POV-Ray : Newsgroups : povray.general : Scene won't render - missing povray.ini Server Time
10 Oct 2026 14:54:49 EDT (-0400)
  Scene won't render - missing povray.ini (Message 1 to 5 of 5)
Subject: Scene won't render - missing povray.ini
Date: 4 Feb 2015 07:06:35
Message: <54d20b4b$1@news.povray.org>
I am using Povray version 3.7.0.msvc10.win64 in Windows 7 Pro SP1 64-bit.
I tried rendering a LDraw model and got this error:
Preset INI file is 'D:\GOOGLE DRIVE\WORKING\POVRAY\QUICKRES.INI',
section is '[1600x1200, AA 0.3, Alpha]'.
Preset source file is 'D:\Google
Drive\Working\Povray\LDraw\web_androbot.pov'.
Cannot open INI file
'C:\Users\Mike-7PRO\Documents\POV-Ray\v3.7\ini\povray.ini'.
Failed to start render: Failed to parse INI file
Notably, povray.ini is missing from that location. Not sure what to do
next to get it working. Thanks.
Mike
Subject: Re: Scene won't render - missing povray.ini
Date: 4 Feb 2015 07:24:49
Message: <54d20f91$1@news.povray.org>
I think this has to do with the user account I used to install the program.
How do I install povray on Windows 7 so that my non-admin account can
use it? If I try to install as a regular user, then I can't install into
Program Files. If I install as an admin, then all the support files get
placed in the admin's Documents directory, and I am locked out.
Help!
Date: 4 Feb 2015 11:09:39
Message: <54d24443$1@news.povray.org>
Am 04.02.2015 um 13:25 schrieb Mike Horvath:
> Help!
Have a look at this:
http://wiki.povray.org/content/Documentation:Windows_Section_3#The_.2FINSTALL_and_.2FQINSTALL_switches
I've never had a closer look at this option, so I must leave it up to
you to figure out the details, but it's designed for exactly the
situation you're describing.
Date: 4 Feb 2015 22:09:54
Message: <54d2df02$1@news.povray.org>
>> program.
>> Help!
This is a bad situation, period. Using the default Windows installer as
a regular user is not some edge case that should need special configuration.
Mike
Date: 4 Feb 2015 23:36:22
Message: <54d2f346$1@news.povray.org>
Am 05.02.2015 um 04:10 schrieb Mike Horvath:
> configuration.
Using the default Windows installer as a regular user with admin rights
works perfectly.
Using the default Windows installer as a regular user /without/ admin
rights does the perfectly right thing, namely installing the program for
the user only. There is no way whatsoever to install into Program Files
in such a case.
It's the case of using the default Windows installer as an /admin/ to
install POV-Ray for other users that's bonkers to some degree.
The official way to do this would be for the installer to "advertise" a
kind of 2nd-level installer, which would then be run the first time a
user starts POV-Ray. However, this is a feature not supported by the
install system we're using.
The unofficial way to do this would be for POV-Ray itself to
automatically check whether it has been installed for the current user,
and if that's not the case automatically do this 2nd level installation.
However, this is a feature requiring extra work and testing.
At the end of the day it is a matter of priorities. You might like to
hear that we already have plans for this somwhere in the drawer, and
your post might make us reconsider its priority, but don't hold your breath.
