POV-Ray : Newsgroups : povray.general : No repeating pattern? Server Time
31 Oct 2024 21:22:11 EDT (-0400)
  No repeating pattern? (Message 1 to 6 of 6)
Subject: No repeating pattern?
Date: 18 Jan 2016 21:56:06
Message: <569da5c6$1@news.povray.org>
I'm using a gradient pattern for one of my scenes. How do I make it so
that it doesn't repeat, and instead stays at the last value? Thanks!
Mike
Subject: Re: No repeating pattern?
Date: 18 Jan 2016 22:35:24
Message: <569daefc$1@news.povray.org>
I would union two objects such that the value of the "outer" object is 1.0;
0    .3   .6   1
                1                 1
Date: 19 Jan 2016 02:00:28
Message: <web.569dde3f1d6d59392aaea5cb0@news.povray.org>
> Mike
Not quite sure what you're asking here, but if I understand correctly, you might
try:
create two pigment functions, one with your gradient and the other solid with
the value of the last pigment in the gradient, then
create another function that selects between the two based on a numeric value.
I think you should be able to do this with the select() function, but you'll
have to look it up.
A.D.B.
Date: 19 Jan 2016 03:20:01
Message: <web.569df1631d6d59395b7d07940@news.povray.org>
You could use a planar pattern instead:
http://www.povray.org/documentation/3.7.0/r3_4.html#r3_4_7_1_20
Bill
Date: 19 Jan 2016 05:25:04
Message: <569e0f00@news.povray.org>
> Bill
Unfortunately, my scene is not flat. But now that you mention it, I
should really be using a spherical pattern for the ChromaDepth pattern,
not a gradient. Thank you!
Mike
Date: 19 Jan 2016 12:15:21
Message: <569e6f29$1@news.povray.org>
Am 19.01.2016 um 03:56 schrieb Mike Horvath:
Maybe use the "planar" pigment instead?
As a last resort, you can always use a function pattern.
