For some time now I have been wondering about the meaning of:
Parse warning: Suspicious expression after rgb.
There is no reference to any file in which this may happen, nor to the
suspicious place. I have been browsing different potential issues
without finding anything /suspicious/.
Any smart idea?
Le 02/01/2013 13:02, Thomas de Groot nous fit lire :
> Any smart idea?
Code analysis: warning due to number of terms in expression not equal to 3.
Lack of file location means that Token.FileHandle is NULL.
> Any smart idea?
> Thomas
seen this before as well, iirc: look for pigment statements that have
rgb followed a predefined color like Yellow ... effectively it's seeing
it as pigment { rgb rgb <1,1,0> }
That warning is the one I most see... due to my tendency to mix
colors by arithmetic operations (i.e.: Red*.5+Yellow*.3). I learned to
just ignore it... ;)
Jaime
> Jaime
LOL that's where I'd seen that before, thanks for the nudge ... perhaps
my other recollection was incorrect then
I also do that a lot (mixing and... ignoring) ;-)
I just got curious because sometimes it seems not to make sense,
everything loud an clear, so to speak, but I probably have some hidden
things I overlook in the process.
Thanks all for the clarification.
Whenever I see that warning, I almost automatically go to section 3.2.1.5.5
"Common Color Pitfalls" in the docs, to 'refresh' my memory of the odd behavior
of dot operators re: colors. If some insight there doesn't solve it, then I
usually ignore it.
BTW, another irritation for me is seeing the warning about 'no pigment type
given' for an object when it's in a lightgroup. That *always* seems to happen
(in v3.6.2), for no apparent reason. Again, I just ignore it.
> Thomas
I'm not sure completelly but I see his warning often when I add a forth or fifth
component to a color vector (e.g. something like this: color Red +
<0,0,0,0.5,0.5>) to get filtered or general transmittance. Mainly within color
maps and the like.
Best regards,
Michael
> > Thomas
> maps and the like.
> Best regards,
> Michael
My solution is like Kenneth's: ignore the warning.
Michael
