POV-Ray : Newsgroups : povray.general : QUESTION: STL to POV (INC)? Server Time
5 Nov 2026 01:17:33 EST (-0500)
  QUESTION: STL to POV (INC)? (Message 1 to 50 of 59)
Goto Latest 50 Messages Next 9 Messages >>>
Subject: QUESTION: STL to POV (INC)?
Date: 27 Jul 2017 03:46:09
Message: <59799a41$1@news.povray.org>
Hi, there is the NASA 3D Resources website, offering various vehicles
and planetary landscapes as 3D models, formats OBJ and STL.
1. Is there any OBJ to POV converter?
2. I tried to convert the Martian and Lunar landscapes (STLs) to the
POV-Ray format, using STL2POV:
command line: "stl2pov -s InputFile.stl >OutputFile.inc".
It reads STL files, and creates a POV-Ray mesh and saves that file as
INC. But the result is horrible: instead of a block with a planetary
surface, I get a block on the one side and a thin surface on the other
side (90° angle!), and there are many holes in that landscape. Is there
any better way to convert STLs into POV? I need a massive block with the
landscape above, as I want to "dig tunnels" into it, too.
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: QUESTION: STL to POV (INC)?
Date: 27 Jul 2017 04:09:29
Message: <59799fb9$1@news.povray.org>
> http://www.avg.com
For obj to pov, use Poseray: https://sites.google.com/view/poseray
Which is - by far - the best converter.
Date: 27 Jul 2017 05:00:01
Message: <web.5979ab4ddb2ef7709c5d6c810@news.povray.org>
> Thomas
And MeshLab  http://www.meshlab.net/  seems to be okay for the STL to OBJ
conversion.
I don't use mesh files much at all but I checked Tharsis mountains from the NASA
3D models site and could use the resulting mesh (after PoseRay POV/INC export)
in CSG difference okay from what I was able to see.
Date: 27 Jul 2017 05:39:42
Message: <5979b4de$1@news.povray.org>
Am 27.07.2017 um 08:45 schrieb Sven Littkowski:
The mesh files provided by NASA are certainly just the surface, and
since it's not the entire planet but just a tile (or so I guess),
turning it into a solid 3D volume isn't trivial. You'll need to proceed
as follows:
(1) Generate the mesh INC file.
At this point, all you have is a mesh patch object, i.e. a genuinely
non-solid sheet.
(2) To the mesh, add an `inside_vector` specifying whatever direction is
supposed to be "up" with respect to the tile.
At this point, you have a chimera between a solid and a patch: It now
has a well-defined inside (namely every point that is "below" the tile,
i.e. the tile extruded "downwards" toward infinity). The surface
definition is still patchy though (pun intended), so right now you won't
see any effect, because POV-Ray can only render surfaces, not volumes.
Note however that this chimera is already good enough to start "digging"
using CSG.
(3) Intersect the mesh with another object, e.g. a box, defining the
dimensions of the "massive block" you want.
Make sure that for any point on the box that is supposed to be "below"
the landscape, if you trace a line in the direction given by the
`inside_vector`, it should properly intersect the mesh (note that
grazing it might not be enough).
This step will add surfaces to the "sides" and the "bottom" of your
block of landscape, so that they can be seen as well. If that's not a
thing you need, this third step is entirely optional.
Date: 27 Jul 2017 06:01:10
Message: <5979b9e6@news.povray.org>
1. My search engine is not your search engine, so please provide
accurate links for accurate help.
2. STL will always be a mesh (collection of triangles), stl that can be
drilled is an illusion.
And how are you going to dig your tunnels ?
There is no default orientation of stl model. And no scale either.
I found  moon_near_side.stl & moon_far_side.stl, they are funny: they
use negative part of two axes (i.e. the origin is in the middle of the
square, at the bottom of the landscape), so be careful when sending to a
printer.
they use the traditional right handed for landscape (z is up).
They seems to be closed, meshlab does not show any obvious holes. Which
means you might be able to make tunnel via CSG difference/intersection,
if your tunnel are solid shapes.
They are optimized: the bottom is made of large triangles (5x6 squares),
I can use them directly in hg-povray via stl_load, but that's another story.
Download 'a.png' (470 KB)
Preview of image 'a.png'
Date: 27 Jul 2017 06:01:58
Message: <5979ba16$1@news.povray.org>
It is too. IME
>> Thomas
> conversion.
Blender does the conversion as well.
Thinking about it. If you use the PovRay exporter it must convert it to
Mesh2 internally.
Regards
Date: 27 Jul 2017 06:56:22
Message: <5979c6d6$2@news.povray.org>
i use blender as well then export as obj ... poseray to mesh2
Date: 27 Jul 2017 06:56:56
Message: <5979c6f8@news.povray.org>
> Mesh2 internally.
I just checked and Blender exports a Mesh2 section in its Pov file.
BTW the STL was imported as a solid section with no holes.
Regards
Date: 27 Jul 2017 07:55:00
Message: <web.5979d3f7db2ef770c437ac910@news.povray.org>
Perhaps if the mesh is viewed with an orthographic camera, with even ambient
lighting, and an even gradient pigment, then the resulting render can be used as
a heightfield.
Just exploring other options.  :)
Date: 27 Jul 2017 08:33:04
Message: <5979dd80$1@news.povray.org>
> a heightfield.
The mesh I downloaded, from that site, enclosed a volume with no holes.
But even if it were only a collection of triangles. It is trivial in
blender to join then into a surface and extrude that into a volume. [Did
I actually say that something was trivial in Blender? ^ ^ ]
It is hard not to. :)
Regards
Date: 27 Jul 2017 14:33:39
Message: <597a3203$1@news.povray.org>
> http://www.avg.com
Wow! Thank you all - so many new ideas and options!
My problem is, that I am not experienced at all with Poseray and Blender
and MeshLab, I have to find out with them, how to do these tasks. If it
is just importing and exporting, well, that is easy.
Clipka made me getting a first glimpse of many things I could do with
POV-Ray that I did not even knew about at all. Will have to explore,
might need more instructions on all these procedures that he outlined.
Actually, the NASA files seem to be massive blocks just with that
planetary surface, but I am understanding now that they are just hollow
triangle meshes. I wished,
POV-Ray would offer an easier way to replace one of the surfaces of a
box with a heightfield or mesh structure. His way is complicated - at
least for me. never done anything like that before. But then again,
mankind never explored space and other celestial bodies before, and now
we do. So I have to learn Clipka's procedures, too.
Stephen mentions a way to make a mesh solid in Blender. Here, too, I
need further instructions for my very first time trying to do such.
Compliment to everyone: we have a great spirit in this group, and a lot
of expertise! Thank you all!
Date: 27 Jul 2017 15:07:59
Message: <597a3a0f$1@news.povray.org>
Am 27.07.2017 um 19:33 schrieb Sven Littkowski:
With NASA's meshes being genuine boxes, things get a good deal easier:
All you need to do is add `inside_vector WHATEVER` to the mesh, with
WHATEVER being an arbitrary vector.
Date: 15 Aug 2017 04:35:01
Message: <5992b235$1@news.povray.org>
> as follows:
> non-solid sheet.
> using CSG.
Hi Clipka,
I am trying to follow up now your advise. I opened Blender 2.78, and
imported the STL file (MarsVallesMarineris2). But I never worked with
Blender before. Where can I find the option to add an "inside_vector",
and specify its direction?
Might be, I have to ask you a few more things afterwards. But only 1x,
soon i will be able to do it by myself. Hope you don't mind.
http://www.avg.com
Date: 15 Aug 2017 05:25:10
Message: <5992bdf6$1@news.povray.org>
I don't know if you can, Sven. But maybe Mr will be able to answer you
properly.
What you can do is activate the PovRay rendering addon then render the
scene. This will allow you to open the generated .pov file and extract
the mesh2 object. You can then edit it manually to add the inside_vector.
In blender the shortcut for making the normals consistent is (in edit
mode or it will open a new scene file) Ctrl + n or to make them face
inward is Ctrl + Shift + n
Regards
Date: 15 Aug 2017 08:10:00
Message: <web.5992e379db2ef770c437ac910@news.povray.org>
As Stephen pointed out, I don't think that's an option in Blender, because it's
a mesh modeler, not a mathematical primitive modeler like POV-Ray which uses
"real" 3D shapes.
Check out the foloowinf=g to get an idea:
https://blender.stackexchange.com/questions/5849/how-do-i-create-a-solid-object-cube
A mesh sphere is mathematically a 2D object, because you only need 2 data points
to specify a location on its surface.  It's like a hollow soap bubble with no
soap filling.
Right now, you only have a frozen fragment of the surface of that bubble - so
what you can do is either add more faces to complete/close the shell as shown in
the above link (or create a 'solid' spherical wedge [a cone]),
or,
you [manually] tell POV-Ray which direction is the outward facing side of your
mesh, and which direction is the inside-facing direction (by editing the text
file output by Blender), and then use CSG to have POV-Ray construct a truly 3D
shape.
Another option you might try, just because it's another possibility, is giving
your mesh a y-gradient pigment with white for the high points and black for the
low points, and telling POV-Ray to use that as a heightfield.  Then you can do
CSG on the heightfield.
There are probably more, and more clever, and more complicated methods of
accomplishing the goal, but Keep It Simple, and find a fast and reliable way to
get the task done.
Date: 15 Aug 2017 19:15:00
Message: <web.59937fd4db2ef77061ea16670@news.povray.org>
> properly.
> Regards
>      Stephen
Hi, Reading this made me add a few of Lanuhum's properties among which the
"hollow" keyword option to objects properties interface, otherwise objects are
solid or as much as pov does it. The inside_vector wasn't supported yet but
maybe we could add it using the object's origin. that way, if people want a
specific inside vector they can just mov object's origin knowing that its
coordinates will be used for inside vector?
Date: 15 Aug 2017 22:45:24
Message: <5993b1c4$1@news.povray.org>
> as follows:
> non-solid sheet.
> using CSG.
Thanks.
When talking about that "inside_Vector", I refer to Clipka's information
he gave me, when I mentioned that I wanted to have solid shapes (and not
hollow meshes) for POV-Ray.
My understanding of Clipka's information was, that I should open the STL
meshes in Blender and that I would find there an option to add that
mysterious "inside_vector".
When you all read Clipka's instructions, what is your understanding? I
still want to assume his information is correct.
Please continue to provide assistance to me in regards to make my NASA
STL meshes solid. Thanks.
http://www.avg.com
Date: 16 Aug 2017 00:25:22
Message: <5993c932$1@news.povray.org>
> properly.
How can I activate the EDIT mode in Blender? I am really a beginner with
Blender.
http://www.avg.com
Date: 16 Aug 2017 01:28:22
Message: <5993d7f6$1@news.povray.org>
> Blender.
There is a lot of learning and Blender does not use the usual shortcuts.
Keeping your eye on the top status line that will tell you how many
objects you have selected. (That is the info screen which is normally
positioned at the top with only the status line showing.)
"a" toggles selecting all or none. Right click your object to select it.
"Tab" toggles between Object and Edit mode. Or you can use the drop down
on the bottom status line of the 3D view.
Again "a" toggles selecting all or no vertices, lines or faces.
Ctrl Z or Object > Undo history can be useful. ;)
It is good practice to always press Ctrl N when you have finished
editing. Otherwise you might get strange shadows in your render.
But as Mr has pointed out inside vector is not supported in Blender.
Regards
Date: 16 Aug 2017 01:45:02
Message: <5993dbde$1@news.povray.org>
>> as follows:
>> non-solid sheet.
>> using CSG.
> Thanks.
How I read the instructions you posted above is:
Open the STL file in Blender and export the mesh as an Obj or 3ds
object. Convert that using PoseRay to use the mesh in PovRay. (or use
the PovRay exporter to export it to a pov file directly by rendering it.
(You will need to deselect the "delete" flag in the Render tab of the
properties screen, camera icon)
Is a good site to ask Blender questions unrelated to PovRay.
> http://www.avg.com
Regards
Date: 16 Aug 2017 04:33:09
Message: <59940345$1@news.povray.org>
>>> inside_vector.
>> Blender.
Thanks, got the editing mode. :-)
I really have to all this step-by-step. :-(
You wrote: "In blender the shortcut for making the normals consistent is
(in edit mode or it will open a new scene file) Ctrl + n or to make them
face inward is Ctrl + Shift + n".
What is the meaning of "making normals consistent", and of "make normals
face inwards"? I need to understand this. And ... sorry for all my
questions. :-)
http://www.avg.com
Date: 16 Aug 2017 05:20:33
Message: <59940e61@news.povray.org>
On 8/16/2017 9:33 AM, Sven Littkowski wrote:
> Thanks, got the editing mode.:-)
Good :-)
> I really have to all this step-by-step.:-(
The best way until you don't need to think about it.
I am still learning too. You need a different way of thinking using a
mesh modeller than to using Pov. But the Blender community is very
helpful so for blender issues GIYF. ;-)
Maybe this link will help.
https://docs.blender.org/manual/ja/dev/modeling/meshes/editing/normals.html
This has nothing to do with your original post, btw.
Regards
Date: 16 Aug 2017 08:00:00
Message: <web.5994334adb2ef770c437ac910@news.povray.org>
Blender probably has some very nice code to make sure that all of your triangles
in your mesh have all the sides "pointing the right way" - rather than having
some of them (using a coin analogy) tail side up rather than head side up.
See what that might look like below:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.57b4f3192c2caea5e7df57c0@news.povray.org%3E/?ttop=413577&to
ff=50
you can probably test for this in your scene by defining both a texture{} AND a
contrasting interior_texture{}.
Date: 16 Aug 2017 10:01:44
Message: <59945048$1@news.povray.org>
> ff=50
As far as Blender goes. I am only an egg. I have not gotten round to
needing that yet. But I know what you mean.
Because Blender displays the scene using OpenGL it is obvious if a face
is A for Elbow when using a material or texture viewport.
Oh! I see you were replying to Sven but I'm not going to waste my typing. :)
Regards
Date: 16 Aug 2017 23:50:01
Message: <web.5995119fdb2ef770883fb31c0@news.povray.org>
I have never used Blender, but the analogy in POV-Ray would be this:
A mesh object-- like a simple sphere, for example-- should have ALL of the
triangles' normals facing OUTWARD into the surrounding space, for the sphere to
render correctly. Those would be "consistent normals." Any mesh-creation tool
should do that automatically-- if it's working correctly ;-) But if a triangle
happens to be made 'incorrectly' (that is, the three vector-location-points of a
particular triangle are simply written in the 'reverse order' to what they
should be, looking face-on at the triangle), its normal will actually face in
the opposite direction(!), and will not render correctly. (Or rather, it will
show the INSIDE texture, if the object has one.) BTW, this is a typical mistake
when trying to write triangle vectors *manually*; it's hard to keep track of the
necessary and consistent 'orientation' from triangle to triangle.
Making all the normals "face inwards" would be the opposite of the above. I'm
not clear as to why that would be necessary, but I guess it can be done. (I
don't know if POV-Ray's 'inverse' keyword-- when applied to an object to change
its 'outside' to its 'inside') switches the normals as well; I never thought to
test it.)
Date: 17 Aug 2017 00:21:00
Message: <599519ac$1@news.povray.org>
> should do that automatically-- if it's working correctly;-)But if a triangle
Yes, this fits in with my experience.
When you manually edit a mesh you can do it in a way that is ambiguous
to the modeller. Hence the need to make the normals consistent.
> (Or rather, it will
> when trying to write triangle vectors*manually*; it's hard to keep track of the
If you wanted to make a solid looking pipe. You could create a cylinder,
copy the outside faces and scale them down to create the inside of the
pipe. Those normals will still be pointing outwards. To get the inside
of the pipe to render properly you reverse them to point inwards. For
example.
> (I don't know if POV-Ray's 'inverse' keyword-- when applied to an object to change
> test it.)
Regards
Date: 17 Aug 2017 04:50:01
Message: <web.59955824db2ef77016086ed00@news.povray.org>
> > Blender.
> Regards
>      Stephen
Indeed I added it while reading this discussion but it's currently commented out
as it's related only to CSG that's not implemented yet, best for now is to add
it by hand in the exported file, but next release might have it if I manage.
Date: 17 Aug 2017 07:31:53
Message: <59957ea9$1@news.povray.org>
>>>> inside_vector.
>>> Blender.
> questions. :-)
> http://www.avg.com
Thanks everyone. But I admit, I am feeling more and more frustrated with
this project - no progress or any success up to now.
Blender is a book with seven seals for me, cannot use it properly. And
the explanations I received, so far, are irritating me as I am not
English. I switched on the POV-Ray plugin, but don't know yet how to
create a POV-Ray scene file with Blender (mesh2).
What I want is this: being able to "dig" tunnels into these Martian
landscapes in my render scenes. I believe, these square-shaped landscape
meshes from NASA should be solid for that, am I right?
Date: 17 Aug 2017 08:05:01
Message: <web.59958566db2ef770c437ac910@news.povray.org>
STL to pov, yes.
https://www.google.com/search?q=stl2pov
OBJ to POV - Poseray
http://www.povray.org/resources/links/3D_Programs/Conversion_Utilities/
I'd probably take the time to do a VERY tiny test scene to get all the comands
and syntaxes worked out, so that you're making it as easy as possible for
yourself.
After that, you can just swap out one mesh for the other.
I find it easiest to use mesh files by treating them as include files.
The triangles in a mesh have a "handedness" - an axial chirality.
Give a "thumbs up" with your left hand, and if you order your triangle vertices
in the order that your fingers curl, then the normal points up like your thumb.
Order them in the reverse direction, and then the normal points in the opposite
direction - "thumbs down"
I'd stop trying to use Blender if you want to render your scene in POV-Ray ----
just convert your OBJ or STL to a mesh, and then do all the fine-tuning in
POV-ray.
AND, as you know, you can post a (small) mesh and your scene file, and then
someone can edit it to get it to work.
Date: 17 Aug 2017 08:28:37
Message: <59958bf5$1@news.povray.org>
> STL to pov, yes.
> yourself.
> POV-ray.
Thanks. Actually, I did that search some weeks ago, and downloaded the
DOS command-line tool STL2POV. But upon encountering problems with doing
it that way, I started to post here inside the POV newsgroup. Don't even
remember at the moment, what sort of problems I encountered.
Basically, out of these NASA-provided square-shaped Martian terrain
meshes, I want to create solid bodies. Because I want to "dig"
(difference) tunnels into the Martian terrain, in my scenes later on.
I remember now: the resulting meshes in POV-Ray were full of
distortions, insane spikes. STL2POV is not a good solution.
http://www.avg.com
Date: 17 Aug 2017 08:29:38
Message: <59958c32$1@news.povray.org>
> POV-ray.
I think that is probably the best idea.
STL > OBJ > Mesh 2
Blender is an all things to all people program and there is so much to
learn.
Actually I might download one of the Martian landscapes (Sven, which one
are you using?) and see what I can do. But first I am trying to unlock a
HDD from an old PVR and having problems with it and the utility I am
using hdat2.exe
So it might take a while.
Regards
Date: 17 Aug 2017 08:39:11
Message: <59958e6f@news.povray.org>
Am 16.08.2017 um 01:12 schrieb Mr:
Does that option directly correspond to POV-Ray's `hollow on` object
modifier, or does it do something different?
The `inside_vector` parameter is /not/ a location, but a direction,
serving a rather technical purpose.
The background is that in order to test whether a point P is inside a
mesh or not, POV-Ray shoots a ray in the direction specified by
`inside_vector`, and counts the number of intersections with the mesh.
If it finds an odd number of intersections in that direction, P is
considered inside, otherwise it is considered outside.
Date: 17 Aug 2017 08:48:16
Message: <59959090$1@news.povray.org>
Am 16.08.2017 um 03:44 schrieb Sven Littkowski:
Actually no; the workflow I tried to suggest was to export the mesh to
POV-Ray format as usual, then edit the generated POV-Ray file manually,
adding `inside_vector y` (or whatever direction corresponds to "up") to
the mesh.
Date: 17 Aug 2017 12:25:01
Message: <web.5995c262db2ef770c437ac910@news.povray.org>
I'd be interested in seeing a diagram of this - and I thought about coding one
up myself - potentially for use in the docs (since this comes up a lot)
But the information that I need to do that is:
POV-ray shoots a ray in the direction specified by `inside_vector` _FROM_ ---
where?
Date: 17 Aug 2017 15:05:00
Message: <web.5995dcd0db2ef770883fb31c0@news.povray.org>
> where?
That's something I've wondered about as well.
From newsgroup comments years ago, my own understanding about inside_vector is
currently this (and I could be wrong):
1) it isn't used until the mesh is CSG'd with some other object.
2) Perhaps the 'shoot-from point' (or from *multiple* points) is actually the
surface of the other intersecting object. That would *seem* to make sense--
because a successful vector direction should naturally point toward the inside
of the now-partial 'hull' (of the mesh object), *as seen from* the other
object's surface.  And if the mesh isn't a completely CLOSED one-- if there's a
'hole' in the mesh somewhere-- then the chosen inside_vector direction (if not a
'good' one) could conceivably point at that hole, with NO surface triangle being
detected there... resulting in that particular part of the CSG construct not
being rendered at all. (Possibly an example of the 'odd/even' rule that Clipka
mentioned?-- a hole returning 'ZERO intersections', which is 'even'.)
It's also my understanding that each and every triangle of the 'partial CSG'd
hull' is tested with the inside_vector. In other words, it isn't just a one-time
affair.
That's about as far as I've gotten ;-)
Date: 17 Aug 2017 15:20:00
Message: <web.5995ebe8db2ef770c437ac910@news.povray.org>
I would think it would HAVE to be multiple points - because
(a) if it were just a single point, then
     (1) it wouldn't make any sense, as there would only ever be one ray
     (2) and/or you'd get a solid wedge of sorts
(b) if you only "scan" along that single vector - let's say, starting from any
point along the other object's bounding box - then how do you handle the case(s)
where the triangle being tested is perfectly parallel to the ray?
How many intersection would it be calculated as?
This suggests that a similar mechanism might be used in reverse to take a
non-mesh object and construct a point cloud where the ray-[object]surface
intersection points are.  Then "just" triangulate the point cloud.
Date: 17 Aug 2017 16:24:15
Message: <5995fb6f$1@news.povray.org>
> the mesh.
Ohhhh, okay. That is now one of the clarifications I needed. Thanks. :-)
http://www.avg.com
Date: 17 Aug 2017 16:33:29
Message: <5995fd99@news.povray.org>
The answer for this one is NAN (Not A Number)
The test ray is shot from amy point that need to be tested to see wether
or not it's inside the mesh.
The case of a triangle been perfectly parallel to the vector do exist
and lead to artefacts. In that case, you need to slightly alter the
direction of the vector. Adding something like +0.000001 to one of the
components should be enough in most cases, but there are situations
where it can cause another triangle to become parallel to the vector.
Date: 17 Aug 2017 16:37:35
Message: <5995fe8f@news.povray.org>
>> the mesh.
> http://www.avg.com
One last thing : You need to add the inside_vector at the end ot the
mesh's definition. Normally, it's just before it's last closing brace "}".
Date: 18 Aug 2017 02:48:30
Message: <59968dbe$1@news.povray.org>
Hmmm... either that or (1) the stl files are corrupt or (2) normals are
/not/ consistently outward oriented. I recognise those spikes when
working on a badly modelled object in Silo.
Date: 18 Aug 2017 05:20:00
Message: <web.5996b056db2ef77016086ed00@news.povray.org>
The same yes
Indeed I realised this and first thought about using the object center's
orientation, but this could have led to too many problems when animating...
therefore I chose another solution: a simple interface xyz field where to fill
in numbers of the vector this will appear only when a boolean modifier is on,
which I intend to use as interface to CSG
To Sven, do not get scared in believing you need to "learn Blender", actually
three steps after opening the software are enough to create a pov file with it,
They are explained here:
https://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Render/POV-Ray#Quick_Start
In your case, you need to add the extra steps below:
*4 right click default cube to select it hit SUPPR and Enter to delete it
*5 going to the menu File > Import > STL, pick your original data.
*6 uncheck the car icon to deactivate automatic initial options and temporary
file naming, also uncheck the "Delete files" option and check "POV Editor" if
you installed Povwin
*7 fill in a file name and folder
Then just hit F12. and after the first render, Povwin will stay open, you can
just use it to navigate to the pov file of your chosen location.
modify/save/rerender it,
*8 come back here, report any problems
Date: 18 Aug 2017 06:29:40
Message: <5996c194@news.povray.org>
8: where is that car icon? I searched the GUI, and also the top menus.
http://www.avg.com
Date: 18 Aug 2017 06:39:12
Message: <5996c3d0$1@news.povray.org>
https://nasa3d.arc.nasa.gov/models
Contents of folder "C:\Documents\My 3D\STL\Space":
AsteroidVestaWhole.stl
MarsGaleCrater-209kmAcross.stl
MarsGaleCrater-3xV.stl
MarsPahrumpHills1.obj
MarsPahrumpHills2.obj
MarsTharsisRegion6xv.stl
MarsVallesMarineris1.stl
MarsVallesMarineris2.stl
MarsVallesMarineris3.stl
MoonAristarchusRegion3xV.stl
MoonCopernicusCrater3xV.stl
MoonFarSide.stl
MoonGassendiCrater3xV.stl
MoonNearSide.stl
Yes, I encourage you to download those files. And if you like, I invite
you and everyone else here to join me and to sit seriously together to
make concepts for different types of Moon and Mars bases: which parts
can be underground, and which parts have to remain on the surface, what
materials to be used, what areas the bases would consist of, energy
sources, food sources, and all that. Even texture development.
http://www.avg.com
Date: 18 Aug 2017 07:16:47
Message: <5996cc9f$1@news.povray.org>
OK. I think I got an easy and safe method for you to follow:
1) If you do not have it already, download Meshlab
(http://www.meshlab.net/) and install it.
2) open Meshlab and load the stl mesh.
3) Open 'Export Mesh As...' and export the mesh as an obj file.
4) Open Poseray and load the obj mesh.
5) Go to the 'Groups' folder and press 'Recalculate normals'.
6) Go to the 'POV-Ray Output' folder and export the mesh to POV-Ray
(results in a mesh2 include file).
Date: 18 Aug 2017 08:05:00
Message: <web.5996d747db2ef770c437ac910@news.povray.org>
> > where?
I did a wee bit more digging, and I found this from the megapov docs:
"To determine if a point is inside a triangle mesh, POV-Ray shoots a ray from
the point in some arbitrary direction (the default is <1, 0, 0>). If this vector
intersects an odd number of triangles, the point is inside the mesh. If it
intersects an even number of triangles, the point is outside of the mesh. You
can specify the direction of this vector. For example, to use +z as the
direction, you would add the following line to the triangle mesh description
(following all other mesh data, but before the object modifiers)."
So it's taking a point that it needs to know whether it's inside or outside the
mesh, and shooting a ray from that point in the direction of the vector you
supply.  So there ARE multiple points - all of the points being tested.
My guess is that the vector can be supplied as a 'tweak' to override the default
value in case there are any weird artefacts showing up due to the cases I
mentioned before.  Skootch the vector a little one way or the other, or give it
a good 30-6-90 degree twist, and you may get a vastly better rendering.
Date: 18 Aug 2017 09:30:01
Message: <web.5996ebacdb2ef77016086ed00@news.povray.org>
> http://www.avg.com
Unchecking OS Tempfiles in export settings of older versions, was similar to
unchecking the car icon, in most recent downloads of the script :
https://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Render/POV-Ray#Download
Date: 19 Aug 2017 03:01:59
Message: <5997e267$1@news.povray.org>
YES! Finally I got these objects into the POV-Ray scene language!
This was the first challenge.
For the 2nd challenge, seeing all these many posting here in this
thread, I would prefer to open a new thread here in this group:
"Solidifying a Mesh Object".
There we can look for solutions, how to transfer what is now a mesh,
into a solid object. I believe they need to be solid, in order to create
caves and tunnels through Difference into that body.
http://www.avg.com
Date: 19 Aug 2017 05:02:01
Message: <5997fe89$1@news.povray.org>
Am 17.08.2017 um 21:01 schrieb Kenneth:
>> where?
More precisely, it is only used in non-`union` CSGs.
Exactly that.
As a raytracer, POV-Ray's main schtick to render any objects in the
scene is to compute intersection points between rays (usually
originating at the camera location) and object surfaces.
For geometric primitives, ray-surface intersections are computed via
more or less complicated mathematical formulae.
For `union` CSGs, ray-surface intersections are computed simply by
computing the ray-surface intersections with all child objects.
For all other CSGs, the ray-surface intersection points of all the child
objects are filtered according to whether they are /inside/ sibling objects.
Date: 19 Aug 2017 05:24:48
Message: <599803e0$1@news.povray.org>
Am 17.08.2017 um 21:18 schrieb Bald Eagle:
In practice, this should only be a problem when all of the following
conditions come together:
1) The mesh must be in a non-union CSG.
2) The `inside_vector` must be parallel to one of the mesh triangles.
3) That triangle must lie in the same plane as one of the sibling object
surfaces.
If conditions 1) and 2) aren't met, this whole thing is a non-issue for
presumably obvious reasons. If condition 3) isn't met, the set of points
for which the test would become problematic is collapsed into
infinitesimally thin lines where the problematic triangles are projected
onto the sibling object surfaces, and the risk of any ray ever hitting
such a region is rather low.
That said, the described scenario may be one of the motivations (if not
the primary one) for making the `inside_vector` a parameter in the first
place, rather than just using a constant direction and toggling the
mechanism on and off with a boolean parameter.
Date: 19 Aug 2017 18:55:01
Message: <web.5998c0f5db2ef770883fb31c0@news.povray.org>
Sven wrote:
> Blender is a book with seven seals for me...
Ha! That's a good biblical analogy (to someone like me, who hasn't tried
learning even the basics of Blender yet.) I got a good laugh out of that.
> vertices in the order that your fingers curl, then the normal points up
> like your thumb.
Well-said; much better than my rather clumsy explanation. And "chiraity" is the
word I was trying to think of (in a different newsgroup post.)
> from the point in some arbitrary direction (the default is <1, 0, 0>)...
I actually didn't know (or remember?) that there was a *default* inside_vector.
I should have re-read the docs; it has been awhile re: this topic.
> the default value in case there are any weird artefacts showing up...
Yes, that makes sense now.
