POV-Ray : Newsgroups : povray.general : Make a hollow object solid Server Time
21 Feb 2025 13:22:10 EST (-0500)
  Make a hollow object solid (Message 1 to 5 of 5)
Subject: Make a hollow object solid
Date: 16 Dec 2010 21:03:21
Message: <4d0ac4e9@news.povray.org>
Hi, is there an easy way to make a hollow object solid?
I have some poser imported objects that are hollow.
I would like to test to see if vectors are inside the object, but its not
working and I believe that its because the object is hollow.
Unfortunately I cant work out how to make the object a solid....
Cheers Dre
Subject: Re: Make a hollow object solid
Date: 16 Dec 2010 23:40:44
Message: <4d0ae9cc@news.povray.org>
> Cheers Dre
If the mesh is closed and the "inside_vector" is specified, POV treats
it as a solid unless the "hollow" keyword is explicitly provided.
http://wiki.povray.org/content/Documentation:Reference_Section_4.2#Solid_Mesh
I would assume that the problem lies in 'inside_vector' not being defined.
Date: 17 Dec 2010 23:04:46
Message: <4d0c32de@news.povray.org>
> Cheers Dre
Poser models are mesh. Normaly, they are only a surface with no
thickness, but that can be changed.
You need to provide an inside_vector to your mesh object. It will work
even if the mesh is not perfectly closed, but, in that case, you can get
some eroneous results.
Syntax: inside_vector Direction
Some samples:
inside_vector y
inside_vector 1
inside_vector<1, 0.01, 0.5>
Date: 19 Dec 2010 17:45:56
Message: <4d0e8b24$1@news.povray.org>
"CShake" <cshake+pov### [at] gmailcom> wrote in message
news:4d0ae9cc@news.povray.org...
>> Cheers Dre
> If the mesh is closed and the "inside_vector" is specified, POV treats it
Hi, yes you are right, there is no inside_vector specified.
Looks like I need to read up on UV stuff as I've never played with it
before!
Thanks for the help!
Cheers Dre
Date: 19 Dec 2010 17:46:48
Message: <4d0e8b58$1@news.povray.org>
"Alain" <aze### [at] qwertyorg> wrote in message
news:4d0c32de@news.povray.org...
>> Cheers Dre
> Poser models are mesh. Normaly, they are only a surface with no thickness,
> Some samples:
> inside_vector y
> inside_vector 1
> Alain
Yep thats exactly my problem.  Thanks for the headups, I'm going to read up
on UV mapping now...
Cheers Dre
