POV-Ray : Newsgroups : povray.general : HELP: Round Blurred Fog Server Time
29 Oct 2026 03:08:22 EDT (-0400)
  HELP: Round Blurred Fog (Message 1 to 14 of 14)
Subject: HELP: Round Blurred Fog
Date: 17 Dec 2015 17:23:29
Message: <567335e1@news.povray.org>
I admit, I never worked with fog or media before, and thus I don't
really even know, what exactly to look for in the help file. When
looking up there for FOG, I did not see what I need.
Thus I am asking here for some starting advise.
My intention is, to create a spherical object that appears like a
blurred fog, wish shades of glowing orange inside. There is no shark
outside edge. Just imagine a glowing, but relatively dim sun. I wonder,
if FOG or MEDIA can do the trick, but need here some advises what
exactly to look for inside the Help file. Thanks.
Subject: Re: HELP: Round Blurred Fog
Date: 17 Dec 2015 19:08:55
Message: <56734e97@news.povray.org>
Le 15-12-17 17:23, Sven Littkowski a écrit :
> Hi,
fog is not what you need. It can't be shaped in any way.
What you need is media.
As you want a glowing thing, emissive media seems to impose itself.
You probably don't want your glowing media to fill the whole scene, so,
you need to contain it in something. A good shape, in your case, is the
sphere.
Here's a minimal example:
sphere{
	0, 1
	pigment{rgbt 1} //make it totaly invisible
	hollow // enable it to contain your media
// the "magic" start here
	interior{
	 media{ emission 1 // adjust as needed
	 density{ spherical }
// start at 1 at <0,0,0> and drop to zero at radius 1
	scale Dimention
	translate Location
This will give you a spherical shaped area of luminous gray to white
media at the origin that you can scale as wanted, then, translate/move
to the desired location.
If you create the sphere elsewhere, the media pattern will NOT be placed
adequately.
If you scale, the media effect will change proportionately.
The value for emission can be a colour and it's value is not limited to
the 0..1 range.
emission<10, 100, 1000> is legal as is emission<-1, 1, 1>
The pattern used can have a color_map that can change the effective colour.
If you add some turbulence to the pattern, you need to make the
containing sphere larger: turbulence 0.5 need a sphere's radius of about
1.5, otherwise, part of it will be clipped.
If you use radiosity, adding "media on" in the radiosity block will
allow that media to illuminate it's surrounding. In a normal scene, you
need to add an actual light_source to have it shed any light around.
Beter to use an area_light in this case.
Date: 17 Dec 2015 21:09:48
Message: <56736aec$1@news.povray.org>
Alan, this is a great start-up help you have given, my appreciation! I
started already to make experiments with it.
Still, there is something I need to know:
I want that the media covers up a sphere, let's say, of a radius of 1
unit. Just outside that 1-unit-radius sphere, the density should fade
down to 0.0 at a distance of 0.3 units to the outside of that sphere.
That means, the density does not decrease constantly from center to 1.3
units away. How can I implement it this way?
Date: 17 Dec 2015 21:11:50
Message: <56736b66$1@news.povray.org>
Besides this all, it seems, when trying to look up MEDIA and DENSITY
inside the help file, they were forgotten to be cross-linked to. I also
tried successly to click these keywords inside the scene source code and
then pressing "F1" - this just opens up the Help File's start page. Can
that be? Do you all have the same experience? Please test.
Date: 17 Dec 2015 21:30:35
Message: <56736fcb@news.povray.org>
Alan, I experimented a little bit. At the moment, using your code and
also (now that I know what to look for) POV-Ray's example files, I am
ending up with this:
sphere
 < 0.0, 0.0, 0.0 > 10.0
 pigment { rgbt 1.0 } //makes it invisible
 interior // the "magic" starts here
  media
   emission 0.5
   intervals 1
   samples 5
   method 3
   density
    spherical
	color_map
	 [ 0.0 color rgb < 0.0,     0.0,     0.0 >        ]
	 [ 0.1 color rgb < 0.74902, 0.34118, 0.22353 > /4 ]
	 [ 1.0 color rgb < 0.74902, 0.34118, 0.22353 >    ]
   } // starts at 1 at <0,0,0> and drops to zero at radius 1
 scale 10.0
 translate < 0.0, 0.0, 0.0 >
cylinder
 < 0.0, 0.0, -50.0 > < 0.0, 0.0,  50.0 > 2.50
 pigment { rgb < 1.0, 0.5, 0.0 > }
The media sphere, and for test purposes a cylinder.
I am quite happy, but would like still to have the same high density
within 1.0 units from the center, and then a fading out from 1.0 to 1.3.
The fading out I achieve, is not regular enough - it seems to end quite
fast.
Date: 17 Dec 2015 21:51:57
Message: <567374cd@news.povray.org>
By judiciously using a color_map as follow:
sphere{
     0, 1
     interior{
      density{ spherical  color_map{[0 rgb 0][1-(1/1.3) rgb 1 ]}}
     scale 1.3
// scale the sphere and the media as a single unit
     translate Location
This way, for all values of the pattern that are larger than about 0.23
will have the maximum density. For those smaller, the density will
decrease much faster doen to zero.
If you need to increase the quality of the media in case of missing
details or banding, you increase the samples count. NEVER increase
intervals to any value larger than 1.
The defaults are:
method 3
samples 10
intervals 1
In my tests, I found that "samples 100 intervals 1" is much faster than
"samples 1, 5 intervals 5" and give a beter result.
Emissive media is the fastest to render, followed by absorbing and
scattering is the slowest.
Date: 17 Dec 2015 21:54:31
Message: <56737567$1@news.povray.org>
The help page you get is absolutely huge!
It contains material for ALL aspects of the scene.
The part about media is about 85% down, before the lengthy description
of the standard include files.
Date: 17 Dec 2015 22:30:54
Message: <56737dee$1@news.povray.org>
This is strange - my Help File lacks functionality, it seems. Will check
out that problem later. The media works now the way I want it, and I am
very happy. Thanks a lot!
Date: 18 Dec 2015 03:02:44
Message: <5673bda4$1@news.povray.org>
The help file (F1) resident in POV-Ray has not been too good for some
time now nor is it entirely up-to-date. Many links are broken, some do
not exist. It would need a serious overhaul. However, The wiki page is
entirely up-to-date and of easy access:
http://wiki.povray.org/content/Documentation:Contents
Date: 18 Dec 2015 03:25:48
Message: <5673c30c@news.povray.org>
Alan, for you I have attached a first rendering of my spaceship, using
the media as you told me. I still have to make some adjustments, but it
looks really neat on my little ship.
Download 'sl - seneca ii - close view 1 km - wormhole generator - 002.jpg' (543 KB)
Preview of image 'sl - seneca ii - close view 1 km - wormhole generator - 002.jpg'
Date: 18 Dec 2015 03:26:35
Message: <5673c33b@news.povray.org>
Thanks, Thomas! Good hint!
Date: 18 Dec 2015 15:28:18
Message: <56746c62@news.povray.org>
Thanks again for the assistance, Alain. See here the fine result. She's
not finished yet, but she's already a fine ship, and looks even finer
thanks to your help.
Download 'sl - seneca ii - distance - 001 - compressed .jpg' (5603 KB)
Preview of image 'sl - seneca ii - distance - 001 - compressed .jpg'
Date: 18 Dec 2015 22:17:06
Message: <5674cc32@news.povray.org>
Am 18.12.2015 um 21:24 schrieb Sven Littkowski:
Sven, please don't post such huge pictures.
Not generally, and certainly not in newsgroups without "binaries" in
their name.
Are you even aware that your image is 5.5 MB large (despite apparently
being heavily compressed)?
Also, the image size in pixels is beyond what we can possibly view on
screen. Heck, even on a 4K display it doesn't fit even remotely!
A 16th of the file size (a 4th by a 4th in terms of resolution) would
have been more than enough for most of us.
If you do want to provide us with extremely high resolution images (e.g.
for poster printing), please feel free to make them available on your
website and post a link.
If you want to show off high-resolution details, please feel free to
post detail views (i.e. images showing only a subsection of the original
image) rather than the entire image in high-res, on
povray.binaries.images rather than povray.general.
(BTW, someone cut off a piece of your planet. Not good. Expect massive
earthquakes, the oceans draining into that region, and -- presuming that
the hot core is exposed -- the drained water promptly and violently
evaporating into the atmosphere, leading to disastrous climate
changes... or is that why the people have built the ark?)
Date: 19 Dec 2015 05:01:24
Message: <56752af4@news.povray.org>
Hi Clipka, I think, I have to agree with you. The loading and display of
the image are not good. Point taken. Will host the image from now on one
of my websites and link here with a small thumbnail and URL. Even my own
newsgroup client (Mozilla Thunderbird) crashes sometimes while loading
the image. Not a good idea...
The planet:
I didn't even see that i missed a part of the planet when adding it to
this image. Did it after an entire night without sleep but working on
this scene. Yes, this is the target planet. It contains an ocean of a
liquid, and even better, that liquid is water, too! And even better,
this planet got an atmosphere, though it is not breathable for humans
without equipment or genetic/operative adaptions. I think, no Earth-like
planet we may discover in the entire future will already have an
atmosphere that can be breathed right away. I think, in all cases we
have to adapt - the atmosphere if the planet is uninhibited, or
ourselves if there is some sort of life there already. I believe,
mankind will develop, having then these special needs, scientific
knowledge how to change our own bodies through genetic engineering, or
to implant artificial organic or non-organic mechanisms into our bodies
that can do this extra job. No planet ever we will find, will be
"perfect to enter right away". There are too many factors in the
development of a planet, to create a perfect 2nd Earth. There will
always be differences. Even any animals there wouldn't be edible just
like that. And besides, who says, that on other inhabited planets there
are exactly the same divisions of life into bacteria, fungi, amoebas,
fauna and flora as here on this planet? our five "kingdomes" developed
based on the conditions of this planet. Expect different divisions on
other planets, though the extremities of life forms on other planets
will be of similar designs as gas, solid surfaces, and liquids fall
under the same physical rules applicable to movement. Wow, this is one
of my favorite subjects to discuss and exchange with others about, so I
better stop now. Otherwise I am writing here entire books...
Besides, I am actually writing a book. It is a scifi novel of a human,
stranded in a far far future 5 billion years from now, in a solar system
modified by its future inhabitants, encountering sentient life forms of
different development stages (culturally, technically, psychologically),
and also seeing the continued aging of the entire universe, and how
these different sentient life forms may have managed each in their own
way to live together or not. Lots of work still ahead, I am just on page
20... :-)
Sven
