 2017 08:38:50
Message: <59b683da$1@news.povray.org>
We do now have a user defined by functions camera. If you can work out
how to map each 'trace' to an equivalent user defined camera ray, it
should be you can create an image - sort of a new version of the uv
mapped texture as 'seen' mapped onto the object. This rendered image
could then be queried at the appropriate x,y positions for each trace to
give you the color values.
Likely want to create that image with a modified finish of ambient 1.0
or emission 1.0 - and diffuse 0.0 for the object's texture.
I've had the reverse of what you are attempting floating around in my
head for creating uv mapped images via texture baking environments for
all POV-Ray's uv mapped objects. We have the uv mapping for a
significant number of primitives, but for most, no easy way to create uv
image maps for them. In other words, as part of the uv mapping
capability for each primitive, might we be able to provide uv mapping
functions which could be use to create inward or outward facing user
defined functional cameras more or less in the 'shape' of the primitive
object. Kind of a mesh camera capability. Every uv mapped primitive
could also be a primitive shaped camera by using the uv appropriate
functions and matching shape parameters. ;-)
Using the mesh camera to get a rendered image for the traced colors is I
think another possibility. Create a triangle in the 'camera' mesh for
each traced ray.
Bill P.
Date: 11 Sep 2017 09:05:01
Message: <web.59b68980c9840c1a64d483f00@news.povray.org>
> each traced ray.
> Bill P.
More food for thought. I am going to die of glutony. ;-)
I've been meaning to look at the mesh camera for ages. I like the idea of using
it as a UV mapper.
But with my luck at the moment...
I'm having to post this from the web interface as TBird did not load the text.
Computers!
Date: 11 Sep 2017 09:28:51
Message: <59b68f93@news.povray.org>
Am 10.09.2017 um 23:50 schrieb Bald Eagle:
Actually no, the `trace` function is essentially the same as the one
used in the render. And the `eval_pigment` function is also essentially
the same as the one used in the render.
But the `trace`-like function used in the render not only computes the
3D XYZ location and surface normal, but also the UV coordinate as yet
another output value; and the render alghorithm then decides whether to
call the `eval_pigment`-like function with <X,Y,Z> as the location
parameter, or whether to use <U,V,0> instead.
> Can you:
Yes, absolutely.
> same normal
> workaround... )
You're right, that sounds a bit... confabulated. ;)
Whatever your brain is concocting there, it can't replace computing the
UV coordinate of the intersection.
You cannot do `eval_pigment` on shapes. You can only call it on pigments.
Date: 11 Sep 2017 09:38:38
Message: <59b691de$1@news.povray.org>
Am 11.09.2017 um 09:11 schrieb Stephen:
> Follow up question.
> Is it possible?
Presuming the CSG elements have different textures... no.
So with that in mind, probably the easiest (from a user perspective) way
to solve this whole group of issues would be to provide a function that
not only computes a ray-object intersection, but also does a proper
pigment lookup.
Which has its own issues though; most notably, texture patterns and
layered textures would be a b*tch to deal with, as in the actual render
algorithm they're not handled at the pigment level, but at the "what
does that texture actually look like as seen from this angle" level
(finish level if you will, with highlights and reflections and all).
Date: 11 Sep 2017 10:11:19
Message: <59b69987$1@news.povray.org>
>> Follow up question.
>> Is it possible?
> pigment lookup.
So that means it will be ready after PovRay Ver 4.0 and Moray's
re-write. ;-)
Thanks for looking into it Clipka.
Regards
