POV-Ray : Newsgroups : povray.general : default input name doesn't work Server Time
3 Nov 2026 02:49:05 EST (-0500)
  default input name doesn't work (Message 1 to 5 of 5)
Subject: default input name doesn't work
Date: 16 Jul 2002 08:08:51
Message: <5438jucur15rf1nkkipq0mbdnrmo1g2j17@4ax.com>
In documentation there is a note "you can now specify a POV file on the
command-line without the use of the +i switch (...), the POV file then should
be the last on the commandline." and that "the default input filename is
object.pov". But seems it interfere with windows specific settings. When I
call
pvengine /RENDER /EXIT
I expect it to open object.pov, render it with default settings and exit after
rendering. But engine stays opened with error:
Initialization Error: Could not find file '/EXIT.pov'
Moreover pvengine /RENDER doesn't work with default input file either.
Any confirmation ? Similiar problems with platform specific settings on other
platforms ?
ABX
Subject: Re: default input name doesn't work
Date: 16 Jul 2002 08:22:39
Message: <oq38ju4fnejbh4hbg75gm98us3av5ea1fm@4ax.com>
On Tue, 16 Jul 2002 14:07:49 +0200, W�odzimierz ABX Skiba <abx### [at] babilonorg>
> pvengine /RENDER
Or default file name doesn't work becouse as specified in 1.9.1 it is supposed
only "to render the file following" ?
ABX
Date: 16 Jul 2002 11:39:34
Message: <3d343e36$1@news.povray.org>
so try
pvengine /RENDER object.pov /EXIT
> > pvengine /RENDER
supposed
> ABX
Date: 18 Jul 2002 04:42:18
Message: <4bvcju0paapeaa3opf5t5b4vbsp9f2j61i@4ax.com>
On Tue, 16 Jul 2002 10:43:55 -0500, "Andrew Wilcox" <awi### [at] unpuzzledcom>
wrote:
> so try
Do you really think I didn't ?
The problem is that it looks like some kind inconsistency in options system
but there was probably a reason. For example simplified communication
requested with one some tool.
ABX
Date: 18 Jul 2002 10:47:39
Message: <3d36d50b$1@news.povray.org>
Yeah, you are right, I think I missed the point of your post.  You were
pointing out a conflict in options, not stuck on a problem.
Sorry about that,
Andrew
> > so try
system
> ABX
