POV-Ray : Newsgroups : povray.general : #ifdef fails? Server Time
27 Jun 2026 22:21:05 EDT (-0400)
  #ifdef fails? (Message 1 to 5 of 5)
Subject: #ifdef fails?
Date: 17 Nov 2012 14:22:20
Message: <50a7e3ec$1@news.povray.org>
Consider then following code;
    #fopen FN FileName read
    #ifdef (FN)
      #while (defined(FN))
	#read ( FN , Vector)
	action( Vector )
After processing Filename001 - FileName100, the next file doesn't exist
(FileName101). Afaik #ifdef (FN) should catch that and not allow the #while
loop to continue.
Or am I missing something?
Ger
Using Pov 3.7 on Linux
Subject: Re: #ifdef fails?
Date: 17 Nov 2012 16:42:15
Message: <50a804b7$1@news.povray.org>
>     #ifdef (FN)
> 	action( Vector )
>       #end
>     #end
the documentation of #fopen states that IDENTIFIER should be
an undefined identifier. So it might be that the #ifdef test
only works if FN was not alreaday defined prior to #fopen.
Date: 17 Nov 2012 17:44:04
Message: <50a81334$1@news.povray.org>
Christian Froeschlin wrote:
>>     #ifdef (FN)
>> action( Vector )
>>       #end
>>     #end
From the manual
You may use #ifdef FILE_HANDLE_IDENTIFIER to see if a file is open.
Ger
Date: 18 Nov 2012 03:16:30
Message: <50a8995e$1@news.povray.org>
>      #ifdef (FN)
> 	action( Vector )
>        #end
>      #end
> loop to continue.
I wonder: shouldn't #fopen not give a parse error message when trying to
open a non-existing file? Before even #ifdef()?
I remember having misquoted a filename and having the parser abort.
[quote]You may use #ifdef FILE_HANDLE_IDENTIFIER to see if a file is
open[unquote] only tests if the file is /open/ not if it /exists/. That
might be a subtle difference...
Date: 19 Nov 2012 02:34:46
Message: <50a9e116@news.povray.org>
Am 17.11.2012 20:22, schrieb Ger:
>      #ifdef (FN)
>          action( Vector )
>        #end
>      #end
> loop to continue.
Well, if FN is undefined, the #while loop itself should refuse to run
even a single time, so the #ifdef is redundant.
But if the file doesn't exist, #fopen doesn't fail with an undefined FN,
but rather with an error message.
You might want to use the following code:
#if (file_exists(FileName))
   #fopen ...
   #while ...
