How do I calculate a random integer between n and p, inclusively?
Thanks
> Thanks
#declare RSeed = seed(1);
#declare RandomNumber = n + rand(RSeed) * (p - n);
Ger
Ger wrote:
>> Thanks
#declare RandomNumber = int(n + rand(RSeed) * (p - n));
Ger
On 1/31/2016 9:06 PM, Ger wrote:
>> Thanks
That results in a float, not an integer.
Mike
Am 01.02.2016 um 02:55 schrieb Mike Horvath:
floor( rand(R)*((p-n)+1) + 0.5 )
should do the trick
>>> Thanks
> Mike
I corrected it.
Ger
Am 01.02.2016 um 03:10 schrieb clipka:
> should do the trick
... provided you figure out that you need to add n ;)
Oops.
Yes, there are two functions to convert a float to a close-by integer:
1. Floor
If the float is, let's say, "11.4676475" (could be a multiplication of a
"rand" random result), floor returns "11" (the next integer BELOW that
float).
2. Ceil(ing)
"rand" random result), floor returns "12" (the next integer ABOVE that
float).
> should do the trick
Why not this: int(RRand(n,p,R))
>> should do the trick
RRand(Min,Max,RandSeededStream) from rand.inc. To get the inclusive part
of the request I think we need:
int(RRand(n,p+(1-1e-6),R))
or
floor(RRand(n,p+(1-1e-6),R))
Bill P.
>>> should do the trick
> or
> Bill P.
Are the Min and Max not inclusive by default? I always got that impression.
>>>> should do the trick
>> or
>> Bill P.
For floats yes.
Mike wants integers so we are using int() or floor(). Seems to me the
only way we can get the Max integer value is if the rand() function
returns exactly 1.0 - which it will pretty much never do, but might.
The +(1-1e-6) makes it so we get the Max integer value only one
millionth less often than ideally we should.
We could specify a max integer 1 larger than we really want for p, but
then rand() will be a troublemaker and give us that 1.0 value in our
scene.
Bill P.
>>>>> should do the trick
>>> or
>>> Bill P.
>> impression.
> For floats yes.
> then rand() will be a troublemaker and give us that 1.0 value in our scene.
> Bill P.
OK. Got it. Thanks a lot!
On 1/31/2016 9:08 PM, Ger wrote:
> Ger wrote:
>>> Thanks
Shouldn't you use floor instead of int? What if n and p are both negative?
Mike
> 1. Floor
> float).
> 2. Ceil(ing)
> float).
There is also int, which varies depending on if the number is greater or
less than zero.
>>>>> should do the trick
>>> or
>>> Bill P.
>> impression.
> For floats yes.
> Bill P.
So should I use int or floor? The result is different for numbers below
zero.
Mike
>> should do the trick
> Oops.
Where do I add n?
> zero.
> Mike
Good question. If you have negative integers as part of your potential
integer range, use floor().
Aside: In some languages to really get an integer you need int() too as
in : int(floor(...)) because ceil() and floor() in those languages
return floats.
Bill P.
Am 05.02.2016 um 03:50 schrieb Mike Horvath:
>>> should do the trick
>> Oops.
> Where do I add n?
Never mind -- I also included other nonsense in the formula.
Let me try that again:
min( n+floor( rand(R)*((p-n)+1) ), p )
The min() is there to ensure that the result is never larger than p,
even if R is so close to 1.0 that the expression in floor() is at some
point rounded up to give a result of (p-n)+1, in which case the entire
expression (without the min()) would result in p+1.
I'm adding n only after rounding, because the lower the magnitude of a
floating point number, the higher its absolute precision.
Am 05.02.2016 um 03:49 schrieb Mike Horvath:
> zero.
In your case you want floor(); otherwise, if your interval includes 0,
too many random numbers will be mapped to 0, and not enough random
numbers will be mapped to 0.
On 02/05/2016 08:56 AM, clipka a dit:
>> zero.
*BREAKING NEWS*
Annoucing POVray 3.9, _Now_ with quantum computation !
*wip* http://la.buvette.org/vrac/essai.avi *wip*
Am 10.02.2016 um 07:39 schrieb tth:
>>> zero.
> *BREAKING NEWS*
Whoops. That should read, "... and not enough random numbers will be
mapped to n."
Sorry, no support for quantum computers in the near future ;)
