POV-Ray : Newsgroups : povray.general : Wanted: Air and Water Server Time
5 Nov 2026 07:24:25 EST (-0500)
  Wanted: Air and Water (Message 1 to 50 of 51)
Goto Latest 50 Messages Next 1 Messages >>>
Subject: Wanted: Air and Water
Date: 10 Feb 2016 21:35:27
Message: <56bbf36f@news.povray.org>
does anyone have a realistic way to simulate air and water?
For the air, it should make everything fading in distance to a air blue
and behave in all other ways also like atmosphere.
And the water should have transparency that becomes more bluish in
distance, simply like real water, too.
I intend to use both inside a cylinder, where the air would be in the
shape of a cylinder, and the water in the shape of a difference
(cylinder/cylinder).
Thanks a lot for your help.
Subject: Re: Wanted: Air and Water
Date: 11 Feb 2016 02:53:59
Message: <56bc3e17$1@news.povray.org>
On 11-2-2016 3:35, Sven Littkowski wrote:
> Hi,
The keyword for both is: media.
If you want to learn about POV-Ray, I suggest you first experiment
deeply with the technique involved and then show us the results
(successes and failures).
Date: 11 Feb 2016 06:11:31
Message: <56bc6c63@news.povray.org>
Yes, I have used Media in a few cases before. But I find it hard, to
make it having the colors I want, and I indeed (here you're right) don't
have much understanding on how to work with it.
The media I need, would me of a cylindrical shape, thus I would create a
cylinder and fill it with media, that I know. But beyond that, there is
the vast void that I have to conquer, thus I need help to develop the
technologies for that. ;-)
Date: 11 Feb 2016 07:21:43
Message: <56bc7cd7@news.povray.org>
You can only get a generalised help. From my experience every time I use
media I have to relearn how to use it. It seems to me that each
different usage requires different settings.
Regards
Date: 11 Feb 2016 07:31:09
Message: <56bc7f0d$1@news.povray.org>
As for the air, I would say that a scattering media with a slightly
bluish tint would do the trick. Water is more tricky as it involves
absorption (red I would guess) in addition to scattering.
Date: 11 Feb 2016 07:45:06
Message: <56bc8252$1@news.povray.org>
Yes, that is exactly the reason, why I find it so difficult to use,
despite of the gains it has.
Date: 11 Feb 2016 07:45:58
Message: <56bc8286$1@news.povray.org>
Thanks. There are two keywords in it, which will help me now to
investigate better: scattering and absorption.
Date: 11 Feb 2016 08:04:08
Message: <56bc86c8$1@news.povray.org>
With scattering you might also need to scatter a reddish/orange colour
to get blue. I think I was wrong in my previous post.
Good starting point for air and water are - as always:
http://www.f-lohmueller.de/pov_tut/
http://www.imagico.de/pov/water/water04.php
Date: 11 Feb 2016 09:41:51
Message: <56bc9daf$1@news.povray.org>
There is also emission which you could use for the central light source.
I was going to mention Rune Johansen's "electric.inc" but that uses the
glow keyword which requires MegaPov. So it will not work with the
official PovRay.
Nevertheless Rune's site does have some good include files that you
might find useful. I often use his Grass Tex Include File and his
Particle System is good too.
Regards
Date: 11 Feb 2016 09:45:03
Message: <56bc9e6f$1@news.povray.org>
On 2/11/2016 2:41 PM, Stephen wrote:
> Rune's site
Oops!
http://runevision.com/3d/
Regards
Date: 11 Feb 2016 16:05:31
Message: <56bcf79b$1@news.povray.org>
Lohmueller and Imagico give a good tutorial on water. That was a good help.
Lohmueller has a tutorial only about clouds, but I need something
different, interior or media or so, for the entire air body.
Still trying to find some ways to create an atmosphere...
Date: 11 Feb 2016 20:07:09
Message: <56bd303d@news.povray.org>
Le 16-02-10 21:35, Sven Littkowski a écrit :
> Hi,
For air, use a low density scattering media with a blueish tint, like
rgb<0.5, 0.7, 1>
Make sure that your container have the hollow option enabled. Simply
adding "hollow" is enough.
A quick and dirty alternative is the use of fog with the appropriate
colour. fog is fast and never interact with your light sources. It will
affect shadowed areas in the same way it affect lighted areas.
Appropriate for testing in the composition phase.
For the water, you can also use media, but, you can also use colour fading.
Adding refraction is crutial to get beleiveable water. Refraction is
turned on by having an ior in the interior block.
interior{ior 1.33 // typical water ior
  fade_colour <0.4, 0.66, 0.9>
  fade_distance SomeDistanceValue
  fade_power 1 // or 1001
Adjust "SomeDistanceValue" as needed to get the result that you want.
Fading is compatible with the use of media.
You don't need the media if you want to model very limpid water, but
media is required if the water is to have any turbidity.
Colour fading is fast, very fast compared with scattering media, so, the
testing won't take much time.
Date: 11 Feb 2016 20:13:52
Message: <56bd31d0$1@news.povray.org>
> official PovRay.
For the glow, you can use emissive media with an appropriate pattern.
The spherical pattern is often the best suitted one, followed by
cylindrical.
media{emission Colour}
This gives you an uniform glowing media.
sphere{0, 1 pigment{rgbt 1}
  hollow
  media{emission Colour density{spherical}}
gives you a spherical glowing media, contained within an unit sphere,
that goes from full strength at the center and drop to zero at the
surface of the sphere.
Date: 11 Feb 2016 23:20:05
Message: <56bd5d75$1@news.povray.org>
Thanks. :-)
Not bad. But in my scenario, it is a bit different: there is an
illuminated day" side inside that hollow cylinder, but also a dark
"night" side. The illumination is done already by light sources at the
moment, or an emissive image maybe in the future.
The medium I need, would not need to glow. But it should give that blue
"dust" to the distance, and be brighter around a light or emission source.
Date: 11 Feb 2016 23:33:59
Message: <56bd60b7$1@news.povray.org>
For the air, I am trying to use he code below. But I am getting an error:
"Fatal Error in Renderer: A POV-Ray internal nesting limit was reached."
cylinder // Air
 < 0.0, 0.0,  0.0 > < 0.0, 0.0, 5000.0 > 1500.0
 hollow
 interior
  ior 1.3
  fade_distance 10
  fade_power 1001
  fade_color < 0.5, 0.7, 1.0 >
  media
   scattering
    3
    < 0.5, 0.65, 0.4 >
    extinction 1.0
For the water body, I am using successfully this (still dependent on the
blue of the future air medium):
difference // Water
 cylinder { < 0.0, 0.0,  0.0 > < 0.0, 0.0, 5000.0 > 1500.0 }
 cylinder { < 0.0, 0.0, -0.1 > < 0.0, 0.0, 5000.1 > MyWaterLevel }
 material
  texture
   pigment { color rgbt < 0.2, 0.7, 0.3, 0.5 > }
   finish
    ambient 0.0
    diffuse 0.0
    emission 0.0
    reflection
     0.0, 1.0
     falloff 5
     fresnel on
    specular 0.4
    roughness 0.003
   normal
    function { f_ridged_mf(x, y, z, 0.1, 3.0, 7, 0.7, 0.7, 2) } 0.8
    scale 0.13
  interior
   ior 1.3
   fade_distance 10
   fade_power 1001
   fade_color < 0.8, 0.2, 0.2, 0.5 >
   media
//    absorption < 0.8, 0.6, 1.0, 0.5 >
    scattering
     3
     < 0.5, 0.65, 0.4 >
     extinction 1.0
 normal
  0.8
  scale < 0.13, 0.4, 0.13 >
Date: 12 Feb 2016 01:35:40
Message: <56bd7d3c$1@news.povray.org>
UPDATE
For the air, I am using now successlessly the code below: it is just dark.
cylinder // Air
 hollow
 interior
  media
   scattering
    3
    < 0.5, 0.7, 1.0 >
    extinction 1.0
Date: 12 Feb 2016 03:07:28
Message: <56bd92c0$1@news.povray.org>
On 12-2-2016 7:34, Sven Littkowski wrote:
> UPDATE
Try this:
cylinder // Air
  < 0.0, 0.0,  0.0 > < 0.0, 0.0, 5.000 > 1.500
  hollow
  pigment {rgbt 1}
  interior
   media
    scattering
     1
     < 1.0, 0.7, 0.5 >/1000
     extinction 1.0
  scale 1000
(1) Note the scaling of the cylinder /and/ of the scattering.
(2) I changed the scattering colour
(3) The cylinder needs a transparent pigment
Date: 12 Feb 2016 03:09:23
Message: <56bd9333$1@news.povray.org>
> UPDATE
Try this:
cylinder // Air
  hollow
  pigment {rgbt 1}
  interior
   media
    scattering
     3
     extinction 1.0
  scale 1000
Date: 12 Feb 2016 03:25:44
Message: <56bd9708@news.povray.org>
Note also that you can thicken or thinning the atmosphere by adding an
extra multiplicator to the scattering colour:
This will thicken the atmosphere:
scattering {3  < 1.0, 0.7, 0.5 >*1.5 /1000
   extinction 1.0
This will thin it:
scattering {3 < 1.0, 0.7, 0.5 >*0.5 /1000
extinction 1.0
Date: 12 Feb 2016 03:26:59
Message: <56bd9753$1@news.povray.org>
Note also that you can thicken or thin the atmosphere by adding an extra
   extinction 1.0
This will thin it:
extinction 1.0
Date: 12 Feb 2016 03:31:32
Message: <56bd9864$1@news.povray.org>
>    extinction 1.0
> This will thin it:
> extinction 1.0
We are getting double posts from you, Thomas
Regards
Date: 12 Feb 2016 03:40:34
Message: <56bd9a82$1@news.povray.org>
>>    extinction 1.0
>> This will thin it:
>> extinction 1.0
Due to typing errors, I deleted my initial messages and sent the
corrected ones again. Apparently, Thunderbird correctly makes the
deletions invisible (at least for me) but not the website.
Date: 12 Feb 2016 04:43:40
Message: <56bda94c@news.povray.org>
Update
I made some progress, but still have a problem: while seen from the
daytime position everything looks fine, the sunset and night positions
are not correct: no night darkness, and no sunset colors.
If you can help, please try. Thanks.
#version 3.7;
#include "macros.inc"
#include "shapes.inc"
#declare MyRadiosity             = on; // on or off
#declare MediumRadiosity         = on;
#declare FastRadiosity           = off;
#declare CameraDaytime           = on;
#declare CameraSunset            = off; // Problem: doesn't look like sunset
#declare CameraNighttime         = off; // Problem: doesn't look like sunset
#declare CameraOutside           = off;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   #if(FastRadiosity)
    pretrace_end   0.015
   #elseif(MediumRadiosity)
    pretrace_end   0.008
   #else
    pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
 adc_bailout       0.0039
 ambient_light     rgb < 1.000, 1.000, 1.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#default { pigment { rgb 1.0 } finish { ambient 0.0 specular 1.0 } }
#if(CameraDaytime)
camera // Daytime Position Inside
 location < 0.0, -1400.0, 100.0 >
 look_at  < 0.0, -1400.0, 200.0 >
 right 1.77*x
#elseif(CameraSunset)
camera // Sunset Position Inside
 location < 1400.0, 0.0, 100.0 >
 look_at  < 1400.0, 0.0, 200.0 >
 right 1.77*x
#elseif(CameraNighttime)
camera // Nighttime Position Inside
 location < 0.0, 1400.0, 100.0 >
 look_at  < 0.0, 1400.0, 200.0 >
 right 1.77*x
#elseif(CameraOutside)
camera // Outside
 location < -5000.0, 5000.0, -5000.0 >
 look_at < 0.0, 0.0, 0.0 >
 right 1.77*x
#declare Seed=seed(441);
#if(CameraOutside)
/*light_source
 < -10000.0, 10000.0, 10000.0 >
 color rgb < 1.0, 1.0, 1.0 >
light_source { < -5000, 10000, 10000 > color rgb < 0.2, 0.1, 0.0 > *3.0 }
light_source { < -10000, 05000, 10000 > color rgb < 0.5, 0.5, 0.5 > }
light_source { < -5000, -10000, 10000 > color rgb < 0.005, 0.0, 0.01 > }
#declare LightDistance = -253.1;
#declare LightWidth = 50.0;
#declare MyRadius = 5;
#declare MyTightness = 50;
#declare MyFalloff = 80;
#declare MyLightMultiplicator = 0.007;
#declare LightSectionHalf = union
 light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.98824,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 000.0, -1500.0,
0.0 > radius 10 tightness 10 falloff 20 rotate < 0.0, 0.0,  2.5 > }
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 050.0, -1350.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 100.0, -0950.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 150.0, -0700.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 175.0, -0600.0,
0.0 > radius MyRadius tightness MyTightness falloff MyFalloff rotate <
0.0, 0.0,  5.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.88627,
0.50196 > * MyLightMultiplicator*05 spotlight point_at < 200.0, -0550.0,
0.0, 0.0,  7.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.69412,
0.28235 > * MyLightMultiplicator*04 spotlight point_at < 225.0, -0500.0,
0.0, 0.0, 10.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.99608, 0.35686,
0.08627 > * MyLightMultiplicator*04 spotlight point_at < 250.0, -0450.0,
0.0, 0.0, 12.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.76863, 0.27059,
0.05882 > * MyLightMultiplicator*04 spotlight point_at < 275.0, -0400.0,
0.0, 0.0, 15.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.54902, 0.10980,
0.10980 > * MyLightMultiplicator*03 spotlight point_at < 300.0, -0350.0,
0.0, 0.0, 17.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.43922, 0.09412,
0.16078 > * MyLightMultiplicator*03 spotlight point_at < 325.0, -0300.0,
0.0, 0.0, 20.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.31373, 0.07843,
0.14902 > * MyLightMultiplicator*02 spotlight point_at < 350.0, -0250.0,
0.0, 0.0, 22.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.15294, 0.04706,
0.10588 > * MyLightMultiplicator*02 spotlight point_at < 375.0, -0200.0,
0.0, 0.0, 25.0 > }
#declare LightSection = union
 object { LightSectionHalf scale <  1.0, 1.0, 1.0 > }
 object { LightSectionHalf scale < -1.0, 1.0, 1.0 > }
#declare RundeLight = 50.0;
#while(RundeLight<4950.0)
 object { LightSection  translate < 0.0, 0.0, RundeLight > }
 #declare RundeLight = RundeLight+50.0;
#macro
RoundCilinderSegment(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,BevelHeight,MaxLength)
	#local Start=y*(StartHeight+Bevel);
	#local Eind=y*(EindHeight-Bevel);
	#local Start2=y*StartHeight;
	#local Eind2=y*EindHeight;
		#local StartHoek2=StartHoek+degrees(Bevel/Radius);
		#local EindHoek2=EindHoek-degrees(Bevel/Radius);
		#local TotaleLengte=radians(EindHoek-StartHoek)*(Radius+BevelHeight);
		#local Aantal=max(int(TotaleLengte/MaxLength),1);
		#local Tel=0;
		mesh {
			triangle {
				vrotate(<Radius,StartHeight,0>,y*StartHoek),
				vrotate(<Radius,EindHeight,0>,y*StartHoek),
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*StartHoek2)
			triangle {
				vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*StartHoek2),
			triangle {
				vrotate(<Radius,EindHeight,0>,y*StartHoek2),
			triangle {
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*StartHoek2),
				vrotate(<Radius,StartHeight,0>,y*StartHoek2)
			triangle {
				vrotate(<Radius,StartHeight,0>,y*EindHoek),
				vrotate(<Radius,EindHeight,0>,y*EindHoek),
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*EindHoek2)
			triangle {
				vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*EindHoek2),
			triangle {
				vrotate(<Radius,EindHeight,0>,y*EindHoek2),
			triangle {
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*EindHoek2),
				vrotate(<Radius,StartHeight,0>,y*EindHoek2)
			#while (Tel<Aantal)
				#local H1=StartHoek2+(EindHoek2-StartHoek2)*(Tel/Aantal);
				#local H2=StartHoek2+(EindHoek2-StartHoek2)*((Tel+1)/Aantal);
				#local P1=vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*H1);
				#local P2=vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*H1);
				#local P3=vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*H2);
				#local P4=vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*H2);
				#local N1=vrotate(x,y*H1);
				#local N2=vrotate(x,y*H2);
				smooth_triangle {P1,N1,P2,N1,P4,N2}
				smooth_triangle {P2,N1,P3,N2,P4,N2}
				//triangle {P1,P2,P4}
				//triangle {P2,P3,P4}
				#local P2B=vrotate(<Radius,EindHeight,0>,y*H1);
				#local P3B=vrotate(<Radius,EindHeight,0>,y*H2);
				triangle {P2,P2B,P3}
				triangle {P2B,P3B,P3}
				#local P2B=vrotate(<Radius,StartHeight,0>,y*H2);
				#local P3B=vrotate(<Radius,StartHeight,0>,y*H1);
				triangle {P2B,P1,P3B}
				triangle {P1,P4,P2B}
				#local Tel=Tel+1;
#macro Verlaag(X)
	#local R=X-(1+rand(Seed)*2.5);
	R
#macro
CilinderGreeble(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,BevelHeight,MaxLength,Detail)
	#local Start=(StartHeight+Bevel);
	#local Eind=(EindHeight-Bevel);
	#local StartH=StartHoek+degrees(Bevel/Radius);
	#local EindH=EindHoek-degrees(Bevel/Radius);
	//cilindertjes:
	#local Aantal=rand(Seed)*Detail;
	#while (Aantal>0)
		#local Size=(Bevel*.01)+rand(Seed)*Bevel*.99*2;
		#local Hoek=StartH+(EindH-StartH)*rand(Seed);
		#local Hoogte=Start+(Eind-Start)*rand(Seed);
		#local Depth=BevelHeight/2+rand(Seed)*BevelHeight/2;
		superellipsoid {<1,.1+rand(Seed)*.3> rotate y*90  scale
<Depth,Size,Size> translate x*Radius rotate y*Hoek translate y*Hoogte}
		#local Aantal=Aantal-1;
	//vakjes:
	#while (Aantal>0)
		#local S=Start+(Eind-Start)*rand(Seed);
		#local E=S+(Eind-S)*rand(Seed);
		#local SH=StartH+(EindH-StartH)*rand(Seed);
		#local EH=SH+(EindH-SH)*rand(Seed);
		#local H=BevelHeight/2+rand(Seed)*BevelHeight/2;
		RoundCilinderSegment(S,E,Radius,SH,EH,Bevel/2,H,AantalStapjes)
	//verticale buisjes
	#while (Aantal>0)
		//#local EH=SH+(EindH-SH)*rand(Seed);
		#local H=(BevelHeight/2+rand(Seed)*BevelHeight/2)/2;
		//RoundCilinderSegment(S,E,Radius,SH,EH,Bevel/2,H,AantalStapjes)
		cylinder {y*S,y*E,H translate x*Radius rotate y*SH}
		sphere {y*S,H translate x*Radius rotate y*SH}
		sphere {y*E,H translate x*Radius rotate y*SH}
	//horizontale buisjes simuleren, toruskes zouden wsl te traag gaan
	#while (Aantal>0)
		#local H=min((Eind-S),H*2)/2;
		#local E=S+H*2;
		RoundCilinderSegment(S,E,Radius,SH,EH,H,H,AantalStapjes)
#macro
VerdeelCilinder(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Diepte,Bevel,BevelHeight)
	#if (Diepte<0)
		#ifndef(Detail) #local Detail=5; #end
		#local H=rand(Seed)*BevelHeight;
		#ifndef(MaxSegmentLength) #local AantalStapjes=Bevel; //(eigenlijk de
maximale lengte van een segment)
		#else #local AantalStapjes= MaxSegmentLength; #end
RoundCilinderSegment(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,H,AantalStapjes)
CilinderGreeble(StartHeight,EindHeight,Radius+H,StartHoek,EindHoek,Bevel,H,AantalStapjes,Detail)
	#else
		// eerst es checken of 't nie onvoorstelbaar ongelijk verdeeld is:
		#local Lengte=radians(EindHoek-StartHoek)*Radius;
		#local Hoogte=EindHeight-StartHeight;
		#local PercentageU=.5+(rand(Seed)-rand(Seed))*.5*.9;
		#local PercentageV=.5+(rand(Seed)-rand(Seed))*.5*.9;
		#local MidHeight=StartHeight+(EindHeight-StartHeight)*PercentageU;
		#local MidHoek=StartHoek+(EindHoek-StartHoek)*PercentageV;
		// als't 2 keer zo hoog als breed is (of nog hoger), dan ff enkel in
de hoogte bijsnijden:
		#if ((Hoogte>(Lengte*2))&(rand(Seed)>.125))
VerdeelCilinder(StartHeight,MidHeight,Radius,StartHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,StartHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
		// als't 2 keer lager dan breed is (of nog lager), dan ff enkel in de
breedte bijsnijden:
		#else
			#if (((Hoogte*2)<Lengte)&(rand(Seed)>.125))
VerdeelCilinder(StartHeight,EindHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(StartHeight,EindHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
			#else
VerdeelCilinder(StartHeight,MidHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(StartHeight,MidHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
//#include "textures.inc"
#declare HabitatOutside = union
 #declare Detail=5;
 #declare MaxSegmentLength=.1;
 VerdeelCilinder(-3,3,1,0,360,10,.002,.0075)
 cylinder {-3*y,3*y,1}
 //Metaal()
 rotate < 90.0, 0.0, 0.0 >
 translate < 0.0, 0.0, 3.0 >
 scale < 1.0*1600.0, 1.0*1600.0, (1.0/6.0)*5200.0 >
 translate < 0.0, 0.0, -100.0 >
#declare Backbone = union
 #declare Detail=5;
 //Metaal()
 scale < 750.0, 750.0, (1.0/6.0)*5000.0 >
 translate < 0.0, 0.0, 0.0 >
#declare MyLight = difference  // Backbone Light
 cylinder { < 0.0, 0.0, 0.0 > < 0.0, 0.0, 5000.0 > 760.0 }
 box { < -760.1, 0.0, -0.1 > <  760.1, 760.1, 5000.1 > }
 pigment
  gradient x
  color_map
   [ 0.00 rgb < 0.00000, 0.00000, 0.00000 > * 1 ]
   [ 0.05 rgb < 0.15294, 0.04706, 0.10588 > * 1 ]
   [ 0.10 rgb < 0.31373, 0.07843, 0.14902 > * 1 ]
   [ 0.30 rgb < 1.00000, 0.69412, 0.28235 > * 1 ]
   [ 0.425 rgb < 1.00000, 0.98824, 0.88235 >* 2 ]
   [ 0.575 rgb < 1.00000, 0.98824, 0.88235 >* 2 ]
   [ 0.70 rgb < 1.00000, 0.69412, 0.28235 > * 1 ]
   [ 0.90 rgb < 0.31373, 0.07843, 0.14902 > * 1 ]
   [ 0.95 rgb < 0.15294, 0.04706, 0.10588 > * 1 ]
   [ 1.00 rgb < 0.00000, 0.00000, 0.00000 > * 1 ]
  translate < -0.5, 0.0, 0.0 >
  scale < 1520.0, 1.0, 1.0 >
 finish { emission 1.0 }
 translate < 0.0, -10.0, 0.0 >
#declare MyAtmosphere = cylinder // Air
 pigment { rgbt < 1.0, 1.0, 1.0, 1.0 > }
 hollow
 interior
  fade_colour < 0.4, 0.66, 0.9 >
  fade_distance 5000.0
  fade_power 1001
  media
   emission 0.0005
   density
    gradient y
    density_map
     [ 0.0 rgb < 0.5, 0.7, 1.0 > * 0.1 ]
     [ 0.4 rgb < 0.5, 0.7, 1.0 > ]
     [ 0.5 rgb < 0.5, 0.7, 1.0 > ]
     [ 1.0 rgb < 0.0, 0.0, 0.0 > ]
    translate < 0.0, -0.5, 0.0 >
    scale < 3000.0, 3000.0, 1.0 >
//   absorption 1000.0
/*   scattering
    1
    < 0.5, 0.7, 1.0 >
    extinction 1.0
#declare Fn_1 = function(x,y,z)
 1-(-f_snoise3d(x*5,y*3,z*5)*0.8)
#declare TheLandscape = object
 HF_Cylinder( Fn_1, // Function,
                 0, // UseUVheight:  0 or 1
                 1, // UseUVtexture: 0 or 1
           <50,50>, // Resolution,
                 1, // Smooth: 0 or 1
 "", // FileName, ""=no file,  Colony Ship I - Heightfield Landscape.png
           <0,0,0>, // EndA,
         <0,1.5,0>, // EndB
              1.60 ,// Radius
               0.05  // Depth
 scale < 0.58, 0.67, 0.58 >
 scale < 1500.0, 1500.0, 2500.0 >
#declare MyLandscape = union
 object { TheLandscape scale < 1.0, 1.0,  1.0 > translate < 0.0, 0.0,
0000.0 > }
 object { TheLandscape scale < 1.0, 1.0, -1.0 > translate < 0.0, 0.0,
5000.0 > }
 pigment { rgb < 0.05, 0.25, 0.0 > }
 finish { emission 0.0 }
#declare MyWaterLevel = 1440.0;
#declare fn_pattern = function
 pattern { bozo scale 0.15 }
#declare fn_water = function
 z - fn_pattern(x, y, 0)*0.25
#declare MyWater = difference // Water
 material
  texture
   finish
    ambient 0.0
    diffuse 0.0
    emission 0.0
    reflection
     0.0, 1.0
     falloff 5
     fresnel on
    specular 0.4
    roughness 0.003
   normal
    scale 0.13
  interior
   ior 1.3
   fade_distance 10
   fade_power 1001
   media
    scattering
     3
     < 0.5, 0.65, 0.4 >
     extinction 1.0
 normal
  0.8
object { HabitatOutside hollow }
object { Backbone hollow }
object { MyLight }
object { MyAtmosphere }
object { MyLandscape }
object { MyWater }
Download 'sl - colony ship i.png' (106 KB)
Preview of image 'sl - colony ship i.png'
Date: 12 Feb 2016 04:47:27
Message: <56bdaa2f$1@news.povray.org>
Thanks, seeing your advises now. Look further down - how do you like my
atmosphere? It is not perfect: the nighttime position is not dark but
blue, and the sunset camera position also does not show sunset colors.
Any idea?
Code and image inside my update posting.
Date: 12 Feb 2016 05:27:19
Message: <56bdb387$1@news.povray.org>
I am using Thunderbird too.
I must have looked and downloaded them before you cancelled.
No big deal. :)
Regards
Date: 12 Feb 2016 07:31:27
Message: <56bdd09f@news.povray.org>
> Any idea?
I am afraid I have no real experience with sunset or night atmospheres.
Bruno Cabasson seems to get very close though.
Date: 12 Feb 2016 08:21:25
Message: <56bddc55$1@news.povray.org>
Am 12.02.2016 um 10:42 schrieb Sven Littkowski:
> Update
Please don't post images in povray.general (or any newsgroup without
".binaries." in the name, for that matter).
Date: 12 Feb 2016 14:58:14
Message: <56be3956$1@news.povray.org>
Ah, yes. okay. :-)
Date: 13 Feb 2016 16:14:53
Message: <56bf9ccd$1@news.povray.org>
Le 16-02-11 23:19, Sven Littkowski a écrit :
> Thanks. :-)
Your light need to be fading.
That mean using fade_power 2 and fade_distance SomeRelativelyShortDistance.
That also mean that the light's intensity will large to very large,
possibly in the 1000000 range.
That wat, the illumination will be much stronger near the lights, making
it right for scattering media. Just make the media have a blue colour.
It will glow blue, and the illumination reatching the surface will get a
yellow tint.
Also, that scattering media will gives a blue tint to things farther away.
If you use radiosity and emissive image/pattern, that can't illuminate
your media. In that case, you'll need to use emissive media to get the
same result.
Date: 13 Feb 2016 16:17:46
Message: <56bf9d7a@news.povray.org>
> cylinder // Air
>   hollow
>   interior
>    ior 1.3
>    fade_distance 10
>    fade_power 1001
>    media
>     scattering
>      3
>      < 0.5, 0.65, 0.4 >
>      extinction 1.0
An ior of 1.3 for the air? It's air, not water.
A correct ior here would be around 1.000001... Beter off leaving the ior
totaly out for the air.
Date: 13 Feb 2016 23:47:11
Message: <56c006cf$1@news.povray.org>
Thanks, Alan.
Yes, the strength of the light must have been the problem: I tried
scattering, but got only a black screen. i couldn't explain it to
myself, and that was one of the reasons why I redesigned the
illumination of my scene and removed all light sources 8and use now a
long, emitting bar with radiosity).
I think, I will make one more try with the scattering, as it sound
promising. :-)
> yellow tint.
> same result.
Date: 13 Feb 2016 23:48:18
Message: <56c00712$1@news.povray.org>
Thanks, another source of errors fixed. :-)
Date: 14 Feb 2016 02:55:00
Message: <56c032d4$1@news.povray.org>
On 14-2-2016 5:47, Sven Littkowski wrote:
> Thanks, Alan.
If you get a black screen (or a white screen for that matter) it is
because your scattering vector value is out of range, either too high or
too low. You need to experiment with that too. The intensity of the
light source inside the media may also play an important role.
Important note! Always (repeat: Always) scale your media object and the
inverse scattering vector proportionally (as I showed you in my example).
In one word: experiment, experiment, experiment (3 words now) :-)
Date: 14 Feb 2016 08:51:18
Message: <56c08656@news.povray.org>
I am, actually, getting a very different problem now, when trying to use
a scattering effect:
"Fetal Error in Renderer: A POV-Ray internal nesting limit was reached."
What part of my code could cause that?
#if(IlluminationType="Lights")
 #declare MyLightMultiplicator = 0.007 * 1000.0;
0.88235 > * MyLightMultiplicator*05 fade_power 2 fade_distance 100.0
spotlight point_at < 000.0, -1500.0, 0.0 > radius 10 tightness 10
spotlight point_at < 050.0, -1350.0, 0.0 > radius 10 tightness 10
spotlight point_at < 100.0, -0950.0, 0.0 > radius 10 tightness 10
spotlight point_at < 150.0, -0700.0, 0.0 > radius 10 tightness 10
spotlight point_at < 175.0, -0600.0, 0.0 > radius MyRadius tightness
MyTightness falloff MyFalloff rotate < 0.0, 0.0,  5.0 > }
0.50196 > * MyLightMultiplicator*05 fade_power 2 fade_distance 100.0
spotlight point_at < 200.0, -0550.0, 0.0 > radius MyRadius tightness
MyTightness falloff MyFalloff rotate < 0.0, 0.0,  7.5 > }
0.28235 > * MyLightMultiplicator*04 fade_power 2 fade_distance 100.0
spotlight point_at < 225.0, -0500.0, 0.0 > radius MyRadius tightness
MyTightness falloff MyFalloff rotate < 0.0, 0.0, 10.0 > }
0.08627 > * MyLightMultiplicator*04 fade_power 2 fade_distance 100.0
spotlight point_at < 250.0, -0450.0, 0.0 > radius MyRadius tightness
MyTightness falloff MyFalloff rotate < 0.0, 0.0, 12.5 > }
0.05882 > * MyLightMultiplicator*04 fade_power 2 fade_distance 100.0
spotlight point_at < 275.0, -0400.0, 0.0 > radius MyRadius tightness
MyTightness falloff MyFalloff rotate < 0.0, 0.0, 15.0 > }
0.10980 > * MyLightMultiplicator*03 fade_power 2 fade_distance 100.0
spotlight point_at < 300.0, -0350.0, 0.0 > radius MyRadius tightness
MyTightness falloff MyFalloff rotate < 0.0, 0.0, 17.5 > }
0.16078 > * MyLightMultiplicator*03 fade_power 2 fade_distance 100.0
spotlight point_at < 325.0, -0300.0, 0.0 > radius MyRadius tightness
MyTightness falloff MyFalloff rotate < 0.0, 0.0, 20.0 > }
0.14902 > * MyLightMultiplicator*02 fade_power 2 fade_distance 100.0
spotlight point_at < 350.0, -0250.0, 0.0 > radius MyRadius tightness
MyTightness falloff MyFalloff rotate < 0.0, 0.0, 22.5 > }
0.10588 > * MyLightMultiplicator*02 fade_power 2 fade_distance 100.0
spotlight point_at < 375.0, -0200.0, 0.0 > radius MyRadius tightness
MyTightness falloff MyFalloff rotate < 0.0, 0.0, 25.0 > }
 #declare MyLight = union
 hollow
 interior
  fade_power 1001
  media
   emission 0.0005
   density
    gradient y
    density_map
     [ 0.4 rgb < 0.5, 0.7, 1.0 > * 1.0 ]
     [ 0.5 rgb < 0.5, 0.7, 1.0 > * 1.0 ]
     [ 1.0 rgb < 0.0, 0.0, 0.0 > * 1.0 ]
    absorption 1000.0
    scattering
     1
     < 0.5, 0.7, 1.0 >
     extinction 1.0
Date: 14 Feb 2016 10:01:26
Message: <56c096c6@news.povray.org>
Which is why I use a modeller. Every line of code I write has to be
debugged. :-(
I could not code my way out of a wet paper bag.
Regards
Date: 14 Feb 2016 10:46:59
Message: <56c0a173$1@news.povray.org>
> #end
Maybe you have to many light interacting with the media.
Use only a single or a few, long and very narrow, area_light using
area_illumination. If using a few lights, don't go over 4 or 5 TOTAL.
Use something like this for the area_light parameters:
area_light HabitatLength*z, AxleRadius*x*0.7, 257, 33 adaptive 0
area_illumination
adaptive 0 turn on the adaptive sampling starting with only the 4
cormers and will subdivide as needed in the penumbrae.
adaptive 1 will start with the corners plus the mid point in each
directions, for a total of 9 initial samples.
Don't use spotlight but rely on the edges of the cylinder's window to
limit the area of illumination.
cylinder{0, HabitatLength*z, AxleRadius
  pigment{radial
   color_map{[0 rgb 0.5][0.05 rgbf<0.8, 0.5, 0.2, 1>][0.1 rgbf 1]
   [0.4 rgbf 1][0.45 rgbf<1, 0.7, 0.5, 1>][0.5 rgb 0.5]}
  rotate 180*z}
Date: 14 Feb 2016 15:03:37
Message: <56c0dd99$1@news.povray.org>
Okay, I will give a try. Thanks a lot.
Should I use "looks_like" or "projected_through" for the cylinder (see
below (quote)?
>  pigment{radial
>  rotate 180*z}
Date: 14 Feb 2016 15:05:50
Message: <56c0de1e$1@news.povray.org>
Am 14.02.2016 um 14:51 schrieb Sven Littkowski:
This message indicates that any one of the following limits was reached:
- 256 media statements relevant at any point in space.
- 256 media intervals (between two object surfaces?).
- 512 lit media intervals (between two object surfaces ?).
- (256 light sources used with media *).
- A limit of 512 overlapping textured elements at any point in space in
a blob or a CSG union, merge or intersection.
- 1024 light sources used with media and/or photons.
(? At present I'm not exactly sure how these limits work.)
(* This limit is only relevant with some alternative code that is
currently disabled.)
Date: 14 Feb 2016 15:25:06
Message: <56c0e2a2$1@news.povray.org>
> below (quote)?
>>   pigment{radial
>>   rotate 180*z}
You want the cylinder to cast shadows, so, looks_like can't be used.
looks_like have an implied no_shadow.
projected_through can be seen as an "anti-shadow" thing. Also, it's
supposed to totaly ignore any pigment and textures and is never visible.
So, it's not what you need.
No, just a plain cylinder with a pattern that is partly transparent in
the direction where you want the light to shine through and opaque on
the "night" side.
You may want to add some shiny or luminous texture on the inside. You do
that using interior_texture after the normal texture.
Date: 14 Feb 2016 19:32:26
Message: <56c11c9a$1@news.povray.org>
I use 2,000 light sources or so, the last condition might be the one
that applies.  What would happen, if POV-Ray would have higher limits?
Which development file(s) contain these limits? Thanks.
Date: 14 Feb 2016 22:58:42
Message: <56c14cf2$1@news.povray.org>
Am 15.02.2016 um 01:32 schrieb Sven Littkowski:
In the current versions that would be LIGHTSOURCE_VECTOR_SIZE in
source/core/configcore.h.
The only adverse effect would be higher memory consumption and possibly
slightly degraded performance.
The reason why these limits are there in the first place is simply
because, for the sake of performance, the respective data structures
need to be of /some/ fixed size.
Date: 15 Feb 2016 02:59:40
Message: <56c1856c$1@news.povray.org>
The question immediately arises: Do you /really/ need 2000 light
sources? Looks like overkill to me.
Date: 15 Feb 2016 04:40:35
Message: <56c19d13$1@news.povray.org>
In my scene with an area light of 8 sources there was noticeable banding
of the shadows. 2000 does sound like a lot though.
Mike
Date: 15 Feb 2016 05:21:35
Message: <56c1a6af$1@news.povray.org>
I never worked with area light and area illumination before. I tried to
establish this kind of light based on your example, but I am not sure if
I gave the correct numbers. And I also don't know the correct order.
  light_source
   5000.0*z      // Location
   760.0*x*0.7   // Color?
   257, 33       // ?
   area_light    // Type
 // The POV-Ray docu says vectors and sizes are required for area light
   < -1000.0, -1300.0, 0.0 > < 1000.0, -1300.0, 5000.0 > 3, 3 // OK?
   adaptive 0    //
   area_illumination on //
  cylinder
   0, 5000.0*z, 760.0
   pigment
    radial
    color_map
     [ 0.00 rgb  0.5 ]
     [ 0.05 rgbf < 0.8, 0.5, 0.2, 1.0 > ]
     [ 0.10 rgbf 1.0 ]
     [ 0.40 rgbf 1.0 ]
     [ 0.45 rgbf < 1.0, 0.7, 0.5, 1.0 > ]
     [ 0.50 rgb  0.5 ]
    rotate 180*z
> area_light HabitatLength*z, AxleRadius*x*0.7, 257, 33 adaptive 0 area_illumination
Date: 15 Feb 2016 05:29:41
Message: <56c1a895$1@news.povray.org>
I came to use 2,000 light sources, because I want soft shadows along the
Z axis (a light each 40 meters) for the one reason, and also a flow from
day-white light via afternoon-peach to sunset-purple along the Z axis.
Alternatively, working with no light source but with emitting surfaces
of those colors and radiosity, does also the trick.
But I am also interested to learn about media atmospheric effects, and
so I try both illuminations still and find out, which way gives me the
best results.
I am considering to create a custom version of POV-Ray that does not
give me those limits. Maybe, one day, these limits can be set within the
appropriate .ini file or within the menu bar of the program (settings,
options), or don't exist anymore but POV-Ray would give a warning or
advise when parsing such a scene. Hey, CLipka, how do you do today? :-)
> Mike
Date: 15 Feb 2016 07:34:36
Message: <56c1c5dc$1@news.povray.org>
Small Update, Alain:
I copied your code and made small adaptions. But due to the fact, that I
still have no full understanding of what I am doing here ( :-) ), I
produce errors at the location where I use your "257, 33".
  light_source
   4999.8*(z+0.1)// Location  - small difference to walls (0.1)
   257, 33       // ? ERROR ---
   area_light    // Type
   < -1000.0, -1300.0, 0.1 > < 1000.0, -1300.0, 4999.9 > 3, 3 // Vectors?
   adaptive 0    //
  cylinder
   0, 5000.0*z, 760.0
   pigment
    radial
    color_map
     [ 0.00 rgb  0.5 ]
     [ 0.10 rgbf 1.0 ]
     [ 0.40 rgbf 1.0 ]
     [ 0.50 rgb  0.5 ]
    rotate 180*z
//   interior_texture  // not yet in place. But shouldn't that cylinder
be hollow then?
On 14.02.2016 10:47, Alain did some écrit:
> area_illumination
>  pigment{radial
>  rotate 180*z}
Date: 15 Feb 2016 15:03:23
Message: <56c22f0b$1@news.povray.org>
Am 15.02.2016 um 11:29 schrieb Sven Littkowski:
Mild headache, thanks to you ;)
Date: 15 Feb 2016 22:12:37
Message: <56c293a5$1@news.povray.org>
Too much pressure in your life?   3:)
>> (ideas to improve POV-Ray...) Hey, CLipka, how do you do today? :-)
Date: 16 Feb 2016 14:10:26
Message: <56c37422@news.povray.org>
Le 16-02-15 05:21, Sven Littkowski a écrit :
> Hi,
>    light_source
Yes, location of <0, 0, 5000>
That makes your light red. It evaluate to rgb <760*0.7, 0, 0>
>     257, 33       // ?
This WILL cause an error and stop parsing.
MUST folloow both area_light AND the two axis
>     area_light    // Type
That can be ok. This define a rectangle set -1300 unit down the y axis,
and set at an angle.
A 3 by 3 array is extremely croase. Barely ok for a test render. Could
be used simulate an actual array of 3 by 3 lights if used without jitter
and adaptive.
>     adaptive 0    //
Good for test render. If good enough, may be kept for final render.
OK
You first define the location of the light, then it's colour.
After that, you add the area_light parameters and other light options.
It's as follow, after location and colour/intensity:
area_light
First size of the area light as an axis
Second size of the area light also as an axis
For both axis, the shortcut n*x, n*y and n*z are legal.
Number of samples along the first axis
Number of samples along the second axis
For the axis, it's usualy beter to define them along the reference axis.
After that, if needed, you can rotate the light as a whole to orient the
plane as needed. That's much easier than giguring the correct values for
the axis. Alternatively, it's possible to use some axis manipulation
macros to calculate the correct values.
It's followed by the other options in any order:
area_illumination will affect the illumination of objects that are close
to the light's location.
adaptive turn on the adaptive subsampling. The keyword is followed by an
integer value that set the minimal number of initial subsampling.
A value of 0 will start with only the 4 corners, and if they are not all
visible or invisible from a given point, then subdivision will occur.
A value of 1 will start with a 3 by 3 array, adaptive 2 will start with
a 5 by 5 array, subjected to the actual number of sublights in that
direction.
adaptive allow the use of large number of samples with minimal
performance hit.
circular moves the sublights inward so that they reside within a circle
or ellips.
orient will pivot the sublights array so that it's always facing any
point bein evaluated. It MUST be used with circular and the two axis
must be ov the same length and the number of samples must be the same in
both directions.
jitter will randomly move the sublights to reduce banding. If used with
antialiasing, each antialiasing samples will have a different jittering
of the sublights.
area_light is compatible with spotlight, cylinder, projected_through,
parallel.
It's pointless for a shadowless light.
Correctly writing your sample:
light_source{
  Location
  Colour
  area_light // turn on the area_light feature
  5000*z 760*0.7*x //surface covered be the area_light
  257 33 //number of samples along the long and short axis
  jitter // very small effect in this case, help reduce banding
This area_light is parallel with the X-Z plane, and it's longest extent
is alligned along the z axis.
If location is set for 500*y or <0, 500, 0>, the light will be located
within this square:
<-16.5, 500, -2500> <16.5, 500, 2500>
Date: 16 Feb 2016 20:16:57
Message: <56c3ca09$1@news.povray.org>
Hi, big thanks, so far. please let's continue.
I used "760.0*x*0.7   // Color?" because you wrote: "AxleRadius*x*0.7".
I don't need a red light, so I will change it. :-)
Right after you wrote "257,33", that is why I placed them right after,
too. What are these two numbers actually about, or for?
And where exactly to place them? After the vectors of the area_light as
replacement for "3,3"?
Vectors of the area_light:
What exactly do they describe? The illuminated area? Or the area
(rectangle) in which all lights are in? I might have to make some
changes to those two vectors, based on your answer. :-)
At the moment, I have this as light system, but the resulting image is
just showing a distant gray ring:
  light_source
   5000*z                   // Location
   rgb < 1.00000, 0.98824, 0.88235 > // Color
   area_light               // Type
   5000*z 760*0.7*x 257, 33 // Vectors
   adaptive 0               //
  cylinder
   0, 5000.0*z, 760.0
   pigment
    radial
    color_map
     [ 0.00 rgb  0.5 ]
     [ 0.10 rgbf 1.0 ]
     [ 0.40 rgbf 1.0 ]
     [ 0.50 rgb  0.5 ]
    rotate 180*z
be hollow then?
> area_illumination
>  pigment{radial
>  rotate 180*z}
>>     257, 33       // ?
>>     area_light    // Type
> area_light
> direction.
> performance hit.
> or ellips.
> both directions.
> of the sublights.
> parallel.
> light_source{
>  Location
>  Colour
> within this square:
> Alain
