I am trying to add focal_point to this scene (scroll down):
https://commons.wikimedia.org/wiki/File:Camera_focal_length_distance_house_animation.gif
I've replaced the camera with this:
camera
#if (clock = 0)
orthographic
location CameraLocation
direction CameraDirection
up CameraUp
right CameraRight
#if (clock != 0)
focal_point <0,0,0>
aperture 0.25 // 0.05 ~ 1.5; // more = more blurring
blur_samples 25 // 4 ~ 100, more = higher quality; fewer = faster
// confidence 0.9 // how close to the correct color, 0 ~ 1, default 0.9
// variance 1/128 //(default) smallest displayable color difference
transform {CameraTransform}
However, the text on the image disappears. Any idea why?
Mike
Should I apply the camera transforms before or after I specify focal_point?
Mike
> Mike
If you apply your transformation before you set focal_point, it will
affect the location and direction of the camera only. If you apply it
after, then, focal_point will be transformes along with everything else.
So, if you want to move/rotate your camera and keep your focal_point
stationary, set it after the transformation.
If you want the focal_point to remain stationary relative to the camera,
set it before the transformation.
If I comment out the focal blur stuff, the text returns. I also tried
lowering the aperture size, but it does not help.
Mike
camera
#if (clock = 0)
orthographic
up CameraUp
right CameraRight
#if (clock != 0)
focal_point <0,0,0>
= faster
1, default 0.9
difference
http://wiki.povray.org/content/Reference:Camera#Focal_Blur
The docs say, "The center of the zone of sharpness is specified by the
focal_point vector. The zone of sharpness is a plane through the
focal_point and is parallel to the camera. Objects close to this plane
of focus are in focus and those farther from that plane are more
blurred. The default value is focal_point<0,0,0>."
How can a plane be parallel to the camera? Can't a plane only be
perpendicular to a vector?
Also, I don't understand why a plane is used at all. All points
equidistant from focal_point should form a sphere, don't they?
Mike
Probably parallel in the view sense, every plane forward of the camera view
would be considered parallel.
Someone else would need to answer that second part, but I think the way it works
is to simply use a flat plane like orthographic projection does. Maybe... maybe
not.
I looked at your SDL and the new screen.inc (I renamed mine here screen2.inc to
not mix it up with the old one).
Found that by using aperture 0.01 to focus the blurring while testing, and using
the camera location instead of <0,0,0> I could get a look at the text again by
adding a little z to it.
Of course, it blurs away immediately after clock increases away from 0.
focal_point CameraLocation+z*0.4
If 0.3 or 0.5 is used the text blurs out, so obviously there's a very narrow
focus area.
I don't know if you will be able to discover a method to keep the text at the
focal plane but seems like it shouldn't be impossible either.
Am 09.11.2016 um 05:28 schrieb Mike Horvath:
Interpret it as "parallel to the image plane" -- or, in other words,
"perpendicular to the camera axis".
Uh, yes, technically, all points equidistant from _any_ given point form
a sphere, but how would a sphere centered around focal_point (= an
arbitrary point by which the location of the zone of sharpness is
defined) be of any relevance?
Presuming that you mean "all points equidistant from the camera
location", the answer is: Yes, that would also be a sphere -- but the
zone of sharpness in a normal camera is _not_ the set of points
equidistant to the camera lens; rather, in a real-life camera it is the
set of points equidistant to the image plane, and that's also the case
for POV-Ray's camera.
Am 09.11.2016 um 01:23 schrieb Mike Horvath:
My guess would be that the text is far too close to the camera, and
therefore hopelessly out of focus.
Okay, thanks.
Mike
You are correct.
Mike
> not.
> focus area.
> Bob
Eventually I got the text to show up, but as you said it doesn't stay in
focus as the clock increases. I gave up and added the text using
ImageMagick instead.
Mike
Can I simulate an f-number of the camera by using the focal length and
aperture in a calculation? Is the aperture supposed to be a physical
measurement? Thanks.
Mike
> Mike
For instance, I have the following numbers:
#local CameraDistance = 16;
#local CameraAperture = clock * 4;
#local CameraFStop = CameraDistance/CameraAperture;
Mike
Am 10.11.2016 um 14:06 schrieb Mike Horvath:
The `aperture` setting is the (virtual) size of the diaphragm opening in
POV-Ray units, though I keep forgetting whether it is the diameter or
the radius.
> the radius.
Thank you. Could you check whether it is the diameter or radius in the
code? It is commonly supposed to be diameter according to Wikipedia.
Mike
> the radius.
In my experience, it's neither. Comparing aperture to a jittered
camera, it seems that dividing the aperture by about 2.7 or so yields
the diameter. (Or is it multiplying by 2.7...?)
Am 10.11.2016 um 18:38 schrieb Mike Horvath:
>> the radius.
There's a line
r = camera.Aperture * 0.5
in the source code, indicating that the `aperture` parameter is intended
to specify the diameter.
But maybe someone can check Cousin Ricky's claim that the size is off by
a factor.
