POV-Ray : Newsgroups : povray.general : Is this a bug? Server Time
5 Nov 2026 07:26:15 EST (-0500)
  Is this a bug? (Message 1 to 41 of 41)
Subject: Is this a bug?
Date: 17 Jan 2016 14:43:05
Message: <569beec9$1@news.povray.org>
or am I just plain dense
Consider the following piece of code
Including a datafile in the main body works, but
including it inside a #macro results in an error
at random frames in the animation. It can be at
frame 10 or at frame 500.
Content of data.inc looks like this
#declare CFS[0] = <45.139115, 100.000000, 18.290612>;
#declare CFS[49] = <44.641327, 100.000000, 17.771019>;
// CODE
#version 3.7;
#declare CenterOfMass = yes;
#declare COMF = 50;
#declare StartLookAt = <0, 80, 0>;
#declare CFS = array[COMF];
#declare LookAt =  <500, 100, 0>;
#declare CenterOfMassLookAt =  <0, 0, 0>;
#macro WriteCOMFile()
  #fopen filehandle "data/data.inc" write
  #for(Count, 0, COMF-1, 1)
    #write(filehandle, "#declare CFS[",str(Count,0,0),"] = <", vstr(3,
CFS[Count], ", ", -1,-1),">;\n")
  #fclose filehandle
#macro InitCenterOfMass()
  #for(Count,0, COMF-1, 1)
    #declare CFS[Count] = StartLookAt;
  WriteCOMFile()
#macro ParseCenterOfMass(NewCenter)
// Including the data file here works sometimes
//#include "data/data.inc"
  #for(Count, COMF-1, 1, -1)
    #declare CFS[Count] = CFS[Count-1];
  #declare CFS[0] = NewCenter;
  WriteCOMFile()
  #local COMLookAt = <0, 0, 0>;
  #declare Count = 0;
    #local COMLookAt = COMLookAt + CFS[Count];
  #local COMLookAt = COMLookAt / COMF;
  #declare CenterOfMassLookAt =  COMLookAt;
#if(frame_number=0)
    InitCenterOfMass()
#declare CameraLocation = < 900, 800,-2900>;
#declare Direction = 1;
// Including the data file here works all the time
#if(frame_number=1)
  #declare LookAt =  ParseCenterOfMass(StartLookAt);
#else
  ParseCenterOfMass(LookAt)
  #declare LookAt = CenterOfMassLookAt;
#declare Direction = vlength(CameraLocation-LookAt)/2000;
    location CameraLocation
    look_at LookAt
    direction z * Direction
    right image_width / image_height * x
Ger
Subject: Re: Is this a bug?
Date: 17 Jan 2016 16:46:21
Message: <569c0bad$1@news.povray.org>
Am 17.01.2016 um 20:43 schrieb Ger:
It certainly isn't intended behaviour, otherwise it would give you an
error all the time ;)
Can you be more specific about the error message you get? Version and
operating system might also play a role.
Date: 17 Jan 2016 16:55:50
Message: <569c0de6$1@news.povray.org>
Povray V3.7 running on  Opensuse 13.2
Error message is all over the field and makes zero sense to me.
Error at line 249 (or any other bizarre line number, file only has 51 lines)
in data.inc. Expected {fill in whatever }, found {fill in whatever} instead
Or it stops with a "mismatched #end"
I have ran it with array sizes from only 5 lines to 15K lines and that
doesn't make a difference in either error message or frame number when it
crashes.
Ger
Date: 17 Jan 2016 17:28:51
Message: <569c15a3$1@news.povray.org>
Am 17.01.2016 um 22:55 schrieb Ger:
Um... /what/ version of POV-Ray 3.7? 3.7.0 stable? 3.7.1-alpha.7678995?
3.7.1-alpha.8433080?
Did you build it yourself, or did you get it as binary via some package
manager?
That /certainly/ is a bug, though I have no initial idea what might be
going wrong there.
> crashes.
Can you provide me with a complete scene file (attachment please;
pasting into a newsgroup post tends to break things due to line wrapping
and the like)?
Date: 17 Jan 2016 17:43:32
Message: <569c1914$1@news.povray.org>
> manager?
>> lines) in data.inc. Expected {fill in whatever }, found {fill in whatever}
>> instead Or it stops with a "mismatched #end"
> going wrong there.
>> crashes.
> and the like)?
Persistence of Vision(tm) Ray Tracer Version 3.7.1-alpha.7695039.unofficial
(g++
 4.8 @ x86_64-suse-linux-gnu)
This is an unofficial version compiled by:
 Pietje Puk <p.p### [at] gmailcom>
 The POV-Ray Team is not responsible for supporting this version.
Support libraries used by POV-Ray:
  ZLib 1.2.8, Copyright 1995-2012 Jean-loup Gailly and Mark Adler
  LibPNG 1.6.13, Copyright 1998-2012 Glenn Randers-Pehrson
  LibJPEG 80, Copyright 1991-2013 Thomas G. Lane, Guido Vollbeding
  LibTIFF 4.0.4, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
  Boost 1.54, http://www.boost.org/
  OpenEXR, Copyright (c) 2004-2007, Industrial Light & Magic.
2 files attached
As I was typing this reply the next error message come up
File 'data.inc' line 169: Parse Error: Expected 'object or directive', ]
found
 instead
Fatal error in parser: Cannot parse input.
Render failed
There is no line 169
Ger
Download 'us-ascii' (6 KB) Download 'us-ascii' (1 KB)
Date: 18 Jan 2016 00:27:50
Message: <569c77d6$1@news.povray.org>
Am 17.01.2016 um 23:43 schrieb Ger:
Uh... that's 17 months old. Ever thought of trying a newer version?
> (g++
I take it "Pietje Puk" is not the real name of whoever built the binary
-- which in turn leads me to presume that you built it yourself.
Date: 18 Jan 2016 02:03:56
Message: <569c8e5c@news.povray.org>
I have thought of it, but somehow never got around to it.
Okay, got the latest? stable version
built it, and guess what. It doesn't accept the -CC option
Ran the render with the #include data.inc inside the macro  and it did the
same thing.
Random errors on non-existing line numbers.
>> (g++
It's the first version with the -CC option (no povstatefile) that I
requested.
Ger
Date: 18 Jan 2016 02:08:02
Message: <569c8f52$1@news.povray.org>
Ger wrote:
Forgot the version info
Persistence of Vision(tm) Ray Tracer Version 3.7.0.unofficial (g++ 4.8 @
 x86_64-unknown-linux-gnu)
Btw, Pietje Puk is my alter ego :)
Ger
Date: 18 Jan 2016 02:27:23
Message: <569c93db@news.povray.org>
Got the latest? Master
Persistence of Vision(tm) Ray Tracer Version 3.7.1-alpha.8431458.unofficial
(g++
  OpenEXR 2.2.0 and IlmBase 2.2.0, Copyright (c) 2002-2011 Industrial Light &
 Magic.
Same deal, but this one does support -CC
Ger
Date: 18 Jan 2016 02:40:56
Message: <569c9708$1@news.povray.org>
> found
>   instead
> Render failed
I ran your render and only got to frame 21:
"data.inc" line 218: Parse Error: Illegal character in input file, value
is 85.
(I had to change #if (frame_number=0) to =1 to seed data.inc)
It smells like a bizarre race condition to me.  How about trying
separate data files per frame?
#include concat("data", str(frame_number,0,0), ".inc")
Date: 18 Jan 2016 02:54:03
Message: <569c9a1b$1@news.povray.org>
>> found
>>   instead
>> Render failed
> is 85.
I had already tried that and it does exactly the same thing. Maybe with other
frame numbers but the same error messages on the same non-existing line
numbers.
Ger
Date: 18 Jan 2016 03:10:02
Message: <569c9dda$1@news.povray.org>
LOL (strictly for Dutch)
Date: 18 Jan 2016 05:25:00
Message: <web.569cbd5dc0eb7a16ad6fa18f0@news.povray.org>
> requested.
Dang, I was just about to ask what the "-CC" option is... do remember now.
Send a few round tuits my way and I'll have a look at both issues.
Date: 18 Jan 2016 05:30:01
Message: <web.569cbe46c0eb7a16ad6fa18f0@news.povray.org>
Ah, okay... THAT is NOT the lastest version, so no surprise about the "-CC"
option.
You want the "master" branch, not anything else. Looks like you downloaded the
"stable" branch, or the only official release. Which boils down to the same.
Date: 18 Jan 2016 07:26:37
Message: <569cd9fd@news.povray.org>
   I guessed it doesn't means line 169 on data.inc, but on test.pov...
that is, on the ParseCenterOfMass macro.
   After some tests making changes to that macro, the errors seemed to
suggest that sometimes data.inc was not fully written when it was
included in that macro.
   So I tried moving the call to include data.inc outside the macro, and
worked just fine. BTW, judging by the line 162 seems you already tried that?
jaime
Date: 18 Jan 2016 12:07:04
Message: <569d1bb8@news.povray.org>
> that?
   Sorry, I see now that indeed you tried, and that was the original
question: why it works outside the macro but not inside.
   Anyhow, I did a test putting the macro in a separate include file,
and now at least the error message isn't random anymore: it's always
"Attempt to access uninitialized array element" on this line:
   But as data.inc is included and has valid #declares, that cannot be
the real reason...
jaime
Date: 18 Jan 2016 14:16:16
Message: <569d3a00$1@news.povray.org>
Correct.
That's the error I started out with.
> the real reason...
That's how I started out. I like certain things kept together in separate
include files, and since I don't always use the CenterOfMass calculations
it's a perfect candidate for the #if(CenterOfMass) clause.
> jaime
Ger
Date: 18 Jan 2016 16:53:01
Message: <569d5ebd@news.povray.org>
>> requested.
A whole bag of tuits is on the way, but you don't need them for the -CC
option thingy. Only for the #include thingy. So you may have some spare left
over that you can use for other stuff.
Ger
Date: 18 Jan 2016 16:53:31
Message: <569d5edb@news.povray.org>
What can I say? :)
Ger
Date: 18 Jan 2016 18:29:19
Message: <569d754f@news.povray.org>
Well... I'm puzzled. After some more tests, my only conclusion is that
the #include inside the macro sometimes fails to load correctly the
included file contents, leaving there "unparseable" code.
jaime
Date: 18 Jan 2016 19:59:16
Message: <569d8a64$1@news.povray.org>
> jaime
I have tried it in every possible way I can come up with and what I have
found is that povray sometimes chokes on reading data while inside a #macro.
Which indicates to me that povray does not handle #macros correctly. Another
indicator to that is that shortly before it crashes the memory usage goes up
strongly.
Ger
Date: 18 Jan 2016 21:28:26
Message: <569d9f4a$1@news.povray.org>
On 1/18/2016 7:59 PM, Ger wrote:
> Another
> strongly.
That *could* just be an artifact.  It's parsing crap, who knows what
objects it thinks it's creating.
Date: 19 Jan 2016 01:53:27
Message: <569ddd67@news.povray.org>
>> Another
>> up strongly.
Indeed, that is always a possibility, but I had a test render running this
evening and when I came back to check on it, it was using ~30GB of memory to
process ~28K spheres. And that's a wee bit too much.
After I stopped it and let the computer settle down a bit, I restarted it
where it left off and memory usage was up to 2GB within minutes.
Ger
Subject: Re: Is this a bug? : WORKAROUND
Date: 19 Jan 2016 03:58:48
Message: <569dfac8@news.povray.org>
> have found is that povray sometimes chokes on reading data while
> inside a #macro. Which indicates to me that povray does not handle
> #macros correctly. Another indicator to that is that shortly before
> it crashes the memory usage goes up strongly.
   Well, thanks to a recent question by Thomas about Parse_String(), if
you absolutely need to include code on a macro, there is a workaround
using that function from strings.inc:
   Write the include file like this:
#write(filehandle, "\"#declare CFS[",str(Count,0,0),"] = <", vstr(3,
CFS[Count], ", ", -1,-1),">;\",\n")
   Then, instead using #include "data.inc", use a call to this macro:
#macro ParseInclude(IncludeFile)
   #fopen filehandle IncludeFile read
   #while (defined(filehandle))
     #read (filehandle,IncludeLine)
     #debug IncludeLine
     #debug "\n"
     Parse_String(IncludeLine)
   #fclose filehandle
   like this:
ParseInclude("data.inc")
   Hope this helps...
jaime
Date: 19 Jan 2016 04:24:40
Message: <569e00d8@news.povray.org>
>      #debug IncludeLine
>      #debug "\n"
>    #end
>    #fclose filehandle
> #end
>    like this:
>    Hope this helps...
> jaime
It's an interesting technique to say the least, and I must say that it works
all be it slow (I did implement it in this little animation). But the whole
point is that an #include should work inside a #macro.
The simplest workaround for me would be to put the #include in the main body
of the scene. I've done it and it works fine.
So it's not like "It doesn't work" but more like "It doesn't work the way it
should"
Ger
Date: 19 Jan 2016 06:23:46
Message: <569e1cc2@news.povray.org>
> it works all be it slow (I did implement it in this little
> animation).
   Yes, it was just an interesting exercise...
> main body
   As I said, the workaround is only useful if you absolutely need to use
the include inside the macro, for whatever reason.
> way it should"
   I noticed that file size seems to affect it... I mean, when you run
the animation and get the error at some frame, rendering it again with
the "faulty" include will fail again and again. But if you add/remove a
single character from any file (data.inc or test.pov), then magically it
will be parseable (but not if you change the content without changing
file size).
jaime
Date: 19 Jan 2016 12:26:12
Message: <569e71b4$1@news.povray.org>
Am 19.01.2016 um 09:58 schrieb Jaime Vives Piqueres:
Fun fact to know, especially in this context:
Parse_String itself is nothing more than a macro that writes a temporary
file and then includes it.
So I wouldn't consider it a perfect cure for the symptoms.
Date: 19 Jan 2016 13:57:52
Message: <569e8730$1@news.povray.org>
   The thing is that it works without any problem... maybe it has to do
with the fact that it only includes one line at a time?
jaime
Date: 19 Jan 2016 14:44:54
Message: <569e9236$1@news.povray.org>
> jaime
Sounds kinda ridiculous and that's why I tried and it works. It runs with 50
lines/files and even with 50K lines/files. I let it run until I had >1K
frames.
Ger
Date: 20 Jan 2016 08:19:12
Message: <569f8950$1@news.povray.org>
Am 19.01.2016 um 19:57 schrieb Jaime Vives Piqueres:
I'm more inclined to suspect that it's because generation and inclusion
of the file are done in one and the same macro.
Date: 20 Jan 2016 14:31:11
Message: <569fe07f$1@news.povray.org>
*HA!*
Got that son of a bitch!
Quick workaround: Add /anything/ anywhere before the "#end" statement of
ParseCenterOfMass(); even somewhere before the macro will do. But no
more than about 50 characters.
"WTF?!" you might ask.
Well, here's what happens in a nutshell:
- For each macro defined, POV-Ray stores some information like what file
it resides in, where it starts and, most importantly in this context,
where it ends. More specifically, it stores the position of the "#end"
that ends the macro.
- While executing a macro, to determine whether it has reached the end,
POV-Ray keeps its eyes peeled for any "#" at the position it has stored
as the macro's end.
- In your example, the 10th (give or take 1) "#declare" in "data.inc"
happens to be at the very same position as the "#end" of
ParseCenterOfMass() in your main file.
Do I need to say more? They say never to spoil a joke by explaining its
punchline, but yeah: When looking out for the end of the macro, POV-Ray
does indeed /not/ bother to test whether it is even in the right file.
*Facepalm!*
Date: 20 Jan 2016 15:41:44
Message: <569ff108$1@news.povray.org>
Am 20.01.2016 um 20:31 schrieb clipka:
Slight flaw in my analysis there: I was under the impression "data.inc"
would grow with another line every frame.
Truth is, there is /some/ "#declare" that /sometimes/ coincides in file
position, depending on the values written. That's the case in frame 10,
but not earlier.
Date: 20 Jan 2016 18:08:26
Message: <56a0136a$1@news.povray.org>
> *HA!*
A fix is available now at https://github.com/POV-Ray/povray (source
code) and https://github.com/c-lipka/povray/releases (semi-official
Windows build).
Date: 20 Jan 2016 19:30:03
Message: <56a0268b@news.povray.org>
>> *HA!*
> Windows build).
Compile fails
Ger
Date: 20 Jan 2016 20:08:03
Message: <56a02f73$1@news.povray.org>
>>> *HA!*
>> Windows build).
> Compile fails
difficult to diagnose. "Compile fails" doesn't grep out of the source code.
Date: 20 Jan 2016 20:14:39
Message: <56a030ff$1@news.povray.org>
>>>> *HA!*
>>> Windows build).
>> Compile fails
:) Yeah, I know. I was still digging at it.
It was just meant as an early shout that something is out of line.
Ger
Date: 20 Jan 2016 20:50:02
Message: <56a0394a$1@news.povray.org>
>>>>> *HA!*
>>>> Windows build).
>>> Compile fails
>> code.
Fails at
make[1]: Entering directory '/home/ger/Downloads/povray-master/source'
depbase=`echo backend/interior/interior.o | sed 's|[^/]*$|.deps/&|;s|
\.o$||'`;\
g++ -DHAVE_CONFIG_H -I. -I..  -I../unix/povconfig -I.. -I../unix -I../vfe -
I../vfe/unix -I/usr/include/SDL -D_GNU_SOURCE=1 -D_REENTRANT -
I/usr/include/OpenEXR  -pthread -I/usr/include  -I/usr/include  -pipe -Wno-
multichar -Wno-write-strings -fno-enforce-eh-specs -Wno-non-template-friend -
s -O3 -ffast-math -march=native -pthread -MT backend/interior/interior.o -MD
-MP -MF $depbase.Tpo -c -o backend/interior/interior.o
backend/interior/interior.cpp &&\
mv -f $depbase.Tpo $depbase.Po
In file included from ./backend/render/trace.h:44:0,
                 from ./backend/interior/media.h:39,
                 from ./backend/interior/interior.h:37,
                 from backend/interior/interior.cpp:36:
./backend/bounding/bbox.h:59:7: error: redefinition of ‘class pov::Rayinfo’
 class Rayinfo
Ger
Date: 21 Jan 2016 00:03:11
Message: <56a0668f$1@news.povray.org>
Am 21.01.2016 um 02:49 schrieb Ger:
>>>>> Windows build).
> Fails at
> \.o$||'`;\
> ../backend/bounding/bbox.h:59:7: error: redefinition of ‘class pov::Rayinfo’
>  class Rayinfo
I have no idea what source code you are compiling there -- it is
definitely /not/ what the doctor prescribed, because all the files
"interior.cpp", "interior.h", "media.h" and "trace.h" and "bbox.h" no
longer reside in the "backend" directory sub-tree.
Let me reiterate: You do /not/ want the "stable" branch. You want "master".
Also, make sure you don't have any zombie source files from the "stable"
branch (or any other older version for that matter) lying around when
building.
The source code in question demonstrably builds fine with both g++ 4.6.3
on Ubuntu 12.04 and with g++ 4.8 on Ubuntu 14.04.
Date: 21 Jan 2016 02:37:13
Message: <56a08aa9$1@news.povray.org>
> building.
You're right, my bad, sorry for that.
I had some old master zip thingy stuck under the keyboard or to the back of
the monitor and mistakenly unpacked that one.
It compiled just fine on a clean installed opensuse tumbleweed. I'll try and
let you know tomorrow about the macro bug story.
Ger
Date: 21 Jan 2016 02:56:30
Message: <56a08f2e$1@news.povray.org>
> and let you know tomorrow about the macro bug story.
This the correct version?
Persistence of Vision(tm) Ray Tracer Version 3.7.1-alpha.8443996.unofficial
(g++
 5 @ x86_64-suse-linux-gnu)
Ger
Date: 21 Jan 2016 07:45:01
Message: <web.56a0d27fc0eb7a16ad6fa18f0@news.povray.org>
The 3996 looks familiar.
