*NOTE: Please also reply if you don't care!*
*NOTE: This thread is not intended for discussion!*
Since the topic of gamma handling has recently been brought to the dev
team's attention again, I'd like to get a clearer picture of how POV-Ray
users have come to feel about the issue. Even if you don't care, please
answer at least the following question:
Do you care about gamma handling?
( ) Not enough to bother answering any more of this survey.
( ) Enough to be willing to help you with this survey.
Thank you for deciding to provide some feedback on gamma; please take
the time to answer the following questions (feel free to tick more than
one box per question, and elaborate where you think it might be helpful)
-- or just ignore them and write some prose on what's really on your
mind regarding the topic.
Bystanders, please refrain from replying to people's feedback; we can
have a discussion in a separate thread.
What version of POV-Ray are you typically using?
( ) POV-Ray 3.7 (or a derivative, e.g. UberPOV, HG-Povray)
( ) POV-Ray 3.6 (or a derivative, e.g. MegaPOV, MCPov)
( ) Other: [___]
What "assumed_gamma" setting are you typically using?
( ) none
( ) 1
( ) 1.8
( ) 2.2
( ) srgb
( ) Other: [___]
Why are you using that setting?
( ) I find it easiest to work with.
( ) I think it gives the most pleasing results.
( ) I think it gives the most accurate results.
( ) I think it is the recommended setting.
( ) Other: [___]
What keyword do you typically use to specify colours?
( ) "rgb"
( ) "srgb"
( ) Other (e.g. a macro): [___]
Why are you using that keyword?
( ) I get colour values from elsewhere in that format.
( ) I think it is the recommended format.
( ) Other: [___]
What other gamma-related features do you know?
( ) "Display_Gamma" INI setting
( ) "File_Gamma" INI setting
( ) "Antialias_Gamma" INI setting
( ) "gamma" setting for input images
( ) "blend_gamma" setting for colour and pigment maps
( ) Other: [___]
Which of them do you make frequent use of?
( ) Other: [___]
Why are you using those other features?
( ) I like to toy around with them.
( ) I like the flexibility they provide.
( ) I need them to handle special cases.
( ) They don't default to the settings I typically want.
( ) Other: [___]
How do you feel in general about gamma handling in POV-Ray 3.7?
( ) I really like it.
( ) I think it's mostly ok.
( ) I think it's so-so.
( ) I think it's mostly broken.
( ) I really detest it.
( ) Dunno - I'm not using POV-Ray 3.7.
How well do you get along with gamma handling in POV-Ray 3.7?
( ) It works like a charm for me.
( ) It has its quirks, but I can live with them.
( ) I'm still learning to deal with its quirks.
( ) Its quirks still keep getting in my way.
( ) It just doesn't work for me at all.
What's your opinion on the claim that "assumed_gamma 1.0" gives more
realistic render results than other settings?
( ) Yes, "assumed_gamma 1.0" is more realistic.
( ) No, "assumed_gamma" has no effect on realism.
( ) No, "assumed_gamma 1.0" is actually less realistic.
( ) Dunno - I haven't heard that claim before.
( ) Dunno - I haven't made up my mind yet.
( ) Dunno - I don't really care.
How did you come to that opinion?
( ) People say so, and that's good enough for me.
( ) The docs imply it, and that's good enough for me.
( ) That's what sounds most plausible to me.
( ) My own research led me to that conclusion.
( ) It can be proven beyond doubt.
( ) Dunno - I don't have a clear opinion yet.
How do you feel about "assumed_gamma 1.0" in POV-Ray 3.7, compared to
the same setting 3.6?
( ) It is an overall improvement.
( ) It seems to work just the same.
( ) The following behaviour came as a negative surprise to me: [___]
( ) Dunno - I don't use it.
How do you feel about "assumed_gamma 2.2" (or any non-1.0 setting) in
POV-Ray 3.7, compared to the same setting 3.6?
What other feedback would you like to give about the gamma handling in
POV-Ray 3.7?
[___]
> (x) Enough to be willing to help you with this survey.
Although I generally design for "shape and shadow", I would like the
option to share my image with others.
Gamma handling is one tool to help others see, and provide feedback, of
my picture.
I've only posted two pictures, lego helicopter and micrometer, that fit
this description. Should I make another one, I would like default values
as a starting place, to help me along.
Stephen S
in news:5803ed6b$1@news.povray.org clipka wrote:
I'll awnser the rest later
> POV-Ray 3.7?
> [___]
The way for example Krita does it is rather nice, define a
colourspace/model/profile including gamma etc.
Ingo
(X) Enough to be willing to help you with this survey.
(X) POV-Ray 3.7 (or a derivative, e.g. UberPOV, HG-Povray)
> ( ) Other: [___]
> ( ) none
(X) 1
> ( ) 1.8
(X) 2.2
(X) srgb
> ( ) Other: [___]
(X) I think it gives the most pleasing results.
> ( ) Other: [___]
(X) "rgb"
> ( ) "srgb"
(X) I find it easiest to work with.
> ( ) Other: [___]
(X) "Display_Gamma" INI setting
(X) "File_Gamma" INI setting
> ( ) Other: [___]
> ( ) Other: [___]
(X) Other: [in my POVRAY.INI from earlier versions]
(X) I think it's so-so.
(X) I'm still learning to deal with its quirks.
(X) Dunno - I haven't made up my mind yet.
(X) Dunno - I don't have a clear opinion yet.
(X) It seems to work just the same.
> POV-Ray 3.7?
[I have only used it due to it being recommended and for visual correction, not
because I understand its output and input file properties]
> (x) POV-Ray 3.7 (or a derivative, e.g. UberPOV, HG-Povray)
> ( ) Other: [___]
> ( ) none
> (x) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> (x) I think it gives the most accurate results.
> (x) I think it is the recommended setting.
> ( ) Other: [___]
> ( ) "rgb"
> (x) "srgb"
> (x) I think it is the recommended format.
> (x) Other: I think it is more accurate for self-generated colours/textures.
> ( ) Other: [___]
> (x) "Display_Gamma" INI setting
> (x) "gamma" setting for input images
> ( ) Other: [___]
> (x) Other: for input images, I think of height_field functions where it is
essential.
> (x) I really like it.
> (x) It works like a charm for me.
> (x) Dunno - I haven't made up my mind yet.
> (x) It is an overall improvement.
> (x) It seems to work just the same.
> (x) Dunno - I don't use it.
> POV-Ray 3.7?
> Following the hot debates in the past, it seems we are now in more quiet waters.
Still, I think there is some confusion remaining about what gamma
handling is about and its relation to the physical world. People tend to
tweak gamma settings in order to get a "more pleasing" image but forget
that this often results in darker or lighter images on other systems. Is
there a need for more/better documentation on the subject? I don't
really know. Just my half cent.
> (*) Enough to be willing to help you with this survey.
> (*) POV-Ray 3.7 (or a derivative, e.g. UberPOV, HG-Povray)
> ( ) Other: [___]
> ( ) none
> (*) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> (*) I think it gives the most accurate results.
> ( ) Other: [___]
> ( ) "rgb"
> (*) "srgb"
> (*) I get colour values from elsewhere in that format.
> ( ) Other: [___]
> (*) "Display_Gamma" INI setting
> (*) "File_Gamma" INI setting
> (*) "gamma" setting for input images
> ( ) Other: [___]
> (*) Other: [None of them frequently]
> (*) I like to toy around with them.
> ( ) Other: [___]
> (*) I think it's mostly ok.
> (*) It works like a charm for me.
> (*) Yes, "assumed_gamma 1.0" is more realistic.
> (*) It can be proven beyond doubt.
> (*) It is an overall improvement.
> POV-Ray 3.7?
"assumed_gamma" is still a bit unintuitive IMO in what it actually does.
I'm pretty sure if you took a person who knew a lot about gamma handling
but had never used POV before, and asked them what they thought it did,
they would most likely get it wrong.
> ( ) Other: [___]
> ( ) none
> (x) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> (x) I think it gives the most pleasing results.
> ( ) Other: [___]
> (x) "rgb"
> ( ) "srgb"
> (x) Other: [old habit]
> ( ) Other: [___]
> ( ) Other: [___]
> (x) I like to toy around with them.
> ( ) Other: [___]
> (x) Yes, "assumed_gamma 1.0" is more realistic.
> (x) My own research led me to that conclusion.
> (x) It seems to work just the same (IIRC).
> POV-Ray 3.7?
> [___]
Am 17.10.2016 um 01:12 schrieb StephenS:
> my picture.
You don't happen to be able to be more specific what default values you
would like to see, do you?
hi,
where is the reply-to address? (not keen on seeing everyone's replies
to questionnaire, feels voyeuristic).
jr.
I will always have to relearn Gamma handling each time I get a picture
this far along.
My personal preference are values that would help import/export with
people who work with pictures for a living.
I "think" Gamma handling is important, I just don't know the values.
Stephen S
> ( x) Enough to be willing to help you with this survey.
> ( x) POV-Ray 3.7 (or a derivative, e.g. UberPOV, HG-Povray)
> ( ) Other: [___]
> ( ) none
> ( x) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> ( x) I think it gives the most accurate results.
> ( ) Other: [___]
> ( x) "rgb"
> ( ) "srgb"
> ( x) Other: [think lineair, let the soft calculate]
> ( x) "Display_Gamma" INI setting
> ( x) "gamma" setting for input images
> ( ) Other: [___]
> ( ) Other: [___]
> ( x) I need them to handle special cases.
> ( ) Other: [___]
> ( x) I really like it.
> ( x) It works like a charm for me.
> ( x) Yes, "assumed_gamma 1.0" is more realistic.
> ( x) My own research led me to that conclusion.
> ( x) It seems to work just the same.
> ( x) Dunno - I don't use it.
> (x) Admittedly its been a time since I rendered anything
> ( ) Other: [___]
> ( ) none
> (x) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> ( ) Other: [___]
> (x) "rgb"
> ( ) "srgb"
> (x) Other: [I'm used to it and usually define colors manually. I would use srgb if I
got the result from a color picker.]
> (x) "File_Gamma" INI setting
> ( ) Other: [___]
> ( ) Other: [None]
> (x) Other: [Defaults appear to be fine. Also I work mostly with PNG where I think
gamma is already considered]
> (x) I think it's mostly ok.
(X) Really I don't worry about it too much. My monitor is also not
well calibrated. While I did a simple calibration procedure it is
probably useless since I adjust brightness depending on what feels
comfortable for the eye in current lighting conditions
> (x) See above. But also I don't really remember getting much feedback along
> the lines of "your image look super dark to me" etc.
> (x) That's what sounds most plausible to me.
> (x) But also I don't remember what 3.6 did exactly :)
> POV-Ray 3.7?
> [___]
>> (x) "rgb"
>> use srgb if I got the result from a color picker.]
Adding to that I also got the impression linear rgb is more
directly related to the physical characteristics of the material
(even if it is just a 3 element spectrum :D).
> ( ) none
> (x) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) "rgb"
> (x) "srgb"
> (x) I get colour values from elsewhere in that format.
> ( ) Other: [___]
> (x) "Antialias_Gamma" INI setting
> ( ) Other: [___]
> ( ) Other: [___]
> (x) I like the flexibility they provide.
> (x) I need them to handle special cases.
> ( ) Other: [___]
> (x) It has its quirks, but I can live with them.
> ( ) Dunno - I haven't made up my mind yet.>
> (x) Other: [Accurate. 'realistic' perhaps too subjective a term]
> (x) Other: [I believe the math more accurate.]
> (x) Other: [Don't routinely use non-1.0 or compare to 3.6 when I do.]
> POV-Ray 3.7?
> (X) Thought it was a quiz.
> (X) POV-Ray 3.6 (or a derivative, e.g. MegaPOV, MCPov)
> ( ) Other: [ I use both. 3.7 for integration with Bishop3d and
> 3.7/UberPov for speed.]
> ( ) none
> ( ) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> (X) Other: [1 When I can remember.]
> ( ) Other: [I will feel guilty if I don't.]
> (X) "rgb"
> ( ) "srgb"
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> (X) Other: [N/A]
> (X) Do not know - I've not thought about it much.
> ( ) Do not know - I'm not using POV-Ray 3.7.
> ( ) Do not know - I haven't heard that claim before.
> (X) Do not know - I haven't made up my mind yet.
> ( ) Do not know - I don't really care.
> (X) Do not know - I don't have a clear opinion yet.
> ( ) The following behaviour came as a negative surprise to me: [I've
not paid much attention, to be honest.]
> ( ) Do not know - I don't use it.
> POV-Ray 3.7?
> [___]
Regards
On 10/17/2016 7:00 PM, Stephen wrote:
> > ( ) Other: [ I use both. 3.6 for integration with Bishop3d and >
Regards
Am 17.10.2016 um 09:24 schrieb scott:
>> POV-Ray 3.7?
Do you think the naming of the setting plays a major role in this, or
would you expect it to be just about as unintuitive under any other name?
> ( ) Other: [___]
> ( ) none
> (*) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [Did not use in versions before 3.7]
> (*) I find it easiest to work with. Seems more "intuitive" for me.
> ( ) Other: [___]
> (*) "rgb"
> ( ) "srgb"
> ( ) Other: [___]
> (*) "Antialias_Gamma" INI setting
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> (*) Dunno - I don't really care.
> (*) Dunno - I don't use it. Never used in 3.6.
> POV-Ray 3.7?
> [___]
>>> POV-Ray 3.7?
Both I think - AFAIK it effectively does two things (set the gamma
assumed for non-gamma-corrected input values, and set the gamma used in
the internal engine calculations). If it just did one or the other, the
name could probably be more self-explanatory then.
> ( ) Other: [___]
> ( ) none
> ( ) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> (X) Other: [1.7]
> (X) I think it is the recommended setting.
> ( ) Other: [___]
> (X) "rgb"
> ( ) "srgb"
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> (X) I think it's mostly ok.
> (X) It works like a charm for me.
> (X) My own research led me to that conclusion.
> (X) Dunno - I don't use it.
> POV-Ray 3.7?
> [___]
dik
> (X) 1
> (X) I think it gives the most accurate results.
> (X) "rgb"
I do occasionally use "srgb," though.
> (X) "Antialias_Gamma" INI setting
> (X) "gamma" setting for input images
> (X) "blend_gamma" setting for colour and pigment maps
> (*) "blend_gamma" setting for colour and pigment maps
* Not really frequent.
"gamma" setting for input images is something I dearly wished for in
POV-Ray 3.6, but the new image_map default in POV-Ray 3.7 ironically
obviates the need! (I searched all my scene files, and not once have I
ever used it.) It still seems like a good idea to have this feature
available, though.
> (X) I like the flexibility they provide.
> (X) I need them to handle special cases.
> (X) I really like it.
> (X) Yes, "assumed_gamma 1.0" is more realistic.
> (X) That's what sounds most plausible to me.
> ( ) Other: [___]
> ( ) none
> (x) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> ( ) Other: [___]
> (x) "rgb" for lights
> (x) "srgb" for pigments
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> (x) I think it's so-so.
> (x) I'm still learning to deal with its quirks.
> (x) People say so, and that's good enough for me.
> (x) The following behaviour came as a negative surprise to me: [I have to switch all
the pigments srgb too. Even then, old scenes don't always look the same in 3.7.]
> POV-Ray 3.7?
> [___]
> ( ) Other: [___]
> ( ) none
> (x) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> (x) Other: [clipka authoritatively said to, and not doing so makes me a bad POV
user]
> (x) "rgb"
> (x) "srgb"
> (x) Other (e.g. a macro): [ HSV using the colors.inc HSVtoRGB macro]
> (x) Other: [ sRGB gives colors more closely matching those I've scanned or sampled]
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
I think a tutorial with example images that clearly show the purpose,
function, and usage of POV-Ray's gamma handling, and ample SDL example scenes
would be the best way to educate users about gamma. Until then, I can't say
that my uneducated opinion is worth much - I understand gamma from a photography
standpoint - Ansel Adams' books were excellent on the subject.
> (x) Dunno - I don't have a clear opinion yet.
> POV-Ray 3.7?
> [___]
This is a good idea! I don't feel I really know what is going on either!
Mike
clipka wrote on 16/10/2016 23:13:
> ( ) Other: [___]
> ( ) none
> (x) 1
> (x) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> ( ) Other: [___]
> (x) "rgb"
> ( ) "srgb"
> (x) I find it easiest to work with.
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> POV-Ray 3.7?
> [___]
Although my main Windows XP computer FAILED on me several months ago-- and I'm
currently using an iPad to temporarily communicate with the world-- I thought
I'd answer the survey anyway. I hope to have my computer fixed soon, or to buy a
new one. (Money issues, naturally.) I sorely miss working with POV-ray!
> ( X) Enough to be willing to help you with this survey.
> ( X) POV-Ray 3.7 (or a derivative, e.g. UberPOV, HG-Povray)
> ( X) POV-Ray 3.6 (or a derivative, e.g. MegaPOV, MCPov)
> ( ) Other: [___]
> ( ) none
> ( X) 1
> ( ) 1.8
> (X) 2.2
> ( ) srgb
> ( ) Other: [___]
(Depends on what POV-Ray version I'm using; gamma 1.0 for v3.7xx, and gamma 2.2
for my older scenes in v3.62
Regarding gamma 1.0...
> ( X) I think it gives the most accurate results.
> ( X) I think it is the recommended setting.
> ( ) Other: [___]
> ( ) "rgb"
> (X ) "srgb"
> ( X) I find it easiest to work with.
> ( X) I get colour values from elsewhere in that format.
> ( ) Other: [___]
> ( X) "Display_Gamma" INI setting
> ( X) "File_Gamma" INI setting
> ( X) "gamma" setting for input images
> ( ) Other: [___]
> ( ) Other: [assumed_gamma]
> ( X) I like to toy around with them.
> ( X) I like the flexibility they provide.
> ( ) Other: [___]
> ( X) I really like it.
> ( X) It works like a charm for me.
> ( X) I'm still learning to deal with its quirks.
> (X ) Dunno - I haven't made up my mind yet.
Hmm, that's a difficult question for me to answer, as I haven't done enough
scenes lately to truly compare the visual differences. As long as the *colors*
are chosen correctly (via srgb), it really boils down to getting the 'look' of
an actual real-life scene. My own *visual* sense tells me that assumed_gamma 1.0
reproduces that better-- for example, the light/shadow terminator on a spherical
shape; but I had been using 2.2 for so long (prior to POV-Ray 3.7xx being
available) that I'm more 'visually familiar' with that-- based on looking at
typical mid-level-quality gamma-bent digital photos (not HDR) and how THEY show
up on a monitor. Decisions, decisions...
> ( X) The docs imply it, and that's good enough for me.
> ( X) My own research led me to that conclusion.
> ( X) It is an overall improvement.
Mainly because I didn't understand at the time that assumed_gamma 1.0 in v3.6
also required a rethinking of the color values-- I was trying to use the same
color values for 1.0 and that I had used for 2.2, resulting in the oft-mentioned
'washed-out' color appearance, a BIG mistake on my part. That has been corrected
in v3.7xx with the newer 'srgb' color choice.
Haven't had enough experience comparing the two.
> POV-Ray 3.7?
> [___]
I would like to know your opinion on these as well:
1) Which one of these images do you think looks more realistic?
http://koti.kapsi.fi/warp/media/pov37_test1.png
http://koti.kapsi.fi/warp/media/pov37_test2.png
2) Currently, when using assumed_gamma 1 in povray 3.7 mode, default
color values in things like the ambient finish do not get adjusted in
terms of srgb, but remain in their rgb values (for example, the default
ambient finish is "rgb 0.1"), which means that a change in assumed_gamma
will affect their brightness.
The second image above was rendered by explicitly specifying the default
ambient finish (using the #default directive in the scene file) using
"srgb". Without this explicit setting, ie. using the default value, the
image looks like this:
http://koti.kapsi.fi/warp/media/pov37_test4.png
(It's essentially impossible to get any shades are darker than that due to
the default ambient finish.)
So my question is: Should POV-Ray define default colors (eg. in the ambient
finish, and anywhere else where there are default colors) in terms of srgb
(which would result in the second image by default, without having to
explicitly set those defaults), or is the current functionality ok (which
by default results in the third image).
> (x) Other: [POV-Ray 3.5 (with Moray)]
> ( ) none
> ( ) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> (X) Other: [1.9]
> (X) Other: [setting used in Moray's default scene]
> (X) "rgb"
> ( ) "srgb"
> (X) Other: [POV-Ray 3.5 doesn't work with srgb]
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> (X) Dunno - I'm not using POV-Ray 3.7.
> (X) Dunno - I haven't heard that claim before.
> POV-Ray 3.7?
> [___]
You POV-Ray devs are so high tech! this survey is such an impressive technology
:-P (clever honestly !)
> ( ) Other: [___]
> ( ) none
> (X) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> ( ) Other: [___]
> (X) "rgb"
> (X) "srgb"
> (X) Other: [I think srgb is recommended but sopmetimes forget probably because
wondering about rgbt rgbf and if these
alpha values are inverted in regard to Blender]
> ( ) Other: [___]
> ( ) Other: [___]
> (X) Other: [to use the exported value specified in Blender Interface]
> (X) No, "assumed_gamma" has no effect on realism.
> (X) It is an overall improvement.
> POV-Ray 3.7?
> [___]
