POV-Ray : Newsgroups : povray.general : Help with Blobs Server Time
5 Nov 2026 20:39:27 EST (-0500)
  Help with Blobs (Message 1 to 19 of 19)
Subject: Help with Blobs
Date: 13 Oct 2012 09:04:29
Message: <507966dd$1@news.povray.org>
I am trying to make an hourglass and I cannot get the settings right.
Would some kind person give me some starting values for a realistic
looking sandglass? Or suggest another method as I have never managed to
work successfully with blobs.
Regards
Subject: Re: Help with Blobs
Date: 13 Oct 2012 09:31:12
Message: <50796d20@news.povray.org>
An hourglass shape is much easier to achieve with the sor object.
Date: 13 Oct 2012 09:39:42
Message: <50796f1e$1@news.povray.org>
Greetings,
Le 13/10/2012 15:04, Stephen nous fit lire :
Why did you choose blob ?
Have a look in the portfolio the o_shapesq12: the Lemniscate.
Or in scenes/objects/quartic/lemnisca.pov
and scenes/objects/quartic/lemnisc2.pov
Date: 13 Oct 2012 09:51:15
Message: <507971d3$1@news.povray.org>
...and for the sand inside, you can use sor too.
(lathe is another option)
Date: 13 Oct 2012 10:08:48
Message: <507975f0$1@news.povray.org>
It just seemed the right object, for a blown glass shape, to me.
I did, or rather I tried the function f_lemniscate_of_gerono(x,y,z, P0).
But the halves come together at a point, making it hard for the sand to
get through. ;-)
A good suggestion if I did not want a close shot.
Regards
Date: 13 Oct 2012 10:13:23
Message: <50797703$1@news.povray.org>
Duh! I did not even think of that. It would have been the first thing I
thought of a couple of years ago.
Thanks.
Regards
Date: 13 Oct 2012 10:51:55
Message: <5079800b$1@news.povray.org>
On 13/10/2012 2:51 PM, Thomas de Groot wrote:
> ....and for the sand inside, you can use sor too.
The glass will be lying on its side, so we will see.
Probably a better one as it uses splines.
Regards
Date: 13 Oct 2012 11:09:45
Message: <50798439@news.povray.org>
Le 13/10/2012 16:08, Stephen nous fit lire :
> get through. ;-)
Merge it with a small cylinder where it is not thick enough (and I have
a preference for the quartic form, probably my old age)
something along:
difference {
  merge {
    outer_lemniscate
    cylinder_at_point
  inner_lemniscate
 material { glass... }
For once, the point of the lemniscate seems good for the bottleneck (or
you can also add a cylinder too.
Date: 13 Oct 2012 13:44:47
Message: <5079a88f@news.povray.org>
An excellent suggestion but I will "'fess up".
I use a modeller that does not support quartics and although I could
include the code. This is supposed to be a quick and dirty image, so I
will stick with using lathes. (Probably my old age)
Regards
Date: 13 Oct 2012 13:50:01
Message: <web.5079a9422980527c55ed6d350@news.povray.org>
> Regards
>      Stephen
As ever a good starting point is the old IRTC. First topic was "time" and
contained at least four useable hourglasses. (What means the POV-code is quite
running without bigger efforts.) There was another one later, but I cannot find
it so soon. As I think you are interested in quick solutions ;-), maybe this
hint helps. Of course all other proposed ideas here are quit right.
Best regards,
Michael
Date: 13 Oct 2012 14:47:53
Message: <5079b759$1@news.povray.org>
  Just remember to move the camera a tiny bit up if you see these pesky
black lines... ;)
Jaime
Date: 13 Oct 2012 14:53:53
Message: <5079b8c1@news.povray.org>
> black lines... ;)
An old friend. ;-)
Regards
Date: 15 Oct 2012 03:30:01
Message: <web.507bbaad2980527c5b7d07940@news.povray.org>
That's ok - make a complete inner sor (or lathe), then intersect it with a 'sand
level' plane to get sand sitting along the inside.
I often use Inkscape for making POV-Ray lathes - it can export the splines in
..pov format.
Better yet, having seen everyone's excellent physics simulations recently,
create the hourglass in Blender, add 10^12 sand grains, run your simulation, and
export the resulting gajillion GB of transformation data to POV-Ray! ;-)
Bill
Date: 15 Oct 2012 05:40:01
Message: <web.507bd99d2980527cf2eb76540@news.povray.org>
I must admit that the IRTC is a resource I seldom use. I don’t know why as there
is some fine images there. I could do with studying some of the texture masters.
Date: 15 Oct 2012 06:05:01
Message: <web.507bdf722980527cf2eb76540@news.povray.org>
Yes, that is the way I’ve done it. Only I used a reference of the inner Lathe.
> ..pov format.
I must try Inkscape, I have heard nothing but good about it. But first I need to
dig out my graphics tablet. I find that Bishop3D is quite good. Besides
manipulating the points of a spline, you can export the Pov script, manipulate
them and import them again. And you get a visualisation of the surface.
Ooo! That is a good idea. I don’t think. ;-)
This started out as a quick doodle for a logo and it is turning into a project.
Firstly I created the outside bulb and scaled a reference to difference for the
inside. Then I referenced the difference for the other half. This gave me
banding as if the thickness of the glass was not constant.
The next try was to copy the outside spline and manually move the spline points
to get the wall thickness constant. This gives better results but talk about
slow rendering (max_trace_level = 6) and there seems to be a bloom on one of the
bulbs.
I might post some WIPs.
Date: 15 Oct 2012 08:35:01
Message: <web.507c01f62980527c5b7d07940@news.povray.org>
You don't really need a graphics tablet, although I expect it makes it easier.
Ah well, an accurate preview of the surface is quite important, I'd stick with
Bishop3D in that case!
Please do!
Date: 17 Oct 2012 11:25:01
Message: <web.507ecc9d2980527cf2eb76540@news.povray.org>
I don't know how accurate it is, actually.
> Please do!
Okay, done in p.b.i. under Lathe problems.
Date: 17 Oct 2012 12:00:01
Message: <web.507ed48f2980527cc21bdf370@news.povray.org>
Of course it's a personal style question.
Personally I always look first to existent codes.
One good spline hourglass solution comes frm Tekno Frannansa (IRTC round
Desert), which I changed a bit for a wallpaper of my own...
Code is:
//our time is running out, our time is running out, can't put us on the ground,
you can't stop us screaming out, how did it come to this?
//+kfi0 +kff1 (remove these to render only pass 2)
//scene switches, these sometimes get overridden later.
#if (1)
 //standard
 #declare glassEnabled = on;
 #declare rad = on;
 #declare useRadFile = off;
 #declare areaLights = on;
 #declare hfMip = 0;
 #declare maxInter = 12;
#else
 //low quality test
 #declare glassEnabled = off;
 #declare rad = off;
 #declare areaLights = off;
 #declare hfMip = 2;
 #declare maxInter = 10;
#include "rad_def.inc"
#include "shapes.inc"
global_settings {
        assumed_gamma 2.2
 max_intersections maxInter
#if (rad)
 radiosity {
         brightness 1
  #if (!useRadFile | frame_number<final_frame)
   Rad_Settings(Radiosity_Fast,on,on)
   #declare radRender = on;
  gray_threshold 0
#if (rad)
 #default { pigment { rgb 1 } finish { diffuse .7 ambient 0 } }
#else
 #default { pigment { rgb 1 } finish { diffuse .7 ambient .3 } }
#declare hourglassSpline = array[9] {
  <1, -9>,
  <1, -1>,
  <0.87, -0.5>,
  <0.12, -0.1>,
  <0.007, 0>,
  <0.12, 0.1>,
  <0.87, 0.5>,
  <1, 1>,
  <1, 9>
#declare hourglassNumPoints = dimension_size (hourglassSpline,1);
#declare hourglassShapeInner =
 sor {
  hourglassNumPoints
  #local i=0;
  #while (i < hourglassNumPoints)
   hourglassSpline[i]
   #local i = i+1;
  sturm
  scale <1,1.5,1>
#declare hourglassShapeInnerShift = //nudge outwards fractionally
 #local f = 0.005;
 sor {
  hourglassNumPoints
  #local i=0;
   hourglassSpline[i]+f*u
   #local i = i+1;
  sturm
  scale <1,1.5,1>
#declare hourglassShapeOuter =
 #local f = 0.01;
 sor {
  hourglassNumPoints
  #local i=0;
   hourglassSpline[i]*<.92,.99>+<.08,0>+f*u
   #local i = i+1;
  sturm
  scale <1,1.5,1>
//hourglass objects, origin = pinch in the glass.
union {
 #declare sand =
    //checker rgb 0, rgb 1 scale .3 //surreal!
    crackle
    solid
    scale 0.001
    #local f=1;//.7; //radiosity tends to multiply the colour by itself (through
interreflection) so balance for that. maybe, or could use gray_threshold
    colour_map {
     [0 rgb <pow(0.9,f),pow(.8,f),pow(0.5,f)>] //0.9,0.8,0.5
     [1 rgb <pow(1,f),pow(1,f),pow(0.9,f)>] //1,1,0.9
   finish {
    //specular 1 roughness 0.01
    phong 1 phong_size 100
   normal {
    facets 1
    coords 1
    scale 0.001
 //upper sand
 intersection {
  object { hourglassShapeInner }
  height_field {
   function 512/pow(2,hfMip), 512/pow(2,hfMip) {
    max(0,0.13+0.15*sin(pi*20*sqrt((x-0.5)*(x-0.5)+(y-0.5)*(y-0.5))))
   translate -.5
   scale <2,0.4,2>
   translate 0.2*y
  plane {-y,-0.02 }
  texture { sand }
  no_shadow
 //lower sand
 intersection {
  object {hourglassShapeInner}
  height_field {
   function 2048/pow(2,hfMip),2048/pow(2,hfMip) {//why do programmers always use
power of 2's???! :)
     average
     pigment_map {
      [1 spotted  translate 7/0.6 scale 0.6]
      [0.03 spotted scale <0.01,0.05,0.05> rotate 47 warp { turbulence 0.2
octaves 2 } ]
   smooth
   translate -0.5
   scale <2,0.8,2>
   translate -0.7*y
  texture { sand }
 //falling sand
 union {
  cylinder { <0,0,0>, <0,1,0>, .01 }
  hollow on
   pigment_pattern {
    slope { -z }
    pigment_map {
     [0 rgb 0]
     [1
      average
      pigment_map {
       [0.2 gradient y poly_wave 5]
       [1 crackle solid scale 0.001]
   texture_map {
    [0.4 pigment { rgbt 1 }]
    [0.4 sand]
  scale 0.721*y
  translate -0.7*y
 //pile of sand
 cone { -0.7*y, 0.2, -0.5*y, 0 texture { sand } }
 //glass
#if (glassEnabled)
 difference {
  object { hourglassShapeOuter }// scale <1.03,.99,1.03> }
  object { hourglassShapeInnerShift } //avoid coincidence with sand.
   pigment { rgbt 1 }
   finish { phong 2 phong_size 600 reflection { 0, 1 fresnel } conserve_energy }
  interior_texture {
   pigment { rgbt 1 }
   finish { reflection { 0, 1 fresnel } conserve_energy } //no specular
  interior { ior 1.5 }
#end //glassEnabledg
#ifdef (radRender)
 //infinite desert
 plane { y, -1 texture { sand } }
#else
 //background
 plane { -z, -1000 pigment { rgb 0 } no_reflection no_shadow }
 translate <-0.5,0.4,1.5>
 scale 1000 //fix some accuracy problems in the mesh. Looks like pov's got a
hard coded threshold...
#declare BC = <pow(4/7,1/2.2),pow(5.5/7,1/2.2),1>;
sky_sphere {pigment {planar colour_map {[0 rgb
0.3*<pow(BC.x,4),pow(BC.y,4),pow(BC.z,4)>*1.5][1 rgb 0.7*BC*1.5]}}}
fog {
 fog_type 2
 colour rgb BC*0.3
 distance 100*100
 fog_alt 6*100
 fog_offset -7*100
fog {
 fog_type 2
 colour rgb (1-BC)*0.5
 distance 500*100
 fog_alt 15*100
 fog_offset -7*100
//use a bit of 3 point lighting, but let saved rad be the fill light
light_source { <3,2,-1>*10000, rgb <1,0.9,0.7>*0.8  //key
 #if (areaLights) area_light z*2000,y*2000,4,4 adaptive 1 orient jitter #end
light_source { <0.2,1,3>*10000, rgb 1.2*<1,0.9,0.7>*0.8  //highlight
 #if (areaLights) area_light x*10000,y*10000,4,4 adaptive 1 orient jitter #end
 right  -x*image_width/image_height
 up  y
 direction z*1
 angle           100
 scale 1000
//   End of code
Have fun
Norbert
Date: 17 Oct 2012 15:48:37
Message: <507f0b95$1@news.povray.org>
Thanks Norbert.
Looking at Tek's code has made me realise that it would be simpler to
use one SOR for both the bulbs rather than mirroring one bulb.
Regards
