Subject: QUESTION: Ho-Res Martian 3D Surface Files: Where?
Date: 27 Aug 2017 13:23:38
Message: <59a3001a$1@news.povray.org>
as many know, i want to work on a number of Martian renders. I
downloaded from the NASA 3D Resources website a number of Martian 3D
surface files, but sadly, they all are in a very low resolution, lots of
triangles and corners.
At the same time, I am seeing on the Internet some renders that show
some very impressively detailed martian landscapes, among them my Valles
Marineris. But these renders were done long time ago, around 2004.
Does anyone here know, where to get POV-Ray usable hi-res Mars 3D
surface files? I do not have the ability to convert Hi-Rise images.
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: QUESTION: Ho-Res Martian 3D Surface Files: Where?
Date: 28 Aug 2017 02:57:00
Message: <59a3bebc$1@news.povray.org>
On 27-8-2017 19:23, Sven Littkowski wrote:
> Hi,
I suppose these lower res meshes are posted by NASA in order to reduce
the 'weight' of the files.
What you can do with your own meshes is to subdivide them in Poseray.
However, you may be in trouble rapidly as the file becomes too large for
OpenGL to redraw the mesh, I found out. I don't know if the subdivided
mesh can still be saved (I didn't try). Somebody with a better suggestion?
Date: 28 Aug 2017 03:27:33
Message: <59a3c5e5$1@news.povray.org>
>> Hi,
I think it is the other way round. The High Res meshes are made
available as a courtesy. You can't expect NASA to give it a high
priority when no one in their right mind would try to build a planet in
High Res. What would the memory requirements be anyway?
No more than two subdivisions, I would say. Can PoseRay displace faces
along their normal? (I don't have it installed atm.)
Regards
Date: 28 Aug 2017 07:06:06
Message: <59a3f91e@news.povray.org>
>>> Hi,
I am lost now. The Nasa meshes we downloaded from NASA (like Valles
Marineris) are they considered hi- or lo-res? Additionally, I think that
mesh landscapes always show a resolution problem; so do height_fields
too of course, and both when used for a close, detailed, view. I don't
think there really is a solution for that, except using the
mesh/heightfield for background or mid-range view, and a separate,
local, one for a detailed foreground. That is what I do in those cases.
>> for OpenGL to redraw the mesh, I found out. I don't know if the
>> subdivided mesh can still be saved (I didn't try). Somebody with a
>> better suggestion?
You can do displacement mapping, if that is what you mean, but that is
tricky. I don't know how good MeshLab is for these kind of
manipulations, by the way. Might be worth the try.
Date: 28 Aug 2017 07:31:36
Message: <59a3ff18$1@news.povray.org>
>>>> Hi,
>>> reduce the 'weight' of the files.
>> in High Res. What would the memory requirements be anyway?
From what I can remember. Only a few of the Mars sites have a high Res
mesh.
Unless Sven is talking about another site.
The man uses mountain ranges as props. Respect. :-)
> tricky.
It is and it is.
I'd like to test but I can't.
Regards
Date: 28 Aug 2017 10:47:22
Message: <59a42cfa$1@news.povray.org>
>>>>> Hi,
> mesh.
>> Additionally, I think that mesh landscapes always show a resolution
>> problem; so do height_fields too of course, and both when used for a
>> close, detailed, view. I don't think there really is a solution for
>> that, except using the mesh/heightfield for background or mid-range
>> view, and a separate, local, one for a detailed foreground. That is
>>> faces along their normal? (I don't have it installed atm.)
>> tricky.
> It is and it is.
>> I don't know how good MeshLab is for these kind of manipulations, by
Someone mentioned those famous HiRise graphic files that somehow can be
converted to hi-res meshes. But I don't know, how, nor do I have the
right software on my Windows system. Can anyone assist?
http://www.avg.com
Date: 29 Aug 2017 02:36:29
Message: <59a50b6d$1@news.povray.org>
Can you redirect us to that message? I don't remember this.
Date: 30 Aug 2017 09:35:25
Message: <59a6bf1d$1@news.povray.org>
It was not this thread, but inside one of my other threads, not longer
than 3 months ago. The problem is, some threads got more than 60
follow-ups. Lots to search, to find and redirect. Will try, but not
promise. :-)
http://www.avg.com
Date: 30 Aug 2017 09:49:49
Message: <59a6c27d$1@news.povray.org>
On 27.08.2017 13:23, Sven Littkowski wrote:
> Hi,
> http://www.avg.com
Is there a way, to convert Celestia's CMOD terrain files into OBJ or any
other 3D file format? Thanks.
Date: 30 Aug 2017 10:12:31
Message: <59a6c7cf$1@news.povray.org>
Mr. Google says try http://3doc.i3dconverter.com/index.html
Regards
Date: 25 Oct 2017 19:32:13
Message: <59f11efd$1@news.povray.org>
Am 27.08.2017 um 19:23 schrieb Sven Littkowski:
I'm pretty sure you mean Li-Res files. At least that's what Dr. Freud
said. I'm pretty sure he said that. Or he thought that. I'm pretty sure.
SCNR
Gregor
