POV-Ray : Newsgroups : povray.general : Observation: Memory Increase During Render Server Time
4 Mar 2026 04:08:04 EST (-0500)
  Observation: Memory Increase During Render (Message 1 to 10 of 16)
Subject: Observation: Memory Increase During Render
Date: 31 Jan 2016 18:37:53
Message: <56ae9ad1$1@news.povray.org>
in order to speed up my POV-Ray rendering, I keep my Windows Task
Manager (WTM) on and changed the Priority of POV-Ray to "High", but only
during the nights.
But having the WTM always open, allows me also to see the memory usage
of POV-Ray. I am observing, that I started the render with a usage of
450 MB or so. Now, after 8 days, the memory usage lays at 3.7 GB.
1
Does this point towards memory leak(s), or is this normal?
2
I have 8 GB of memory. What will happen if POV-Ray reaches a memory
consumption 0f 7 or even 8 GB?
Subject: Re: Observation: Memory Increase During Render
Date: 31 Jan 2016 18:39:38
Message: <56ae9b3a$1@news.povray.org>
On 1/31/2016 6:37 PM, Sven Littkowski wrote:
> Hi,
> during the nights.
> 1
> 2
This is normal. If you run out of memory your whole computer will lock up.
Mike
Date: 31 Jan 2016 19:30:50
Message: <56aea73a$1@news.povray.org>
On 1/31/2016 11:37 PM, Sven Littkowski wrote:
> Hi,
> during the nights.
> 1
What version are you using?
Regards
Date: 31 Jan 2016 20:20:20
Message: <56aeb2d4$1@news.povray.org>
Le 16-01-31 18:37, Sven Littkowski a écrit :
> Hi,
> during the nights.
> 1
Normal
> 2
You'll start on the road of paging hell as more and more of the data for
the scene get swapped back and forth between the RAM and the disk.
If you have no more space in virtual memory, welcome computer crash.
Date: 31 Jan 2016 20:51:19
Message: <56aeba17@news.povray.org>
Am 01.02.2016 um 02:20 schrieb Alain:
>> 2
Running out of /virtual/ memory is a feat that on a Windows system
rarely ever happens. Before that, Swap Hell will become so bad that the
render (and everything else on the computer) grinds to a
near-standstill, including anything that would allocate additional memory.
Date: 31 Jan 2016 21:16:50
Message: <56aec012$1@news.povray.org>
The end of the universe. Suns dim to red giants, and die. Red dwars.
Break-down of atoms, neutrons. The end of matter as we know it. The big
freeze.
I hope, after POV-Ray finished the area with the red hangars, all
remaining stuff will be faster and be finished before the memory
consumption gets too bad.
Date: 1 Feb 2016 13:10:45
Message: <56af9fa5$1@news.povray.org>
I actually had povwin suck down all my memory the other day.  Windows
(8.1) was kind enough to say "you really want to kill this guy".
I currently have a povwin idling at 2GB real memory and 8GB virtual
memory.  In this instance, I have rendered maybe 800-1000 frames (test
frames, low object count).
This isn't anything I even looked at until the other day when it freaked
out.  I'm not saying it's leaking, but it would be nice if it gave back
the memory when it was doing nothing.
Date: 1 Feb 2016 14:48:33
Message: <56afb691$1@news.povray.org>
Am 01.02.2016 um 19:10 schrieb dick balaska:
Okay -- that is new then.
That, too, is something new (at least to me). Needs more details to
investigate though.
Date: 10 Feb 2016 13:00:48
Message: <56bb7ad0$1@news.povray.org>
> investigate though.
:(  I'm gonna have to go with this is a thing now.
povwin 3.7.1-alpha.8358383+av65.msvc14.win
I think you built it.
I was starting up to run 100 frames. I looked at System Explorer
7.0.0.5356 and noticed a handful of petabytes consumed by povwin (I
don't remember how much, it was a lot).  I restarted povwin and started
my render.  I notice it is leaking about 50MB per frame.
So I've done 48 frames and I'm sitting at
Mem Usage (KB) 1,972,724
VM Size (KB)   2,020,552
That works out to 42MB leaking per frame.  Seems low. What does the next
frame give us?
Mem Usage (KB) 2,006,148
VM Size (KB)   2,055,804
It does give a little back between frames. It dropped to
Mem Usage (KB) 1,996,000
and then climbed to
Mem Usage (KB) 2,042,780
VM Size (KB)   2,094,184
I can't wait to see what it says when I get up in the morning...
99 frames rendered.
Mem Usage (KB) 4,217,172
VM Size (KB)   8,005,052
And then after it finished 100 frames and povwin went idle, it actually
gave a little memory back and currently sits at.
Mem Usage (KB) 3,761,412
VM Size (KB)   8,055,384
This is the baseline memory usage for my next render job.  It will never
go below this.  It will only go up.
Date: 10 Feb 2016 14:20:53
Message: <56bb8d95$1@news.povray.org>
Am 10.02.2016 um 19:00 schrieb dick balaska:
To be precise, I didn't -- it was AppVeyor that did. All builds
identifying as "+av<number>" are automated builds generated by that service.
But yes, I did authorize the build and its distribution.
Can you do me a favour and try out whether the most recent build does
the same?
I just recently discovered a bug in the cleanup of user-defined
functions; as I couldn't pinpoint when exactly it was introduced, it
might have been around longer than I suspected. If that's the root cause
of the memory leaks you're seeing, this build should fix it:
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8463913%2Bav107
