POV-Ray : Newsgroups : povray.general : looks_like Server Time
4 Mar 2026 05:46:54 EST (-0500)
  looks_like (Message 1 to 8 of 8)
Subject: looks_like
Date: 14 Jan 2016 02:47:07
Message: <5697527b@news.povray.org>
I have the following code:
#local lamp_sphere = sphere
	0, 1
	scale lamp_radius
	hollow
light_source
	0, lamp_color
	looks_like {lamp_sphere}
	translate spiral_coo
Unfortunately the sphere is blocking the light source when it should let
the light shine through. What am I doing wrong? Thanks.
Mike
Subject: Re: looks_like
Date: 14 Jan 2016 05:51:21
Message: <56977da9$1@news.povray.org>
>      0, 1
>      scale lamp_radius
>      hollow
> light_source
>      0, lamp_color
> Mike
Never mind. I had wrapped everything in a merge when I should have
instead wrapped everything in a union.
Mike
Date: 14 Jan 2016 09:05:06
Message: <web.5697aaf4e29f651ad6fa18f0@news.povray.org>
>  0, 1
>  scale lamp_radius
>  hollow
> light_source
>  0, lamp_color
I'd suggest testing this in different versions of POV-Ray.
My initial thought is that looks_like should automatically set "no_shadow on"
(and also "no_radiosity on") for the object; if that doesn't happen, I guess it
should be considered a bug. I'll need to look it up in the docs myself though.
Date: 14 Jan 2016 12:58:39
Message: <5697e1cf$1@news.povray.org>
>>   0, 1
>>   scale lamp_radius
>>   hollow
>> light_source
>>   0, lamp_color
Is that not for "projected_through"?
Which might be a solution.
Regards
Date: 14 Jan 2016 15:40:46
Message: <569807ce$1@news.povray.org>
Am 14.01.2016 um 18:58 schrieb Stephen:
>> "no_shadow on"
>> guess it
>> though.
"There is an implied no_shadow attached to the looks_like object so that
light is not blocked by the object."
The projected_through object has an implied no_whatsoever: It is never
inserted into the scene as a regular object, and only contributes as
part of a special feature -- similar to object specified in bounded_by,
object patterns, and other odds & ends.
Date: 14 Jan 2016 16:59:41
Message: <56981a4d$1@news.povray.org>
>>> "no_shadow on"
>>> guess it
>>> though.
Is it possible to have multiple lights look_like the same object?
Mike
Date: 14 Jan 2016 17:31:50
Message: <569821d6$1@news.povray.org>
>>> "no_shadow on"
>>> guess it
>>> though.
It is years since I have used looks_like or projected_through. My memory
fails. Good job we have documentation.
Regards
Date: 14 Jan 2016 18:06:10
Message: <569829e2$1@news.povray.org>
Am 14.01.2016 um 22:59 schrieb Mike Horvath:
>>>> "no_shadow on"
>>>> guess it
>>>> though.
No, but it should be perfectly possible to either...
(a) attach the object to just one of the lights, or
(b) specify the object separately from the light sources (or bundle the
object and the corresponding light sources together in a union, making
them easier to manage as a group, e.g. rotate them, hide them in test
renders, or whatever), and explicitly specify "no_shadow" on the object.
