POV-Ray : Newsgroups : povray.general : Does anyone still use AA, or do you just over-render? Server Time
5 Nov 2026 02:39:26 EST (-0500)
  Does anyone still use AA, or do you just over-render? (Message 1 to 11 of 11)
Subject: Does anyone still use AA, or do you just over-render?
Date: 9 Apr 2017 11:48:21
Message: <58ea57c5$1@news.povray.org>
I find I get better results by rendering at a massively larger scale
(often as much as 8 or 16 times larger in each dimension), and then
downsizing in the GIMP. Of course, I rarely use POV for anything that
takes more than a few minutes these days...
Subject: Re: Does anyone still use AA, or do you just over-render?
Date: 9 Apr 2017 16:00:01
Message: <web.58ea924a36789582883fb31c0@news.povray.org>
On occasion, I've done that as well-- downsizing large renders in Photoshop,
using bicubic interpolation there--with pretty good results (compared to using
POV-Ray's 'default' AA with its settings of type 1, threshold of 0.3, and
jittering on.) But I don't use AA's default settings, as they are somewhat
crude, visually speaking.
Your question prompted me to do some more research, mainly about Photoshop's
various methods of downsampling-- bicubic interpolation vs. bilinear vs.
"nearest neighbor."
I looked at 'bicubic interpolation' and 'image scaling' at Wikipedia; the latter
leads me to believe that bicubic and bilinear methods may apply a slight bit of
useful blurring before the downsizing-- or rather, some low-pass filtering, to
help minimize the 'high-frequency' sharp color/brightness transitions between
pixels. That sounds a bit like AA, although not quite the same thing.
I just did a test with POV-Ray's included 'biscuit' scene file-- first rendering
it at 3200 X 2400 pixels with no AA, then again at 800 X 600 *with* AA (using
the defaults.) I then downsized the larger image, first using bicubic
interpolation, then bilinear. Comparing the resulting images close-up in
Photoshop, I actually prefer the bilinear method of interpolation-- it seems to
'match' the look of the smaller AA image better, regarding fine details, which
are retained (more or less.) Bicubic looks a bit *too* smooth--an interesting
discovery.
BTW, something I read long ago (and my own intuition) tells me that, when
downsizing an image, it's best not to use a straight 4-to-1 reduction (as in my
example), or a likewise purely linear reduction. In other words, to choose
something different (odd?), like 7-to-1 or 3-to-1, etc. If I recall correctly,
the interpolation works better this way(?), visually.
Date: 12 Apr 2017 21:00:49
Message: <58eecdc1$1@news.povray.org>
Good point, I need to look at updating my INI files again. I keep
getting back to the default install for one reason or another.
I suspect it has to do with locality, and that using a size which isn't
a multiple of the smaller size would force pixels from a slightly larger
area (including the border around the scaled pixel).
Date: 12 Apr 2017 21:55:18
Message: <58eeda86$1@news.povray.org>
Am 2017-04-09 11:48, also sprach Benjamin Chambers:
I still use AA (no jitter).  Since I have about 28,000 frames to deal
with, loading each into gimp would be a pita!  Maybe ImageMagick/netpbm
would be an option for your me for your cool idea...
dik
Date: 13 Apr 2017 02:44:52
Message: <58ef1e64$1@news.povray.org>
Always AA, even for testing :-)
Out of curiosity: what do you use "for anything that takes more than a
few minutes these days..."?
Date: 13 Apr 2017 06:35:58
Message: <58ef548e$1@news.povray.org>
Have you tried out all the AA settings?
eg something like "+a0.0 +am2 +r4" should give comparable results to
rendering 16x larger in each direction with no AA and then resizing.
Date: 13 Apr 2017 16:01:28
Message: <58efd918$1@news.povray.org>
Sadly, I just don't.
Date: 13 Apr 2017 16:40:00
Message: <web.58efe1f236789582883fb31c0@news.povray.org>
I have GIMP as well, but I'm *much* more familiar with Photoshop; it seems more
intuitive to me.
In PS, there is an 'Actions' feature that I use a lot-- for setting up a series
of operations on an image (like downsizing, for example) which can then
automatically carry out those steps very fast, on thousands of images. I haven't
gotten deeply enough into GIMP to know if it can do that, although I suspect it
can.
Date: 14 Apr 2017 06:08:18
Message: <58f09f92$1@news.povray.org>
XnView or IrfanView can rescale a whole directory full of images.
Mike
Date: 14 Apr 2017 06:09:05
Message: <58f09fc1$1@news.povray.org>
I use default AA settings because I'm lazy.
Mike
Date: 16 Apr 2017 13:00:05
Message: <58f3a315$1@news.povray.org>
Always use AA with the following options:
+am2 +a0.2 or +am2 +a0.1
with default recursion level.
When doing blured reflection, I've found that using +r4 or +r5 gives
much beter results.
