POV-Ray : Newsgroups : povray.general : Transparency maps Server Time
22 Mar 2026 07:37:18 EDT (-0400)
  Transparency maps (Message 1 to 10 of 36)
Subject: Transparency maps
Date: 26 Nov 2014 06:36:13
Message: <5475bb2d$1@news.povray.org>
I am reworking an old globe of the Earth and I see that I used a cloud
map image with 4 bit colour depth. So that I could manage the
transparency (only 16 pallet entries).
It was okay for a small image but now I want something with more
resolution.
Any suggestions?
Regards
Subject: Re: Transparency maps
Date: 26 Nov 2014 07:45:59
Message: <5475cb87$1@news.povray.org>
> resolution.
> Any suggestions?
Could you use this?
http://www.shadedrelief.com/natural3/pages/clouds.html
Date: 26 Nov 2014 08:12:36
Message: <5475d1c4$1@news.povray.org>
>> resolution.
>> Any suggestions?
> Could you use this?
> Thomas
I am or something like it.
My understanding is that PovRay uses either an alpha channel or a pallet
based transparency. With the pallet based method 256 channels are the
most you can use. I was hoping that someone had devised a way to use the
greyscale value.
I have an acceptable result by converting the original image to 8 bit
and blurring it a small bit. Then inputing the pallet entries by hand.
Or by Excel, actually. :-)
Regards
Date: 26 Nov 2014 10:02:28
Message: <5475eb84$1@news.povray.org>
>>> resolution.
>>> Any suggestions?
>> Could you use this?
>> Thomas
> greyscale value.
What is a pallet-based transparency? The term is unfamiliar to me.
Date: 26 Nov 2014 10:34:47
Message: <5475f317$1@news.povray.org>
Not surprised. I made it up.
 From the top of my head:
It is an index of colours used in the image. In Pov we can set the
transparency and filter values in the image_map definition. Each entry
in the index can be set to a transparency, individually. I think that
pallet based images are limited to 8 bit images.
So in a cloud map each grey could have a different level of transparency.
rgb -> rgbft
Regards
Date: 26 Nov 2014 11:15:01
Message: <web.5475fb69745b55605e7df57c0@news.povray.org>
> most you can use.
Are you using image_pattern and/or use_alpha?
> greyscale value.
I sort of see what you want to do...
Maybe you could "scan" the image with eval_pigment and then calculate a
transparency variable using the grayscale value?
I dunno - I'm still only on coffee #2, and the foot of snow we're supposed to be
getting is just starting to come down, so I'm not 100% focused...
That sounds somewhat labor intensive, though interesting.
Maybe some example code and a small illustrative image would help puzzle out a
solution.
Date: 26 Nov 2014 12:09:22
Message: <54760942$1@news.povray.org>
>> most you can use.
I am using image_map
>> greyscale value.
LOL
You might be able to do that. I couldn't code my way out of a wet paper
bag. ;-)
I use a modeller for everything. I can modify and add code, though.
Excuses, excuses. I've been up for eleven hours, allready. ;-)
Yes it is. :-(
But I have automated a lot of it in Excel and I copy and paste into the
modeller.
> solution.
I'll make up a little package including the transparency map, later. But
you could use one of the ones Thomas pointed to.
The basic material is:
#declare CloudedEarth =
   #declare BISHOP3D_TEMPORARY_IDENTIFIER =
         image_map{
           png "f:\Graphics\B3D Data\Maps\Planets\Earth\EarthMap2.png"
This is the image  map of Earth.
           interpolate 4
           map_type 1
       normal {
         bump_map{
           png "f:\Graphics\B3D Data\Maps\Planets\Earth\EarthBum_Neg.png"
This is the bmp  map of Earth.
           interpolate           2
           use_color
           map_type 1
         0.100      }
         image_map{
           png "F:\Graphics\B3D
Data\Maps\Planets\Earth\earthcloudmaptrans_Neg240.png"
This is the cloud map that I want the dark parts transparent.
           interpolate 2
           map_type 1
           transmit 0, 1.000
           transmit 1, 1.000
// Snip lots of entries
           transmit 238, 0.007
           transmit 239, 0.000
   ;// the semicolon is necessary or POV-Ray will not figure out that
the declarations has ended
Regards
Date: 26 Nov 2014 14:00:30
Message: <5476234e$1@news.povray.org>
Am 26.11.2014 14:12, schrieb Stephen:
> ... I was hoping that someone had devised a way to use the
> greyscale value.
#declare PP_Claud = pigment{image_map{jpeg "my_cloud_map" map_type 1
interpolate 2}}
  sphere{ 0, 1.005
      pigment_pattern{PP_Claud}
      texture_map {
       [0.00 texture {pigment{rgb 1 transmit 1} finish{diffuse 1}}]
       [1.00 texture {pigment{rgb 1 transmit 0} finish{diffuse 1}}]
...where "my_cloud_map" is a grayscale, not a color palette image!
and it might be a good idea to add the cloud texture to a slightly
larger scaled sphere (than the planet) and not as top layered texture as
you did.
And you didn't ask for it but anyway: adding a specular map in pretty
much the same way (giving highlights to the ocean covered area but not
to the land mass) makes it even more realistic.
You can obtain maps for this e.g. from NASA's Blue Marble page.
With some scattering media atmosphere it gives something like this:
http://news.povray.org/povray.binaries.images/thread/<4a056976@news.povray.org>
-Ive
Date: 26 Nov 2014 14:17:02
Message: <5476272e$1@news.povray.org>
Before I look at your suggestions. The above link only goes to the index.
And thanks for the reply
Regards
Date: 26 Nov 2014 15:09:58
Message: <54763396$1@news.povray.org>
Am 26.11.2014 20:16, schrieb Stephen:
this should do
http://news.povray.org/povray.binaries.images/message/<4a056976@news.povray.org>/<4a056976@news.povray.org>
-Ive
