Subject: Mesh2 to isosurface - how to do with IsoCSG?
Date: 18 Dec 2010 14:14:00
Message: <4d0d07f8$1@news.povray.org>
High!
Christoph Hormann's Earth renditions, apparently done with mesh2s
converted to isosurfaces (http://earth.imagico.de/technical.html) made
me drool instantly... and as he had done an include called "IsoCSG", I
wonder whether a mesh2 to isosurface conversion feature was contained
therein. But when I looked over the documentation of version 0.7, I
found no hint about how to do this. Could it be that only a version not
yet released contains this - or do I have to do it an entirely different
way! But there MUST be some way to convert mesh2s into isosurfaces...
See you in Khyberspace!
Yadgar
Subject: Re: Mesh2 to isosurface - how to do with IsoCSG?
Date: 19 Dec 2010 08:10:30
Message: <4d0e0446@news.povray.org>
Sorry for asking, but for what possible reason would one want to
convert a mesh into an isosurface? A conversion to the other direction
would make sense and, in fact, be really useful (at least in terms of
rendering speed). However, converting a mesh to an isosurface seems to
be completely backwards. Why would one want to do that?
(One could perhaps argue that you can apply any kinds of transformations
to an isosurface. However, you can do that to a mesh too, although it
requires more indirect means. If you put your vertices and normal vectors
in arrays and then create the vertex and normal vectors of the mesh from
those arrays, you can apply any transformations you want to those vertices
in the arrays before creating the mesh, thus achieving free transformations.
While not absolutely trivial, it's not that hard either.)
Date: 19 Dec 2010 16:51:22
Message: <4d0e7e5a@news.povray.org>
High!
Recently, I started building mesh2s following Earth's curvature from
SRTM Earth elevation data (3 arcseconds per data point)... when
rendering those mesh2s, I found some strange artifacts (gaps between
triangles, see image on p.b.i.) which probably resulted from floating
point inaccuracy (the scale I used is 1 POV unit = 1 kilometre).
As Christoph Hormann, as he writes on his website, apparently uses a
kind of (self-written?) conversion tool, I thought that converting my
mesh2s to isosurfaces possible could solve the gaps problem...
Yadgar
Now playing: Dis-Gorilla (Rick Dees & His Cast Of Idiots)
Date: 19 Dec 2010 16:58:00
Message: <4d0e7fe7@news.povray.org>
I bet it's a bug in your conversion program instead (or, alternatively,
something which gets fixed if you apply double illumination).
Do you really want your earth model to render a hundred times slower?
Date: 19 Dec 2010 17:20:17
Message: <4d0e8521$1@news.povray.org>
High!
When I want to render animations, really not... but high-quality still
images ("When the Internet came to Abdurrahmankhan Kalay") probably
might improve!
Yadgar
Now playing: Love Or Nothing (Uriah Heep)
> High!
No, apparently not. He describes quite clearly that he uses the
elevation data to create an isosurface-function. I'm pretty sure to
remember that on his homepage is even a full blown tutorial including
POV code on how he did it - but right now I'm too lazy to search the
link for you.
> way!
IsoCSG is about doing CSG with isosurfaces (therefor the name, otherwise
I bet Christoph would have named it IsoMesh).
-Ive
Date: 19 Dec 2010 20:40:03
Message: <4d0eb3f3@news.povray.org>
Why wouldn't one want to do it? If it could be done efficiently, a
person could give erosion to a statue, or add rusty lumps to an object,
at will.
The big question is how to do it? You could make an object pattern from
the mesh, and convert that to an isosurface. But that always results in
a lot of artifacts. Or you could average jittered copies of the object
pattern together, but that renders very slowly and the artifacts are
still present (though somewhat reduced). Or perhaps... you could start
with a spherical function and push and pull space at each triangle thus
distributing it into the mesh's shape. It's only a theory, and might
only make sense for small meshes, but maybe it would work...
Sam
Date: 20 Dec 2010 02:10:33
Message: <4d0f0169@news.povray.org>
I don't know... maybe because rendering an isosurface takes about one
hundred or even one thousand times more time than rendering a mesh? The
more complicated the mesh, the slower an equivalent isosurface would be.
> at will.
Those things can be done to a mesh, via subdivision and vertex
transformations. Of course this would require some coding, but it's
nevertheless possible.
Are your adjacent triangles referencing the same vertex, or are you
defining the coordinates repeatedly for each triangle?
It seems unlikely the isosurface rendering code would provide better
accuracy than the triangle rendering code, if indeed you are hitting
some limitation with POV. IIRC the triangle intersection code is only a
few calculations, whereas the isosurface intersection code is much more
complex (which means more calculations and more possibility of floating
point errors building up).
Date: 20 Dec 2010 08:00:48
Message: <4d0f5380@news.povray.org>
High!
No, each vertex is defined only one - as I use mesh2 rather than
classical mesh!
Yadgar
