POV-Ray : Newsgroups : povray.general : QUESTION: Bump_Map not Effective? Server Time
5 Nov 2026 01:17:09 EST (-0500)
  QUESTION: Bump_Map not Effective? (Message 1 to 14 of 14)
Subject: QUESTION: Bump_Map not Effective?
Date: 15 Jul 2017 20:42:01
Message: <596ab659@news.povray.org>
I never actually used bump_maps before. Now I try to use one, but not
seeing any effect. Can someone assist me?
The scene contains a stratosphere helium balloon, and the bump_map
should have created the typical balloon surface. However, I don't see
the surface changed. Before posting any images, I show you the scene
file. is there any error the way I do it?
#version 3.7;
#include "kolors.inc"
#include "finish.inc"
#include "textures.inc"
#declare MyRadiosity = off;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
 subsurface        {}
 adc_bailout       0.0039
 ambient_light     rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 location < -000.0, 400.0, -500.0 >
 look_at < 0.0, -200.0, 0.0 >
 right 1.77*x
light_source
 < 2500.0, 2500.0, 5000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *10.0
#declare MyRadius = 200.0;
#declare MyOuterBalloonFinish = finish
// reflection   0.00
 crand        0.10
#declare MyInnerBalloonFinish = finish
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
#declare MyOuterBalloonTexture = texture
 pigment
  image_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher
- Balloon - Type 001 - Moon Runnings - Balloon Texture.png" }
  translate -0.5
  rotate < 90.0, 0.0, 0.0 >
  scale MyRadius*2
 normal
  bump_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher -
Balloon - Type 001 - Moon Runnings - Balloon BumpMap.png" gamma 1.8
bump_size 150.0 }
  translate -0.5
  scale MyRadius*2
 finish { MyOuterBalloonFinish }
#declare MyInnerBalloonTexture = texture
 pigment { color rgb < 0.7686275,  0.7607843,  0.7333333 > }
 finish { MyInnerBalloonFinish }
#declare UpperBalloonShape = torus     // Balloon Radius: 175 m /
Launcher Radius: 10 m
 95.0, 105.0
 scale < 1.0, 0.5, 1.0 >
#declare LowerBalloonShape = difference
 sphere { < 0.0, 0.0, 0.0 > MyRadius }
 cylinder { < 0.0, 0.0, 0.0 > < 0.0, 175.001, 0.0 > MyRadius+0.001 }
 scale < 1.0, 1.5, 1.0 >
#declare MyBalloonHullOutside = union
 object { UpperBalloonShape }
 object { LowerBalloonShape }
 texture { MyOuterBalloonTexture }
#declare MyBalloonHull = difference
 object { MyBalloonHullOutside }
 object
  scale 0.99999
  texture { MyInnerBalloonTexture }
 cylinder  // Launcher Openings
  < 0.0, -((MyRadius*1.5)+0.001), 0.0 > < 0.0, (MyRadius+0.001), 0.0 > 3.5
#declare Launcher = difference
 union
  #declare MyLength = 10.0;
  #declare MyHeight = 0.0;
  #declare MyTop = 35.0;
  cylinder { < 0.0, -((MyRadius*1.5)+30.0), 0.0 > < 0.0, MyTop, 0.0 >
3.5 }
  box { < MyLength, -MyHeight, -0.1 > < -MyLength, MyTop, 0.1 > rotate <
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
 cylinder { < 0.0, -((MyRadius*1.5)+30.001), 0.0 > < 0.0, MyTop+0.001,
0.0 > 3.3 }
 pigment { color rgb 1.0 }
#declare DoublePositionLight = union
 union
  cylinder { < 0.0, 0.0,  2.5 > < 10.0, 0.0,  2.5 > 0.20 }
  cylinder { < 0.0, 0.0, -2.5 > < 10.0, 0.0, -2.5 > 0.20 }
  pigment { color rgb < 0.05, 0.05, 0.05 > }
 union
  sphere { < 10.0, 0.0, 2.5 > 0.35 }
  sphere { < 10.0, 0.0, -2.5 > 0.35 }
  pigment { color rgbf < 1.0, 0.0, 0.0, 0.5 > }
  finish { ambient rgb < 0.3, 0.1, 0.1 > }
 union
  light_source
   < 10.0, 0.0, 2.5 >
   rgb < 0.7, 0.0, 0.0 > *10.0
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   rgb < 0.7, 0.0, 0.0 > *1.0
   fade_distance 50.0
   fade_power 4
#declare PositionLights = union
 #declare MyDistance = MyRadius-0.1;
 object { DoublePositionLight translate < MyDistance, 0.0, 0.0 > rotate
< 0.0, 000.0, 0.0 > }
< 0.0, 045.0, 0.0 > }
< 0.0, 090.0, 0.0 > }
< 0.0, 135.0, 0.0 > }
< 0.0, 180.0, 0.0 > }
< 0.0, 225.0, 0.0 > }
< 0.0, 270.0, 0.0 > }
< 0.0, 315.0, 0.0 > }
union
 object { MyBalloonHull }
 object { Launcher }
 object { PositionLights }
background { rgb < 0.02392157,  0.03490196,  0.04627451 > }
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: QUESTION: Bump_Map not Effective?
Date: 16 Jul 2017 00:35:01
Message: <web.596aebdd3b5fa6e29c5d6c810@news.povray.org>
That light source is extremely bright, is that really needed?
radiosity=off but you can add:
 normal on // affect surface normal too
into the radiosity statement for when you set it to on.
The extreme bump_size might not be needed, unless your map image lacks contrast.
I made a test map of a dozen vertical lines, repeatedly changing smoothly from
almost black to nearly white, and it shows the "bumps" easily by using only
bump_size 1.5. Just thought I would mention that.
And of course, if you're expecting light to shadow transition bumps... well,
forget it, because a texture normal isn't going to change the surface itself.
Only fakes the bumpiness for the lit area. And you might already know that, I'm
just telling what I can.
For the outside image_map you might want to add:
transmit all [decimal0to1]
so the inside texture is at least partially seen through it.
I'm not sure what you're actually trying for with those outside and inside
textures, but you could also apply it using interior_texture within the object.
Oh, the 'crand' might be a bad idea for that balloon.
Hopefully some help for now.
Date: 16 Jul 2017 02:52:41
Message: <596b0d39$1@news.povray.org>
Same comments as Omniverse. I give you here an example from my
BeenThereDoneThat scene, the moon in the sky:
#declare MoonMap =
       image_map {
         png "PlanetMaps/MoonMap.png" gamma 1.0
         map_type 1
         once
         interpolate 2
     normal {
       bump_map {
         png "PlanetMaps/MoonBump.png"
         map_type 1
         once
         interpolate 2
       bump_size 5.0
     finish {
       diffuse albedo 0.9
That is all that is needed. The bump_size is even rather high but works
best for this scene.
Note that in order for the maps to be effective you need to add the
map_type parameter which seems to be missing in your code. 1 is for a
sphere. See docs for mor info on image_maps and bump_maps.
Date: 16 Jul 2017 03:10:00
Message: <web.596b10e23b5fa6e29c5d6c810@news.povray.org>
> #declare MoonMap =
>    texture {
>      pigment {
>        image_map {
>          map_type 1
>          once
>          interpolate 2
>      normal {
>        bump_map {
>          map_type 1
>          once
>          interpolate 2
>        bump_size 5.0
>      finish {
>        diffuse albedo 0.9
> Thomas
Definitely onto something there Thomas. I was looking at it again because I
thought there was a reason for the default planar mapping, but I wondered if
that could be a mistake for this particular thing.
map_type 1 will wrap around the balloon shape spherically and not need
translate, rotate or scale.
But the main thing I was thinking about was to skip the image_map to get a
better look at what the bump_map is doing. So to try that, Sven, you might want
to look at it with only pigment { rgb 1 filter 0.5 } or similar. That way you
can see the normal alone.
I realized my attempt using my own image file masked the appearance somehow.
Probably something to do with the bump_map being like an illusion and not a real
surface deformation for the visible image to paint onto. So using the plain
pigment color it highlights the bump_map instead of masking it from view.
At least that's my thought on this.
Date: 16 Jul 2017 06:58:49
Message: <596b46e9@news.povray.org>
>> #declare MoonMap =
>>     texture {
>>       pigment {
>>         image_map {
>>           map_type 1
>>           once
>>           interpolate 2
>>       normal {
>>         bump_map {
>>           map_type 1
>>           once
>>           interpolate 2
>>         bump_size 5.0
>>       finish {
>>         diffuse albedo 0.9
>> Thomas
> Bob
You are absolutely right. Best to test with a plain pigment, preferably
a light one. ;-)
Date: 17 Jul 2017 02:00:06
Message: <web.596c51763b5fa6e29c5d6c810@news.povray.org>
Sven, I found some possible errors in other things you might not be aware of
yet. I was trying a remake of your scene file, just like I often do with SDL
shared by other people.
The top of the LowerBalloonShape was not differenced out completely, so unless
you intend a parachute hovering above the balloon you will need to increase the
cylinder height from 175.001 to MyRadius+0.001 in the y direction.
The position lights are embedded into the surface of the cylinder ends, and
moving each light_source from the current 10 to maybe 10.25 (x direction) should
make those visible. I was not seeing them before changing that.
I didn't continue with your bump_map and instead used:
 normal {radial frequency 24 bump_size 6} // wraps around y axis
for both the outside and inside textures.
And just a pigment {rgb 1 transmit 0.2}, although I'm curious what your balloon
bump_map image is and if that was too low in contrast or some other reason for
not showing obvious surface features.
Date: 17 Jul 2017 11:50:01
Message: <web.596cdc593b5fa6e29c5d6c810@news.povray.org>
There should have been a scallop_wave in there too, sorry. Not suggesting you
change your way of doing things, I was just telling what I did.
Date: 23 Jul 2017 18:15:26
Message: <59751ffe$1@news.povray.org>
 you
> Bob
http://www.avg.com
Date: 23 Jul 2017 18:22:07
Message: <5975218f@news.povray.org>
> Bob
Thanks to you all. :-)
And sorry for my absence, I was not at home.
I think, it might be a good idea to attach the bump_map file. Just for
size reasons, it is now a JPG, but you can put it back to a PNG file.
I also added the once keyword and the map_type. Still, no change.
Will apply the other correctional changes as advised. but please see my
bump_map file and check out. Thanks.
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.jpg' (436 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.jpg'
Date: 24 Jul 2017 01:55:00
Message: <web.59758b8e3b5fa6e29c5d6c810@news.povray.org>
I replied to your message at povray.binaries.images with a changed SDL text and
the image file after I enhanced it for contrast and smoothness (was grainy
before).
You should be able to see how the bumpiness looks from rendering that now.
I did some excercises in scaling to get it best way I could, as you might find
out when reading it.
Anyway, see what I wrote there and download the other image for it.
There's probably a better way, that just what I managed to do.
Date: 24 Jul 2017 12:53:50
Message: <5976261e$1@news.povray.org>
Am 24.07.2017 um 00:22 schrieb Sven Littkowski:
That was a good idea indeed.
Your bump map is way oversized in terms of image dimensions. Or, more
precisely, in terms of image dimensions vs. dynamic range. As a
consequence you get color banding, which has the effect of
disintegrating the bumps into almost infinitesimally thin lines.
For a bump map, you want to make sure that the typical "slope" in your
image is /at least/ 1 "brightness step" per pixel.
There are several ways to improve your image in this respect:
(1) Significantly reduce the bump map's size in pixels.
(2) Re-create your bump map with more contrast, to make full use of the
bit depth provided by the image format.
(3) Re-create your bump map at a higher bit depth (e.g. 16 bits instead
of 8).
Date: 24 Jul 2017 19:46:40
Message: <597686e0@news.povray.org>
Here's the updated bump image. I reduced its size, made it 16bit, and
increased the contrast between dark and bright areas. Still - no
success.   :-(
Another problem: The same thread exists inside the IMAGE section. I
posted there at first before making up my mind that it might be a
GENERAL topic. Now we have two identical threads. I think, we all should
just use THIS thread here, inside GENERAL.
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (314 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png'
Date: 25 Jul 2017 01:15:34
Message: <5976d3f6$1@news.povray.org>
Am 25.07.2017 um 01:46 schrieb Sven Littkowski:
> success.   :-(
Since images will probably be sent back and forth,
`povray.binaries.image` is the more suitable location.
Posting attachments is generally discouraged, and actually impossible
from the web interface (http://news.povray.org), in all newsgroups
except those named `povray.binaries.*`.
Date: 25 Jul 2017 01:56:24
Message: <5976dd88$1@news.povray.org>
>> success.   :-(
Agreed. Okay, everyone please check the IMAGES version of this thread
from now on. Thanks. :-)
http://www.avg.com
