POV-Ray : Newsgroups : povray.general : looking for sample code if nested #if #else #etc Server Time
4 Mar 2026 01:16:32 EST (-0500)
  looking for sample code if nested #if #else #etc (Message 1 to 4 of 4)
Subject: looking for sample code if nested #if #else #etc
Date: 28 Dec 2016 02:07:23
Message: <586364ab$1@news.povray.org>
I could have sworn I saw in the include menu samples (or somewhere in
the distribution) a wab of code like:
#if (xfoo=1) xbar1 #else #if (xfoo=2) xbar2 #end #end
#if (yfoo=1) ybar1 #else #if (yfoo=2) ybar2 #end #end
#if (zfoo=1) zbar1 #else #if (zfoo=2) zbar2 #end #end
or somesuch. There were lots of nested #ifs on a single line, then
operated on the 3 axis. Maybe it was in a macro?
Anyway, my mighty povclipse parser threw up on that. I said "huh, I'll
have to get back to that" but I didn't make note of where I saw it.
Help?
dik
Subject: Re: looking for sample code if nested #if #else #etc
Date: 28 Dec 2016 02:35:33
Message: <58636b45$1@news.povray.org>
Am 28.12.2016 um 08:07 schrieb dick balaska:
No two `#end` directives on the same line in the entire official
distribution.
There is an `#if ( #if ( ... ) #end ) #end` construct mentioned in the
documentation about `#if`, but that very construct is only mentioned as
something kids shouldn't try at home, as it apparently sends even
POV-Ray's own parser reeling.
Date: 28 Dec 2016 17:05:00
Message: <web.5864362d36394540883fb31c0@news.povray.org>
I just tried this on my Windows 7 (64-bit) machine, using POV-ray v3.7, and it
works OK, no problems(!) I used only one of the three code lines...
.... but if it works for one, it should work for all three. (I don't *think* I've
ever used such a construct, though-- an #if(...)/#end inside of an #else(...) --
but it works on my system.)
Try this:
#version 3.7
global_settings {assumed_gamma 1.0}
  perspective
  location  <0, 1, -4>
  look_at   <0, 0,  0>
  angle 67
light_source {
  0*x
  color rgb <1,1,1>
  translate <20, 40, -20>
#declare xfoo = 1; // 1 or 2
#declare xbar1 =
sphere {0,1 pigment {srgb <.1,.5,.9>} finish {ambient .1 diffuse .9}} // BLUE
#declare xbar2 =
sphere {0,1 pigment {srgb <.5,.5,.5>} finish {ambient .1 diffuse .9}} // GREY
Date: 28 Dec 2016 20:30:00
Message: <web.586466f9363945409c5d6c810@news.povray.org>
> Try this:
> #version 3.7
> camera {
>   perspective
>   location  <0, 1, -4>
>   look_at   <0, 0,  0>
>   angle 67
> light_source {
>   0*x
>   color rgb <1,1,1>
> #declare xbar1 =
> #declare xbar2 =
I'm bad at writing SDL so I throw stuff together like this all the time and just
fix when an error occurs during parse time. Except that I know to use #elseif
instead of separate conditionals.
This gets interesting because I was able to get a pass on the following as well:
#declare xfoo = 0; // 0, 1 or 2
#declare xbar0 =
sphere {0,1 pigment {srgb <.9,.5,.1>} finish {ambient .1 diffuse .9}} // ORANGE
#declare xbar1 =
#declare xbar2 =
#if (xfoo=1) xbar1 #else #if (xfoo=0) xbar0 #end #if (xfoo=2) xbar2 #end #end
//#if (xfoo=1) xbar1 #elseif (xfoo=2) xbar2 #end #if (xfoo=0) xbar0 #end
Commented line is a change to #elseif which also works okay. This sort of thing
is why I like the Ctrl+} (match brace) feature and would be great if same could
be done for #end.
