LOL ... OK so shoot me for asking here, but I know a number of you
Blender and I thought I'd try amongst friendly faces first.
I've been playing around with the physics plug-ins in particular cloth.
I actually got it to work using this hint:
http://blenderartists.org/forum/showthread.php?271538-Using-cloth-sim-how-can-I-make-a-flag-wrap-around-an-object
the 2nd method mentioned by poster ridix
I just used a cylinder as a pedestal and a plane as the cloth. Sure
enough after hunting for and /eventually/ finding the play button, it
draped the cloth over the pedestal. Well here's the rub ... has anyone
figured out how to get the geometry of the simulation results back into
the 3D view so I can export?
Current versions of Blender have a physics engine that's separate from
the game engine - IIRC it's the "soft body" simulation engine. You might
check that out.
Jim
you mean, instead of pressing play you could just slide the timeline marker just
down below to the most apropriate frame of the simulation? ;)
Well I'll be damned ... appreciate the nudge!
Yes, nowadays, it's as simple as that, add a Cloth modifier to your object and
hit ALT+A.
then of course to render, you just need to activate POV in the add ons window,
choose it as the renderer in the drop down of the menu bar, and press the
"render image" or "render animation button", depending on what you want to do.
