Folks,
I would appreciate it if some of you could sanity-check the RC5
windows installer, which may be found here:
http://www.povray.org/beta/povwin-3.7.RC5-setup.exe
Please advise if you have any installation issues.
-- Chris
Installation successful. No issues met.
in news:4f59d1d0$1@news.povray.org Chris Cason wrote:
Chris,
at the end of the installation process, just after the tow icons appear on
the desktop I moved the installerwindow out of the way. That froze the
win7 GUI. Could move the mouse, but not over the task bar, it stopped just
above. Only a few times right clicking on the desktop "relesed" the freeze
and I was able to finish the process. I could not reproduce it a second
time,
ingo
No comments after a successful installation on my
laptor Acer (Pentium Dual Core T4400) running w7-64bits)
regards
B. Gimeno
Chris Cason <del### [at] deletethistoo povray org> wrote:
> Folks,
> -- Chris
No problem for me.
Bruno
Chris
Same issue with installing as RC4 on XP64 sp2 (no sp3 available).
Probally to do with the certification
greetings
Bert
Subject: Re: Test of RC5 Windows installer
Date: 10 Mar 2012 18:48:38
Message: <4f5be856@news.povray.org>
Installed successfully on Windows 7 x64.
Note that I tried running it without elevation to see what
would happen and got the elevation dialog. Does this mean a
per-user install is no longer supported? Personally I don't
mind but based on previous posts some people do.
Two minor issues:
- The name of the desktop icon is quite long and the version number
got truncated (...). As the "for Windows" part is rather redundant
on a Windows desktop I'd suggest to just use "POV-Ray v3.7 RC5".
- It seems the help index has been fixed, but by chance the first
item I tried was "pigment_pattern" (with underscore), and this mapped
to the documentation for "pavement".
Christian
> Two minor issues:
> Regards,
> Christian
For the name of the icon, I think that only "POV-Ray v3.7 RC" would be
enough.
A test should be made for the partial name "POV-Ray v3.7", and if found,
only update that shortcut, or replace it. I have the habit of shortening
and simplifying to long icon's names, and get duplicates.
Chris Cason wrote:
> Folks,
> -- Chris
Hello,
I have a problem with registering .pov-files to the right POV-Ray application.
Namely, when I double-click on a .pov-file, it opens in the 32-bit POV-Ray
application (pvengine.exe). My operating system is Windows 7 Home premium
64-bit. I cannot change that association to the 64-bit application
(pvengine64.exe) because my Windows doesn't accept opening the file in that when
I use the command "Open with..". Only pvengine.exe becomes an application in the
list of suitable applications.
I can drag and drop .pov-files to the editor if it's already open, but not if
only the Messages-tab is open.
RC4 registered the file types correctly. I uninstalled that before installing
RC5.
-Mika
> Folks,
> -- Chris
Hello,
RC5.
-Mika
