POV-Ray : Newsgroups : povray.general : Help with Blobs Server Time
31 Mar 2026 16:30:01 EDT (-0400)
  Help with Blobs (Message 1 to 10 of 19)
Subject: Help with Blobs
Date: 13 Oct 2012 09:04:29
Message: <507966dd$1@news.povray.org>
I am trying to make an hourglass and I cannot get the settings right.
Would some kind person give me some starting values for a realistic
looking sandglass? Or suggest another method as I have never managed to
work successfully with blobs.
Regards
Subject: Re: Help with Blobs
Date: 13 Oct 2012 09:31:12
Message: <50796d20@news.povray.org>
An hourglass shape is much easier to achieve with the sor object.
Date: 13 Oct 2012 09:39:42
Message: <50796f1e$1@news.povray.org>
Greetings,
Le 13/10/2012 15:04, Stephen nous fit lire :
Why did you choose blob ?
Have a look in the portfolio the o_shapesq12: the Lemniscate.
Or in scenes/objects/quartic/lemnisca.pov
and scenes/objects/quartic/lemnisc2.pov
Date: 13 Oct 2012 09:51:15
Message: <507971d3$1@news.povray.org>
...and for the sand inside, you can use sor too.
(lathe is another option)
Date: 13 Oct 2012 10:08:48
Message: <507975f0$1@news.povray.org>
It just seemed the right object, for a blown glass shape, to me.
I did, or rather I tried the function f_lemniscate_of_gerono(x,y,z, P0).
But the halves come together at a point, making it hard for the sand to
get through. ;-)
A good suggestion if I did not want a close shot.
Regards
Date: 13 Oct 2012 10:13:23
Message: <50797703$1@news.povray.org>
Duh! I did not even think of that. It would have been the first thing I
thought of a couple of years ago.
Thanks.
Regards
Date: 13 Oct 2012 10:51:55
Message: <5079800b$1@news.povray.org>
On 13/10/2012 2:51 PM, Thomas de Groot wrote:
> ....and for the sand inside, you can use sor too.
The glass will be lying on its side, so we will see.
Probably a better one as it uses splines.
Regards
Date: 13 Oct 2012 11:09:45
Message: <50798439@news.povray.org>
Le 13/10/2012 16:08, Stephen nous fit lire :
> get through. ;-)
Merge it with a small cylinder where it is not thick enough (and I have
a preference for the quartic form, probably my old age)
something along:
difference {
  merge {
    outer_lemniscate
    cylinder_at_point
  inner_lemniscate
 material { glass... }
For once, the point of the lemniscate seems good for the bottleneck (or
you can also add a cylinder too.
Date: 13 Oct 2012 13:44:47
Message: <5079a88f@news.povray.org>
An excellent suggestion but I will "'fess up".
I use a modeller that does not support quartics and although I could
include the code. This is supposed to be a quick and dirty image, so I
will stick with using lathes. (Probably my old age)
Regards
Date: 13 Oct 2012 13:50:01
Message: <web.5079a9422980527c55ed6d350@news.povray.org>
> Regards
>      Stephen
As ever a good starting point is the old IRTC. First topic was "time" and
contained at least four useable hourglasses. (What means the POV-code is quite
running without bigger efforts.) There was another one later, but I cannot find
it so soon. As I think you are interested in quick solutions ;-), maybe this
hint helps. Of course all other proposed ideas here are quit right.
Best regards,
Michael
