POV-Ray : Newsgroups : povray.general : Is this a bug in 3.7RC3 ? Or am I missing something? Server Time
6 Nov 2026 02:57:43 EST (-0500)
  Is this a bug in 3.7RC3 ? Or am I missing something? (Message 1 to 50 of 52)
Goto Latest 50 Messages Next 2 Messages >>>
Subject: Is this a bug in 3.7RC3 ? Or am I missing something?
Date: 17 May 2011 20:46:32
Message: <4dd316e8$1@news.povray.org>
OK, I'm either doing something phenomenally stupid, or there's a blatant bug
in isosurface{} in 3.7rc3.
Step 1) Consider the following simple scene:
  #version 3.7;
  global_settings { assumed_gamma 2.2 }
  camera{ location 5 look_at 0 right x*4/3 }
  light_source{<2,4,8>, <1, .8, .6> }
  sky_sphere {pigment {gradient -y}}
  #declare clipper = difference {box {-2 2} box {<0,-3,0> 3}}
  object {clipper pigment {rgbft <0,1,1,.2,.2>} }
I'm declaring an object and displaying it. It is a box with one quarter
taken out. I'm calling it "clipper" because I want to use it to clip another
object.
Step 2) Now add the following object:
  sphere {0 2 pigment {rgb 1}}
Since 'clipper' is parially transparent, you can see the back 3/4 though it
with the front quarter exposed.
Step 3) use 'clipper' to clip the sphere, i.e. modify the 'sphere' object
like this:
  sphere {0 2 clipped_by {clipper} pigment {rgb 1}}
The front part of the sphere is now clipped away by the 'clipper' box, but
the rest can still be seen in the box. Note the shadow cast by the front
right edge of the sphere onto/into the inside of the sphere.
Step 4) Remove the line that shows the clipper box:
  // object {clipper ....
You can now see the (hollow) back 3/4 of a sphere with the opening pointing
at you. You can still see the aforementioned shadow.
So far this is all as I would expect it.
HOWEVER: now do the same thing again, but in step (2), instead of the
sphere{} put this simple isosurface instead:
  isosurface{function{ sqrt(x*x+y*y+z*z) }
        threshold 2 max_gradient 100 contained_by{ box {-5 5} }
     //     clipped_by { clipper }
          pigment {rgb 1}
In steps (2) and (3) I see the exact same thing that I see with the sphere
object. In particular I can see the shadow on step (3) that tells me that I
can see the inside/backside of the isosurface.
But in step 4, the back/inside of the isosurface is gone.
Why?
Subject: Re: Is this a bug in 3.7RC3 ? Or am I missing something?
Date: 18 May 2011 04:09:59
Message: <4dd37ed7$1@news.povray.org>
Have you tried it with 3.6 ?
> Why?
I would not use clipped_by to perform CSG intersection.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 18 May 2011 06:00:01
Message: <web.4dd39775955938cce619b42c0@news.povray.org>
>           pigment {rgb 1}
> Why?
Because you did not read the manual.
See http://www.povray.org/documentation/view/3.6.1/300/
Thorsten
Date: 18 May 2011 07:06:59
Message: <4dd3a853$1@news.povray.org>
>>            pigment {rgb 1}
>> Why?
> Thorsten
hmmm ... I didn't spot the clue. I'm tempted to say the use of or size
clipper ... care to offer another hint ;-)
Date: 18 May 2011 07:20:01
Message: <web.4dd3aa7c955938cce619b42c0@news.povray.org>
> >>            pigment {rgb 1}
> >> Why?
> > Thorsten
The hint about CSG and isosurfaces is at the very end of that page ;-)
Thorsten
Date: 18 May 2011 15:00:57
Message: <4dd41769$1@news.povray.org>
"Thorsten Froehlich" <nomail@nomail> wrote in message
news:web.4dd3aa7c955938cce619b42c0@news.povray.org...
>> >> sphere
>> >> that I
>> >> Why?
>> > Thorsten
> Thorsten
*IF* you are making reference to this sentence:
  "By default POV-Ray searches only for the first surface which the ray
intersects. But when using an isosurface in CSG operations, the other
surfaces must also be found. Therefore, the keyword max_trace must be added
to the isosurface statement. It must be followed by an integer value.
*THEN* I'd like to point out that this sentence is false:
- The back-side of the isosurface IS the first surface the ray intersects
after the sphere is clipped.
- It is in fact found when the 'clipper' object is visible.
It only vanishes after I turn off the clipper object. Even though it is
still the first surface of the sphere that the viewing-ray intersects
(because all surfaces "in front of it" are clipped). Nothing has changed
about the sphere or which of its surfaces should or should not be
intersected by the viewing ray; all that has changed is that I made the
clipper-volume invisible.
Of course there is no reason why 3.7 should conform to the 3.6
documentation. Which makes it a bit disingenous to point people to the 3.6
docs when they ask questions about 3.7 regarding behaviour *that is
definitely in conflict with the 3.6 documentation*.
Date: 18 May 2011 15:15:09
Message: <4dd41abd@news.povray.org>
The sentence is true and correct for 3.6 as well as 3.7. What is wrong is
your interpretation of what you are seeing without knowing the inner
workings of POV-Ray by making assumptions about the inner workings that are
false.
> documentation.
You can be certain POV-Ray conforms to this part of the documentation, be it
3.6 or 3.7.
No.
It certainly helps to read the documentation when being pointed to it,
rather than complain about being helped ... add all_intersections and just
be happy.
	Thorsten
Date: 18 May 2011 20:02:51
Message: <4dd45e2b@news.povray.org>
Am 18.05.2011 21:00, schrieb SGeier:
Well, actually it's not.
The catch is that the back side may be the first surface of the
isosurface /within the clipped_by object/ - but /not/ the first surface
of the isosurface /per se/ - which the ray intersects.
clipped_by is implemented as follows:
(1) The base object's intersection(s) with the ray are determined;
(2) for each intersection it is checked whether it is inside the
clipped_by object.
Any intersections not reported by step (1) are ignored.
Note that strictly speaking the object you're making (in)visible is
/not/ the clipped_by object; rather, the two are independent objects
that just happen to be derived from the same "prototype" object (your
"clipper" object).
Once the ray hits the surface of a partially transparent object, a new
ray is shot from that intersection point in the same direction as the
original ray; with this intersection point being /inside/ the
(non-clipped) isosurface, the back side now is /truly/ the first surface
of the isosurface the ray intersects.
Again, note that the clipped_by object is /not/ a full-fledged scene
object; POV-Ray never performs any intersection tests on it when
shooting rays - it is /exclusively/ used to check whether an
already-found intersection is inside of it.
That's quite a *bold* statement (in any sense, including typographic);
please be aware that /sometimes/ the developers do know POV-Ray better
than the average user ;-)
I'd agree that Thorsten may not be the best diplomat - but technically
he's right: The behaviour you're observing may be surprising, but works
as intended. Maybe the wording in the docs isn't ideal, but aside from
that there's nothing wrong.
Date: 18 May 2011 23:06:05
Message: <4dd4891d$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4dd45e2b@news.povray.org...
>> added
> The catch is that the back side may be the first surface of the isosurface
> /within the clipped_by object/ - but /not/ the first surface of the
> clipped_by object.
Good to know that this is how it is implemented. However this is NOT how it
is documented. Put the above paragraph into the documentation and
implementation and documentation are in agreement.
>> 3.6
I would hope so - that's why I post things here that do not work as
documented.
There's a perennial communications problem between programmers and users: To
the programmer, the code is the end-all and be-all. Whatever the code does
is "true" and if the documentation deviates from it, then the documetation
is wrong. However from the user perspective, the documentation is all there
is - it tell me what is *supposed* to happen and if the observed results are
different then the code is buggy.
I'm happy to go either way - but there IS still a mismatch between
implementation and documentation here.
> he's right: The behaviour you're observing may be surprising, but works as
> intended.
To a user of POV-Ray it does not (can not) matter what the programmers
*intended*. Unless you want every single one of us folks out here to come
here and post so that you can explain every single one of us what you
intended. The only thing that *can* matter to us is what is *documented*.
> Maybe the wording in the docs isn't ideal, but aside from that there's
> nothing wrong.
If the wording in the docs leads the reader to expect behaviour different
from what is implemented, then the wording is far enough from ideal that we
might as well call it false. No part of the documentation indicates that the
back/inside of the isosurface object will be found when the outer clipping
object is made visible (or the clipped object embedded into a transparent
object or any such thing). In the case of the sphere object, it is visible
in both cases, in the case of the isosurface object it is visible in the
one, but not the other case.
If that is "as intended", then this intention needs to be communicated (in
the docs, not here).
Which it isn't.
Date: 19 May 2011 06:59:05
Message: <4dd4f7f9$1@news.povray.org>
> Which it isn't.
if you think it's /that/ out of whack then ... get yourself a login on
the wiki and edit the section to your liking ... i'll even meet you
halfway. i've copied the aforementioned section into a talk page so have
at it
http://wiki.povray.org/content/Documentation_Talk:Reference_Section_4.2
Date: 19 May 2011 12:14:51
Message: <4dd541fb@news.povray.org>
Am 19.05.2011 05:06, schrieb SGeier:
>> clipped_by object.
If you think the documentation is bad, then you're happily invited to
help make it better.
It's not like the developers & other people helping with POV-Ray would
be paid anything for it; our only payment is the joy of doing it (and
every programmer knows that implementation work is more fun than writing
documentation), the joy of seeing people get good results of it, and the
joy of receiving some motivating feedback from the community now and then.
So if you /want/ anything from us, or want to /insist/ on some point of
view that the dev team does not share, you're in the wrong place.
> documented.
It's one thing to get feedback on things that people /think/ is wrong.
Getting feedback from someone who /knows better/ (or at least sounds
like that) is something entirely different.
No. To the programmer, the /intention/ is the end-all and be-all. If the
code fails to match that, it is buggy. If the documentation fails to
match that, it is either wrong (making an explicit statement that is not
true), incomplete (failing to make an explicit statement that is true
bot not necessarily obvious to the user), or imprecise (making a
statement that can be interpreted in a way that is true, but also in
another way that is not).
In this particular case, the documentation is /incomplete/, but not
wrong: It does /not/ make an explicit statement about the situation you
encountered. It does however make a statement about similar situations
with CSG, which /might/ give resourceful users a hint what's going wrong
with regard to clipped_by.
BTW, to the end user, the /expectation/ is the end-all and be-all; the
documentation can only serve to modify those expectations. So if some
docs do not explicitly mention the program's behaviour in a very rare
situation, who is outright /wrong/: The documentation, or the user's
expectations? I dare say the latter, because the docs simply cannot
foresee all that a user may expect.
Also note that in real life there is no such thing as a /complete/
documentation.
I disagree in some points:
(1) The docs do not /lead/ the reader to expect behaviour different from
what is implemented in this case. It is /your/ expectation, and all you
can blame the documentation for is that it did not /lead you away/ from
that expectation. Provided that you even gave it a chance to do so, by
thoroughly reading the isosurfaces doc section.
(2) I guess that careful reading of the doc section on isosurfaces
/will/ lead the majority of readers away from that expectation, at least
to the degree that they're not too surprised when their original
expectation proves wrong.
(3) My definition of a "false" documentation is more strict than yours
seems to be. In my terminology, "incomplete" or "imprecise" is not
necessarily "false".
(4) There is no /need/ to communicate the programmers' intentions to the
users. It's probably /helpful/, but there is no such /obligation/ to the
dev team - neither legally (see the license) nor morally (what you get
from the dev team is a free gift, and you can either take it or leave
it, and there's nothing you can /demand/ on top).
Date: 19 May 2011 14:47:21
Message: <4dd565b9$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:4dd41abd@news.povray.org...
It /also/ certainly helps to try a non-functioning case of code when being
pointed to it, rather than complain about being helped. Because that's what
*I'm* doing when I point out things that don't work: help you. By either
alerting you to buggy code (code that does not work as intended) or buggy
documentation (documentation that does not communicate how things are
intended to work).
>... add all_intersections and just be happy.
Why don't you try it yourself?
Seriously: Why not?
I gave you the best bug-report I can think of writing; with a few discrete
steps where I describe at each step why I am taking it, what I expect to see
and what I actually see.
What do I have to do to motivate you to simply follow along with my example,
see for yourself where things stop working - and then enter that line and
see it /start/ working. Wouldn't that give you satisfaction? Why are you so
afraid of simply trying it? What do you have to lose here?
Let me save you typing effort and reproduce the whole file so you can just
cut/paste it:
// --------------------start here
  #version 3.7;
          pigment {rgb 1}
          all_intersections
//--------------------end here
See: I have the best documentation there is: the program itself. Whatever
the program does is whatever it does. You may /imagine/ that you know it
better than me, but I've actually looked at it. I get to see the actual
binary, produced by compiler 'x', using library 'y' interacting with OS 'z'.
(OS'es are Windows Server.03 32bit and and Server.08 64bit just in case
anybody really cares).
Date: 19 May 2011 19:21:17
Message: <4dd5a5ed$1@news.povray.org>
Am 19.05.2011 20:47, schrieb SGeier:
> cut/paste it:
>    #version 3.7;
>    light_source{<2,4,8>,<1, .8, .6>  }
>            pigment {rgb 1}
>            all_intersections
You didn't actually /try/ the code you posted, did you? Otherwise you'd
have noticed that above code does not support your point at all, but
instead just gives a parse error.
all_intersections needs to go before the clipped_by statement. That, by
the way, is in the docs, too.
Once you place all_intersections at the /right/ place everything /will/
be fine.
You're complaining that Thorsten did not try out the code you posted -
but why should he, if he knows POV-Ray good enough (and yes, obviously
better than you) that he's not in the least surprised, and can even tell
you /why/ it is happening? (Besides, what makes you so sure that he
didn't try it?)
Date: 19 May 2011 21:12:05
Message: <4dd5bfe5$1@news.povray.org>
news:4dd5a5ed$1@news.povray.org...
>> just
>> cut/paste it:
>>    #version 3.7;
>>            pigment {rgb 1}
>>            all_intersections
>> 'z'.
Yes, I did. Noting that this doesn't work.
> Otherwise you'd have noticed that above code does not support your point
> at all, but instead just gives a parse error.
Indeed, it does. Which I noticed. Which is why I was trying to coax Thorsten
Froehlich into trying his own suggestion. Which was this:
Which does not work. Thank you for trying it. Thank you for noticing that
*the advice given by people who know the program so well DOES NOT WORK*.
Thank you for pointing that out. Always pleased to learn something.
> That, by the way, is in the docs, too.
No, it is not.
This is exactly where our views on the documentation differ drastically.
Yes, now that you mention it, I can see how one *could* read the
documentation such as to suggest that. However it *definitely* does not
contain the sentence
"all_intersections needs to go before the clipped_by statement."
or any sentence anywhere close to it.
Here's what section 3.4.4 of the documentation shipping with the windows
verion *actually* says:
isosurface {
  function { FUNCTION_ITEMS }
  [contained_by { SPHERE | BOX }]
  [threshold FLOAT_VALUE]
  [accuracy FLOAT_VALUE]
  [max_gradient FLOAT_VALUE]
  [evaluate P0, P1, P2]
  [open]
  [max_trace INTEGER] | [all_intersections]
  [OBJECT_MODIFIERS...]
This tells me that a number of items can occur inside the isosurface{}
entity. For example [threshold ...] or [contained_by ...] and a whole class
of [object modifiers]. Nowhere in the docs is any mention that their order
matters in any way and as a matter of fact some of the examples in the
tutorial have them in an order different from the above.
If the [object modifiers] have a special status here, in that they *have* to
be at any one particular place (at the end), then that needs to be spelled
out. If it isn't spelled out, then you cannot claim that it is in the docs.
Here is a place where the documentation might not be in direct contradiction
with the behavior of the program, but the program certainly doesn't behave
as documented. [all_intersections] can apparently go anywhere it wants in
that list up there *except* after [object modifiers] -- and users are
supposed to magically know that even though it is definitely NOT written
anywhere.
And when someone like myself complains about the documentation we're being
told that we should improve it. But of course we *cannot* improve it since
there is no way to find out what the real behaviour actually *is*, since the
documentation doesn't mention it and asking on usenet gets me helpful advice
like
which I had seen, tried, and noticed it didn't work. So I figured that
something changed since the docs were written, so I post here.
So it turns out the whole thing was *really* not about clipping at all, all
the blah-blah about reading the documentation on clipping and max_trace and
all_intersections was completely besides the point. Apparently neither you
nor Thorsten had the slightest idea what was wrong, you just immediately
assumed that *obviously* I hadn't read the documentation and *obviously* you
know exactly what's going on, no need to actually investigate anything or
think about anything.
Cool, so there's nothing wrong with the binary, it's the documentation that
is unclear. Good to know.
Now why is it like pulling teeth to get someone to actually come out and
examine things and state these things here on the ng? Until I posted the few
lines there in toto, nobody around here had even *tried* to diagnose what my
problem might be -- you all just assumed you knew exactly what the problem
was (and it turned out to be somewhere else).
> You're complaining that Thorsten did not try out the code you posted - but
> why should he, if he knows POV-Ray good enough (and yes, obviously better
> than you) that he's not in the least surprised, and can even tell you
> /why/ it is happening? (Besides, what makes you so sure that he didn't try
> it?)
Because his answer "add this line to your SDL and it'll all work" did NOT
work. Either he doesn't know POV-Ray as well as you both think, or he knows
it *too* well, where he's not stating what assumptions *he* is making (which
is exactly what I find myself accused of).
Date: 19 May 2011 21:56:32
Message: <4dd5ca50$1@news.povray.org>
news:4dd541fb@news.povray.org...
> If you think the documentation is bad, then you're happily invited to help
> make it better.
I am honestly not being facetious when I (honestly, serious!) ask: How is
that supposed to work, when I don't know how POV-Ray works? I look into the
documentation when something doesn't work as I expect. I learn something,
try something, and realize it doesn't work as written in the docs either.
How on earth am I supposed to now suddenly write better docs?
I've been poking my head into POV-Ray for several years now - I d/l the
current version, I tinker with it, I give up. Because every time I run into
the same kinds of problems that aren't documented and when I ask about them
nobody takes the time to examine what was communicated how in the docs and
when I complain about the docs I'm being told that I'm free to make them
better. But how should I do that, when I don't even understand some very
basic, simple things about POV-Ray *because they're not documented*?
You really think those who don't know how POV-Ray works wil create better
documentation than those who do know it?
> It's not like the developers & other people helping with POV-Ray would be
> paid anything for it; our only payment is the joy of doing it (and every
I've been writing (and giving away) code since the eighties, I understand
that joy. But I also understand that the chance of "seeing people get good
results of it, and the joy of receiving some motivating feedback from the
community" increases when people actually have chance to use my creations --
which requires clear, unambiguous documentation. In which someone can find
what they're looking for.
Otherwise you've created a magic binary that people *cannot* get good
results from.
I understand well, that in the end you're just hurting yourself by not
taking the opportunity to take every post to these ng as an opportunity to
ask "how should we have written the answer to this in the docs and where did
you look for it". But exactly *because* I've written my share of software,
it frustrates me to no end that there's something here that seems pretty
solid enough and appears to be getting better every time I look -- but it
will never be something I use in any serious way, because nobody who knows
the inner workings can be bothered to write down what is actually going on
in this piece of code.
> code fails to match that, it is buggy. If the documentation fails to match
> that, it is either wrong (making an explicit statement that is not true),
> incomplete (failing to make an explicit statement that is true bot not
> necessarily obvious to the user), or imprecise (making a statement that
> can be interpreted in a way that is true, but also in another way that is
> not).
It's all fine that you have all these fine levels of gradation in which
documentation fails. To the end-user, however, they make no difference: As
Feynman said "if it disagrees with experiment, it's wrong".
But OK: so the documentation is "incomplete". Yet nobody is changing it.
Instead *I* have been asked to improve on it - even though I have no idea of
the very things that made me post here in the first place. It would be great
if every post to these ng was taken as an opportunity to improve your
stuff -- but if you don't want to do that, then why bother in the first
place? Why even have these ng?
Once you posted the order in which the intersection test and clipping
happen, that side of POV-Ray's behaviour was clear to me. So why haven't you
put that explanation into the docs yet? Yes, I could try to do it myself,
but I'd only mess it up in some subtle way since I only heard of it the
first time yesterday (or whenever I read your reply).
> documentation can only serve to modify those expectations. So if some docs
> documentation.
Actually, there is: the program as shipped is the final documentation. If
you aren't sure about something, feed it to the program and see what
happens. Whatever that is, that's how this program works.
Much of that can be predicted if you know the source, some details may hinge
on details in some library or the compiler or OS. If someone says "just add
all_intersections" and I add all_intersections and the result is a
parse-error, then the advice was wrong. You may niggle over "incomplete" or
"imprecise" or whatever, but when everything is said and done, following the
advice to the dot leads to a parse error. *correct* advice solves my
problem. *good* advice is like much of what you've been doing: pointing out
what's wrong and where and how.
>> (in
> from the dev team is a free gift, and you can either take it or leave it,
The concept of "need" is always tied to a purpose of some sort: in order to
achieve X you *need* to Y.
If, to the programmers, the intent is the end-all be-all (as you claimed,
and as I'm happy agreeing with) and if the programmers hope that people will
get good use out of their producs (as you maintain and as I have no quarrels
agreeing with) then they *need* to document their intent.
You are the only one here construing any kind of legal or moral dimension to
the term "need".
Date: 20 May 2011 03:15:01
Message: <web.4dd613da955938cce619b42c0@news.povray.org>
> isosurface {
>   [open]
Actually, you misread the grammar: As there is no "|" between the
isosurface-specific modifiers and the "[OBJECT_MODIFIERS...]", the grammar
clearly states that putting "all_intersections" after "[OBJECT_MODIFIERS...]" is
not possible.
BTW, that you find at http://www.povray.org/documentation/view/3.6.1/214/  ;-)
    Thorsten
Date: 20 May 2011 03:31:53
Message: <4dd618e9$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
In all fairness, and without wanting to further the debate, this is neither
in the docs, nor in the tutorials. Well, at least I did not find it. Neither
is clipped_by mentioned by the way, in the isosurface section, so the error
seems very comprehensible to me.
The logical stream of thought probably is that contained_by and clipped_by
are equivalent (which they are not?) and as contained_by is mentioned before
all_intersection in the docs....
No need to hone the sabers now  ;-)
Date: 20 May 2011 03:48:15
Message: <4dd61cbf$1@news.povray.org>
[after reading Thorten's message above]
... and which shows, there is a semantic problem, difficult to solve in
fact. Increased by the number of non-native speakers among us.. I have the
impression that many people (me included) not always realise that Object
Modifiers is much more than just transformations. :-)  The contained_by in
isosurfaces is also an object modifier, strictly speaking.
I think that in this case, there should be a little sentence in the docs
just stressing that all isosurface parameters have to be placed *before*
any object modifier.
I hope this helps....
Date: 20 May 2011 06:14:44
Message: <4dd63f14$1@news.povray.org>
> Thomas
ah ... finally something of substance! (instead of all this childish
posturing) I added a "Note" just after the syntax diagram:
http://wiki.povray.org/content/Documentation:Reference_Section_4.2#Isosurface_Object
oh and btw the clue that clipped_by is indeed an object modifier is in
the first sentence:
http://wiki.povray.org/content/Documentation:Reference_Section_4.5#Clipped_By
Date: 20 May 2011 07:10:01
Message: <web.4dd64b47955938cc34d207310@news.povray.org>
> > isosurface {
> >   [open]
> not possible.
>     Thorsten
I just tried max_gradient before threshold. The scene did not bomb out in the
way that putting all_intersections in the wrong place does. His point is valid.
Date: 20 May 2011 07:26:01
Message: <4dd64fc9@news.povray.org>
Actually, this rule applies to many object modifiers in other objects as
well. It is not a unique behavior in isosurfaces. And it is documented.
	Thorsten
Date: 20 May 2011 07:32:23
Message: <4dd65147@news.povray.org>
>>> isosurface {
>>>    [open]
>> not possible.
>>      Thorsten
Your logic is broken - saying that the negation of my statement yields no
error is not the same as what I said. Sorry.
	Thorsten
Date: 20 May 2011 07:39:38
Message: <4dd652fa$1@news.povray.org>
Jim, please remove the note as it is superfluous and does not document
anything special in isosurfaces that does not exist in other objects as
well. The better place to improve is the grammar explanation section (the
equivalent of http://www.povray.org/documentation/view/3.6.1/214/ ). It is
not all that obvious for non-programmers and very brief.
> oh and btw the clue that clipped_by is indeed an object modifier is in the
> first sentence:
I would say this is more than a hint - after all, it is a subsection of the
"object modifiers" section :-)
	Thorsten
Date: 20 May 2011 07:40:38
Message: <4dd65336$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> schreef in bericht
news:4dd64fc9@news.povray.org...
You are certainly right, but as it does not *always* apply, an extra note is
not superfluous here and there. Never take for granted that everything is
obvious for the layman ;-)
As I implied before, it is often a matter of semantics, and we try to tend
towards perfection, which is impossible... but we try, we try!
Date: 20 May 2011 07:50:18
Message: <4dd6557a$1@news.povray.org>
"Jim Holsenback" <jho### [at] povrayorg> schreef in bericht
news:4dd63f14$1@news.povray.org...
> posturing)
<grin>
> first sentence:
Yes, no doubt about that. It is mainly the fact that you have to be careful
where to place those object modifiers which can be a problem (or not) as it
doesn't always generate a parse error, and sometimes it might just generate
unexpected results I guess.
Poll (not serious): Who knows all the docs content (and their cross-links)
by heart?
Date: 20 May 2011 07:55:33
Message: <4dd656b5@news.povray.org>
Am 20.05.2011 03:56, schrieb SGeier:
>> make it better.
You're surprised, you ask, you learn, you document what you learned so
that others don't need to ask again. That's how it /could/ work.
The dev team is not constantly skimming through the docs with the eyes
of a new user (how could they!) searching for stuff that's poorly
documented.
Nor does the dev team have an abundance of energy to work on the docs.
Jim is doing a great work on that, but he has a life, too. Essentially
we need people who not only /find/ flaws in the docs, but also /fix/ them.
Another thing that should be noted is that the dev team has changed a
lot over the lifetime of POV-Ray so far; some members left, others went,
and various people outside the official dev team contributed code and/or
documentation. There are things in both the docs and the code the
current dev team does /not/ know by heart.
That may well be. Software authors who know how their software works
tend to take some things for granted that new users possibly won't.
They're also prone to language that a fellow programmer might
understand, but an artistically oriented user may possibly not.
... and I bet you've always supplied a correct, error-free, complete and
end-user-friendly documentation, huh?
If you did, then congrats - you might be the type of person we could
need help from.
> results from.
Well, the source code is there to have a look at, too (and even toy
around with). It's the most precise documentation we cold ever ask for.
(Unfortunately it's not very end-user-palatable.)
You know, I have my own approach at things that frustrate me.
A while ago it frustrated me as a POV-Ray end user that while POV-Ray
3.7 beta (I think it was beta 28 or 29) could make use of multiple
cores, it couldn't do so for radiosity.
Knowing that the dev team was pretty busy, I decided to give it a try
and invest some of my /own/ energy into /making/ it use multiple cores
for radiosity.
I did. Previously I had only vague ideas of how POV-Ray worked at its
core, how radiosity worked, and so forth. I invested the energy to
/learn/ how it worked, in order to fix what was frustrating me. Yes, I
did my own share of ranting over the existing radiosity code as I dug
deeper into it - but at the same time I busied myself fixing it.
So pointing out flaws is one thing - ranting about them without adding
anything more helpful is a different thing.
Believe me - we /want/ the documentation improved. We just don't have
the energy ourselves at present. There's other things that have priority
(for us as a dev team) over fixing stuff in the docs that hasn't changed
at all from 3.6 to 3.7.
I'm not doing it myself because I'm poor at writing end-user docs; being
pedantic as I am, I find it difficult to find a proper balance between
precision and legibility, so it costs me a lot of energy to do such doc
changes. I have a much easier time explaining things to individual
people than to a broad anonymous audience. And if we'd be talking about
a technical specification, where precision is all that matters, I'd have
a much easier time.
So Thorsten's advice was "incorrect" because he simply wrote "just add
all_intersections" rather than "just add all_intersections where it fits
according to the documented isosurface syntax"? Great. I prefer to disagree.
Date: 20 May 2011 08:43:48
Message: <4dd66204@news.povray.org>
Am 20.05.2011 03:12, schrieb SGeier:
> No, it is not.
Yes, it is.
It does explicitly specify it in the section you quoted:
> isosurface {
>    [open]
Read section 3.1.1 "Notation and Basic Assumptions"; nowhere in there
does it say that the items can be specified in arbitrary order, so it's
your assumption that is wrong again here. The fact that /some/ of the
stuff can be re-ordered is, as a matter of fact, a feature documented
elsewhere.
See sections 3.8 "Quick Reference" for a description of the notation
used for the syntax specification, and section 3.8.8.4 "Isosurface" for
the description of the isosurface syntax. There you will find that
ISOSURFACE_ITEMS (including all_intersections) may be specified in
arbitrary order, but must go before OBJECT_MODIFIERS.
> like
(As you seem to like precision, please note that we're not on usenet;
we're on a private news server.)
Thorsten knew /exactly/ why the stuff was happening that you saw, and I
myself didn't post a reply until I had figured it out as well. (Believe
me, while as a matter of fact I often /do/ start writing responses to
reports of possible errors before checking it out, I virtually never
press "send" before I checked that I'm not talking nonsense.) The only
thing unclear was why you insisted it was an error.
Maybe because with your originally posted code we didn't need to examine
things, because your description matched the behaviour /we/ did expect?
That was when your problem apparently shifted, from getting an
unexpected (for you) result from your originally posted code to some
rather vague complaint in connection with all_intersections (which you
hadn't mentioned earlier, so we all naturally assumed - and still assume
- you hadn't tried it).
So why are you surprised you're getting a more thorough inspection only
later? It's like you're phoning up the garage complaining to the
mechanic that the engine on your car stutters, and by the way there's a
red light in the display, looking somewhat like a fuel pump (*); not
surprisingly the mechanic will simply recommend to try and fill her up
(knowing that stuttering engines are to be expected when there's a lack
of fuel), but now you start complaining that the fuel pump doesn't fit
in the tank. It's probably only /then/ that the mechanic will consider a
more thorough inspection. (And as it turns out the problem is that you
tried to pump your diesel at a pump for heavy trucks, so you blame the
car manufacturer for failing to make a note of this incompatibility in
the car's user manual.)
(* I am well aware that the example limps here because usually those
lights are well documented. However, the fact that a car needs fuel to
drive is typically taken for granted.)
>> it?)
... or he knows some things mentioned in sections of the docs you didn't
read.
Date: 20 May 2011 08:48:51
Message: <4dd66333$1@news.povray.org>
Am 20.05.2011 09:46, schrieb Thomas de Groot:
> The contained_by in
No, not really. Not according to how OBJECT_MODIFIERS is defined
syntactically.
Note the same goes for /any/ object type: Object-type specific keywords
must go first, before any generic object modifiers. So do we need such a
sentence in the description of /all/ the primitives?
Date: 20 May 2011 08:51:31
Message: <4dd663d3$1@news.povray.org>
Am 20.05.2011 13:39, schrieb Thorsten Froehlich:
> (the equivalent of http://www.povray.org/documentation/view/3.6.1/214/
> ). It is not all that obvious for non-programmers and very brief.
Maybe it would be good to use the same notation as in the quick
reference, using "&" to list items with arbitrary ordering.
Date: 20 May 2011 09:12:58
Message: <4dd668da$1@news.povray.org>
> Maybe it would be good to use the same notation as in the quick reference,
I think aligning the quick ref and the remainder of the documentation would
be a good idea. It is a lot of tedious editing required though :-(
	Thorsten
Date: 20 May 2011 10:54:15
Message: <4dd68097$1@news.povray.org>
news:4dd66333$1@news.povray.org...
>> The contained_by in
> syntactically.
I am sure I agree with you here. What I mean to say is that - for the
layman - contained_by is looked upon in the same way as an object modifier.
Well, it seems I am not one of those lucky ones who know the docs perfectly
:-)  Your point is well taken, only I had never really thought about it in
that way, and I suppose many are in the same position as me...
I think this whole discussion is not useless. We all learned something
essential it seems. Hurray!  :-)
Date: 21 May 2011 09:15:40
Message: <4dd7bafc$1@news.povray.org>
Have the clocks gone back 10 years?
Have we returned to the days where the simplest question was met by RTFM?
I thought that we had developed into a nice community not one that
answered a legitimate question with “I know and I’m not going to tell you”.
I’m very disappointed with the behaviour of some people here.
Date: 21 May 2011 09:40:37
Message: <4dd7c0d5@news.povray.org>
I'd like to suggest that the response of some people in this group could
have been a bit nicer. Please however understand that geeks are sometimes a
little short on social graces :(
Date: 21 May 2011 10:39:37
Message: <4dd7cea9$1@news.povray.org>
And more helpful IMO.
> little short on social graces:(
And that is an acceptable excuse?
It is like saying that we Glaswegians are renowned for mindless violence
so don't take the stitches and broken leg personally.
An apology goes a long way. (Not directed at you cobber.)
Regards
Date: 21 May 2011 14:56:52
Message: <4dd80af4@news.povray.org>
> answered a legitimate question with ???I know and I???m not going to tell you???.
> I???m very disappointed with the behaviour of some people here.
  I don't think it's fair to judge the entire community because of the
behavior of one person. People are different and have different
personalities, and sometimes personalities might clash a bit. However,
judging everybody for this is not nice.
Date: 21 May 2011 15:23:57
Message: <4dd8114d$1@news.povray.org>
You are entirely right.
With all that implies.
Regards
Date: 23 May 2011 19:56:22
Message: <4ddaf426$1@news.povray.org>
news:web.4dd613da955938cce619b42c0@news.povray.org...
> not possible.
>    Thorsten
Is this some kind of character set issue? Did you really mean to use a pipe
symbol (vertical bar) in your quotation marks up there?
I'm staring at the page to which you posted a link there and I fail to see
ANY mention of any relationship between a pipe symbol and the order in which
things need to be provided. As a matter of fact the only mention of a pipe
symbol that I see there is this pair of sentences:
> Choices are represented by a vertical bar between
> syntax items. For example a choice between three
> items would be written as ITEM1 | ITEM2 | ITEM3.
Could you please quote to me the sentence/s on that page that you linked up
there that indicates that vertical bars have anything whatsoever to do with
the order of things.
(Yes, I'm aware that the quick-reference has such a statement, but it also
has a warning that the syntax convention there is different from the user
documentation).
Date: 23 May 2011 21:21:59
Message: <4ddb0837@news.povray.org>
news:4dd66204@news.povray.org...
>> isosurface {
>>    [open]
>> class
>> order
> Read section 3.1.1 "Notation and Basic Assumptions"; nowhere in there does
> it say that the items can be specified in arbitrary order, so it's your
No, it is not an assumption. It is an *observation*.
I learned about isosurfaces by reading the isosurface tutorial. Isn't that
what it's for? In the tutorial there are bits of example code. They have
various items in various order, including order that is expressly in
conflict with the above list. For example section 2.3.3.3.6 of the
documentation that ships with the current RC3 has this piece of code:
  #declare Blob_threshold=0.01;
  isosurface {
    function {
      (1+Blob_threshold)
      -pow(Blob_threshold, fn_A(x,y,z))
      -pow(Blob_threshold, fn_B(x,y,z))
    max_gradient 4
    contained_by { box { -2, 2 } }
This has max_gradient *before* contained_by. And it works just fine. At this
point I'm not exactly "assuming" anything when I start moving the other
parts around -- and meeting with perfectly fine success. No problems placing
any of the above in any order - *except* those "object_modifiers".
And no, nowhere in the tutorial is there any mention that there's any
exceptions to this floating around.
> See sections 3.8 "Quick Reference" for a description of the notation used
> for the syntax specification, and section 3.8.8.4 "Isosurface" for the
I'm having trouble figuring out how things work by reading the verbose parts
of the documentation and you think I'm going to go to the *quick-reference*
to look them up? Seriously?
Especially after I've seen it start with a warning that it uses incompatible
notation and thus that anything I learn here will not actually transfer to
what I read elsewhere in the docs?
> [...] The only thing unclear was why you insisted it was an error.
I didn't "insist" on anything - Here's the first and last part of my
original post:
>"SGeier" <som### [at] somewherecom> wrote in message
>news:<4dd316e8$1@news.povray.org>...
> bug
> Why?
I posted something and asked "why is this like that". If someone had simply
told me why it is that way, I would have learned something. Instead I was
told "you didn't read the docs".  Huh. Very helpful. Turns out what I was
*really* bumping into was about some subtle distinction about the items I
can put into an isosurface{} statement, namely that some of them are
"object_modifiers" and assume a special place, while others are
object-specific and can go wherever.
Why? Who knows. I already have a max_trace_level in my global_settings, but
isosurface ignores that and instead needs to be told its own specialized
max_trace and when I do that it magically becomes  isosurface-specific and
thus cannot be placed after clipped_by. Even though it is only ever needed
*because* I am using clipped_by in the first place. IF I use clipped_by,
THEN I need a max_trace and it must come BEFORE the clipped_by that
necessitated it. And this is so amazingly *obvious* that it is sufficient to
post "you didn't read the docs" because the docs are so completely clear on
this.
Seriously.
Yes, I was making an assumption there somewhere: if the program and the docs
disagree, the program wins. Thus something changed in the program since the
docs were written. Not a big deal - let me post and ask around. Hah.
> read.
To be as clear as I can: I have certainly NOT read every single page in the
docs. Because the documentation is amazingly self-indulgent in page upon
page of tutorials on what the frickin' #if command does, but fails to
mention the basic things someone trying to compose scripts in the SD
language actually needs to know. Except for the few that are actually tucked
away somewhere and sometimes I even sumble across them (usually while trying
to figure out something else).
I have *easily* spent five times as much time reading POV-Ray documentation
than reading Python docs; yet I am completely confident when I write Python
code because what I have read explained the *why* of the various things in
the simple, straightforward order in which an intelligent reader would
expect to read them. While I keep flailing around in POV-Ray because such
simple things as the order of ray-intersection test and clipping are either
not documented at all or if they are then they're buried somewhere.
Date: 23 May 2011 22:33:59
Message: <4ddb1917$1@news.povray.org>
Le 2011/05/23 21:21, SGeier a écrit :
> "clipka"<ano### [at] anonymousorg>  wrote in message
>>> isosurface {
>>>     [open]
ALL items between the function and here can be placed in ANY order. They
are objects items and are often specific to the primitive used.
Note that all items are lower case, then, you have OBJECT_MODIFIERS in
all UPPERCASE. This tells you that OBJECT_MODIFIERS is not in the same
category. In fact, it tells that OBJECT_MODIFIERS in not an item.
>>> class
>>> order
The documentations clearly state that all object modifiers must follow
all objects items.
You seems to confuse "items" and "modifiers".
Items can be in any order.
Modifiers also can be specified in about any order. They also MUST
follow the last item.
>    isosurface {
>      function {
>        (1+Blob_threshold)
>      max_gradient 4
Still because OBJECT_MODIFIERS are NOT object items.
Uniquely because the tutorials don't scale, rotate or translate the
sample isosurfaces...
The isosurface tutorial concentrate only on creating the isosurface, not
modifying them, clipping them or using them in CSG with other primitives.
> original post:
>> "SGeier"<som### [at] somewherecom>  wrote in message
>> bug
You asked if there was a bug, and there is none.
It leaves the "something phenomenally stupid" part...
>> Why?
Again, "object_modifiers" are not items. It thus don't follows the
general rule of order as the items.
> this.
> Seriously.
Your assumption and interpretation <> documentations that are fidel to
the programm.
This is that way at least since version 1.
primitive_name{mendatory_items [optional_items_in_any_order]
[OBJECT_MODIFIERS_IN_ANY_ORDER]}
>> read.
If you look around, you'll find that:
Most of the time, max_gradient immediately FOLLOWS the function. It's
question of style and general concensus.
Also, most of the time, contained_by is the last isosurface parameter.
Also a question of style and concensus.
max_trace_level apply exclusively to transparency and reflections, never
ever to any surface that can never be visible.
max_trace/all_intersections is very different and there is no "magic"
transforming one into the other.
max_trace_level is a global setting that affect the evaluation of
tracing rays.
max_trace is an object attribute specific to the isosurface in exactly
the same way that max_gradient is. It affect how the isosurface is
evaluated if there are surfaces that can't be seen. Please note that
ther is NO "_level" here. They do LOOK similar, but are totaly different
things.
Then, you have clipped_by, whitch is an OBJECT MODIFIER.
ALL object modifiers always MUST follow ANY object items. This also
apply to any pigment, texture, material, translate, scale and rotate.
You can't translate an isosurface before you use contained_by. Also, you
can't apply a pigment before, say, accuracy or open.
Date: 24 May 2011 06:39:08
Message: <4ddb8acc@news.povray.org>
What that documentation page fails to mention explicitely is that,
in absence of special syntax, everything is to be taken literally
and in the order specified.
For example, "sphere {<Center>, Radius}" means first write sphere,
then write curcly brace open, then write vector expression, then write
scalar expression, then write closing brace.
The reference to the pipe is that typically elements A and B
that may be present in arbitrary order could be given as:
[SOME_ITEM...]
SOME_ITEM: A | B
However, such syntax allows you to give the same item multiple
times, even if that was not the intent. It also seems that some
SDL descriptions are given in a way that imply a specific parameter
order although that is not the intent and not the implementation.
This may lead to confusion where order is important.
For non-technical users this page might benefit from an example.
Date: 24 May 2011 19:36:01
Message: <4ddc40e1$1@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfrde> wrote in message
news:4ddb8acc@news.povray.org...
>> see ANY mention of any relationship between a pipe symbol and the order
>> in which things need to be provided.
"Is to be taken" - by whos opinion? Who says that this is so? The
programmers certainly don't say so. If you disagree with this statement,
show me where they do. Oh, you just said that the documentation "fails to
mention" that. Bummer.
The documentation also fails to mention that chocolate is evil and should be
outlawed. Does that mean you, I or anybody can just claim that it is somehow
"meant" even though it "isn't mentioned explicitely"?
The various items in isosurface *can* be used in arbitrary order, as
*demonstrated* in the tutorial; even though there is no "special syntax"
anywhere. *Except* for those "object_modifiers" that are no more nor less
marked with pipe-symbols or anything but somehow can only go at the very
end. The only vertical pipe is between [max_trace ...] and
[all_intersections] indicating an either/or choice as vertical pipes do in
all EBNF I've ever seen.
So not only does the page "fail to mention expressly" that order is
important, if it did mention such a thing it would be *false* because the
behaviour of the program itself is such that order does not matter *except*
in the case of object modifiers that have to be at the end. And where I'm
coming from, where the documentation and the behaviour of the program
differ, the program is right and the documentation is wrong. Fortunately it
is NOT wrong here, because it does not actually say such a thing.
Meanwhile, this was Thorsten Froehlich's claim:
>not possible.
Cool, if "the gramma clearly states" such a thing then it should be easy to
show me *where* the grammar clearly states such. Because I somehow missed it
and so I'm assuming it is in some area of the documentation that I didn't
read and I assume there's more things in that section that I need to know.
His further claim was
which unfortunately does NOT show any such information at all, so I'm going
to assume that he *accidently* pointed me to the wrong section in the
documentation.
Date: 24 May 2011 19:51:36
Message: <4ddc4488$1@news.povray.org>
Am 24.05.2011 03:21, schrieb SGeier:
>>> class
>>> order
It's an observation that /some/ items can be specified in arbitrary
order (and as a matter of fact happens to be true for all
non-OBJECT_MODIFIER items). However, it was only your /assumption/ that
it was also true for /all/ items including OBJECT_MODIFIER elements.
That said, rather than continuing this interesting nitpicking contest,
please take a step back, rethink, and tell us what you /want/ from the
dev team.
No, we won't improve the docs much before the 3.70 repease proper
(unless some volunteer(s) happen to step up to actively help us with
them - and by actively I mean more than demonstrating that you didn't
understand them), for the simple reason that there's lack of manpower in
that respect. Yes, the docs badly do need some improvement, but (1)
that's not a new issue caused by the 3.6 -> 3.7 transition, and (2) it's
not realistically achievable with just adding a bit of more patchwork
here and there; what's really necessary is a systematic overhaul, which
will possibly include a major rewrite and/or restructuring of many sections.
Date: 24 May 2011 20:00:13
Message: <4ddc468d$1@news.povray.org>
Am 25.05.2011 01:35, schrieb SGeier:
> And where I'm
Where /I'm/ coming from, this is /not/ necessarily the case, but
definitely depends on various other circumstances; for instance, where
the program /tolerates/ something that's not explicitly in the docs,
this is an undocumented feature, may be subject to change without
notice, and therefore should still be avoided despite being tolerated.
Date: 24 May 2011 20:06:11
Message: <4ddc47f3@news.povray.org>
> dev team.
Now that is sensible.
There is no need to make things worse than they re already are.
Regards
Date: 24 May 2011 20:46:21
Message: <4ddc515d$1@news.povray.org>
> sections.
couldn't agree more with what you've said here ... I think my focus was
to get stuff (new features) added in as they just weren't documented
period, and also the code to pull it back out of the wiki in html form.
I /did/ touch on some house keeping issues that were just plain in need
of help, but I'm just one person, so for sure there are some areas that
just didn't get touched. I /still/ give the docs pretty high marks,
because hey I've seen MUCH worse (other apps) and would be the first to
admit that there are areas that still need some attention ... everyone
knows that documentation is usually the /last/ thing to be addressed
with most projects and everyone hates to do it ;-)
Date: 24 May 2011 20:55:27
Message: <4ddc537f$1@news.povray.org>
"Alain" <aze### [at] qwertyorg> wrote in message
news:4ddb1917$1@news.povray.org...
[...]>>>>     [OBJECT_MODIFIERS...]
> Note that all items are lower case, then, you have OBJECT_MODIFIERS in all
Pray tell. Could you imagine that this might be the case why I called it "a
whole class of [object_modifiers]" in the paragraph directly following this
(that you so politely quoted right here:)
>>>> class of [object modifiers].
Not that it has any bearing on this:
> The documentations clearly state that all object modifiers must follow all
> objects items.
It is good to hear that there is at least one thing that the documentation
"clearly states". Because most parts of the documentations are rather
unclear.
Surely it wouldn't be too much of a bother if you could kindly direct me to
the section in the documentation that "clearly states" such a thing? It
seems that I keep missing all the important parts of the docs and I'd like
to make sure I have read at least those parts that clearly state things.
> Modifiers also can be specified in about any order. They also MUST follow
> the last item.
The word "item" has a fairly well-established meaning in the English
language, a meaning that would make every "thing" inside the {}, including
any modifier, an "item". If the POV-Ray docs would like the reader to
understand the term it in a manner incompatible with the common meaning then
I'm sure they "clearly state" such a thing. Could you please simply tell me
where I should go to find that?
>>> bug
As it turns out there was a third possibility: the documentation is wrong.
This is clearly a problem with my expectations: when I use the RC of some
software, I expect to find a bug here'n'there. And maybe possibly that I'm
just using the software wrong. I don't really expect to find documentation
that
- doesn't document the behaviour of the software correctly AND
- doesn't express the intent of the programmers
> Again, "object_modifiers" are not items. It thus don't follows the general
Oh, so there is such a thing as a "general rule of order"? Surely you can
point me to the part of the documentation that expresses that rule, right?
And if object_modifiers *must* be in a certain position because they *don't*
follow that "general rule", then I am concluding that the "general rule" is
that I can put items into any order? Because that seems to be in direct
contradiction with Christian Froeschlin's claim "in absence of special
syntax, everything is to be taken literally and in the order specified."
That line there - can you show me where I can find that in the docs?
Obviously it must be in there somewhere if it has been that way since
version 1. Thanks.
And where, exactly, would I do that "looking around" thing you're talking
about? The newsgroups have very little POV code on them, and where they do
it's usually someone posting something that *doesn't* work.
I guess the obvious place would be the "code samples" section of the
documentation. Oh, sorry, there is no such section. Hummm ...
I think you might benefit from reading the actual message I posted here that
started the thread. It would allow you to make comments that have a bearing
on the matter at hand. The suface I was writing about  was perfectly visible
*if* it was encased in a transparent object. It vanished when the enclosing
transparent object was removed. The issue is thus *very much* one of
"transparency and reflection" and nobody here anywhere wrote about a surface
"that can never be visible".
It would be possible to *make* the surface in question "never be visible" by
setting
 global_settings {max_trace_level 1}
> max_trace_level is a global setting that affect the evaluation of tracing
> rays.
> max_trace is an object attribute specific to the isosurface in exactly the
> same way that max_gradient is. It affect how the isosurface is evaluated
> if there are surfaces that can't be seen. Please note that ther is NO
> "_level" here. They do LOOK similar, but are totaly different things.
Both are instructions that tell POV-Ray how many ray-surface intersections
to follow before giving up.
I am at a loss how a sentient being can claim that they are "totally
different things".
Date: 25 May 2011 12:19:14
Message: <4ddd2c02$1@news.povray.org>
Le 2011/05/24 20:55, SGeier a écrit :
> "Alain"<aze### [at] qwertyorg>  wrote in message
>> objects items.
> unclear.
Maybe if you look in the documentations for object modifiers...
You'll see that clipped_by IS an object modifier.
You'll also see, at the top, that object modifiers must be at the end of
any object's definition.
> different things".
max_trace_level (default value 5) is how many ray-surface to follow when
you have refraction or reflection. Each surface do have an effect on the
value of a specific pixel. In 3.7, contrary to versions 3.6.2 and
earlier, plain transparent surfaces that don't reflect nor refract are
not counted against max_trace_level.
When you exeed max_trace_level, the colour returned is black (rgb 0).
max_trace (default value 1) is, for an isosurface in a CSG, how many
surface to EVALUATE or FIND. Here, the crossed surface don't have ANY
effect when computing the falue of a pixel.
If you set max_trace_level 1, it means that you stop following new rays
after the first reflection or refraction. You'll get black instead of
reflection or refractions.
With max_trace 1, the second and successive surfaces are not evaluated.
That means that you don't find when you exit the isosurface.
Date: 25 May 2011 20:48:00
Message: <4ddda340$1@news.povray.org>
news:4ddd2c02$1@news.povray.org...
>>> all
>>> objects items.
>> documentation
>> unclear.
OK, I am rapidly losing my patience here. The following is a cut-and-paste
of the complete pertinent sections of the *currently shipping* 3.7RC3
windows help file:
============== begin cut/paste =============================
3.4.9 Object Modifiers
A variety of modifiers may be attached to objects. The following items may
be applied to any object:
OBJECT_MODIFIER:
  clipped_by { UNTEXTURED_SOLID_OBJECT... } |
  clipped_by { bounded_by }                 |
  bounded_by { UNTEXTURED_SOLID_OBJECT... } |
  bounded_by { clipped_by }                 |
  no_shadow                  |
  no_image [ Bool ]          |
  no_radiosity [ Bool ]     |
  no_reflection [ Bool ]     |
  inverse                    |
  sturm [ Bool ]             |
  hierarchy [ Bool ]         |
  double_illuminate [ Bool ] |
  hollow  [ Bool ]           |
  interior { INTERIOR_ITEMS... }                        |
  material { [MATERIAL_IDENTIFIER][MATERIAL_ITEMS...] } |
  texture { TEXTURE_BODY }   |
  interior_texture { TEXTURE_BODY } |
  pigment { PIGMENT_BODY }   |
  normal { NORMAL_BODY }     |
  finish { FINISH_ITEMS... } |
  photons { PHOTON_ITEMS...}
  radiosity { RADIOSITY_ITEMS...}
  TRANSFORMATION
Transformations such as translate, rotate and scale have already been
discussed. The modifiers Textures and its parts Pigment, Normal, and Finish
as well as Interior, and Media (which is part of interior) are each in major
chapters of their own below. In the sub-sections below we cover several
other important modifiers: clipped_by, bounded_by, material, inverse,
hollow, no_shadow, no_image, no_reflection, double_illuminate and sturm.
Although the examples below use object statements and object identifiers,
these modifiers may be used on any type of object such as sphere, box etc.
3.4.9.1 Bounded_By
3.4.9.2 Clipped_By
The clipped_by statement is technically an object modifier but it provides a
type of CSG similar to CSG intersection. The syntax is:
CLIPPED_BY:
Where UNTEXTURED_SOLID_OBJECT is one or more solid objects which have had no
texture applied. For example:
object {
  My_Thing
  clipped_by{plane{y,0}}
Every part of the object My_Thing that is inside the plane is retained while
the remaining part is clipped off and discarded. In an intersection object
the hole is closed off. With clipped_by it leaves an opning. For example the
following figure shows object A being clipped by object B.
[image here]
You may use clipped_by to slice off portions of any shape. In many cases it
will also result in faster rendering times than other methods of altering a
shape. Occasionally you will want to use the clipped_by and bounded_by
options with the same object. The following shortcut saves typing and uses
less memory.
object {
  My_Thing
  bounded_by { box { <0,0,0>, <1,1,1> } }
This tells POV-Ray to use the same box as a clip that was used as a bound.
3.4.9.3 Double_Illuminate
==================== end cut/paste ======================
No, I will NOT see that because it is NOT in the documentation.
At this point, there are two possiblities left:
1) You have no idea what is actually in the documentation and you cannot be
bothered to look it up and actually inform yourself OR
2) You are deliberately lying
Either way, you are NOT qualified to tell other people who have actually
LOOKED at the documentation what is or isn't supposedly in there.
I asked you for pointers to *several* things you claimed were allegedly in
the documentation.
You provided *none*.
I do not know what you imagine you're accomplishing by this, but neither
POV-Ray, nor the POV-Ray documentation, nor myself or the dev-team benefit
from people making *false* claims about what is actually in the actual
documentation.
Subject: Re: Is this a bug in 3.7RC3 ? Or am I missing something?
Date: 25 May 2011 23:15:42
Message: <4dddc5de$1@news.povray.org>
news:4ddc4488$1@news.povray.org...
> It's an observation that /some/ items can be specified in arbitrary order
> (and as a matter of fact happens to be true for all non-OBJECT_MODIFIER
> items). However, it was only your /assumption/ that it was also true for
When I *should* have assumed that it is true for all items *except*
object_modifiers?
Seriously?
You *document* (in words) that there's a bunch of parameters and you
*document* (by example) that they can be used in different order but there's
a problem with *my assumption* because I didn't expect *undocumented*
exceptions to *documented* behaviour?
Maybe you should take a step back yourself and ask yourself what you imagine
you're accomplishing with this bullshit.
> please take a step back, rethink, and tell us what you /want/ from the dev
> team.
Here's one thing I definitely want from the dev team: Stop lying. Neither
the program nor the docs nor me nor you benefit from post after post after
post of claims of this-or-that things that are allegedly "clearly
documented" that nobody can *show* or *point to* because they *doesn't
exist*.
3) The POV-Ray documentation is
   *one* *hairy* *clusterfuck*
  (pardon the language, I already toned this down)
POV-Ray is one of the three worst-documented software projects I have ever
encountered. The other two are samba and ntp. Notice a commonality here?
Each of these three comes with megabyte upon megabyte of "documentation"
that *carefully avoids* ever actually spelling anything out. Ever providing
any actual information. Ever explaining the simple basics.
The reason for this sorry state is
2) The POV-Ray Scene Description Language is
I've written code in languages that require a semicolon at the end of a
statement. Languages that don't. Languages that allow semicolons but don't
require them. But POV-Ray is the only language known to me that makes a
semicolon mandatory for *some* statements, optional for *some* others and
throws a parse error for yet some others. Some day I'll end a statement with
", please" and I half expect that to actually work.
Abnd the reason for *that* is
1) POV-Ray was cobbled together over two decades without any kind of
unifying style document. Various people with various motivations keep adding
and patching and fiddling and there is no steering committee or mission
statement or anything that would lead to a self-consistent syntax,
self-consistent grammar, self-consistent semantics. There is no Persistence
of Visison of the developers. "Hey, I'd like xyz feature"; "you're welcome
to write the code for it"; "Oh, ok, I added a flag to the crackle pattern to
do it".
They're numbered in causal order, as far as I can discern it.
#3 could be massively improved by the developers if only they could be arsed
to actually *look* at the documentation. Not tell people "xyz is in the
docs", which doesn't help anybody. Half the time is is NOT in the docs, and
the other half the correct response is "where in the docs did you look and
how did you interpret this-or-that sentence" and then move the information
that people are looking for where people expect it.
There's nothing wrong with the line
   objectName {mandatoryItems [optional items in any order] [object
modifiers in any order]}
Why is that line not in the docs? Why is there *nothing* in the docs that
simply documents what the parser expects and when and where?
Simple exercise: Create a document that brings someone up-to-speed who's
never touched POV-Ray and wont be able to get back to you to ask questions.
You have, say, 10 pages to write everything a new user needs to know. No
more. No megabytes of tutorials. And no, not a "quick reference" either: You
will have to write the sentences that the current docs lack: "Every scene
needs a camera, should probably have at least one object of some sort so
there's something to look at and usually should probably also have a
light_source". That's one-and-a-half lines of text and it contains more
information than the first ten pages of the POV-Ray docs combined.
Other simple exercise: install the windows version, hit F1, start reading at
the beginning: Section 1.1 Introduction. The docs call themselves a "book",
and that's how you read a book. The goal is to read until you have read
everything you need to render your first scene (no, the demo doesn't count.
Your *own* first scene). Pages upon pages upon pages upon even more pages of
blah-blah without any kind of content. If your goal is to *make* people skip
whole sections of the docs, congrats: you've succeeded. But seriously: keep
reading. And reading. I think you get all the tools to render a simple scene
somewhere around section 2.2, so just keep reading.
#2 Is harder, but would require little more than all dev-folks coming
together and laying out how POV-Ray is actually *supposed* to work. Spell it
out *without* writing code: How do you want things to happen, how should
they be structured.
Then implement what you decided.
No sane developer will *design* a language where some statements *must*
start with a "#", while some others *can* have a "#" at the beginning.
"sphere" and "#sphere" are both acceptable, "declare" throws a warning but
works, "if" is an error. That's just absurd. Some mechanisms take parameters
in {} braces, others take them in () brackets. Some places take "x" to be a
unit vector, some others interpret it as a float. *Of course* the
documentation is going to be complete bullshit if the thing to be documented
is bullshit.
Just in this one thread I've heard from one person that there is a supposed
"general rule" of order that is that everything can be in arbitrary order
except for object_modifiers and from another person that "unless there is
special syntax, everything should be taken literally in the order given".
These two are in mutual contradiction. NEITHER of these two can be found in
the documentation. This is where I'd want the developers to talk amongst
each other and decide which of these behaviours they actually *want*, then
*implement* that and then *document* it.
Yes, this would require that the developers negotiate amongst themselves
what it is that they actually want.
And then they'd have to implement it, which I'm sure is less fun than just
will-nilly throwing yet-another-interpretation of some identifier into the
parser. But that way someone starting to tinker with POV-Ray could actually
stand a chance of discerning what is *supposed* to happen, since there would
in fact be something that *is* *supposed* to happen.
POV-Ray has had two decades for the various shifting dev-teams to come to
*some* basic understanding of how things *should* happen. A brief style
manual. Some outline what the syntax rules should be. What the actual rules
of the parser should be. Something against which it can be measured whether
or not adding yet another keyword-with-its-own-incompatible-sub-syntax is
the right thing to do.
And it is pretty clear that none of that ever happened.
> Yes, the docs badly do need some improvement, but (1) that's not a new
> issue caused by the 3.6 -> 3.7 transition, and (2) it's not realistically
> achievable with just adding a bit of more patchwork here and there; what's
> really necessary is a systematic overhaul, which will possibly include a
Step one will be convincing your fellow developers that this is true --
because they seem to *imagine* that the documentation is great and contains
all kinda of wonderful things. And they cannot be arsed to read the docs
themselves to see what a sorry state they're really in.
Step two will be for you to realize that half of the sorry state of the docs
is a reflection of the sorry state of the parser.
OK, you asked what I want, here I told you.
I'm not necessarily expecting to get all (or any) of that, I'm merely
answering your question.
Now the *REASON* I want all this is because POV-Ray *could* fill a niche if
only it worked (and that includes working documentation and a working
feedback mechanism where developers don't just simply *deny* the reality
everybody can see with their own eyes).
The concept of a fully analytic ray-tracer is appealing. Yes, I could get
Blender and start throwing meshes around. I might end up doing that. Like
many people before me. But I still think the basic *idea* behind POV-Ray is
sound. I *like* POV-Ray, or I wouldn't come back once a year for year after
year. But after sufficiently many years I see the execution *bungled* by
developers who think as long as they had their fun writing code, nothing
else matters. Screw the users.
Date: 26 May 2011 02:48:54
Message: <4dddf7d6$1@news.povray.org>
Instead of focusing your rage on this thread, what about using all that
energy to contribute to the documentation itself (on the pov-wiki pages)?
I'm sure you know the right spot to add or amend a paragraph or two
about the behaviour you observed (i.e. all specific object options must
be before the very first option from OBJECT_MODIFIER). At least you
would be expecting it there, so, in fact, you do know that place.
> the documentation.
I used to know the povray documentation by heart... but it was at the
time of 3.1 (well, I started with 2.12 of something not called povray).
I get a bit lost with the 3.5 and further. (and it seems there is
duplicate data for the SDL: often in the object description, and later
in the SDL summary. It's like having two watches (clock), if they are
different, I'm unable to know which one is true (if any)).
I would reckon (but I'm not able to provide a better tool) that the
search engine on the wiki is far too weak, at least for my taste, i'm
never able to find a good match. I might not be using the right wordings.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Goto Latest 50 Messages Next 2 Messages >>>
