POV-Ray : Newsgroups : povray.general : Materials before or after bounded_by? Server Time
4 Mar 2026 04:06:11 EST (-0500)
  Materials before or after bounded_by? (Message 1 to 8 of 8)
Subject: Materials before or after bounded_by?
Date: 29 Jan 2016 04:20:12
Message: <56ab2ecc@news.povray.org>
Should the bounded_by statement be the very last statement in a CSG
block? Or is it okay to have textures/materials/etc. come after?
Mike
Subject: Re: Materials before or after bounded_by?
Date: 29 Jan 2016 04:30:52
Message: <56ab314c$1@news.povray.org>
> Mike
Also, is there any benefit to using bounded_by in the following case?
difference
	object {MyObject1}
	object {MyObject2}
	bounded_by {MyObject1}
intersection
	object {MyObject1}
	object {MyObject2}
Date: 29 Jan 2016 05:15:44
Message: <56ab3bd0$1@news.povray.org>
Am 29.01.2016 um 10:31 schrieb Mike Horvath:
It's totally irrelevant.
> difference
>     object {MyObject1}
>     object {MyObject2}
> intersection
>     object {MyObject1}
>     object {MyObject2}
That depends.
If MyObject1 is significantly easier to compute than MyObject2, then it
may indeed speed up rendering.
Date: 29 Jan 2016 05:49:37
Message: <56ab43c1$1@news.povray.org>
>> difference
>>      object {MyObject1}
>>      object {MyObject2}
>> intersection
>>      object {MyObject1}
>>      object {MyObject2}
> That depends.
What if they both happen to be spheres or cylinders? I.e. similar types
of objects.
Mike
Date: 29 Jan 2016 11:24:14
Message: <56ab922e$1@news.povray.org>
Am 29.01.2016 um 11:49 schrieb Mike Horvath:
>>> difference
>>>      object {MyObject1}
>>>      object {MyObject2}
>>> intersection
>>>      object {MyObject1}
>>>      object {MyObject2}
>> That depends.
> of objects.
In that case it would be useless at best, and may actually slow down
render times.
To the best of my knowledge, that is. I still haven't spent enough time
studying the bounding mechanism to understand every detail of it.
Date: 29 Jan 2016 12:21:04
Message: <56ab9f80$1@news.povray.org>
>>>> difference
>>>>       object {MyObject1}
>>>>       object {MyObject2}
>>>> intersection
>>>>       object {MyObject1}
>>>>       object {MyObject2}
>>> That depends.
>> of objects.
> render times.
I am also wondering if both objects are cylinders, whether there is a
benefit to bound the CSG using a box.
Mike
Date: 30 Jan 2016 02:57:49
Message: <56ac6cfd$1@news.povray.org>
>>>>> difference
>>>>>       object {MyObject1}
>>>>>       object {MyObject2}
>>>>> intersection
>>>>>       object {MyObject1}
>>>>>       object {MyObject2}
>>>> That depends.
>>> of objects.
>> render times.
> Mike
My guess is no. In general, I never use bounded_by; my experience
(whatever that may be worth in this case) is that it slows the render.
Date: 31 Jan 2016 20:11:15
Message: <56aeb0b3$1@news.povray.org>
>>>>> difference
>>>>>       object {MyObject1}
>>>>>       object {MyObject2}
>>>>> intersection
>>>>>       object {MyObject1}
>>>>>       object {MyObject2}
>>>> That depends.
>>> of objects.
>> render times.
> Mike
In the case of a difference, I doubt that it may help.
In the case of the intersection, when the remaining part is small
relative to both parent objects, then, bounding with a box or sphere
/may/ help as long as that object is as tight as possible around the
important part.
