POV-Ray : Newsgroups : povray.general : Lego renders using MODO Server Time
29 Oct 2026 04:03:56 EDT (-0400)
  Lego renders using MODO (Message 1 to 6 of 6)
Subject: Lego renders using MODO
Date: 24 Feb 2015 14:14:28
Message: <54eccd94$1@news.povray.org>
Hi folks,
I recently came across this post on the LDraw forums:
http://forums.ldraw.org/read.php?20,12928
The Lego renders here are pretty awesome. I'm always looking for ways to
acheive better Lego renders in POV-Ray, so would appreciate any advice/code
snippets on how to achieve more realistic renders. Maybe there is some
general "rendering plastic materials" type stuff that I could benefit from?
I think my Lego models always look a bit too shiny:
http://news.povray.org/povray.binaries.images/attachment/%3C51a7b9c2%40news.povray.org%3E/lego_minifigures_3d.png
Thanks in advance.
Reuben
Download 3D Lego models and other resources from:
http://www.pearse.co.uk/lego
Subject: Re: Lego renders using MODO
Date: 24 Feb 2015 15:45:01
Message: <web.54ece24880625e3250e2cbc30@news.povray.org>
"Reuben Pearse" <reu### [at] pearsecouk> wrote:
> Hi folks,
> Thanks in advance.
> Reuben
Hi Reuben,
yes the renderings at the LDraw forum looks really nice. I'm not sure, but I
think first subsurface scattering is in use there to a small amount and second
blurred reflection. The first is implemented in POV 3.7 now, the latter can be
simulated in POV with averaged textures or parametrized with the unofficial
version UberPOV. May be you look at this new features. Unfortunatelly I'm not an
expert at this issues to give further guidance. I can only give you this poor
hints.
Best regards,
Michael
Date: 26 Feb 2015 15:58:01
Message: <54ef88d9@news.povray.org>
Am 24.02.2015 um 21:42 schrieb MichaelJF:
>> Hi folks,
> hints.
Those hints are fare from poor - that's exactly what I think I see in
the MODO renders, too (and I guess I have a keen eye for it): Subsurface
scattering and blurred reflections.
Also, as far as specular highlights are concerned, a common
misconception is that "specular 1.0" would correspond to a totally
reflective surface - it does not, except for the hypothetical case of
"roghtness 0.0"; with the traditional "specular FLOAT" parameterization,
any increase in roughness also increases the total amount of reflected
light. For a physically more straightforward parameterization, use the
new "specular albedo FLOAT" syntax, where "specular albedo 1.0" indeed
corresponds to a totally reflective surface, regardless of the
roughness. (Same goes for "phong FLOAT" vs. "phong albedo FLOAT" with
respect to phong_size, and "diffuse FLOAT" vs. "diffuse albedo FLOAT"
with respect to brilliance.)
Another thing that can really add to the credibility of a material is
the simulation of fresnelian effects, not only for specular reflection
(which gets brighter at shallow angles) but also for highlights (which
should do the same) and diffuse reflection (which should get less bright
at shallow angles). POV-Ray 3.7.0 only supports fresnelian effects for
specular reflection (via the "fresnel on" statement in the reflection
block), but not on highlights, and for diffuse reflections it only
supports them when using subsurface scattering (in which case they
actually can't be turned off). POV-Ray 3.7.1 adds full support for the
latter two (by specifying "fresnel on" directly in the finish block as
well; note that "fresnel on" in the reflection block is still required
as well); UberPOV 1.37.1.X supports this new syntax as well.
Ideally, you would be using UberPOV 1.37.1.X with the following finish
settings:
     finish {
       diffuse albedo D brilliance B
       specular albedo S roughness R
       phong off
       fresnel on
       reflection { S roughness R fresnel on }
       conserve_energy
       subsurface { ... } // (optional)
where D+S < 1. (Don't forget to specify an interior block with ior to
all your materials, even the opaque ones. If you don't know the
refractive index of a material, 1.5 is a good bet.)
When using POV-Ray 3.7.1, for sufficiently shiny materials an acceptable
approximation is to leave out the "roughness R" statement in the
reflection block:
     finish {
       phong off
       fresnel on
       reflection { S fresnel on }
       conserve_energy
For sufficiently dull materials, you can turn off reflections entirely:
     finish {
       phong off
       fresnel on
       reflection { 0.0 fresnel on }
       conserve_energy
(Theoretically you would need to compensate by fudging D up a bit for
the sake of radiosity but not for classic diffuse, but that's something
POV-Ray doesn't support at present.)
For materials in between, there is no really good solution in official
POV-Ray at present.
When using POV-Ray 3.7.0, you should fudge up the specular highlights
and (unless you're using subsurface scattering) fudge down the diffuse
reflection, to compensate for the fact that they don't honor fresnelian
effects:
     finish {
       diffuse albedo D*(1-F) brilliance B
       specular albedo S*F roughness R
       phong off
       conserve_energy
or:
     finish {
       phong off
       conserve_energy
       subsurface { ... } // (mandatory)
where F is some fudge factor very roughly around 2.0.
High-quality diffuse inter-reflections are of high importance for
creadibility as well. If you're using POV-Ray, this means using
high-quality radiosity settings; with UberPOV, I'd recommend using
"no_cache" in the readiosity block instead.
Finally, some of the MODO renders also use focal blur, which can also
add to credibility, provided you don't overdo it. Ideally, the aperture
value for a POV-Ray focal blur camera should correspond to somewhere
about 1mm to at most 1cm in scene units.
Date: 27 Feb 2015 05:31:43
Message: <54f0478f$1@news.povray.org>
Am 24.02.2015 um 20:14 schrieb Reuben Pearse:
> Hi folks,
On a related note, I just tested the LDD2POVRAY mentioned in that post:
It really sucks hard, as it is artificially constrained to selected
POV-Ray versions. No way to render those scenes with UberPOV, not even
development versions of POV-Ray.
Date: 27 Feb 2015 05:37:39
Message: <54f048f3$1@news.povray.org>
Am 26.02.2015 um 21:58 schrieb clipka:
BTW, the material definitions that come with LDD2POVRAY specify the ior
of opaque bricks as 1.57, and that of transparent bricks as 1.2.
Date: 9 Feb 2018 07:49:20
Message: <5a7d98d0$1@news.povray.org>
Some of the Sunflow renders look really good too.
http://slswww.free.fr/neo-6930.5b.png
Unfortunately, I can't get the LDraw converter to work on my PC.
Mike
On 2/24/2015 2:14 PM, Reuben Pearse wrote:
> Hi folks,
> Thanks in advance.
> Reuben
