I am looking for a function to use in an isosurface that will give me
ripples that will decay to zero over a short distance.
Can anyone suggest one?
TIA
Regards
How about something like:
sin(a*x)*exp(-b*x^2)
Plot it, e.g., here for a quick preview:
http://rechneronline.de/function-graphs/
For more ripples over a given range, increase a
For a greater range, decrease b
Bill
> Bill
Ah! The exponential, just what I was looking for.
It is true that if you don't use it, you lose it.
Thanks Bill
Regards
> > Bill
Too true. I use it a little too much to be honest :)
> Too true. I use it a little too much to be honest:)
In that case you could use your mathematical brain ;-) to tell me how to
translate the function below along the z axis. I used the formula that
you suggestion to create a ripple but for the life of me I cannot move
it from the origin. After reading the doc I substituted z-2 for z and
that did not work properly. I am at a loss.
(sqrt(exp(-0.5*x*x) *exp(-0.5*z*z) )) }
Regards
Am 23.04.2012 16:09, schrieb Stephen:
> *exp(-0.5*z*z) )) }
Should have worked, maybe you missed a z somewhere.
The more robust approach is to leave your function as-is, and call it
from another function such as:
function { foo(x,y,z-2) }
>> *exp(-0.5*z*z) )) }
I had so many Zeds in it that I almost fell asleep. :-)
That makes sense and it's a good idea.
Thanks
Regards
> >> *exp(-0.5*z*z) )) }
Just what I was going to suggest. Mike Williams' isosurface page has lots of
useful tips, eg:
http://www.econym.demon.co.uk/isotut/substitute.htm
Bill
> useful tips, eg:
I have been reading it but I missed that. :-(
For someone who just hacks code (in the original sense), it did not twig.
Regards
On 23/04/2012 12:16 AM, Stephen wrote:
Thanks to both of you. I got what I was aiming for.
Regards
