POV-Ray : Newsgroups : povray.general : 15 Shapes Taking Forever Server Time
4 Mar 2026 04:07:29 EST (-0500)
  15 Shapes Taking Forever (Message 1 to 10 of 12)
Subject: 15 Shapes Taking Forever
Date: 17 Feb 2016 22:39:36
Message: <56c53cf8@news.povray.org>
I have a tiny mini scene, but it takes forever to render it. Wow.
Please let me know, how long this scene needs on your computer.
800x600, AA 0.3, highest quality, radiosity settings as defined inside
the scene.
#version 3.7;
#declare MyRadiosity             = on; // on or off
#declare MediumRadiosity         = off;
#declare FastRadiosity           = on;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   #if(FastRadiosity)
    pretrace_end   0.015
   #elseif(MediumRadiosity)
    pretrace_end   0.008
   #else
    pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
 adc_bailout       0.0039
 ambient_light     rgb < 1.000, 1.000, 1.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 location < -1.0, 1.0, -1.0 >
 look_at  <  0.0, 0.5,  0.0 >
 right 1.77*x
background { rgb < 0.50980, 0.52157, 0.99216 > * 0.525 }
light_source
 < 10.0, 10.0, -10.0 >
 rgb < 1.0, 1.0, 1.0 > * 0.5
light_source
 < 10.0, 10.0, -10.25 >
light_source
 < 10.0, 10.25, -10.0 >
light_source
 < 10.0, 10.25, -10.25 >
#declare MyGlass = texture
 pigment { rgbt < 0.00784, 0.99216, 0.60000, 0.8 > }
 finish { reflection 0.5 }
// 42 93 26 x 0.6
box // Back
 < -0.21, 0.0, 0.254 > < 0.21, 0.93, 0.26 >
 texture { MyGlass }
box // Left
 < -0.21, 0.0, 0.0 > < -0.204, 0.93, 0.26 >
 texture { MyGlass }
box // Right
 < 0.21, 0.0, 0.0 > < 0.204, 0.93, 0.26 >
 texture { MyGlass }
box // Bottom
 < -0.21, 0.0, 0.0 > < 0.21, 0.006, 0.26 >
 texture { MyGlass }
box // Top
 < -0.21, 0.924, 0.0 > < 0.21, 0.93, 0.26 >
 texture { MyGlass }
box // Balcony Bottom
 < -0.21, 0.80, 0.18 > < 0.21, 0.806, 0.26 >
 texture { MyGlass }
box // Balcony Front
 < -0.21, 0.80, 0.18 > < 0.21, 0.85, 0.186 >
 texture { MyGlass }
box // Front Top Border
 < -0.21, 0.886, 0.04 > < 0.21, 0.93, 0.046 >
 texture { MyGlass }
box // Front Bottom Border
 < -0.21, 0.0, 0.04 > < 0.21, 0.106, 0.046 >
 texture { MyGlass }
box // Front Bottom Front
 < -0.21, 0.0, 0.0 > < 0.21, 0.046, 0.006 >
 texture { MyGlass }
box // Bottom Pool Left
 < -0.056, 0.0, 0.04 > < -0.05, 0.106, 0.26 >
 texture { MyGlass }
box // Bottom Pool Right
 < 0.056, 0.0, 0.04 > < 0.05, 0.106, 0.26 >
 texture { MyGlass }
box // Front Door
 < 0.5, 0.0, -0.1 > < 0.92, 0.93, -0.094 >
 texture { MyGlass }
difference
 union
  torus { 0.05, 0.01 rotate < 0.0, 0.0, 90.0 > translate < 0.60, 0.65,
-0.1 > }
  torus { 0.05, 0.01 rotate < 0.0, 0.0, 90.0 > translate < 0.82, 0.65,
-0.1 > }
 box { < 0.5, 0.55, -0.1 > < 0.92, 0.75, 0.05 > }
 pigment { rgb < 0.9, 0.9, 0.95 > }
 finish { reflection 0.9 metallic 0.5 }
cylinder // Ground
 < 0.0, -0.1, 0.0 > < 0.0, -0.0001, 0.0 > 1.0
 pigment
  spherical
  color_map
   [ 0.00 rgb  < 0.50980, 0.52157, 0.99216 > * 0.525 ]
   [ 1.00 rgb  2.0 ]
  rotate < 0.0, 0.0, 0.0 >
 translate < 0.2, 0.0, 0.2 >
Subject: Re: 15 Shapes Taking Forever
Date: 18 Feb 2016 04:11:30
Message: <56c58ac2$1@news.povray.org>
six minutes [with +wt6 (out of 8)]
Date: 18 Feb 2016 05:05:15
Message: <56c5975b$1@news.povray.org>
> the scene.
Two minutes 30 seconds in an i7 machine 12 threads.
Two minutes 24 seconds +BS8
Two minutes 24 seconds +BS16
Three minutes 7 seconds +BS64
Two minutes 20 seconds +BS8 Priority high (PovRay) display closed.
Two minutes 21 seconds +BS8 Priority high (PovRay) display open.
Two minutes 20 seconds +BS8 Priority high (PovRay) Priority Realtime
(Windows) display open.
Two minutes 23 seconds +BS8 Priority Normal (PovRay) Priority Realtime
(Windows) display closed.
Regards
Date: 18 Feb 2016 06:50:29
Message: <56c5b005$1@news.povray.org>
> the scene.
Spot on 2 mins 30 s here too, I just chose 800x600 AA0.3 from the menu
and hit Run (no command line options). Xeon E5-1650
Date: 18 Feb 2016 10:01:52
Message: <56c5dce0@news.povray.org>
Thanks to everyone. In my case, over 30 minutes. Don't know, why. My
machine is slower, but it shouldn't be thaaat slow.
Can you post these images inside the image section? Thanks.
Date: 18 Feb 2016 10:35:05
Message: <56c5e4a9@news.povray.org>
What CPU is it?
Date: 18 Feb 2016 12:30:00
Message: <web.56c5feb2ed845ad833c457550@news.povray.org>
> the scene.
Just as a point of reference:
On my old but trusty Windows XP machine (single-core, 32-bit, with AMD Athlon64
3400 processor but running in 32-bit mode) and using the latest v3.71
'development build'...
   55 min  45 sec
OOOH, that's sad. And embarrassing. :-O
Maybe if I used TWO Windows XP machines...  (ha!)
Date: 18 Feb 2016 12:38:50
Message: <56c601aa@news.povray.org>
> the scene.
i7 980 (3.33GHz), 6 cores+HT
 -Itime.pov +H600 +W800 +A0.3 +WT12
  Radiosity Time:   0 hours  2 minutes 15 seconds (135.492 seconds)
              using 12 thread(s) with 1489.054 CPU-seconds total
  Trace Time:       0 hours  0 minutes 29 seconds (29.746 seconds)
              using 12 thread(s) with 274.329 CPU-seconds total
	Percent of CPU this job got: 1061%
	Elapsed (wall clock) time (h:mm:ss or m:ss): 2:46.12
	Maximum resident set size (kbytes): 69328
 -Itime.pov +H600 +W800 +A0.3 +WT6
(only true cores)
  Radiosity Time:   0 hours  2 minutes 34 seconds (154.453 seconds)
              using 6 thread(s) with 896.823 CPU-seconds total
  Trace Time:       0 hours  0 minutes 36 seconds (36.837 seconds)
              using 6 thread(s) with 188.611 CPU-seconds total
	Percent of CPU this job got: 565%
	Elapsed (wall clock) time (h:mm:ss or m:ss): 3:12.16
	Maximum resident set size (kbytes): 49616
  Radiosity Time:   0 hours 14 minutes 42 seconds (882.553 seconds)
              using 1 thread(s) with 882.539 CPU-seconds total
  Trace Time:       0 hours  3 minutes  6 seconds (186.465 seconds)
              using 1 thread(s) with 186.457 CPU-seconds total
	Percent of CPU this job got: 100%
	Elapsed (wall clock) time (h:mm:ss or m:ss): 17:49.93
	Maximum resident set size (kbytes): 38160
Download 'time.png' (62 KB)
Preview of image 'time.png'
Date: 18 Feb 2016 13:30:04
Message: <56c60dac$1@news.povray.org>
Am 18.02.2016 um 18:38 schrieb Le_Forgeron:
> [...image...]
Tsk, tsk... you should know better than to post images here ;)
Date: 18 Feb 2016 15:52:58
Message: <56c62f2a@news.povray.org>
I want to express my honest big thanks to all of you here. There is
really a very great spirit in this group, and I like it very much. My
appreciation to everyone.
Some of you get really amazing speeds, I can only dream about it.   :-D
