POV-Ray : Newsgroups : povray.general : smooth gradient color_map Server Time
3 Mar 2026 22:13:47 EST (-0500)
  smooth gradient color_map (Message 1 to 10 of 37)
Subject: smooth gradient color_map
Date: 21 Jul 2017 18:28:48
Message: <59728020$1@news.povray.org>
hi,
can someone please point me to a color_map example which provides a
smooth blend/gradient from (ideally) blue at 0 to red at 1 in 254
increments?  I'd prefer a solution which does not require (an array of)
named colours.
thank you, jr.
Subject: Re: smooth gradient color_map
Date: 22 Jul 2017 00:30:00
Message: <web.5972d3fc6b1125dc9c5d6c810@news.povray.org>
> named colours.
> thank you, jr.
Thinking ahead here: You are welcome!
You will probably get the idea from my fast example. Funny thing, still took me
half hour to write and edit again and again! I wanted it to do stepped colors
too, and comment on parts.
P.S. you can ignore the "by bob", no need to keep that. :)
/* SIMPLE SPECIFIC NUMBER OF COLORS FOR A GRADIENT PATTERN by bob */
#declare BeginColorCount=1; // or zero and < EndColorCount
#declare EndColorCount=254; // or > BeginColorCount
#declare StepsCount=12; // number to increment by (1 is good too)
box { // apply to this shape
0.00001,0.99999 // unequalize surface and color map
 gradient x // choose a directional axis
 //ramp_wave // default
 color_map {
  #for (It,BeginColorCount,EndColorCount,StepsCount)
  It/EndColorCount, (It+StepsCount)/EndColorCount
  color rgb <(EndColorCount-It)/EndColorCount,0,It/EndColorCount>
finish {
 ambient 1 emission 0 diffuse 0 // see it without light
 translate -0.5 // center on origin vector
 scale 2 // double unit size
 rotate <30,30,30> // change orientation
 translate <0,0,4> // move location
Date: 22 Jul 2017 01:20:00
Message: <web.5972dfb26b1125dc9c5d6c810@news.povray.org>
> > increments?
Sorry, I blame my awful speed reading. I put the red first and blue last, not
the way you said there.
And guess I should have asked why "254" instead of the usual 0 to 255. Won't
matter really, you only need to change the numbers to what you want.
Below is the blue to red way, obviously only a switch around of the rgb elements
to do that. And complete 256 color gradation, of course, just to show that.
Hopefully I did this example correctly, since I am known for flawing the
simplist things... and fouling up complexities for sure.
:D
#declare BeginColorCount=0; // or zero and < EndColorCount
#declare EndColorCount=255; // or > BeginColorCount
#declare StepsCount=1; // number to increment by (1 is good too)
 color_map {
  color rgb <It/EndColorCount,0,(EndColorCount-It)/EndColorCount>
finish {
Date: 22 Jul 2017 03:31:55
Message: <5972ff6b$1@news.povray.org>
Am 22.07.2017 um 00:28 schrieb jr:
> hi,
> named colours.
> thank you, jr.
For a smooth gradient, all you need are the two color_map entries at 0
and 1:
      gradient x
      color_map {
        [0, <0,0,1>]
        [1, <1,0,0>]
This will give the exact same gradient as omniverse's suggestion. If it
is not to your liking, you'll have to specify additional constraints for
the gradient.
If you're unhappy with the above gradient and feel that its brightness
appears non-linear, try the `blend_mode` parameter, and maybe also
`blend_gamma`. For aesthetically pleasing results, `blend_mode 3` is
currently the best choice; it interpolates chromaticity and brightness
separately, using non-linear interpolation for the latter:
    global_settings { assumed_gamma 1.0 }
      gradient x
      color_map {
        blend_mode 3
        blend_gamma 2.5 // default
        [0, <0,0,1>]
        [1, <1,0,0>]
If you're actually interested in the numerical values, you can use the
`eval_pigment` function.
Date: 22 Jul 2017 03:35:37
Message: <59730049$1@news.povray.org>
Am 22.07.2017 um 09:31 schrieb clipka:
Hm... no, actually not. Reading omniverse's suggestion again, he seems
to be using steps, i.e. not a smooth gradient at all.
Date: 22 Jul 2017 03:39:38
Message: <5973013a$1@news.povray.org>
Am 22.07.2017 um 06:26 schrieb omniverse:
>   #end
That syntax is obsolete, and should be avoided. Instead, use the
following for exactly the same effect:
    It/EndColorCount,
    (It+StepsCount)/EndColorCount,
Date: 22 Jul 2017 05:05:12
Message: <59731548$1@news.povray.org>
hi,
thank you for the quick replies, Omniverse & Clipka.
> Won't matter really, you only need to change the numbers to what you
> want.
simple memory fault :-(  I thought I'd read 254 being the max # entries
but, checking, the doc does say "from 2 to 256 entries".
>     pigment {
>       gradient x
>       color_map {
>         blend_mode 3
>         [0, <0,0,1>]
>         [1, <1,0,0>]
I just tried this and get good-ish results (a little too homogeneous
perhaps (the color_map is used to visualise data in a DF3)), but there's
no mention of the blend_* constraints in the installed (v 3.7.1a)
documentation.  I'll have a look in the online docs later.
again, many thanks.
jr.
Date: 22 Jul 2017 06:06:57
Message: <597323c1$1@news.povray.org>
Am 22.07.2017 um 11:04 schrieb jr:
>> want.
... and, as a matter of fact, that's no longer valid for current
versions anyway ;)
Date: 22 Jul 2017 06:55:59
Message: <59732f3f$1@news.povray.org>
Le 22/07/2017 à 00:28, jr a écrit :
> hi,
> named colours.
> thank you, jr.
You can try this :
// --- build colors map ---------------------------------
#declare colorStart = <1.00, 0.00, 0.00>;  // Red
#declare colorEnd = <0.00, 0.00, 1.00>;	   // Blue
#declare colorDelta = colorEnd - colorStart;
#declare nStep = 64; // or others values
#declare colorStep = colorDelta/(nStep);
#declare myMap = color_map {
#declare index = 0;
#while (index <= nStep)
	#declare c = colorStart + index*colorStep;
	#declare s = index/nStep;
	[ s rgb c]
	#declare index=index+1;
// --- use colors map --------------------------------
box {
   <0, 0, 0>,< 5, 5, 100>
     gradient z
     color_map { myMap }
     scale <1,1,100>
Kurtz le pirate
Compagnie de la Banquise
Date: 22 Jul 2017 14:11:01
Message: <59739535$1@news.povray.org>
> hi,
> named colours.
From Blue to Red... in which colorspace would the transition be ?
The naive might expects a change in Hue, in HSV or HSL colorspace, with
a vibrant magenta at 0.5 (or going the other way on the circle, blue,
cyan, green, yellow, red ?)
You might want to have a look at the CHSL2RGB macro from colors.inc and
use it in the code provided in the other posts of this thread.
