... are lying on a rectangular grid. Is it possible to randomly move
those centers? I tried with warp but then only the patterns are warped
but the centers remain at the same place.
Thanks!
> Thanks!
> Thomas
In fact, the centers are within a 1 unit box.
You can move them apart by scaling. In this case, you should also use
frequency of the same value as the scaling if you want to keep the
ridges separation unchanged.
There is nothing preventing you from applying some un-even scaling.
You can rotate the pattern any way you want.
You can try changing the noise generator to see if it have an impact.
The option of using some random stream could be interesting, but will
probably need a more or less complete rewrite of the code for that pattern.
Hmmm... ok. So a random placement of centers (within the unit box) is
not possible; think for instance of rain drops on water. For the time
being I probably can get away with un-even scaling for my project,
although that shall deform the pattern I guess. Maybe an average of
different randomly translated patterns would do the trick? I shall try.
On 12-1-2012 8:53, Thomas de Groot wrote:
> [...]Maybe an average of
Yes, this work to satisfaction indeed and gives randomly spread centers.
Best seems to use number_of_waves 1 and a low frequency.
Thanks for thinking aloud with me ;-)
