hi,
I'm trying to print, from a macro, the declared name of an object passed
to it, ie.
#declare Tobj = torus { ... };
object { Tobj }
mymacro(Tobj)
and in the macro (where the parameter is ObjId)
#debug concat("object's name:", ObjId)
that doesn't work, POV complains "expected string, oid found instead",
so is there a way to get the name string ('Tobj') from the ObjId?
thank you.
jr.
Am 16.03.2016 um 23:35 schrieb jr:
> hi,
> to it, ie.
> object { Tobj }
> mymacro(Tobj)
This question has been asked before.
Short answer: It's not possible.
Almost equally short answer: It doesn't make sense. If it would work,
POV-Ray would print "ObjId" instead of "Tobj", because the macro has no
knowledge of any prior name of the object.
What you /could/ do is approach it the other way round, converting a
string to an identifier:
object { Tobj }
mymacro("Tobj")
and in mymacro use the Parse_String macro (from string.inc... or is it
strings.inc? I never can remember) to convert the string to an identifier.
Note however that in this case you must somehow make sure that you don't
pass the name of an identifier that is also declared locally in the macro.
hi clipka,
On 16/03/2016 23:50, clipka wrote:
thanks for swift response. this approach led to a different problem
(see below). the macro is stored in its own file and meant to be
general purpose (to trace the outline of whichever object was passed via
ObjId), and I need both the object's name (for feedback and to populate
a field in the output), and the object to trace. I'm now thinking,
given the below, it might be easier/better to supply both the name and
the identifier as separate arguments, do you concur?
jr.
object { Tobj }
mymacro("Tobj")
#debug concat("id: ", ObjId)
Parse_String(ObjId)
#local bbox_min = min_extent(ObjId)
POV now fails on the min_extent since I'm passing it a string..
Am 2016-03-16 20:31, also sprach jr:
>I'm now thinking,
That's the way I do it.
C'est la vie.
dik
Am 17.03.2016 um 01:31 schrieb jr:
> hi clipka,
> jr.
> object { Tobj }
> mymacro("Tobj")
> Parse_String(ObjId)
You need to use
#local bbox_min = min_extent( Parse_String(ObjId) );
But yes, it would probably be easier to have two separate parameters,
one specifying the object and one specifying a string to use as a "name"
for that object.
hi,
ok, separate arguments it is. thank you clipka & Dick B.
On 17/03/2016 01:41, clipka wrote:
> You need to use
thank you for showing the correct use. fwiw I did grep for this macro
in all 3.7.0 (scene) files, it does not appear used anywhere.
jr.
> jr.
Given just HOW MUCH stuff POV-Ray has jammed into it, that's not entirely
surprising. Documenting features takes a lot more time and care (for me) than
coding a scene.
Perhaps if you could write up a small, commented SDL file that illustrates and
demonstrates this particular feature, then it would be available to anyone in
the future searching the newsgroups and wanting to know how to go about using
it.
"Many hands make light work", and all that :)
Glad you're getting it to work out.
hi,
> coding a scene.
> it.
man, talk about bein' put on the spot. ;-)
I don't mind doing the 'legwork' (though, as a beginner, just how useful
such a sample scene would be is questionable), but have to confess that
I can not think of /any/ realistic use case for Parse_String(); lack of
use case may well be a contributing factor to the macro not being used
in the sample scenes.
I will put a simple, contrived scene file together, give me a few days
please, I'm in the middle of my own stuff right now.
agree.
a fanciful thought on the subject: given the recent revolution in
self-publishing, perhaps, between the povray news group users, a wiki
could be nurtured to the point of producing/selling a print-on-demand
book on using/programming POV? (I know I'd buy :-))
jr.
:D
It just needs to be a little working SDL blurb that can be used as or pasted
into a macro. Though sometimes it can be surprising what some people can do
with a little feature once they start to contemplate what it might be used for.
It was simply a suggestion - please take your time and pardon my shameless and
opportunistic "tagging" of you. ;)
I hope your project is working out well. I wish you further luck and success.
hi,
>> I will put a simple, contrived scene file together, give me a few days..
I'm sure you know how, (often) immediately writing something like "can
not think of /any/ realistic use case" an idea, from nowhere, lodges
itself in the brain, persistent, like an itch that must be scratched?
anyway, it happened and I had to get it of my system, the resulting file
is attached.
too late! :-)
the .pov illustrates building object identifiers dynamically via cli.
the file is commented and works with version 3.7.0. it does lack visual
pizzazz but I'm no artist anyway. also, the newlines in the error
messages don't work on my machine.
regards, jr.
Download 'utf-8' (2 KB)
Nice! I like your use of the #error stream interrupt
> also, the newlines in the error messages don't work on my machine.
Yeah - they don't work on mine either. So -
I prefaced the #error directive with #warning messages, and _then_ triggered the
error. Seems to sorta do what I think you were after.
I was a little confused, since I run POV-Ray on a Winbloze 7 machine and don't
often use CLI.
Don't judge me. :O
I also rearranged the text a bit to make it somewhat clearer what's going on in
case it gets run without any idea what it's supposed to do.
"Hey, what's this .pov file I have in this directory... ?"
You also forgot to #declare Whip = "Bald Eagle" :P
/* parsestr.pov
* this simple scene demonstrates the use of the 'Parse_String' macro
* to build Object Identifiers dynamically, at runtime.
* Parse_String(String): This macro takes a string, writes it to a file, and
then includes that file.
* This has the effect of parsing that string: "Parse_String("MyColor")" will be
seen by POV-Ray as "MyColor".
* Parameters:
* String = The string to be parsed.
* command-line:
* povray Declare=OBJ=N ... <<< Necessary for this scene to work!
* where N is one of the following:
* 1 - box, 2 - cylinder, 3 - ovus, 4 - sphere, 5 - torus.
* date: 19.3.2016.
* author: jr <cre### [at] gmail com>.
* license: Creative Commons CC0.
* thanks to 'Bald Eagle' who provided the inspiration (motivation!).
#version 3.7;
global_settings { assumed_gamma 1.0 }
// Parse_String.
#include "strings.inc"
light_source { <10,10,-10> White }
location <1.5,1.5,-2.5>
look_at <0,0,0>
// objects to select.
#declare the_box = box {<-0.5, -0.5, -0.5>, <0.5, 0.5, 0.5> texture {pigment
{Blue}}};
#declare the_cylinder = cylinder {<0,-0.5, 0>, <0, 0.5, 0>, .65 texture {pigment
{Blue}}};
#declare the_ovus = ovus {.65, .35 texture {pigment {Blue}}};
#declare the_sphere = sphere {<0,0,0>, 1 texture {pigment {Blue}}};
#declare the_torus = torus {1, .35 texture {pigment {Blue}}};
#declare the_help = "1 (box), (2) cylinder, (3) ovus, (4) sphere, or (5) torus";
#declare the_objs = array[5];
#declare the_objs[0] = "box";
#declare the_objs[1] = "cylinder";
#declare the_objs[2] = "ovus";
#declare the_objs[3] = "sphere";
#declare the_objs[4] = "torus";
#declare the_prefix = "the_";
// verify OBJ has been declared and is in range.
#ifndef (OBJ)
#warning
******\n"
#warning concat("*** Missing argument: OBJ
***\n")
#warning concat("*** Need Command-Line statement \"Declare=OBJ=X\", where X = :
", the_help, ". ***\n")
#warning "***
***\n"
#warning
******\n"
#error concat(" *** Need Command-Line \"Declare=OBJ=X\", where X = : ",
the_help, ".\n")
// Try using _____Declare=OBJ=1_____ in the command-line box to the right of
the render resolution drop-down menu
#elseif (1 > OBJ | 5 < OBJ)
#warning
******\n"
#warning concat("*** Bad argument# for: OBJ Please select
a different number ***\n")
#warning "***
***\n"
#warning concat("*** Select (1-5): ", the_help, ". You used: _",
str(OBJ,0,0),"_. ***\n")
#warning
******\n"
#error concat(" *** Bad argument # for OBJ \n Select (1-5): ", the_help, ".
You used: _", str(OBJ,0,0),"_.\n")
// confirm selection.
#debug concat ("\n \n You chose the '", the_objs[OBJ-1], "', \n Now rendering
object '", the_prefix, the_objs[OBJ-1] ,"'.\n")
// use macro.
object { Parse_String (concat (the_prefix, the_objs[OBJ-1]) ) }
hi,
On 19/03/2016 03:13, Bald Eagle wrote:
cool, thank you. two nits though [cue image of Edvard Munch's "The
Scream" :-)]:
you write:
> often use CLI.
which means that the added comment ("..Try using _____Declare=OBJ=1_____
in the command-line box..") ought to be at the top of the file, along
with the other usage info, to avoid other Windows users getting 'caught
out'.
and wrt the confirmation message, it's one sentence and there's a comma
before the 'now rendering', so the 'now' should be lowercase (unless you
prefer it as two, shorter sentences).
also, given that the .pov is the result of collaborative effort, I think
you ought to rip out the "thank you to" line and add self to authors.
jr.
> Scream" :-)]:
Yes, one can't cue the genuine article as it was stolen.
There's _always_ a nit or two. I do shots of Lagavulin and Rid to keep that to
a minimum when coding...
> out'.
Well, I DO have that arrow pointing to your note
* command-line:
to highlight that, up in the green comment block. I thought that might be
enough.
The line you're referring to is immediately below the yellow highlighted SDL
when the parse error gets triggered, which is where the [new] user's attention
will be at that moment, not at the top of the file.
I was just getting my OCD on, and dabbling with the text.
Most generous and respectful, but I hardly think that a few minor playful edits
merit that.
I do, however, like very much what you're done with using the array, which is
what caught my attention to begin with. I had recently been wanting to do
exactly what you illustrate, but didn't _need_ to, and had other things I was
working on (being thwarted by), so I didn't look up the parse string thing,
which I recalled being mentioned in the past.
I think that _THAT_ is the aspect of this that deserves some attention and
development, as I think we could play with it some and produce some valuable
tools and methods.
Two ideas I have - and feel free to pursue these - are a sort of automatic or
randomized code generation - since different string fragments could be strung
together to make a whole functional SDL scene. :D
More practical though, would be a shorthand method for #declaring lots of
variables. I was trying to think about a way to do something like:
#declare a=1; b=2; c=3; d=4; ... and this seems to be the way to accomplish
that. Either through a loop, or by just arranging the variable names and
values in an array. That cuts out a ton of hand-typed #declares.
I'm sure there are other things to apply this to, but right now I'm just
brainstorming.
I shall let it all bounce around my head some more.
Well met, Mr. jr. :)
hi,
On 19/03/2016 21:25, Bald Eagle wrote:
I may get back to the rest of your post, time and inclination
permitting, but the following caught my eye, there appears to be a
certain amount of overlap in interest:
way ahead of you here (at least wrt design), the idea is a set of GUI
panels[*], one each for camera, light, global_settings, etc. they're
conceptually stand-alone, so a scene file which is complete bar, say,
the lighting, would have said element inserted when user writes/saves
that scene from the lighting panel.
the benefit, as I see it, is that the modularity allows developing a
complete application piecemeal.
there's the potential problem of having a .pov which won't parse because
of syntax. and, although the SDL is Turing-complete, I don't think it'd
be on my shortlist of tools when a pre-processor/generator needs
writing. just a hunch (bearing in mind I'm still fairly new to much of
POv), but I'd keep modified syntax in separate file(s).
jr.
[*] my choice of tool is John Ousterhout's Tool Control Language (Tcl)
and its graphics toolkit. if not familiar with Tcl, I'd recommend a
visit to https://wiki.tcl.tk. Tcl is a source distribution but you can
get Windows binaries from www.activestate.com. and if you feel flush,
the bible aka "Tcl and the Tk Toolkit" by J Ousterhout, now in its 2nd
edition, is very much worth the USD 60 cover price.
Am 19.03.2016 um 22:25 schrieb Bald Eagle:
How about
#declare (a,b,c,d) = (1,2,3,4);
Besides serving as shorthand for multiple declares, it comes with two
extra benefits that your suggestion doesn't provide:
- The values are grouped together, separate from the list of
identifiers, so that the values can be generated by a single macro
invocation, allowing a macro to return a set of values:
#macro MyMacro()
(1,2,3,4)
#declare (a,b,c,d) = MyMacro()
- It is already implemented in the current 3.7.1-alpha ;)
clipka <ano### [at] anonymous org> wrote:
> How about
http://news.povray.org/povray.beta-test/thread/%3C558b4c09$1@news.povray.org%3E/
I see. Thanks for the tip :)
Although it's not explicitly stated in your post that I linked, I'm assuming I
can't mix strings and floats and array elements in a single "tuple-style"
declare.
e.g. #declare (a, filename, MyArray[3]) = (4.2, "TestFile", <1, 2, 3>)
or a mix of scalar and vector quantities
#declare (g, h, i) = (1, <3, 4, 5>, 567.89)
IIRC, someone came up with a way to "trick" POV-Ray to "mix" element types using
arrays of arrays....
Am 21.03.2016 um 03:07 schrieb Bald Eagle:
> declare.
You're assuming wrong there in every respect :)
In this context, I guess it's worth noting that the above syntax is just
shorthand for multiple declares; there is still no tuple data type, i.e.
#declare MyTuple = (1,2,3);
#declare (a,b,c) = MyTuple;
will NOT work.
hi
>> declare.
> will NOT work.
do people (still) use CSV files to provide data, because I think the
syntax looks perfect for a record-at-a-time reading of such files.
jr.
Sure, it's used all the time.
It's actually the format for POV-Ray's file I/O commands.
http://www.povray.org/documentation/view/3.6.1/238/
"The format of the data to be read must be a series of valid string literals,
float literals, or vector literals separated by commas."
hi,
ouch, I never made the connection.. :-(
jr.
