I am baffled.
I have this array:
#declare TexArray =
array[12]{
T_Stone1, T_Stone2,
T_Stone3, T_Stone4,
T_Stone5, T_Stone6,
T_Stone7, T_Stone8,
T_Stone9, T_Stone10,
T_Stone11, T_Stone12
I want to write a selected /texture_identifier/ (like "T_stone1" for
instance) to a file as a string. However, I do not succeed. I thought
that Parse_String() would do the trick but it generates an error telling
me that it expects a string but sees a texture_identifier instead.
What to do? Thanks.
Subject: Re: writing a texture identifier to file
Date: 19 Jan 2016 03:27:16
Message: <569df364$1@news.povray.org>
> thought that Parse_String() would do the trick but it generates an
> error telling me that it expects a string but sees a
> What to do? Thanks.
If I read the docs correctly, Parse_String() does just the contrary:
it takes a string and writes it to a file as an identifier, then
includes that file.
That is, given the following array...
#declare TexArray =
array[12]{
"T_Stone1", "T_Stone2",
"T_Stone3", "T_Stone4",
"T_Stone5", "T_Stone6",
"T_Stone7", "T_Stone8",
"T_Stone9", "T_Stone10",
"T_Stone11", "T_Stone12"
...you would be able to use these as texture identifiers like this:
texture{Parse_String(TexArray[0])}
jaime
Thomas de Groot <tho### [at] degroot org> wrote:
> I am baffled.
[snip]
Parse_String() seems to do the opposite of what you want - given a string, it
allows you to use it as an identifier. However I don't know if what you want is
even possible. No doubt Sensei Clipka will elucidate further at some point :)
> I am baffled.
> I have this array:
> #declare TexArray =
> array[12]{
> T_Stone1, T_Stone2,
> T_Stone3, T_Stone4,
> T_Stone5, T_Stone6,
> T_Stone7, T_Stone8,
I don't see how something like that would work, because if it did, how
would it cope with this:
#declare A = 1;
#declare FloatArray =
array[4]{
A,A*A,sin(A),MyMacro(A)
What I guess you're asking is if the array somehow remembers the SDL
text string that was used to create each element (and does it expand
macros?)? I would be surprised if it did (but then, this is no ordinary
programming language...).
>> I am baffled.
> [snip]
Yes, I see where I went wrong indeed. I misread the docs.
>> What to do? Thanks.
> includes that file.
> #declare TexArray =
> array[12]{
> jaime
The problem is I do not want this, although it could be a solution if
nothing else pops up that is. I would prefer to write the texture
identifier as a text string.
To explain a bit more, I am adapting tiling.inc to include textures
instead of just colours. It is a simple straightforward process where
running the scene is concerned; however, the writing option for this is
more tricky than expected.
On 19-1-2016 9:37, scott wrote:
>> I am baffled.
>> I have this array:
>> #declare TexArray =
>> array[12]{
>> T_Stone1, T_Stone2,
>> T_Stone3, T_Stone4,
>> T_Stone5, T_Stone6,
>> T_Stone7, T_Stone8,
> #declare A = 1;
> array[4]{
Yes, it is this text string I want to write but it looks like I will
need to consider another approach, in the way Jaime indicates...
On 1/19/2016 3:13 AM, Thomas de Groot wrote:
> I am baffled.
> What to do? Thanks.
I had a similar need. I ended up doing this and using the appropriate
array as needed...
#declare TexArray =
array[12]{
T_Stone1, T_Stone2,
T_Stone3, T_Stone4,
T_Stone5, T_Stone6,
T_Stone7, T_Stone8,
#declare TexArrayText =
array[12]{
Am 19.01.2016 um 09:54 schrieb Thomas de Groot:
>> #declare TexArray =
>> array[12]{
The trouble there is, once the texture is inside the array, there is no
trace of the texture identifier left alongside it.
(Or, more to the point, the texture now has a /new/ identifier,
TexArray[something].)
(Actually, even that is a simplified picture of the matter. What you
/really/ have is a /copy/ of the original texture.)
Also note that if you're starting out with an array of textures, you
might have to deal with something like this:
#declare TexArray =
array[12]{
T_Stone1,
T_Stone2,
texture {...},
T_Stone4,
No "original" identifier there at all for TexArray[2].
>>> #declare TexArray =
>>> array[12]{
> #declare TexArray =
> array[12]{
> T_Stone1,
> T_Stone2,
> texture {...},
> T_Stone4,
Thanks indeed Christoph, very clear. Happy to have learned something
again and deepened my understanding of POV-Ray.
Date: 20 Jan 2016 02:43:34
Message: <569f3aa6@news.povray.org>
>> I am baffled.
>> What to do? Thanks.
> array as needed...
> #declare TexArray =
> array[12]{
> T_Stone1, T_Stone2,
> T_Stone3, T_Stone4,
> T_Stone5, T_Stone6,
> T_Stone7, T_Stone8,
> array[12]{
Yes, it seems this is the way I shall have to go.
Date: 24 Jan 2016 18:59:27
Message: <56a5655f$1@news.povray.org>
>> array as needed...
>> #declare TexArray =
>> array[12]{
>> T_Stone1, T_Stone2, ...
>> array[12]{
>> "T_Stone1", "T_Stone2", ...
Note as far as I understand it you don't need to
maintain the list twice, just keep the string version
and fill the non-string version in a loop with
Parse_String as suggested by Jaime.
