POV-Ray : Newsgroups : povray.general : mm_per_unit question Server Time
11 Oct 2026 02:07:19 EDT (-0400)
  mm_per_unit question (Message 1 to 17 of 17)
Subject: mm_per_unit question
Date: 10 Mar 2011 09:42:47
Message: <4d78e367@news.povray.org>
Is there any provision for having more than one specification of
mm_per_unit in the globals block? What if I have two separate items that
have different scalings.
Would it be reasonable to expect that something like the following might
work?
global_settings {
  mm_per_unit one-scale
object {
 finish {
  subsurface {...}
global_settings {
  mm_per_unit another-scale
object {
 finish {
  subsurface {...}
Subject: Re: mm_per_unit question
Date: 10 Mar 2011 10:01:56
Message: <4d78e7e4$1@news.povray.org>
I thought of that too but from one of Christoph’s replies he said that
you should scale the subsurface values.
> work?
I'm sure that the last value overwrites the first.
It should be (I think)
global_settings {
object {
   finish {
    subsurface {...}
object {
   finish {
    subsurface {...} * one-scale/ another-scale // or something like
Regards
Date: 10 Mar 2011 10:15:20
Message: <4d78eb08$1@news.povray.org>
That was my 1st thought as well, but considering that you're able to
declare a default texture/pigment/finish at different places and have to
applied accordingly, I thought it was worth asking :-)
Date: 10 Mar 2011 11:25:56
Message: <4d78fb94@news.povray.org>
I've never done that, myself.
Why don't you experiment with the mm_per_unit and report back?
Remembering that this version of SSLT will be made redundant in the next
release.
Regards
Date: 10 Mar 2011 13:42:27
Message: <4d791b93$1@news.povray.org>
yep that's the case ... it allows multiple definitions but is honoring
the last instance, I had to do:
subsurface {translucency <1,0.25,0.05> *2}
before seeing a diff as suspected
Date: 11 Mar 2011 03:26:23
Message: <4d79dcaf@news.povray.org>
Am 10.03.2011 16:15, schrieb Jim Holsenback:
Note that mm_per_unit it is a global_setting, not a default ;-)
Stephen's right: Last value wins.
Date: 11 Mar 2011 08:36:27
Message: <4d7a255b$1@news.povray.org>
Yep ... realize that. I guess /global/ should have been my 1st clue ...
eh? While we're on the subject, having mm_per_unit in globals just seems
counter-intuitive. I'm sure there's a technical reason for having it
there, or maybe when the feature was implemented it just wasn't
considered that there could be a case of having more than one sslt
object of different scale in a scene. Since scaling (generalized NOT
sslt) is either attached to a material, texture, pigment or object
wouldn't it make more sense to have it on a per object bases ie:
object {
  finish {
    subsurface { translucency color mm_per_unit float }
Date: 11 Mar 2011 09:12:31
Message: <4d7a2dcf$1@news.povray.org>
> object {
>    finish {
I recognise your train of thought. :-)
What I think we need to do is scale both the subsurface values and the
texture, independently but related. (If that makes sense)
     pigment { colour}
    finish {
      subsurface { scattering, absorption }* Scale_for_SSLT
scale Scale_for_Texture
PS I notice that you forgot to put your subsurface values in the RC3
format :-P
Regards
Date: 11 Mar 2011 11:10:00
Message: <web.4d7a48942213d8df3771cd8e0@news.povray.org>
>    texture {
>      pigment { colour}
>     finish {
> format :-P
> Regards
>      Stephen
mm_per_unit is an attribute of the world (scene) not the object.
If you scale an object with the same material it's SUPPOSED to look different,
just like in the real world. If you want it to look the same when it's e.g.
double the size you need to use a different (more translucent) material. So the
logic as it is implemented makes absolute sense.
Regards
Aydan
Date: 11 Mar 2011 11:39:14
Message: <4d7a5032$1@news.povray.org>
agreed ... I'm doing a beauty run on the stanford dragon now, here's
what I have for the material:
object { stanford_dragon
material {
    T_Stone18
    scale 0.035
  finish {
    subsurface {translucency <0.05,1,1>*0.5}
    reflection { SeaGreen*0.001 }
  interior {ior 1.62}
I copied T_Stone18 into my scene file and made a couple of mods (ambient
to 0 and dialed down diffuse a touch) in the bottom layer texture, then
changed phong to specular/roughness on the outer layer.
To setup the sslt I used a plain white texture instead of T_Stone18
while I dialed in the sslt (seems to help with visualizing the effect).
That was interesting because my 1st take on mm_per_unit was that it
would be smaller than default because of the size of the model at scale
1. When smaller didn't seem to be working I tried default without much
luck either, so I increased to 1000 then 2540, but still had to wildly
scale the translucency color. Finally I decided to try a couple of half
step itterations between something I considered to be more reasonable
(100 - 10) and found the sweet spot. The value I arrived at was so close
to the subsurface scene file values, I opted to use mm_per_unit 40 and
quickly was able to tune the translucency setting to what's shown above.
> format :-P
ha-ha ... bleeding edge :-P
Date: 11 Mar 2011 11:49:48
Message: <4d7a52ac$1@news.povray.org>
I understand the current implementation it just seems counter-intuitive
to me.
yep and I get that too ... that's why a too big of a value for
mm_per_unit presents a material that you can practically see through
Date: 11 Mar 2011 11:56:24
Message: <4d7a5438$1@news.povray.org>
You won't get an argument from me, Aydan. ;-)
Regards
Date: 11 Mar 2011 12:06:41
Message: <4d7a56a1@news.povray.org>
I await in anticipation.
> material {
>    texture {
>      T_Stone18
>      scale 0.035
>    finish {
>      subsurface {translucency<0.05,1,1>*0.5}
>    interior {ior 1.62}
Hmm! I might try using coloured reflection sometime. 0.001 seems quite
subtle. :-D
T_Stone18 is quite dark. I can't wait to see it.
Sounds like a good idea.
"Suck it and see" technique. :-D
>> format :-P
I suppose that you deserve something for all your hard work on the docs.
Regards
Date: 11 Mar 2011 12:24:16
Message: <4d7a5ac0$1@news.povray.org>
ha-ha ... yes as I mentioned in another thread it seems a bit like
aligning a piece of electronic equipment ... hey it works for me but I'm
a rather odd duck about some things ;-)
Date: 11 Mar 2011 13:52:53
Message: <4d7a6f85$1@news.povray.org>
On 11/03/2011 5:24 PM, Jim Holsenback wrote:
>> "Suck it and see" technique.:-D
> a rather odd duck about some things;-)
What difficult about aligning electronic equipment, ducky?
Regards
Date: 11 Mar 2011 14:24:03
Message: <4d7a76d3@news.povray.org>
> object {
>    finish {
When you scale an object containing some media, the media's aspect
changes as the amount of media does change. It's the expected behaviour.
When you scale an object with interior fading, the apearance also change
as there is now more or less material involved. Also an expected behaviour.
In both cases, if you want the effect to remain the same, you need to
also scale those features. Increase or deduce the media density, scale
the fade_distance, accordingly to the new dimentions of the object.
Exactly the same apply to any object using SSLT. Here also, it should
the expected behaviour. The effect is dimention dependent.
Date: 11 Mar 2011 15:12:23
Message: <4d7a8227$1@news.povray.org>
thanks ... this ties it together better for me (volume)
