POV-Ray : Newsgroups : povray.general : povclipse2-0.2.0 Server Time
3 Mar 2026 23:41:01 EST (-0500)
  povclipse2-0.2.0 (Message 1 to 5 of 5)
Subject: povclipse2-0.2.0
Date: 1 Feb 2017 02:45:02
Message: <589191fe$1@news.povray.org>
1) Moved the parser to a background thread.
2) #switch (#case, #range, #else) gets parsed and shadowed/disabled like
the #if does
5) Support povray built-in variables through the .ini. i.e. image_width,
clock, etc.
http://www.buckosoft.com/povclipse2/
dik
Subject: Re: povclipse2-0.2.0
Date: 5 Feb 2017 10:37:27
Message: <589746b7@news.povray.org>
> the #if does
> clock, etc.
Nice.
(the link also works for automatic install in eclipse)
I had to reinstall eclipse (for new version Neon, instead of Mars), and
the plugin is working like a charm now
(must have been a problem of previous configuration).
What I would like (in the mood: give me a finger, I take the arm):
* A mono-type font for the render message view
* support of srgb and other, in addition to rgb (both for syntax and tools)
* outline: a single quote character instead of double charater for #include
* no more /usr/local/include in library path (where does that come from ?)
* a way to open an include file (such as colors.inc): F2 give the full
path, but how to open it in editor ?
Extra bonus: any way to add keywords, under user control (hint: hgpovray
add a few objects...).
Maybe can be solved with some configurable (additional) syntax file.
So far the outline get stopped by added object.
Download 'povclipse.png' (176 KB)
Preview of image 'povclipse.png'
Date: 5 Feb 2017 17:08:01
Message: <5897a241$1@news.povray.org>
Am 2017-02-05 10:37, also sprach Le_Forgeron:
>> the #if does
>> clock, etc.
> Nice.
I use Mars.2 for povclipse2 dev.  My Neon is not as stable as I'd like.
(And takes *forever* to startup)
agreed
yes
Huh, I hadn't noticed that. Lame. (and embarrassed :) )
Um, Is it in the prefs page?
http://www.buckosoft.com/povclipse2/g/povclipse2_prefs.png
Ctrl-click over #include "colors.inc" works for me. The whole thing is
very tooltip and hyperlink oriented.
#declare MyColor = Yellow;
and ctrl-click on Yellow opens colors.inc positioned at the declaration
for Yellow.
Yes, I can look at that.  Is there a list of objects somewhere?
An object like "lemon {}" would be easy to add. Functionality like srgb
would be much harder.
dik
Date: 6 Feb 2017 12:28:54
Message: <5898b256@news.povray.org>
>> from ?)
Nope, it seems to come from project properties
And no way to have a "delete" for that item.
I'm enjoying the ctrl- click, thank for reminding me of it (I do not use
enough eclipse to remember it)
Download 'properties.png' (44 KB)
Preview of image 'properties.png'
Date: 6 Feb 2017 12:36:49
Message: <5898b431$1@news.povray.org>
The list is in the associated wiki:
https://bitbucket.org/LeForgeron/povray/wiki/Hgpovray
or
https://github.com/LeForgeron/povray/wiki/Hgpovray
which reminds me that I'm late on the nurbs part.
Bad bad zoot.
