POV-Ray : Newsgroups : povray.general : POVORAMA database: MySQL dump Server Time
4 Mar 2026 16:02:04 EST (-0500)
  POVORAMA database: MySQL dump (Message 1 to 1 of 1)
Subject: POVORAMA database: MySQL dump
Date: 27 Apr 2013 22:19:36
Message: <517c8738$1@news.povray.org>
Hi(gh)!
Meanwhile, I have built the structure for the POV-o-Rama image database;
it should be imported to any not-too-old installation of MySQL (remember
to save it as *.sql).
Changes relative to ER diagram: the type designations for external files
(i. e. texture, heightfield, bumpmap etc.) have been transferred to a
table on its own (see "externalfiletypes" in the dump).
Here is the code:
-- phpMyAdmin SQL Dump
-- version 3.4.11.1deb1
-- http://www.phpmyadmin.net
-- Host: localhost
-- Created: 28. Apr 2013 um 04:09
-- Server version: 5.5.30
-- PHP version: 5.4.4-15
SET SQL_MODE="NO_AUTO_VALUE_ON_ZERO";
SET time_zone = "+00:00";
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8 */;
-- Database: `povorama`
-- Table structure for table `addsoftware`
CREATE TABLE IF NOT EXISTS `addsoftware` (
   `ID` smallint(5) unsigned NOT NULL AUTO_INCREMENT,
   `Name` varchar(40) NOT NULL,
   `Link` varchar(200) DEFAULT NULL,
   PRIMARY KEY (`ID`)
) ENGINE=InnoDB DEFAULT CHARSET=latin1 AUTO_INCREMENT=1 ;
-- Table structure for table `externalfiles`
CREATE TABLE IF NOT EXISTS `externalfiles` (
   `ID` mediumint(8) unsigned NOT NULL AUTO_INCREMENT,
   `Filename` varchar(200) NOT NULL,
   `Externalfiletype_ID` tinyint(3) unsigned NOT NULL,
   `Format_ID` tinyint(3) unsigned NOT NULL,
   `Size` int(10) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `externalfiletypes`
CREATE TABLE IF NOT EXISTS `externalfiletypes` (
   `ID` tinyint(3) unsigned NOT NULL AUTO_INCREMENT,
   `Name` varchar(20) NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `formats`
CREATE TABLE IF NOT EXISTS `formats` (
   `Extension` varchar(4) NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `images`
CREATE TABLE IF NOT EXISTS `images` (
   `Title` varchar(80) NOT NULL,
   `Published` date NOT NULL,
   `Width` smallint(5) unsigned NOT NULL,
   `Height` smallint(5) unsigned NOT NULL,
   `POVVersion_ID` tinyint(3) unsigned NOT NULL,
   `ImageVersion` smallint(5) unsigned NOT NULL,
   `PostProcessed` tinyint(1) NOT NULL,
   `NumColors` int(10) unsigned DEFAULT NULL,
   `AvgBrightness` float DEFAULT NULL,
   `AvgSaturation` float DEFAULT NULL,
   `FreqHue0_35` int(10) unsigned DEFAULT NULL,
   `FreqHue36_71` int(10) unsigned DEFAULT NULL,
   `FreqHue72_107` int(10) unsigned DEFAULT NULL,
   `FreqHue108_143` int(10) unsigned DEFAULT NULL,
   `FreqHue144_179` int(10) unsigned DEFAULT NULL,
   `FreqHue180_215` int(10) unsigned DEFAULT NULL,
   `FreqHue216_251` int(10) unsigned DEFAULT NULL,
   `FreqHue252_287` int(10) unsigned DEFAULT NULL,
   `FreqHue288_323` int(10) unsigned DEFAULT NULL,
   `FreqHue324_359` int(10) unsigned DEFAULT NULL,
   `FreqBright0_10` int(10) unsigned DEFAULT NULL,
   `FreqBright11_20` int(10) unsigned DEFAULT NULL,
   `FreqBright21_30` int(10) unsigned DEFAULT NULL,
   `FreqBright31_40` int(10) unsigned DEFAULT NULL,
   `FreqBright41_50` int(10) unsigned DEFAULT NULL,
   `FreqBright51_60` int(10) unsigned DEFAULT NULL,
   `FreqBright61_70` int(10) unsigned DEFAULT NULL,
   `FreqBright71_80` int(10) unsigned DEFAULT NULL,
   `FreqBright81_90` int(10) unsigned DEFAULT NULL,
   `FreqBright91_100` int(10) unsigned DEFAULT NULL,
   `FreqSatur0_10` int(10) unsigned DEFAULT NULL,
   `FreqSatur11_20` int(10) unsigned DEFAULT NULL,
   `FreqSatur21_30` int(10) unsigned DEFAULT NULL,
   `FreqSatur31_40` int(10) unsigned DEFAULT NULL,
   `FreqSatur41_50` int(10) unsigned DEFAULT NULL,
   `FreqSatur51_60` int(10) unsigned DEFAULT NULL,
   `FreqSatur61_70` int(10) unsigned DEFAULT NULL,
   `FreqSatur71_80` int(10) unsigned DEFAULT NULL,
   `FreqSatur81_90` int(10) unsigned DEFAULT NULL,
   `FreqSatur91_100` int(10) unsigned DEFAULT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `images_addsoftware`
CREATE TABLE IF NOT EXISTS `images_addsoftware` (
   `Images_ID` mediumint(8) unsigned NOT NULL,
   `AddSoftware_ID` smallint(5) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `images_externalfiles`
CREATE TABLE IF NOT EXISTS `images_externalfiles` (
   `Externalfiles_ID` mediumint(8) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `images_keycont`
CREATE TABLE IF NOT EXISTS `images_keycont` (
   `KeyCont_ID` smallint(5) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `images_keypov`
CREATE TABLE IF NOT EXISTS `images_keypov` (
   `KeyPOV_ID` smallint(5) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `images_povernicks`
CREATE TABLE IF NOT EXISTS `images_povernicks` (
   `Image_ID` mediumint(8) unsigned NOT NULL,
   `POVerNick_ID` smallint(5) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `images_scripts`
CREATE TABLE IF NOT EXISTS `images_scripts` (
   `Scripts_ID` mediumint(8) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `keycont`
CREATE TABLE IF NOT EXISTS `keycont` (
   `KeyCont3rd_ID` tinyint(3) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `keycont1st`
CREATE TABLE IF NOT EXISTS `keycont1st` (
   PRIMARY KEY (`ID`)
-- Table structure for table `keycont2nd`
CREATE TABLE IF NOT EXISTS `keycont2nd` (
   `KeyCont1st_ID` tinyint(3) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `keycont3rd`
CREATE TABLE IF NOT EXISTS `keycont3rd` (
   `KeyCont2nd_ID` tinyint(3) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `keypov`
CREATE TABLE IF NOT EXISTS `keypov` (
   PRIMARY KEY (`ID`)
-- Table structure for table `povernicks`
CREATE TABLE IF NOT EXISTS `povernicks` (
   `Nickname` varchar(40) NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `povernicks_poverreal`
CREATE TABLE IF NOT EXISTS `povernicks_poverreal` (
   `POVerReal_ID` smallint(5) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `poverreal`
CREATE TABLE IF NOT EXISTS `poverreal` (
   `FirstName` varchar(40) NOT NULL,
   `Surname` varchar(40) NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `povversions`
CREATE TABLE IF NOT EXISTS `povversions` (
   `Name` varchar(30) NOT NULL,
   PRIMARY KEY (`ID`)
-- Table structure for table `scripts`
CREATE TABLE IF NOT EXISTS `scripts` (
   `Type` enum('main','include') NOT NULL,
   `NumLines` mediumint(8) unsigned NOT NULL,
   PRIMARY KEY (`ID`)
/*!40101 SET CHARACTER_SET_CLIENT=@OLD_CHARACTER_SET_CLIENT */;
/*!40101 SET CHARACTER_SET_RESULTS=@OLD_CHARACTER_SET_RESULTS */;
/*!40101 SET COLLATION_CONNECTION=@OLD_COLLATION_CONNECTION */;
See you in Khyberspace!
Yadgar
Now playing: Night Mist (Peak)
