POV-Ray : Newsgroups : povray.general : Function: Making negative numbers positive Server Time
31 Oct 2024 23:29:06 EDT (-0400)
  Function: Making negative numbers positive (Message 1 to 10 of 33)
Subject: Function: Making negative numbers positive
Date: 24 Nov 2015 20:11:15
Message: <56550ab3@news.povray.org>
Hi.
Is there a POV-Ray function that allows to make a negative number to a
positive number? I want to use such a function, to make a coordinate
number to a positive number. Thanks.
Subject: Re: Function: Making negative numbers positive
Date: 24 Nov 2015 20:40:25
Message: <56551189$1@news.povray.org>
On 2015-11-24 17:11, Sven Littkowski wrote:
> Hi.
Multiply the number by -1.
Date: 24 Nov 2015 20:52:15
Message: <5655144f@news.povray.org>
> Hi.
abs()
Ger
Date: 24 Nov 2015 22:45:00
Message: <web.56552e907aaf16cc5e7df57c0@news.povray.org>
sqrt(pow(x,2))
;)  :D
Date: 26 Nov 2015 23:11:51
Message: <5657d807@news.povray.org>
Le 15-11-24 20:11, Sven Littkowski a écrit :
> Hi.
That's the absolute value. The abs() function does exactly what you want.
 From the documentation:
Abs
Absolute value of A. If A is negative, returns -A otherwise returns A.
#declare Abs = abs(A);
A convoluted, and slow, way is to take the square root of the squared value:
#declare Abs = sqrt(pow(x,2));
You can also use the sellect() function:
#declare Abs = sellect(A, -A, A);
Or use an #if...#else...#end test:
#declare Abs = #if(A<0) -A; #lese A; #end
or
#if(A<0) #declare Abs = -A; #elese #declare Abs = A; #end
If you search and experiment, you may find some other ways to do the same.
Date: 27 Nov 2015 05:40:38
Message: <56583326$1@news.povray.org>
>> Hi.
> Abs
> value:
> or
> Alain
Why use a function at all? If you want to change a negative number to a
positive number all you have to do is multiply it by -1.
Date: 27 Nov 2015 05:45:50
Message: <5658345e$1@news.povray.org>
Am 27.11.2015 um 11:40 schrieb Todd Carnes:
That's only true if the number in question is known to be negative.
In that case, however, it is easier and more efficient to just use the
unary minus operator:
#declare PositiveNumber = -NegativeNumber;
Date: 27 Nov 2015 05:52:24
Message: <565835e8$1@news.povray.org>
Am 27.11.2015 um 05:12 schrieb Alain:
The keyword is actually "select".
Date: 27 Nov 2015 06:16:07
Message: <56583b77$1@news.povray.org>
There is an 'L of a difference. ;-)
Regards
Date: 27 Nov 2015 11:20:35
Message: <565882d3$1@news.povray.org>
I know, but that was what the OP asked for.
That works too, but then it's really just masking the fact that you are
doing what I said... i.e. multiplying by -1.
Todd
